Awkward subwoofer install...need help! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 10-17-2009, 04:16 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Originally Posted by OtherSongs View Post
I'm also more than a little surprised at how few understand what sub phase does. When the sub(s) is in phase with the other 5 speakers it shows much more cone movement, and when out of phase there is cancellation and the sub cone moves (via fingertip) noticeably less.
You are wrong. Cozmo is talking about YOU. The phase setting has absolutely no effect upon the sub itself's output. A sub playing a tone by itself at 75dB will have the exact same amount of cone movement no matter where you set the phase. The phase controls how the sound that the sub puts out interacts, acoustically, with the output of the other speakers.
Originally Posted by milkfat View Post
To humor you I did play some sine waves from the main speakers with the subwoofer off. I couldn't feel the cone moving at all... there isn't any vibration there that could be added to the cone movement from the original signal. Not only that but my subwoofer has a servo mechanism that counteracts any cone movement not present in the original signal. Any sympathetic vibrations from anywhere are neutralized by the servo. Yet my subwoofer still has a phase control because the phase issues occur at the listening position where the audio waves are being perceived. Phase issues will be different at each listening position as well, because each position is a different distance from speakers/subwoofer(s).
All I can figure is that he MAY be feeling an increase in the sympathetic movement when the 'correct' phase is achieved.
Or, more likely, he is confusing his phase knob and his low-pass filter knob.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is online now
Old 10-17-2009, 04:44 PM
otk
otk's Avatar
It's like The Twilight Zone in here!
nope. it's the outer limits:
There is nothing wrong with your television set. Do not attempt to adjust the picture. We are controlling transmission. If we wish to make it louder, we will bring up the volume. If we wish to make it softer, we will tune it to a whisper. We will control the horizontal. We will control the vertical. We can roll the image, make it flutter. We can change the focus to a soft blur or sharpen it to crystal clarity. For the next hour, sit quietly and we will control all that you see and hear. We repeat: there is nothing wrong with your television set. You are about to participate in a great adventure. You are about to experience the awe and mystery which reaches from the inner mind to... The Outer Limits.
All this noise about noise.
Finding the acoustic sweet spot.
otk is offline
Old 10-17-2009, 05:39 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Hey, otk. Quit, man. You're scaring me.
Old 10-17-2009, 07:27 PM
otk
otk's Avatar
otk is offline
Old 10-18-2009, 09:12 AM
shinksma's Avatar
Location: Wandering the intertubes, on the way to damnation
Quoted: 80 Post(s)
Liked: 54
Unless you are wearing your subwoofer as a hat then the phase at the subwoofer position is completely irrelevant.
Well there's your problem right there! He rejects your reality and substitutes his own.
shinksma
My opinions are my own, and do not necessarily reflect those of my captors.
shinksma is offline
Old 10-18-2009, 12:06 PM
OtherSongs's Avatar
shinksma
Well there we are, now it's down to alternate realities.
Anyhow IMHO, it's an eyeopener as to how many that post in the AVS subwoofer forum do not understand how to *manually* set up one or two subs in a MC (MultiChannel) sound system, not to mention that many of those in this thread don't both to actually follow-up on what I've accurately stated again and again in this thread.
1st, buy a copy of the best disc I've come across for this is:
"The Ultimate DVD Surround Sound Sampler & 5.1 Set-Up Disc" by Chesky at:
http://www.amazon.com/gp/redirect.ht...&creative=9325
Also read my posts in this relatively short (95 post) thread. All of them are consistent and accurate.
Cheers
The best is the enemy of the good. Voltaire (1694-1778)
OtherSongs is offline
Old 10-18-2009, 01:22 PM
Splicer010's Avatar
Liked: 39
All I can say is what has worked for me for the past 11 years of owning and setting up subwoofers, both for myself and others, have never been disappointed, was said in my first post in this thread, and stands as true as anything. There is NO NEED for 'setup' discs. There is no need for specialized equipment that can graph your response. The ONLY thing neccessary are the listeners ears. Nothing more and nothing less. Regardless of the 'phase' debacle of what a phase switch actually does, what it all boils down to is what sounds best to the listener. And I quote:
Originally Posted by Splicer010 View Post
No scenario neccessary. Place the phase switch at 0 and see how you like the sound. Then change to 180 and see how that sounds. Put switch on whichever setting sounds best to YOU. I have always followed my ears and have never been disappointed or let down with the results.
Splicer010 is offline
OtherSongs's Avatar
I'm done with the dumb/nonsense posting in this thread.
I'll open up a new thread in the subwoofer forum, that
is on topic to the subject of *manually* setting up 1 or
2 subs, which is what I've addressed in this thread.
Reply there, because I'm done with the dumb posting
in this thread.
Cheers
Old 10-18-2009, 02:06 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
in this thread.
So you're admitting it, then?
