Wireless Subwoofer Connection..Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 10-08-2009, 06:46 AM - Thread Starter
sstea's Avatar
Does anybody know of a good wireless solution for connecting a subwoofer? I got a great compact subwoofer but the wife has gone ballistic on the aesthetics. I have to move the subwoofer to the opposite side of the room.
I have been shocked at how little there seems to be readily available as a solution.
The butkicker RF kit is not good for this application by the companies own admission. It is subject to interference and the signal is not clean enough.
Rocketfish has a transciever but it is geared for speaker level inputs and has a Rx with an amp.
Audioengine has an over priced wireless solution. It is $149 for tx and rx usb powered dongles.
Any other suggestions?
The other concern is latency. For example, the Audioengine transceiver lists a latency of 20ms. This translates to an equivalent distance of an extra 22.5 feet. Will this screw up the Audyssey calibration attempted by my AV receiver.
Any help on this topic would be greatly appreciated.
sstea is offline
post #2 of 22 Old 10-08-2009, 07:51 AM
BillCinLR's Avatar
Audyssey will compensate for the delay ... you will just end up with an unusually long distance shown to the subwoofer. As long as you leave the calculated distance alone, all should be fine.
Bill C
BillCinLR is offline
post #3 of 22 Old 10-08-2009, 08:33 AM
Kal Rubinson's Avatar
Quoted: 803 Post(s)
Liked: 569
I have used the AudioEngine device with a subwoofer and with Audyssey just fine.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #4 of 22 Old 10-08-2009, 09:40 AM
EnergyOwner's Avatar
If you have very little RF in your home, how about these: http://www.amazon.com/Terk-LFDAS-Dig...5019907&sr=8-3
The sleeper must awaken.
EnergyOwner is offline
post #5 of 22 Old 10-09-2009, 06:50 PM - Thread Starter
sstea's Avatar
Thanks for the input.
It seems like the audioengine is the only one with decent reviews. I wish they discounted the product some.
sstea is offline
post #6 of 22 Old 11-23-2009, 02:56 PM
malaplace's Avatar
Those that just recently purchased for subwoofer use, results? I'm thinking about doing picking up the audioengine unit myself to move my subwoofer to a more convenient location.
malaplace is offline
post #7 of 22 Old 11-23-2009, 03:26 PM
stc4life's Avatar
Got one of these based on Kal's recommendation. It works great and introduces no noise. Highly recommended. You will probably need a second USB charger though, so plan accordingly (they are about $5 on ebay).
stc4life is offline
post #8 of 22 Old 11-26-2009, 09:09 AM
southchandler's Avatar
Is this the one were talking about guys? I was just searching here for the same thing and came across this thread.
http://www.audioengineusa.com/w1_home.php
southchandler is offline
post #9 of 22 Old 08-29-2012, 11:35 AM
Toadster's Avatar
has anyone tried the Outlaw OAW3?
Toadster is offline
post #10 of 22 Old 08-30-2012, 06:35 AM
ndskurfer's Avatar
Quoted: 43 Post(s)
Liked: 53
I use the amplified version for a second zone, works perfect with no issues. I'm sending it to another room up a flight of stairs. I ended up buying an OAW3 during a recent sale, but have yet to use it. I plan to eventually use it to send a signal to 2 powered subs behind my seating.
ndskurfer is offline
post #11 of 22 Old 09-02-2012, 08:31 AM
Toadster's Avatar
I just found the Channel Vision WA-321 Wireless Transmitter and the Channel Vision 1-to-many Reciever - seems like a pretty solid combo for ~$100
Seems to be a great option for powered subs...
Toadster is offline
post #12 of 22 Old 04-27-2013, 04:04 PM
Coolmeadow Kid's Avatar
Any updates on the Outlaw unit? I'm considering the Sunfire SDSWIRXKIT, but if the Outlaw is working well, it is a little less money. Thanks for any info you can offer! Jim.
Coolmeadow Irish Setters and Irish Setter Rescue of North Texas. When Irish eyes are smiling, they're usually up to something!!
At a minimum, I'm Pentatoxic...but most likely, I'm a Pentaholic. There seems to be no known cure. Pentatonix, winners of The Sing Off, season 3
Coolmeadow Kid is offline
post #13 of 22 Old 04-27-2013, 04:36 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
the rocket fish unit works well @ 69.99. i have 2 of them and getting response down to 14-16hz.
basshead81 is offline
post #14 of 22 Old 04-27-2013, 06:11 PM
Thanks for the quick response. Looks like Best Buy is the only location to get them...at least they are close! Jim.
post #15 of 22 Old 05-04-2013, 03:03 PM
Picked up the Rocketfish RF unit today on the way home from work. Simple and it works! Plug the transmitter into the LFE on the receiver, plug in the receiver to the LFE on the sub. Plug in the wall warts to each unit. That's it. It auto pairs and works. It does lose a little volume. I'm sure if I ran the YPAO on the set up again that the receiver would adjust for the change in output. But for half the price of the other brands it's a keeper! Thanks for the heads up Basshead81!!!! Jim.
post #16 of 22 Old 05-04-2013, 03:36 PM
crn3371's Avatar
Quoted: 257 Post(s)
Liked: 206
That's good to know as I'm sure once I do the sub crawl I'm going to need one. I'd think rerunning ypao would help with the reduced volume and with the delay that's inherent in wireless. Nice to know I'll only have to spend $70.
crn3371 is offline
post #17 of 22 Old 05-04-2013, 08:04 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
no problem glad its working for ya! your going to want to rerun ypao again the avr can get the sub distance set correctly.
post #18 of 22 Old 06-18-2013, 05:12 PM
Just Nick's Avatar
Will Rocketfish work with speaker level inputs instead of LFE?
Just Nick
Just Nick is offline
post #19 of 22 Old 06-18-2013, 08:25 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
post #20 of 22 Old 06-18-2013, 08:51 PM
Just Nick's Avatar
Too bad. It seems like a nice unit. Any ideas for a wireless connection using speaker level inputs?
post #21 of 22 Old 06-18-2013, 09:09 PM
basshead81's Avatar
Quoted: 239 Post(s)
Liked: 6577
post #22 of 22 Old 06-19-2013, 03:27 AM
Just Nick's Avatar
Bummer. Are you positive? Should I double check? Thank you.
Subwoofers , Rocketfish Rf Rbws01 , Rocketfish , Audioengine
