BIC America F12 sub anyone ? - Page 95 - AVS Forum | Home Theater Discussions And Reviews
 51Likes
post #2821 of 3012 Old 02-21-2014, 09:55 AM
Augerhandle's Avatar
Quoted: 869 Post(s)
Liked: 785
The sub in was not designed for speaker level input
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #2822 of 3012 Old 02-21-2014, 12:42 PM
DERG's Avatar
Quoted: 42 Post(s)
Originally Posted by KurianOfBorg View Post
I know that. I am going to use the "Sub Out" from the receiver, but it's speaker level, not pre-out. Can I safely connect this to the "Sub In", or do I have to connect it to just one of the L or R speaker inputs. Can the "Sub In" handle an amplified input?
Sorry, KurianOfBorg! I don't know your equipment or your level of expertise. I'll try again. smile.gif
If you use Receiver "Sub out" to F12 "Sub in" it is safe. If you use the receiver's "Sub out", the receiver manages everything. Do not connect L&R speakers to the F12 when using receiver Sub out. The crossover on the F12 will be bypassed so only F12 sub volume will be active.
On your receiver you will need to go into your Bass Management menu, then select what bass frequency you'd like for crossover. If your L, R & surround speakers are small, try 80db -100db. If larger try 60db. Try several & go by what sounds best to you. Your receiver will manage audio frequencies from there. Your receiver should also have an independent speaker volume level menu to calibrate all speaker levels including the F12 sub but you will need to set the F12 volume to a starting point. Use that to balance volume levels for best surround effects.
If this helps, great, but if not we'll need to know what receiver do you have & go from there.
Marantz VP15s Projector, CIH Man-Cave Home Theater, Marantz SR 8002, Oppo BDP-103 Blu-ray Player, 6 - HSU HB-1 MK2 Front & Surrounds, 1 - HSU HC-1 MK2 Center, 2 - HSU VTF-15H Subwoofers
DERG is offline
post #2823 of 3012 Old 02-21-2014, 12:45 PM
KurianOfBorg's Avatar
Quoted: 151 Post(s)
Liked: 29
How is it safe unless the sub is specifically designed to handlle high level amplified input? I know the L/R speaker inputs can handle it, but there is no information on whether the "Sub In" port can handle it. A "Sub In" port is generally only connected to a line level / pre-amp output.
I have an Onkyo HT-R380 which only has a passive (amplified) sub out.
KurianOfBorg is offline
post #2824 of 3012 Old 02-21-2014, 04:01 PM
DERG's Avatar
Quoted: 42 Post(s)
You're right. The receivers sub out is analog, not digital. Note on page 29
of the manual are directions how to turn on or off the sub. Select No. This will keep your front L & R speakers full range. Wire L & R to the F12 first, then run wires to appropriate L & R speakers. Depending on the size of your L & R speakers is where to set the F12 crossover point. I'd recommend a starting point of 80hz. Everything below 80hz will go to the F12, above 80hz to L & R.
HTH
DERG is offline
post #2825 of 3012 Old 02-21-2014, 06:42 PM
Quoted: 151 Post(s)
Liked: 29
This is all I needed to hear.
post #2826 of 3012 Old 02-21-2014, 06:44 PM
Bond 007's Avatar
Quoted: 2627 Post(s)
Liked: 2090
Will DERGs post help you?
Licence to Kill
Bond 007 is offline
post #2827 of 3012 Old 02-21-2014, 06:46 PM
Quoted: 151 Post(s)
Liked: 29
I'm not planning to hook it up that way. Since I want to control everything from the receiver, I'll try connecting the Sub Out to just one of the L/R speaker level inputs.
post #2828 of 3012 Old 03-13-2014, 03:27 PM
Boots Rojas's Avatar
Does anyone know how 1 or even 2 of these would do with an Infinity Alpha 1200s? I've got an Alpha 1200's that I bought new and has hardly been used, sounds great, would just like to have more base for watching movies.
Boots Rojas is offline
post #2829 of 3012 Old 03-13-2014, 04:42 PM
Bond 007's Avatar
Liked: 2090
Got a link?
Licence to Kill
Bond 007 is offline
post #2830 of 3012 Old 03-13-2014, 04:51 PM
post #2831 of 3012 Old 03-13-2014, 05:14 PM
Bond 007's Avatar
Liked: 2090
Yes. It looks to be similar to the F12. Not sure what you mean by "more bass" though. An F12 will add a little more output but wont go deeper. If youre looking for a real upgrade youd probably be better off to sale the Infinity and get a better sub.
Licence to Kill
Bond 007 is offline
post #2832 of 3012 Old 03-13-2014, 05:33 PM
I meant to say deeper base. Thanks for your help.
post #2833 of 3012 Old 03-13-2014, 05:42 PM
Bond 007's Avatar
Liked: 2090
For a little more money this is a much better sub. If you sell the Infinity it would be less than the F12.
http://www.amazon.com/gp/product/B008FSTU4G/ref=ox_sc_sfl_title_3?ie=UTF8&psc=1&smid=A28SS3BS1DBQ92
Licence to Kill
Bond 007 is offline
post #2834 of 3012 Old 03-13-2014, 06:41 PM
Thanks I'll check it out.
post #2835 of 3012 Old 05-04-2014, 11:21 AM
mwagiru's Avatar
Does anyone know where I can get a F-12 circuit board? Something shorted my circuit board and efforts to restore it have been fruitless.
An ebay link would be great.
mwagiru is offline
post #2836 of 3012 Old 05-05-2014, 03:51 AM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
mwagiru. You could contact BIC directly to determine whether they sell a replacement amp
Alternatively, you could purchase a replacement plate amp from Parts Express. You may have difficulty getting a plate amp that will fit exactly.
wwinkler is offline
post #2837 of 3012 Old 05-05-2014, 04:53 AM
mwagiru's Avatar
Hey wwinkler! Thanks for replying.
I did contact BIC but did not get a response. I went through parts express and came across this 1x600W TAS5630 Class-D Amplifier Board
It might / might not fit exactly but I think the the specs fit just fine. As I have never done a DIY of this kind before, I need some confirmation whether this is good for the F-12.
Much appreciated!
mwagiru is offline
post #2838 of 3012 Old 05-05-2014, 10:42 AM
jmr27's Avatar
i'm selling my 2 BIC f 12's
jmr27 is offline
post #2839 of 3012 Old 05-07-2014, 09:05 AM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1687
Much appreciated!
It isn't all that hard. Most any plate amp will do. If the plate amp is too big just cut out the opening in the sub to the right dimensions. A saber saw is a good tool for the job. If the plate amp is too small, then mount it to a piece of ply wood and glue the plywood to the back of the sub. Here is a shot of my old B&W sub with a new 250 watt plate amp from Parts Express. I only had to enlarge one dimension by 1/8" to fit the amp. I just used a rasp.
FMW is offline
post #2840 of 3012 Old 08-23-2014, 08:40 AM
g.costanza's Avatar
Quoted: 92 Post(s)
This is a long thread! From what I've researched, it looks like the nxg500bas is very close in performance compared to the bic b100 (according to Jim Wilson / jman). And it seems that the bic f12 and h100 are very similar in terms of parts and construction. How similar are they? I'm looking at potentially getting 2 f12's for smoother response throughout the room.
g.costanza is offline
post #2841 of 3012 Old 08-24-2014, 07:36 PM
Quoted: 869 Post(s)
Liked: 785
www.bicamerica.com
post #2842 of 3012 Old 08-25-2014, 12:56 PM
g.costanza's Avatar
Quoted: 92 Post(s)
www.bicamerica.com
Lol. I dont put a lot of faith into company specs. It seems that actual real word use (and measurements) shows that the more expensive H100 performs no better than the F12.
The PL200 looks like same parts as F12, in different box.
post #2843 of 3012 Old 08-26-2014, 08:39 PM
Quoted: 27 Post(s)
Liked: 0
It's the same crappy box, crappier sub with a higher output Amp pushing it hard so it sounds deeper.
glhurd is offline
post #2844 of 3012 Old 08-27-2014, 06:18 AM
FMW
FMW's Avatar
Liked: 1687
I use an F12 for my personal computer audio. It just plays along with music at modest volume levels. If you do the same thing, it will perform very well for you. If you want to use it to play loud LFE in a home theater I would probably get something better. It is a super sub for the price and even a great sub for filling in the bass on speakers that play music. It is comparable to the old B&W you see pictured above. It doesn't perform so well under the stress of loud movie sound tracks. Choose the best the product for the job at hand.
FMW is offline
post #2845 of 3012 Old 08-27-2014, 01:52 PM
Quoted: 27 Post(s)
Liked: 0
The only difference is B&w products will last about 7 years longer before it blows up.
glhurd is offline
post #2846 of 3012 Old 08-27-2014, 02:33 PM
Bond 007's Avatar
Liked: 2090
You know that for a fact? How did you calculate 7 years?
Bond 007 is offline
post #2847 of 3012 Old 08-27-2014, 02:46 PM
FMW
FMW's Avatar
Liked: 1687
Time to work on the anger management.
FMW is offline
post #2848 of 3012 Old 08-27-2014, 07:07 PM
Quoted: 27 Post(s)
Liked: 0
Ya I've owned F12's one broke down in 3 months had to go through hell to get sent another one. 2nd one died after 1 year.
They are from America, I would have hoped they'd actually build better products than this.
Absolutely hate that company!
Subwoofers are bass specialists. If they could wear a hardhat and carry a clipboard, they would.
glhurd is offline
post #2849 of 3012 Old 08-27-2014, 08:50 PM
Bond 007's Avatar
Liked: 2090
Sorry to hear that. I bought one about 4 years ago. Sold it to someone about a year ago for $100 and it still works fine.
Bond 007 is offline
post #2850 of 3012 Old 08-28-2014, 05:37 AM
FMW
FMW's Avatar
Liked: 1687
They are from China. It doesn't take much to overstress a 100 watt amp with a subwoofer. You played them too loud. You chose the wrong product for the purpose.
FMW is offline
