BIC America F12 sub anyone ? - Page 96 - AVS | Home Theater Discussions And Reviews
 4Likes
post #2851 of 2876 Old 08-28-2014, 09:17 AM
Quoted: 27 Post(s)
Liked: 0
Thumbs up
Originally Posted by FMW View Post
They are from China. It doesn't take much to overstress a 100 watt amp with a subwoofer. You played them too loud. You chose the wrong product for the purpose.
BIC products are all designed and engineered in America in 1973.
I play my stuff at moderate levels.
Shows what you know smart one.
Subwoofers are bass specialists. If they could wear a hardhat and carry a clipboard, they would.
glhurd is offline
post #2852 of 2876 Old 08-28-2014, 09:36 AM
Bond 007's Avatar
Quoted: 590 Post(s)
Liked: 939
Designed and engineered I dont doubt. But most American electronics companies buy their parts from overseas and assemble the product here. If you dig deep enough you would probably find that almost nothing in the Bic products is made in America.
Rhythmik is a American company and even their cabinets are made in China.
Bond 007 is online now
post #2853 of 2876 Old 08-28-2014, 09:53 AM
Quoted: 27 Post(s)
Liked: 0
Point of the matter is they are from America in which I stated
glhurd is offline
post #2854 of 2876 Old 09-05-2014, 05:56 PM
Sound Master BIC's Avatar
Ya I've owned F12's one broke down in 3 months had to go through hell to get sent another one. 2nd one died after 1 year.
They are from America, I would have hoped they'd actually build better products than this.
Absolutely hate that company!
I bought one years ago, still have it, still love it, for my theatre viewing as well as music. Maybe you people just don't know how to set it up properly or you drive it past clipping, at which point it doesn't matter which sub you buy, you clip it long enough, it dies. Of course a $1,000 sub wouldn't need to be driven as hard as the F12 but I've cranked the crap out of mine many times, music and movies and no problems. Very happy with it never any issues, more than I can say for some of you!
Sound Master BIC is offline
post #2855 of 2876 Old 09-05-2014, 06:16 PM
rynomyte's Avatar
Quoted: 23 Post(s)
Liked: 26
Had mine for many years. It's been kind to me but I can't say the same for me to it. Audessy has me running it with the gain at about 2 and it will hang with me as loud and as hard as I can push it. I will forever recommend the f12 as THE best budget sub one can buy. Of course, YMMV.
Sound Master BIC likes this.
rynomyte is offline
post #2856 of 2876 Old 09-05-2014, 06:24 PM
Bond 007's Avatar
Quoted: 590 Post(s)
Liked: 939
lol
post #2857 of 2876 Old 09-05-2014, 09:36 PM
Quoted: 27 Post(s)
Liked: 0
Their subs are not good, If you make it past 5 years with one I'd be really shocked and amazed!
glhurd is offline
post #2858 of 2876 Old 09-05-2014, 10:24 PM
g.costanza's Avatar
Quoted: 33 Post(s)
Omg. U don't like the sub. We get it already. Geez.
g.costanza is offline
post #2859 of 2876 Old 09-06-2014, 06:42 AM
g.costanza's Avatar
Quoted: 33 Post(s)
Hmmm? In July 2014 u ask if this is a good sub... http://www.avsforum.com/forum/113-subwoofers-bass-transducers/1622146-bic-f12-crossover-advice.html#post26155554
Now u say u have owned 2?
post #2860 of 2876 Old 09-06-2014, 08:33 AM
AllenA07's Avatar
Quoted: 139 Post(s)
Liked: 147
I ran an F12 for two years in my setup and drove it pretty hard. I never had an issue with it and thought that it was a very solid budget subwoofer. My F12 is in my Dad's system now and continues to run strong.
AllenA07 is offline
post #2861 of 2876 Old 09-13-2014, 06:08 PM
DarthDoxie's Avatar
Liked: 35
Great sub for what it is: budget product for use in smaller rooms played at moderate levels. Been running mine daily and have had no problems at all.
Vizio M551D -- Denon 1613 -- Vizio 3D Blu-ray
I find your lack of schadenfreude disturbing.
DarthDoxie is offline
post #2862 of 2876 Old 09-14-2014, 10:38 AM
Threefiddie's Avatar
Quoted: 42 Post(s)
Liked: 26
i got two f12's and don't see myself ever replacing them. they do just fine.
Threefiddie is offline
post #2863 of 2876 Old 12-27-2014, 01:20 AM
QuiGonJosh's Avatar
Quoted: 118 Post(s)
Liked: 63
Curious what others have the gain set at on their F12's? I have mine set at 4 gain on the subwoofers and -9db in the receiver. I've seen others have the gain set at 1-2 and the receiver at -1db or 0db. Might play around with it to see which sounds better. Thanks.
QuiGonJosh is offline
post #2864 of 2876 Old 12-27-2014, 06:24 AM
rynomyte's Avatar
Quoted: 23 Post(s)
Liked: 26
Mine too is pretty low...probably around 2 (I'm not home right now to verify exactly). When I run audessy I adust the gain to get as close to 0db as possible then bump it up +3db in the AVR afterwards. At first I thought this would be too low as well but we have to remember, gain is not volume and when the source material calls for it my F12 answers with thunderous bass even at very low gain settings. You're right though, what sounds best to YOU is what's most important!
rynomyte is offline
post #2865 of 2876 Old 12-27-2014, 07:16 AM
QuiGonJosh's Avatar
Quoted: 118 Post(s)
Liked: 63
Played around with the gain and offset and I've set the gain on the subwoofers to 2 and the offset on the receiver to -1db. Bass seems a bit punchier and tighter from what I've listened to so far.
post #2866 of 2876 Old 12-29-2014, 04:21 PM
Augerhandle's Avatar
Quoted: 152 Post(s)
Liked: 117
My gain is set at about the 9 o'clock position, Audyssey set the AVR to 0 dB.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_________________________________________________
Augerhandle is offline
post #2867 of 2876 Old 02-11-2015, 01:05 PM
tuckerpc389's Avatar
Quoted: 16 Post(s)
I have owned many subs including SVS and PSA monsters. I have also owned some budget subs including the dayton 1200 and this Bic F12. While it doesn't hold a candle to the SVS/PSA subs I have owned, I continue to be very impressed with how low, deep and excellent sounding the bottom end is with the F12. In it's price range I don't think it has competition frankly....
BenQ HT1085ST|Silver Ticket 106'' Screen| Onkyo TX-NR3030| SVS Ultra Towers X's 2| SVS Ultra Center| SVS Ultra Surrounds X's 2| SVS Ultra Bookshelves X's 2| Def-Tech DI-8R in-ceiling speakers X's 4| PSA XS30SE subs X's 2| Buttkickers X's 4, 2 buttkicker amps| Oppo BDP-103| Darbee Darblet 5000| 3D Bee| Monster HTS 5000 MKII| Carver 705x| PS4| Xbox 360| Harmony Touch| Dell XPS 420 HTPC W/XBMC & MyMovies W/12TB NAS| Seatcraft Adonis Seats| Monoprice & Sewell Direct cables|OmniMount RE42 Rack
tuckerpc389 is offline
post #2868 of 2876 Old 03-20-2015, 10:32 PM
jeep05's Avatar
Anyone by chance have a pdf of the users manual?
jeep05 is online now
post #2869 of 2876 Old 03-21-2015, 05:09 AM
BNestico's Avatar
Quoted: 82 Post(s)
Liked: 167
I don't own an F12 (I have SVS plus, and ultra series 12" cylinder subs) but a friend of mine who recently has started to put a small HT together bought one and asked if I could help him set it up. I was blown away by how good it sounded. It seemed to have ample power and went low enough to feel it in your chair. Now it doesn't have the pure muscle to down under 25hz with authority like my SVS's but for the price (I think he paid $180) it has no equal that I'm aware of.
AllenA07, ChromeJob and Boomassiv like this.
BNestico is offline
post #2870 of 2876 Old 03-21-2015, 06:20 AM
ChromeJob's Avatar
Quoted: 64 Post(s)
Tried Google?
Modest "theater": Samsung UN40ES6150, Panasonic BDT210, Yamaha RXV775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
ChromeJob is offline
post #2871 of 2876 Old 03-21-2015, 06:55 AM
jeep05's Avatar
Originally Posted by ChromeJob View Post
Tried Google?
Didn't initially find it on Google but not a lot of time was spent looking for it. Since I was reviewing the thread, I thought I would ask.
post #2872 of 2876 Old 03-21-2015, 09:37 PM
ChromeJob's Avatar
Quoted: 64 Post(s)
Well, silly me. 10 mins of searching indicates they don't provide PDF manuals. Pfft. If they do, they're well hidden.
post #2873 of 2876 Unread Today, 06:55 PM
ferrari fan's Avatar
Quoted: 14 Post(s)
I also have an SVS, PB12+ for the home theater. Outstanding sub, best I've ever heard. I also have the BIC F12 for the living room tv, and for the money (paid $180.00) it's not too bad. It's used daily for the past 2 1/2 years for tv watching only. An equal, or maybe better to the BIC may be The Pioneer SW-8MK2 Andrew Jones Designed 100-Watt Powered Subwoofer. It's only 8 inches, and so far it does very, very good for my home office 2.1 set up for audio only. It blends in well with my 30 year old Advent Legacy speakers. Just got the Pioneer sub 2 weeks ago, and for music, it's great for my office. Obviously, it can't compair what my SVS does for home theater, but for a smaller home theater, I think the Pioneer would do great, even though it's an 8 inch. Oh, and paid $106.99
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
ferrari fan is online now
post #2874 of 2876 Unread Today, 07:00 PM
Quoted: 14 Post(s)
I could scan mine and e-mail it to you if that would help. Send me your e-mail address by pm and I'll see what I can do.
post #2875 of 2876 Unread Today, 07:43 PM
jeep05's Avatar
Thank you ferrari fan........ done
post #2876 of 2876 Unread Today, 08:16 PM
Bond 007's Avatar
Quoted: 590 Post(s)
Liked: 939
We need you in the Formula One thread.
