JTR Captivator - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 163Likes
post #271 of 5054 Old 03-15-2010, 11:59 AM
goonstopher's Avatar
Quoted: 322 Post(s)
Liked: 66
I keep finding myself looking over at the amps input signals to see when the sound is coming from the speaker and when it is from the sub. The sub definitely outputs a full range of notes cleanely
goonstopher is offline
post #272 of 5054 Old 03-19-2010, 04:06 PM
Quoted: 322 Post(s)
Liked: 66
Could removing the s-converter limit headroom?
When playing what should be VERY loud sub scenes the sub itself does not seem to break a sweat but the sound never reaches the volume I am expecting.
For instance I played some terminator salvation and the gas station explosion was not very loud, some of the chase after it definetly flapped my pants more than I have experienced but it sounded like the sub had more to give but just wasn't getting to give it.
The front of the amp was pretty warm to the touch after one scene but I wonder if my AVR just can't feed enough signal.
avr is onkyo 805 set at 0dB, reckhorn b-1 set at 10 o'clock and ep2500 input sensitivity set to max
post #273 of 5054 Old 03-19-2010, 06:04 PM
ZivkoF's Avatar
Quoted: 23 Post(s)
Liked: 31
How long is the cable (and which cable are you useing RCA or XLR) from onkyo 805 LFE to ep2500. For increase input LFE signal to ep2500 you should to use MACKIE 402-VLZ3 and then your input sensitivity on ep2500 would not be a problem.
http://www.mackie.com/products/402vlz3/index.html
ZivkoF is offline
post #274 of 5054 Old 03-19-2010, 06:13 PM
Quoted: 322 Post(s)
Liked: 66
The samson s-converter introduced a white noise/hiss because it increased the ground floor noise too much. I just worry another similar product will do the same.
I have a 3 foot rca into the as-eq1 then a 1.5 foot rca from that to the reckhorn b-1 then another 1.5 foot out to the ep2500 with a 1/4 adapter
post #275 of 5054 Old 03-20-2010, 04:08 AM
ZivkoF's Avatar
Quoted: 23 Post(s)
Liked: 31
The lenght of the cable is not the problem then just set the reckhorn b-1 at 12 o'clock !
ZivkoF is offline
post #276 of 5054 Old 03-20-2010, 08:35 AM
Quoted: 322 Post(s)
Liked: 66
Maybe my concern (I hate to say problem because it does not seem bad enough to be a problem yet) is better explained like this - Normal volume = bass appropriate level, high volume - bass appropriate level, very high volume - amp starts lagging behind.
I love the way the sub sounds with music and with movies when I am not playing them around reference. Maybe I am just being paranoid because I am aware that I took the s-converter out of the chain (I have been known to do things like that ha)
post #277 of 5054 Old 03-20-2010, 12:43 PM
ZivkoF's Avatar
Quoted: 23 Post(s)
Liked: 31
I think that the problem is ep2500 at the high volume, you get what you paid, ep2500 is not bad ampl but is not the best even, the Captivator is in much, much higher class than ep2500 you should borrow from any of your friends any other ampl and try it or any new D-ampl!
ZivkoF is offline
post #278 of 5054 Old 03-20-2010, 01:06 PM - Thread Starter
RMK!'s Avatar
Quoted: 1697 Post(s)
Liked: 1627
+1
I have dual Captivators being driven by a single Crest CC4000. I run a Speakon cable from each amp channel to the Captivators with no voltage or hum issues. The amp was $750 so the Captivator plus amp makes the total per Captivator cost $1,375 and worth every penny of it.
Anxiety is contagious, please keep yours to yourself.
RMK! is offline
post #279 of 5054 Old 03-22-2010, 01:28 PM
Big Worms's Avatar
I found this from tony123. Maybe you can look at the your settings.
I assumed that all the pin positions on the EP4000 were in the off position to the left! When, in fact, the low pass filter is opposite...it's default position is ON!!! I was running with a filter.
.: Ernie :.
Big Worms is offline
post #280 of 5054 Old 03-22-2010, 02:18 PM
Quoted: 322 Post(s)
Liked: 66
I am thinking of getting marathon audio amps with selectable input sensitivity
post #281 of 5054 Old 03-22-2010, 09:48 PM
Quoted: 322 Post(s)
Liked: 66
I have gotten to do some more listening with some bass heavy movies.
Here are some rambling thoughts...
I would compare it with the PB13 ultra with better sound quality with music. As far as raw output I think the second will finally satisfy my insane wildest bass dreams. I like to listen close to reference with the sub running pretty hot and the captivator holds up just fine but a second will make it have just a bit more ease at the highest levels of the highest peaks so that I don't push the sub TOO hard (this is just me being careful and paranoid, the sub hasn't given me any reason to think it is being pushed too hard). It has handled every movie with reference level bass just fine and I have only been able to get the PR moving once during star wars which also got some air coming out of the port but no chuffing or distortion. This sub has HEAVY mid bass impact. Definitely a chair shaker and pant flapper. I had shorts on while sitting down so they were pressed to the chair and I still felt them vibrate. I LOVE tactile impact so to me this is very important. The lack of this is why I did not like the Epik dynasty and while, until now, the pb13 ultra was my reference sub. As I have stated it is very musical IMO the sub definitely can stop on a dime while going up and down the scale.
post #282 of 5054 Old 03-22-2010, 11:30 PM
gnocchi's Avatar
goonstopher,
How many 180's are you going to do? You have been all over the place when reviewing subs.
gnocchi is offline
post #283 of 5054 Old 03-23-2010, 12:12 AM
Quoted: 322 Post(s)
Liked: 66
Originally Posted by gnocchi View Post
goonstopher,
I have?
I have only said good things about the captivator BESIDES my hum issue.
Before that the PB13 was my favorite and the dynasty was effortless and blended well but lacked impact. All my reviews will fit that pattern
post #284 of 5054 Old 03-27-2010, 05:20 AM
bodhisafa's Avatar
Came across this and thought how would this passive radiator work with the captivator?
Would it be better or the same as the current radiator.
http://www.parts-express.com/pe/show...number=293-684
bodhisafa is offline
post #285 of 5054 Old 03-27-2010, 10:22 AM
Quoted: 322 Post(s)
Liked: 66
I highly doubt it because most PR's are tuned to extend the frequency depth while the 6th order bandpass design of the captivator actually uses the pr to extend the upper frequency range and handles the higher end.
The sub definitely is the most musical and clean I have had. The massive woofer of the dynasty may have topped it in pure output and subsonic frequencies but it has the punch an sq I was craving while still being able to play most material at reference level which is no easy task.
Basically I am saying, Jeff is onl waiting on the pr because there are few if any commercial options he can turn to and also that if you can wait then it definitely is worth it if you want top sq that is no slouch in spl. Once my second one comes I am sure full reference at all frequencies will be playing with a cleanliness that will finally satisfy 100% of my bass desires, hope the others waiting get that feeling as well... and soon.
post #286 of 5054 Old 03-29-2010, 05:16 PM
pinktri's Avatar
that PR is way too deep. You need a shallow basket-less PR.
PRO-60X5FD
PRO-70X5FD
pinktri is offline
post #287 of 5054 Old 03-29-2010, 09:42 PM
datgai's Avatar
Goonstopher,
I'm not exactly tracking your comments well. I would expect a EP2500 (measured at 2K watts @ 4ohms bridged) to drive the captivator in your room. Have you done any measurements in your room? This could explain the inconsistencies you're experiencing. How are you quantifying the amp is lagging behind at reference levels?
datgai is offline
post #288 of 5054 Old 11-12-2010, 11:18 AM
Jeff Permanian's Avatar
Quoted: 817 Post(s)
Liked: 1737
The all new 2011 Captivator is a bass reflex design with a 18" driver that is 6db more sensitive, double the power handling and the same cost!
Jeff Permanian is offline
post #289 of 5054 Old 11-12-2010, 12:02 PM - Thread Starter
RMK!'s Avatar
Liked: 1627
Wow, that sounds interesting.
RMK! is offline
post #290 of 5054 Old 11-12-2010, 12:26 PM
Quoted: 817 Post(s)
Liked: 1737
Also, the previous models can be upgraded however it does take a little wood working. You have to remove the passive radiator, remove the driver, remove the inner baffle where the 12" driver was mounted and then install the new 18" driver.
post #291 of 5054 Old 11-12-2010, 12:43 PM
bodhisafa's Avatar
You have to love the flexibility of JTR products, what a dramatic change, good for you Jeff
post #292 of 5054 Old 11-12-2010, 01:18 PM
minpin's Avatar
Just curious... for those of us waiting for Captivators, are we getting 2011 models or still on the 2010 platform?
Good..... Bad..... I'm the guy with the gun.
"Theater in the Thicket" dedicated build thread
minpin is offline
post #293 of 5054 Old 11-12-2010, 01:22 PM
Quoted: 817 Post(s)
Liked: 1737
2011s
post #294 of 5054 Old 11-12-2010, 05:36 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
Man the new Cap sounds like it might just be the sweet spot! I know 10hz would be the best but I think I could live with it being a beast down to 15hz Jeff will the cabinet be the same as the 2010 with the woodworking mentioned in post #290 already done? Where would it need to be high passed at 15hz or can it go a little lower?
gpmbc is online now
post #295 of 5054 Old 11-12-2010, 06:07 PM
diamonddelts's Avatar
If this new design contains one big 18" woofer for the same price I am definitely interested. When is this new design going to be released?
diamonddelts is offline
post #296 of 5054 Old 11-12-2010, 06:46 PM
mojomike's Avatar
Liked: 30
I've heard enough about it. I'm ordering one.
mojomike is offline
post #297 of 5054 Old 11-12-2010, 06:49 PM
Quoted: 817 Post(s)
Liked: 1737
The 2011 appears the same as the previous model with the new cosmetic changes to match the rest of the 2011 line up (rounded over corners, flatter black and light texture). Recommended high pass at 14hz.
The first batch will be in stock and ready to ship 11/29.
post #298 of 5054 Old 11-12-2010, 06:51 PM
The 2011 appears the same as the previous model. Recomended high pass at 14hz.
So what will be the final price including shipping for one?
post #299 of 5054 Old 11-12-2010, 07:01 PM
Quoted: 817 Post(s)
Liked: 1737
Manufacturer direct is $999 then minus sales and/or discounts. Average shipping cost is around $80. Shoot me an email for an exact quote.
post #300 of 5054 Old 11-13-2010, 06:29 AM
mojomike's Avatar
Liked: 30
Is the new Cap getting that same beastly 68 pound 18" driver that goes into the Orbit Shifter?
http://www.avsforum.com/avs-vb/showt...0#post19097480
(Drool)
mojomike is offline
