sub placement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-06-2009, 01:04 PM - Thread Starter
Denophile's Avatar
so here's the situation-
I have a 7.1 focal setup with a 106 in pj screen. I currently have 2 velodyne spl1200-r subs in the front set at 270degrees out of phase (which gives by far the best results of the 4 opptions) about a few inches from the back wall behind the 2 l/r mains (pics to follow tonight).
That is all well and good but given the cement floor under the carpet I am adding 2 spl-800r subs to fill things out a bit--my question is
would it be best to put them in the back of the room facing forward, on the sides of the couches (perpendicular to the larger subs) or in front of the room in between the other 2 subs. There are currently 2 rows of seating, one on a 12"platform. room size in total is 625 sq ft with 8 ft drop ceilings. the rectangular listening/movie watching area area is about 26X12 and rectangular. is there a way of pre-planning what is likely to be the best setup or is there no way of predicting other than trial and error (and hearing what works best)?
Denophile is offline
post #2 of 5 Old 04-06-2009, 03:58 PM
Wayne A. Pflughaupt's Avatar
Quoted: 88 Post(s)
Liked: 67
Generally, the more subs you spread around the room, the harder it is to balance response. You might want to get the free Room EQ Wizard program at the Home Theater Shack. It will let you take in-room measurements and take the guesswork out of what you're trying to do.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #3 of 5 Old 04-06-2009, 04:03 PM
brandonnash's Avatar
Liked: 32
I think harman did a white paper on multiple sub placement too. You may want to do a search on it. Of course your situation will be specific to only you, but that may help you get a better grasp on it.
brandonnash is offline
post #4 of 5 Old 04-06-2009, 04:29 PM
JBLsound4645's Avatar
You mean this one.
Loudspeakers and Rooms for Multichannel Audio Reproduction
http://forums.klipsch.com/forums/sto...ndRoomsPt3.pdf
JBLsound4645 is offline
post #5 of 5 Old 04-06-2009, 06:41 PM - Thread Starter
Denophile's Avatar
thanks very much guys--that is exactly what i was looking for!
