Need a sub for my apartment...critique my setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 05-13-2009, 11:44 AM - Thread Starter
pianoman90's Avatar
I'm in the process of moving to an apartment and have been buying new HT stuff. Since this is an apartment, I didn't want to go too crazy. Everything sounds good together, it is just noticably lacking in bass. I'm looking to spend $300-400 on a sub and here is what I have so far:
46" Sharp Aquos LC46D85U 1080p
Sony S350 Blu-Ray
Yamaha RX-665 630 watt 7.1 Receiver (planning on running 5.1)
Klipsch Synergy F1s
Klipsch Synergy C1
Klipsch Synergy S1s
The apartment I'm moving into is on the top floor, corner unit and has 15' vaulted ceilings on the other end of the room. The room itself is about 14x16. I've attached a pic to show you where I'm looking to put the sub:
And the other end of the room with the vaulted ceilings
I was looking at the Klipsch SUB10 or Polk PSW110.
Which sub would be best for good bass, while disturbing the neighbors? Does the placement of the sub look good, or would you recommend moving it? I'm also thinking of picking up a subdude, just for extra measure.
pianoman90 is offline
post #2 of 22 Old 05-13-2009, 12:01 PM
KlipschHead281's Avatar
Quoted: 35 Post(s)
Liked: 41
Sony S350 Blu-Ray
Klipsch Synergy F1s
Klipsch Synergy C1
Klipsch Synergy S1s
I think it will work out fine but can only imagine neighbor complaints no matter which sub you buy. For an apartment either the SUB10 or PSW110 will suffice, been hearing about issues with the SUB10 though, might want to check into it's reliability.
AVR/Blu-Ray - Marantz SR7009 (9.3.2) - Blu-Ray Oppo UDP 203 - Apple TV
Front Height Amplifier - 2 Marantz MA6100's
Speakers - Klipsch RF-82 - Center RC-64 - Front Wide 2 RP-160M, Front Height 2 RB-10
Rear Surround - Surround Back 2 RS-52, Surround 2 R-14M
Subs - Triple MFW15's (Seaton Sound ICE amplifiers, 1 still has an AV123 amp, sadly)
TV -Samsung 55" 8500
KlipschHead281 is offline
post #3 of 22 Old 05-13-2009, 12:43 PM
Jakeman02's Avatar
Check out the Elemental Designs A2-300 and HSU STF-2. Both are within your budget and will outperform the 2 listed in all areas. As said above neighbors are going to be an issue no matter which sub you buy. The best options you have there is to place the sub as close to the listening position as possible and use common since with the volume control.
Jakeman02 is offline
post #4 of 22 Old 05-13-2009, 12:44 PM
LilGator's Avatar
There's no question for $300-400 you want the eD A2-300: http://www.edesignaudio.com/product_...roducts_id=407
I'd jump on it, because the price is going up to $400 on the 15th; but it's a killer deal either way.
I wouldn't worry about buying too much sub for your apartment. There's no such thing.
I've lived in an apartment with an eD sub (10" though) for nearly 2 years and only wished I went bigger, though even the eD babies hold their own.
You can turn any sub down, but you can't get more output than you purchased.
LilGator is offline
post #5 of 22 Old 05-13-2009, 12:48 PM
House72's Avatar
Yea, Def look into getting an ED sub.. As others have stated, there is no such thing as too much sub.. Get the biggest sub you can afford and enjoy.. Invite the neighbors up to watch a movie with you as well, it will go a long way...
PSN Forensics80
House72 is offline
post #6 of 22 Old 05-13-2009, 01:42 PM - Thread Starter
pianoman90's Avatar
Thanks for the replies. So can I use a normal subwoofer cable with the ED sub (it's hard to see the pic)? Any other recommendations?
And I'll be sure to mention everything to the neighbors when we meet. Hopefully I can get started out on the right foot.
post #7 of 22 Old 05-13-2009, 02:06 PM
Jakeman02's Avatar
There are several choices that are better alternatives than the SUB10 or Polk PSW110 in the original post. IMO the A2-300 or STF-2 are the ones to consider to be the among if not the best choices within your budget.
You'll use the same type cable no matter which sub you choose. Any quality RCA type audio cable will work, such as the link below. Just be sure to get the length you need. They don't stretch, I've tried.
post #8 of 22 Old 05-13-2009, 03:43 PM
chitown_badger's Avatar
You're in the exact same situation as me..I'm in a third floor apt, and just bought the A2-300 last night for the reasons mentioned here ($350 shipped, no tax). Regarding the placement, I always heard that the sub should go in the corner or close to it, but I was doing some research last night online at dolby labs, and they said NOT to put it in a corner...as that can lead to it sounding boomy.
chitown_badger is offline
post #9 of 22 Old 05-13-2009, 03:56 PM
Jakeman02's Avatar
Corner placement is usually recommended for output and boosting the low end and usually isn't the best placement for an even room response across the full band which can cause it to sound boomy. It works for some and not for others, every situation, room and preference is different. In my room I've found the most even response to be up front between the mains but again that could change, every situation is different and that's only a general guide.
For an apartment I would shoot for nearfield placement as close as possible to the listening position, even using the sub as and end table if possible. This will allow the sub to be calibrated at a lower level to the mains and the room itself won't have as much effect on the overall frequency response with nearfield placement.
post #10 of 22 Old 05-13-2009, 03:59 PM
Great post...thanks for the tips!
post #11 of 22 Old 05-13-2009, 04:05 PM
jurio's Avatar
you can rent a house for near apartment costs (at least in my area)
jurio is offline
post #12 of 22 Old 05-13-2009, 07:31 PM
jaejw1's Avatar
have u thought about using budget subs,,, with your price range you easily buy a pair of them..... and the more subs u have the smoother ur bass response will be,,, gets rid of standing waves
Premier Acoustic PA-120 230bux each
BIC H100 ???
BIC PL200 ???
Acoustic Audio HD-SUB12 198bux each
jaejw1 is offline
post #13 of 22 Old 05-13-2009, 07:48 PM
BIC H100 ???
BIC PL200 ???
I saw a couple other posts that said get one good sub rather than two entry level subs. Different strokes? In an apt, I struggle to give up the floor space for one sub!
post #14 of 22 Old 05-13-2009, 08:01 PM
PD50U's Avatar
Yes, keep repeating this right up to the time you get your eviction notice.
Hearing is believing vs Believing is hearing.
PD50U is offline
post #15 of 22 Old 05-13-2009, 08:29 PM
LilGator's Avatar
Good job with those reading skills.
LilGator is offline
post #16 of 22 Old 05-13-2009, 08:47 PM
jaejw1's Avatar
i suffer from a vaulted ceiling awell.. http://www.blu-ray.com/community/gal...?member=jaejw1 i plan on buying another sub soon.. was told by many that i will need dual subs to overcome the room volume
the more you have the better the response.. http://forum.blu-ray.com/showpost.ph...68&postcount=2
here are links to reviews of the subs i mentioned... note they are not the end all be all.. but in their price range the are very hard to beat..
PREMIER ACOUSTIC PA120 http://forum.blu-ray.com/showthread.php?t=82738
ACOUSTIC AUDIO HD-SUB12 http://forum.blu-ray.com/showthread.php?t=85212
and the BIC's can be found almost anywhere..
jaejw1 is offline
post #17 of 22 Old 05-14-2009, 03:47 PM
PD50U's Avatar
Yes, I read your blinding insight. It makes perfect sense to buy a prodigous sub for which you can only use a fraction of it's capability in an apartment.
PD50U is offline
post #18 of 22 Old 05-14-2009, 06:24 PM
theelviscerator's Avatar
Ok ladies simmer down.
I think he is ASSUMING the OP won't live in an apt forever....
I know I didnt.
I am no longer able to watch a movie. I am monitoring a video display with regards to chroma, brightness, contrast and correct pulldown.
theelviscerator is offline
post #19 of 22 Old 05-14-2009, 11:34 PM - Thread Starter
pianoman90's Avatar
Well I'm moving to Ft Lauderdale for med school and the homes that I can afford in S. Florida are not as nice as this apartment lol. The unit we're getting was built in 2006 and has new appliances, etc... So I'm
The AA SUB12 looks nice, especially for $200. So would the A2-300 or the SUB12 be a better choice?
post #20 of 22 Old 05-15-2009, 08:12 AM
jaejw1's Avatar
me personally,,, I would say get what you can afford for now... and when ur ready to make the sacrifice for something more expensive in the future,,, it will be easier.... cause u will have something to go by..... just me .02
btw I will be ordering my second PA-120 this weekend...
jaejw1 is offline
post #21 of 22 Old 05-15-2009, 02:40 PM
LilGator's Avatar
If your budget is $300-400, there's no reason to buy a $200 sub just because you think you have a small room, or an apartment can't have nice bass. That's all I'm saying.
I say this from experience, and most would agree, you will always want more sub.
LilGator is offline
post #22 of 22 Old 05-15-2009, 02:57 PM
xj0hnx's Avatar
Location: Location: Location: Location: Location: Location
Unless he's one of those people that turns over equipment weekly But yes, I completely agree, there's no reason whatsoever to buy less than what you want, as you said, you can always turn it down, but you can only turn it up so far.
xj0hnx is offline
