Antimode 8033 - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 18Likes
post #541 of 624 Old 06-16-2013, 12:18 PM
dondino's Avatar
Originally Posted by Brian Fineberg View Post
Ill find out soon. I just bought an 818. Ill let you know. If so there will be an antimode for sale soon smile.gif
Might want to check a few searches here because I think I've read the XT32 implementation in the 818 is "crippled" as in it does not include the full sub EQ component? I could be wrong on this. Just a friendly heads up.
FWIW, I've used an onkyo 905 (with XT) with the antimode S-II and it does not sound as good as my 5009 with XT32 alone. I haven't run any graphs, just my opinion.
I will most likely sell mine soon.
ala Yoda...
"Tweeters". Heh! "Treble". Heh! A basshead craves not these things! ...
dondino is offline
post #542 of 624 Old 06-16-2013, 12:45 PM
globalgreg's Avatar
Liked: 29
Put up my 8033S in the classifieds.
globalgreg is offline
post #543 of 624 Old 07-04-2013, 07:15 PM
wse
wse's Avatar
Quoted: 2204 Post(s)
Liked: 806
Originally Posted by BeeMan458 View Post
Hint, hint, you can download REW for free:cool: But the rest of it is going cost's ya.tongue.gif (Something to be considered.)
Difficult to use with a Mac!
wse is offline
post #544 of 624 Old 07-04-2013, 07:16 PM
wse
wse's Avatar
Liked: 806
Why? Upgrading? Not useful? Over promised?
wse is offline
post #545 of 624 Old 07-04-2013, 07:29 PM
globalgreg's Avatar
Liked: 29
Upgraded to an AVR with Audyssey XT32. Bass is so good with justt XT32 that I figured I don't need it. Too lazy to see how it is with both the Antimode and XT32. biggrin.gif
post #546 of 624 Old 07-05-2013, 06:34 AM
wse
wse's Avatar
Liked: 806
Originally Posted by globalgreg View PostUpgraded to an AVR with Audyssey XT32. Bass is so good with justt XT32 that I figured I don't need it. Too lazy to see how it is with both the Antimode and XT32. biggrin.gif
Ah that make sense I heard the XT 32 is very goo, which AVR
wse is offline
post #547 of 624 Old 07-05-2013, 07:01 AM
globalgreg's Avatar
Liked: 29
The Denon AVR-X4000. I like it a lot.
post #548 of 624 Old 12-10-2013, 07:22 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4006
I have a SC-61 pioneer elite on the way, and was considering grabbing a 8033Cinema for my VTF15H.
Couple of questions:
  1. I understand I run the 8033 cal before proceeding with MCACC, but what about sub gain control which wont be tweaked until you see MCACC results? Does that have no bearing on the Anti Mode Cal.
  2. Is there anything in MCACC I should have OFF when using the anti mode?
The manual just makes it like you hook it up, let it do it's thing for 10 mins or so, and then it'll apply that room correction to the sub channel coming in going forward. I get that the signal runs through the Anti Mode and it applies the filters (same principal as a calibrated video processor before the display), but I guess the gain setting is what I do not get. Or does the sub gain setting have no bearing on the room response, meaning the sub will report the same response in a room whether the gain knob is a 25% or 50%?
gadgtfreek is online now
post #549 of 624 Old 12-10-2013, 07:25 AM
BeeMan458's Avatar
Liked: 813
Gain or level match the subs first. Run Anti-Mode in front of MCACC and then run MCACC.
Once turned on, Anti-Mode runs through about eight iterations and then automatically turns off. If you have REW, put REW in RTA mode and you can watch Anti-Mode go through each of it's sweep cycles.
BeeMan458 is offline
post #550 of 624 Old 12-10-2013, 07:33 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4006
OK. I only have one sub, so it may be best to run MCACC, determine what is a good volume setting on the sub by where MCACC sets the trim level, then I can go back and run the 8033 setup, then MCACC?
Thanks. My current sub volume was set with an iteration of Audyssey, so it is probably fine where it is.
post #551 of 624 Old 12-13-2013, 11:04 AM
saprano's Avatar
Quoted: 552 Post(s)
Liked: 547
I'm reading the manual for the antimode and I'm a little confused about the lift settings.
Do they boost frequencies, cut them, or both? I see the part where it says it boosts frequencies by 8db. But there's also another section saying it cuts them by -3db. Is that only when both LED's are on?
Also, if anyone knows any sites I can get the 80333S2 cheaper than dspeaker that would be great.
home theater addict
saprano is offline
post #552 of 624 Old 12-13-2013, 01:16 PM
kma100's Avatar
Quoted: 49 Post(s)
Liked: 35
Brian - did you ever try this? What is your opinion on 818 vs. Antimode?
kma100 is offline
post #553 of 624 Old 12-13-2013, 02:08 PM
rhed's Avatar
Quoted: 642 Post(s)
Liked: 483
Got my 2.0 from here. Very good service. And the DSpeaker is very fast to answer emails if you have any questions..
http://www.simplifiaudio.com/
rhed is offline
post #554 of 624 Old 12-13-2013, 05:38 PM
saprano's Avatar
Quoted: 552 Post(s)
Liked: 547
Ok, thanks.
Anybody can answer my other questions?
home theater addict
saprano is offline
post #555 of 624 Old 05-30-2014, 05:55 PM
brettus's Avatar
Lifting boosts those freqs and also applies a subsonic filter to cut out below 10hz freqs.
I personally use the 15-25hz lift setting for my dual subs as they are 12inch driver with passive radiator (PR) in each box.
Here is a cut from the manual-
-4.2.1. “Flat”
The first lifting EQ setting is no lifting, “flat.” Neither of the LEDs 'LIFT 25' nor 'LIFT
35' is lit. In this setting, the target response is flat from 5 to 148 Hz.
-4.2.2. Lifting 15-25Hz
In lifting 15-25 mode, when the LED “LIFT 25” is lit, the AntiMode
will boost
frequencies between 15 and 25 Hz (max. 7dB at 20Hz). This will also activate digital
infasonic filter, which will filter out frequencies below 10Hz, that can be dangerous to
ported subs without proper protection.
-4.2.3. Lifting 25-35Hz
Third mode, lifting 25-35
similarly boosts range 25-35Hz (max. 7dB at 30Hz) on
subwoofer. This mode is active when the LED LIFT 35 is on. This will also activate
digital infasonic filter, which will filter out frequencies below 10Hz.
It is easiest to find out which of the lifting settings gives best result by simply
listening. Lifting below 35Hz could be useful for reflex subwoofers, which have port
tuning above 30Hz, but the lowest frequencies are attenuated to the listening
position. With music, 'flat' is probably the best option, as it gives the most accurate
transient response. Lifting below 25Hz could be applicable for a large subwoofer,
which has 6dB
point too high because of suboptimal positioning.
saprano likes this.
brettus is offline
post #556 of 624 Old 06-03-2014, 09:56 AM
saprano's Avatar
Quoted: 552 Post(s)
Liked: 547
Thanks for responding to that 5 month old post!
Is it easy to select these different modes? You have to do all kinds of different button presses.
home theater addict
saprano is offline
post #557 of 624 Old 06-04-2014, 03:13 PM
brettus's Avatar
It's easy with 1 button that selects the 25, 35 or Flat setting and the leds light to confirm which is selected! The other button bypasses the Antimodes EQ altogether.
saprano likes this.
brettus is offline
post #558 of 624 Old 12-31-2014, 09:53 AM
NismoZ's Avatar
Quoted: 16 Post(s)
I have been researching Anti-modes 8033 Cinema vs SII. They are about $100-150 difference. Do they both handle 2 subs for auto calibration? What are the features or upgrades of the SII over the Cinema?
Thanks guys.
NismoZ is offline
post #559 of 624 Old 12-31-2014, 10:19 AM
cburbs's Avatar
Quoted: 94 Post(s)
Liked: 29
You can find the comparison midway down -
http://www.dspeaker.com/en/products/...ode-8033.shtml
"You’re KILLIN’ ME Smalls! "
Sony 55EX500 Settings
cburbs is online now
post #560 of 624 Old 12-31-2014, 10:45 AM
NismoZ's Avatar
Quoted: 16 Post(s)
I saw that, just trying to figure out what scenarios I might need the SII over the Cinema? I saw that it offers 8 more filters, 2 RCA inputs over 1, and goes up to 250Hz instead of 160.
NismoZ is offline
post #561 of 624 Old 01-08-2015, 12:49 PM
Ovation's Avatar
Quoted: 104 Post(s)
Liked: 71
I don't think so. I have a 8033-C (pre-cursor to the Cinema) and it has two RCA inputs, though only one channel. One input is inverted 180 degrees out of phase with the other, so setting the second sub to 180 degrees allows the device to EQ both subs in phase (that's how I use mine with my 2 subs). With the Cinema, and only one input, I can't see how it would work with two subs, though perhaps a simple y-splitter could do the job. The extra filters might prove useful in the SII, though. Sorry if this only confuses things further.
Ovation is online now
post #562 of 624 Old 01-08-2015, 02:44 PM
derrickdj1's Avatar
Quoted: 984 Post(s)
Liked: 720
Multiple subs should be treat as one or in pairs to get the best room response. For example, two subs EQ'ed as one or 4 subs EQ'ed as pair A and pair B.
derrickdj1 is offline
post #563 of 624 Old 01-17-2015, 12:34 PM
Ovation's Avatar
Quoted: 104 Post(s)
Liked: 71
Mine are EQ'd as one (the version of the 8033 I have sums combines the sub signal for EQ purposes). Works great for me. The attached graph shows how well--one trace is my recently added SVS PB-2000 alone, without EQ, one trace is the PB-2000 alone with the 8033 engaged and one is the PB-2000 plus my old Boston Acoustics PV900, with EQ (the PV900 effectively deals with the problematic null while helping to smooth things out down to about 35hz, give or take, while letting the PB-2000 do the "heavy lifting"). The 8033 is especially useful at taming the peak on the green trace (which was captured at a lower output--that hump around 22hz should be considerably higher than the other traces at that frequency).
Name:	before and after eq with hts settings for graph.jpg
post #564 of 624 Old 03-18-2015, 07:02 PM
sinisanav's Avatar
Quoted: 88 Post(s)
Liked: 76
I just bought the 8033S-II from creativesound ( here in USA), I was interested in Cinema as I have two subs but working as one on the one LFE from AVR. they were out of the Cinema and offered me the 8033S-II for only 50$ more, so I went for it. Just got it and run the calibration, still have to redo the Audyssey now before checking the impact. I do not need the second out for the separate sub , but if one day I do go stereo with subs then I will be ready.
Change is the only constant.
My HT: http://www.avsforum.com/forum/19-ded...l#post32691273
sinisanav is offline
post #565 of 624 Old 03-19-2015, 02:27 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 520
The antimodes are not designed to EQ stereo subs, you want something like the SVS EQ-1
As for 8033C versus S-II, the S EQ's higher up, has stereo inputs and ouputs, has a few extra modes ie dipole mode. It's more used to be for a stereo system, wheras 8033C is for LFE output (single RCA)
fatbottom is offline
post #566 of 624 Old 03-19-2015, 10:54 AM
sinisanav's Avatar
Quoted: 88 Post(s)
Liked: 76
You are right, 8033S is just for one sub or for two separate subs in a HT and stereo setup. the new 8033 2.0 is a true stereo EQ from Antimode.
post #567 of 624 Old 03-19-2015, 01:02 PM
fatbottom's Avatar
Liked: 520
You probably mean the dual core version? I'm not sure if that EQ's two subs like SVS-EQ1 or higher end XT32/ Sub XT32 or whatever it's called.
post #568 of 624 Old 03-19-2015, 01:38 PM
sinisanav's Avatar
Quoted: 88 Post(s)
Liked: 76
Red face
yes, Dual core.
post #569 of 624 Old 03-20-2015, 12:41 PM
Skylinestar's Avatar
Quoted: 1207 Post(s)
Liked: 225
since the dualcore has usb connection to pc, can i use it with rew?
Skylinestar is offline
post #570 of 624 Old 04-17-2015, 04:37 AM
skinnydoggy's Avatar
Quoted: 45 Post(s)
How would I connect a Behringer nu6000dsp to the antimode 8033sii? I have a Sherborn pt7030, xlr outputs. I'm guessing from my 30 foot male xlr, get an extender (female to stereo rca?) run it in to both 8033 inputs, then use only one of the outputs by rca to xlr male? So confused
skinnydoggy is offline
