i need help with a triple sub configuration for a box. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-15-2009, 03:34 PM - Thread Starter
arthur88's Avatar
hi so i have two 12 inch alpine r's in the back of my 4runner right now, and i just bought a 10 inch sony xplod. ive looked around and i havent really found any way to put a 10 and two 12s in a box together. do you think i could maybe put them in a triangle with the one 10 on top of the two 12s or what?
by the way i also am going to make a vented box if that helps, also keep in mind i have an suv it isnt going to be in a trunk it will be in an open cargo area.
arthur88 is offline
post #2 of 2 Old 06-15-2009, 08:10 PM
brandonnash's Avatar
Liked: 32
I would do separate boxes. All of them in a sealed box will muffle the sound or worse. In a vented box those drivers will act differently. They would need different tunings and probably different size enclosures. Build a double for the 12s and a single for the 10. You may want to check on the car audio forum too.
brandonnash is offline
