Need help diagnosing/repairing Eosone 910 sub - AVS Forum
post #1 of 5 Old 07-09-2009, 07:35 PM - Thread Starter
dlp3719's Avatar
So my FIL had a Eosone RSP910 Subwoofer sitting in his garage that he gave me. Said it worked fine 2 years ago. I thought I would add a second sub to my HT for fun.
First, I unplugged my Infinity sub and plugged in the new Eosone. NOTHING. The standby light is red. It seems to have power but I can not get it to make ANY sound (crackles, hums, nothing). Tried both RCA jacks and a Y splitter into both.
Of course, I am having a tough time finding ANY manuals online. Does anyone have an owner's manual for this thing? I would like to check the fuses if there are any. Cosmetically the sub looks in great shape.
dlp3719 is offline
post #2 of 5 Old 07-10-2009, 03:35 AM
jac86's Avatar
I'm not that good in this area, but, bad fuse or blown capacitor. Or water damage from humidity. Open it up if you can and look for anything odd.
Where did all my money go?
jac86 is offline
post #3 of 5 Old 07-10-2009, 06:15 AM - Thread Starter
dlp3719's Avatar
Plan to open it up this weekend.
He didn't have the power cord for it. Volts on the sub says 115V. I found a Max 125V power cord that fit it. I assume this is ok?
dlp3719 is offline
post #4 of 5 Old 07-10-2009, 06:23 AM
jac86's Avatar
Yes. No problems there.
Could also be the plate amp?
jac86 is offline
post #5 of 5 Old 07-10-2009, 06:37 AM - Thread Starter
dlp3719's Avatar
I called Polk Audio. They were helpful. They suggested I pull the speaker and test it first with direct connection. If it's bad a guy is liquidating Eosone parts on ebay.
dlp3719 is offline
User Tag List
