Awkward subwoofer install...need help! - AVS Forum | Home Theater Discussions And Reviews
Old 10-04-2009, 10:00 PM - Thread Starter
flightc's Avatar
Hello everyone. I am connecting my subwoofer to my home theater and wanted to ask which phase I should set it on? I have the 0 and 180 options. Now here's the scenario. The sub will actually be in the adjacent room, facing opposite of the mains. After reading multiple threads, its seems like it should be on the 180 setting, however I wanted to get some fresh intel and verification on that setup. Thanks
Oh and for those wondering the off question of why is it in another room, well the answer is lack of space.
flightc is offline
Old 10-04-2009, 11:28 PM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
Let us see a drawing of the room or pics?
Bill
bsoko2 is offline
Old 10-05-2009, 11:45 AM
OtherSongs's Avatar
Get a copy of "The Ultimate DVD Surround Sound Sampler & 5.1 Set-Up Disc" at: http://www.amazon.com/s/ref=nb_ss?ur...chesky&x=0&y=0
The disc is both DVD-video (DD5.1) as well as DVD-audio.
What you want is the DD5.1 that is on the DVD-video part of the disc; which has 49 tracks of various DD5.1 tests that any DVD player can play.
There are several tracks that help with sub phase selection; perhaps tracks 30 and 31?
Cheers
The best is the enemy of the good. Voltaire (1694-1778)
OtherSongs is offline
Old 10-14-2009, 02:46 PM - Thread Starter
flightc's Avatar
Thank you for the link to the setup cd
As for a diagram, here is a top view shot of what I'm working with. Made with my expert paint skills
Hopefully this helps some.
Red blocks are the main home theater speakers/tv etc. The blue block is the subwoofer. The arrows are pointing in the firing direction.
flightc is offline
Old 10-14-2009, 02:57 PM
Noubourne's Avatar
Actual testing is the only way to determine this.
The DVD and an SPL meter will be able to help you. More sophisticated tools could do a better job, but for a limited set of listening positions, you'll get by just fine with the DVD and an SPL meter.
Noubourne is offline
Old 10-14-2009, 03:57 PM
frugalhomeav's Avatar
Play some material that has content within the crossover range between the mains and subs (normally around 80Hz). Try it on one setting, then try it on the other with the same material. Choose the setting that is loudest and most "full" sounding in the crossover frequency range (listening at your main seating position).
-Joel
http://www.frugalhomeav.com - Home Audio/Video Excellence on a Budget
frugalhomeav is offline
Old 10-14-2009, 04:17 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is online now
Old 10-14-2009, 05:33 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Lack of space is not a good enough reason to put the sub in another room. Make space for it in the room... anywhere.
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
Old 10-14-2009, 05:43 PM - Thread Starter
flightc's Avatar
Heh, I wish I could. I actually had it right next to a tower before I rearranged the room. Now there is about 6" between the door and the left speaker and about 4" between the right speaker and another door swing clearance. With the sub being about 14" wide, there leaves absolutely no option to put in the same room. I will definitely just do some old school by ear testing. Now tell me if I should change this setting or not. My receiver outputs the sub frequency at 200-150-100hz and my sub crossover can be adjusted between 180 to 50hz. I have the receiver outputting at 150hz with the sub (manual knob control) set at about 140ish hz. Not really on subject, but couldn't hurt to ask.
flightc is offline
Old 10-14-2009, 06:00 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Re-arrange the room back. Or, put it in the middle of the room. Or, use it as a ottoman or an end table. Just get it in the room.
The only sound you'll get from it in the other room will be reflected sound coming through the doorway. It will be so far out of phase that no phase control in the world can adjust for it. Imagine putting one of your mains in the other room. Why would you think it would be OK with your sub? As I said, make room for it *anywhere* in the room... or just get rid of it.
Craig
Lombardi said it:
My System
Old 10-14-2009, 06:14 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Craig
Audyssey will fix it.
Old 10-14-2009, 06:19 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
You have it setup wrong. Once you get the subwoofer in the correct room you need to set the subwoofer's "crossover" as high as possible. The receiver's crossover needs to be adjusted to a setting that is appropriate for your speakers' low end capability and output in your room.
Do you have any pictures of your room's front wall?
Old 10-14-2009, 06:34 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Bill
Lombardi said it:
My System
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
He claims there is no ROOM for the sub and that is why I asked for room layhout or pics.
Bill
bsoko2 is offline
Old 10-14-2009, 06:44 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Bill
A photo.
OK, gotcha. Sorry. I thought you were going to tell him how to adjust his phase based upon his layout.
Old 10-14-2009, 07:32 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Bill
A photo.
Whatever...
Lombardi said it:
My System
Old 10-14-2009, 07:37 PM - Thread Starter
flightc's Avatar
I don't have any actual photos of the room, but I would have a spot for it but I would have to run about 25-20' of cable to get it hooked up. Besides that, there is no where to run the cable and I'm not about to leave a cable top side of the carpet ran from one side of the room to the other.
Here is just the full layout of the room with all doors, open walkways and furniture done the best I could with paint.
Like I said, with where the system is positioned and with all the walkways and doors where they are located, there is no 'clean' way to route a cable back to a sub (which I would put it next to the couch at the back of the room.
flightc is offline
Old 10-14-2009, 07:39 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Whatever...
OK. So what? We still need to see a better diagram or photo if we're going to relocate his sub, don't we? That's what I'm asking for.
edit: ooops, there it is!
Old 10-14-2009, 07:43 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
What is that in the front right corner? What is the light gray square? Can you put it on the right wall near that?
Old 10-14-2009, 07:58 PM - Thread Starter
flightc's Avatar
The jagged line in the top right corner is the swing path to another door. The light gray square is an end table. (and theres actually another on the right side of the couch)
flightc is offline
Old 10-14-2009, 08:06 PM
Splicer010's Avatar
Liked: 39
No scenario neccessary. Place the phase switch at 0 and see how you like the sound. Then change to 180 and see how that sounds. Put switch on whichever setting sounds best to YOU. I have always followed my ears and have never been disappointed or let down with the results.
With that being said, I have my sub phase set to 0 and am completely happy.
Splicer010 is offline
Old 10-14-2009, 08:12 PM
Splicer010's Avatar
Liked: 39
...and with further reading put the sub in the same room. Put the sub between the bottm right corner red square andthe gray circle directly north of the red square.
Old 10-14-2009, 08:14 PM
Splicer010's Avatar
Liked: 39
Fish the sub cable under the carpet at the door way (jagged line). It really isn't hard if you have a metal coat hanger.
Old 10-14-2009, 08:14 PM - Thread Starter
flightc's Avatar
Thanks for the response however I did state that there is no way I can run a cord from the receiver to that position, or any position on an opposite wall, without leaving the cord exposed and on top of the carpet which is not an option.
flightc is offline
Old 10-14-2009, 08:16 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
http://skycraftsurplus.com/ultrathintvcoax25ft.aspx
Old 10-14-2009, 08:18 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
So, why were you confused by bsoko asking for it? As I said, whatever...
OP. I see plenty of potential spots for placement of your sub in your room. If cabling is the issue, then 20' to 25' of cabling is a far superior solution to placing the sub in another room.
Craig
Lombardi said it:
My System
Old 10-14-2009, 08:21 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
That's video cable with "F" connectors, not RCA connectors.
Lombardi said it:
My System
Old 10-14-2009, 08:38 PM
Splicer010's Avatar
Liked: 39
One of these on either end will remedy that:
http://www.amazon.com/RiteAV-Male-F-...5574008&sr=1-1
Sure you can. I told you how. Fish the cable under the carpet at the doorway. Simple. Nothing to it. Done all thetime every day. You just gotta want to do it. And by as much as you seem to be resisting, I am getting the feeling you really don't want to do this right and are yanking everyones chain.
Old 10-14-2009, 08:44 PM
Splicer010's Avatar
Liked: 39
Here. I even went and got you easy, step by step instructions on exactly what to do:
http://www.ehow.com/how_5088296_fish...er-carpet.html
Combine this along with the cheap cable sivadselim linked to and the proper connectors I linked to and you have a complete solution. Unless you don't want a complete solution. The rest is up to you.
Old 10-14-2009, 08:56 PM
BMWM3Rod's Avatar
Why don't you try setting it at 180 and see how it sounds and then at 0 and see how it sounds. Also adjust the crossover and see how it sounds.
Good luck with it.
BMWM3Rod is offline
