Antimode 8033 - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #271 of 624 Old 04-18-2012, 11:03 AM
Venomous's Avatar
Originally Posted by bsoko2 View Post
I was in the first 100 to order and still am waiting.
Gotcha, I figured they were In the hands of the masses by now. I hope to hear some input on it when you receive it. I'm looking to get my hsu vtf15s setup correctly with my Yamaha. Thanks
Dank1209 likes this.
Venomous is offline
post #272 of 624 Old 04-18-2012, 01:04 PM
Kal Rubinson's Avatar
Quoted: 773 Post(s)
Liked: 542
Originally Posted by Venomous View Post
So has anyone received their dual core yet?
I spoke to a US rep at the NY Audio/AV Show. He said that shipment has been delayed because of problems with the casework and that they should be on their way soon. Functional development is done.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #273 of 624 Old 04-18-2012, 02:53 PM
Venomous's Avatar
Thanks Kal!
Venomous is offline
post #274 of 624 Old 04-18-2012, 03:19 PM
jmschnur's Avatar
Looking forward to a review of this one.
jmschnur is offline
post #275 of 624 Old 04-23-2012, 12:46 PM
bsoko2's Avatar
Quoted: 79 Post(s)
Liked: 80
My Duo Core is on the way. Shpped from Finland today the 23rd and will be delivered by UPS at end of day on the 25th. Now that is a quick delivery from Finland to Olympia, WA.
bsoko2 is online now
post #276 of 624 Old 04-23-2012, 04:09 PM
bsoko2's Avatar
Quoted: 79 Post(s)
Liked: 80
post #277 of 624 Old 05-06-2012, 06:44 AM
A L Wong's Avatar
I just took delivery of a Rhythmik F12SE to add to my dual ported SVS PC12NSD
I am running a triple subs set up in a 5.1 system. The AVR is the Denon 3808 with Audyssey XT. The single LFE pre-out is connected to a AM8033c.
I have the two ported subs in front, with both subs' phase set to 0 and connected via a Y connector to the 0 phase output of the AM8033C.
I have the sealed Rhythmik at the rear left of my sofa. I am using the LFE input and set the phase to 180. This sub is connected to the 180 deg phase output of the AM8033 as recommended by AntiMode.
I read some where here, that if connected to the LFE input, this bypass the phase and cross-over in the F12SE.
Will this interfere with the AM8033C 's calibration, which recommended the phase to be set to 180?
Should I instead use the line input of the F12, which enables the phase control?
Thank you and sorry for the long post.
A L Wong is offline
post #278 of 624 Old 05-22-2012, 01:40 PM
moparfan's Avatar
There is now a 8033SII and the 8033 Cinema. Anyone know th real difference between the two other than the brief table on the DSPeaker site?
moparfan is offline
post #279 of 624 Old 06-11-2012, 12:46 PM
jmschnur's Avatar
So?
J
jmschnur is offline
post #280 of 624 Old 06-12-2012, 11:40 AM
a1bert's Avatar
Hardware: S-II has blue LEDs, dual inputs (for stereo systems without LFE out), normal and inverted output (balanced output possible), cinema has yellow LEDs, one input, one output.
Firmware: S-II has wider pass-band and correction range, more Anti-Mode filters, additional lift and lowpass-filter modes. (See the manual.)
a1bert is offline
post #281 of 624 Old 06-12-2012, 02:06 PM
cburbs's Avatar
Quoted: 94 Post(s)
Liked: 29
Info I got from them -
S-II has two inputs that are actively summed (so you can connect stereo systems etc. see the connection examples), and corrects upto 250Hz. S-II also has additional lowpass filters modes. You can see the differences from the comparison chart http://www.dspeaker.com/en/products/anti-mode-8033.shtml and CinemaSII manual: http://www.dspeaker.com/fileadmin/datasheets/dspeaker/antimode8033CinemaSIIen.pdf .
S-II is not yet available, but all remaining 8033S units are programmed with the latest firmware, so they are identical to S-II, except for the LED color (yellow instead of blue)
"You’re KILLIN’ ME Smalls! "
Sony 55EX500 Settings
cburbs is offline
post #282 of 624 Old 08-13-2012, 07:13 AM
vinodk's Avatar
Quoted: 87 Post(s)
Liked: 33
I am contemplating getting Antimode 8033 to use with my Velo SMS-1. I am guessing it will be best of both worlds with 8033 correcting things in time domain also with SMS-1 providing more control over 8033. Has anybody used this combo?
Vinod
vinodk is offline
post #283 of 624 Old 08-13-2012, 10:05 AM
bsoko2's Avatar
Quoted: 79 Post(s)
Liked: 80
What is your reciever? Best not to mix them, one is as good as the other and I prefer the Anti Mode 8033.
post #284 of 624 Old 08-13-2012, 11:47 AM
vinodk's Avatar
Quoted: 87 Post(s)
Liked: 33
My receiver does not have EQ. I figured I can run 8033 first & use SMS-1 just to change presets & final tweaking with its manual EQ.
Vinod
vinodk is offline
post #285 of 624 Old 08-29-2012, 12:00 AM
mike kaw's Avatar
I have a pioneer receiver it does not eq the sub. I thought maybe I should get an antimode.
I'm not really sure which of the two antimodes to get. I would get the cinema because its cheaper but read through the post. Some of you said there is a pop sound when it turns off.
Is the SII worth it over the cinema?
mike kaw is offline
post #286 of 624 Old 08-29-2012, 12:09 AM
Skylinestar's Avatar
Quoted: 1207 Post(s)
Liked: 225
The one with "pop" is 8033c, not the 8033cinema.
Skylinestar is offline
post #287 of 624 Old 08-29-2012, 12:18 AM
mike kaw's Avatar
Good! I should go for the cinema.
thanks
mike kaw is offline
post #288 of 624 Old 08-29-2012, 07:30 AM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Nice, when you get it, tell us how you like it, im gonna order the CInima version on Friday.
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
post #289 of 624 Old 08-29-2012, 09:44 AM
mike kaw's Avatar
oh you'll have to wait... I'm not in a hurry to get it, maybe by the end of the year.
mike kaw is offline
post #290 of 624 Old 08-30-2012, 07:26 AM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Well i should be ordering the CInima version tomarrow.
HT~
2.1CH~
Joshjp is offline
post #291 of 624 Old 08-30-2012, 02:09 PM
Auditor55's Avatar
Can I borrow yours after you're done?
Auditor55 is offline
post #292 of 624 Old 08-31-2012, 09:44 AM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
NO. LOL, BTW, how the F do you order one of these?, every time i try, it says payment declined.
HT~
2.1CH~
Joshjp is offline
post #293 of 624 Old 08-31-2012, 10:14 AM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Nevermind i just used paypal, and it worked, so i should be getting the Cinima version soooon, YAY.
HT~
2.1CH~
Joshjp is offline
post #294 of 624 Old 08-31-2012, 11:35 AM
LowTech1's Avatar
Quoted: 1149 Post(s)
Liked: 272
Nice Josh! I hope it works well!
LowTech1 is offline
post #295 of 624 Old 08-31-2012, 12:34 PM
Skerlnik's Avatar
Where are you dudes ordering these from anyway? Somewhat hard to find a vendor...
Skerlnik is offline
post #296 of 624 Old 08-31-2012, 01:38 PM
globalgreg's Avatar
Liked: 29
I'm in the US and I ordered mine from here. http://www.creativesound.ca/index.html
globalgreg is offline
post #297 of 624 Old 08-31-2012, 02:01 PM
firemanast's Avatar
I ordered mine from here. http://www.tweekgeek.com
firemanast is offline
post #298 of 624 Old 08-31-2012, 06:36 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
I ordered mine from Db speakers.
HT~
2.1CH~
Joshjp is offline
post #299 of 624 Old 09-04-2012, 10:20 AM
Skerlnik's Avatar
Thanks for the links!
It looks like the 8033S has stereo in/outs... does that mean I can use it with 2 subwoofers? I've got 2 low level sub outputs on my AVR, and am thinking about purchasing 2x Hsu ULS-15's.
Skerlnik is offline
post #300 of 624 Old 09-04-2012, 12:22 PM
Brady84's Avatar
You can use it with two subs but it will treat them as one summed unit. If you want independent dual sub calibration you have to upgrade to the 2.0 dual core version.
Brady84 is online now
