JTR Captivator - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 153Likes
Old 12-07-2010, 01:59 AM
HT_New_Guy's Avatar
So is this the best sub (for the price) to get the ultra low 10-15hz output? I see the HSU ULS-15 is said to play down to 10hz... but no one else really claims that for less than $3500. Is this the best bet?
HT_New_Guy is offline
Old 12-07-2010, 05:29 AM
mojomike's Avatar
Liked: 30
We're talking about a Captivator that is tuned to 15hz and would best be used with a 14hz filter below that. So no, I wouldn't consider it the best choice for 10hz response. It may be one of the most powerful subs at 15hz however.
Also last I heard, the ones built from here on in will be tuned to 20hz instead of 15. Output will be even greater, but not as deep. You might want to check with Jeff to find out if he is still willing to build the 15hz version.
For true 10hz response, you need multiple sealed subs that run without low filters and you might also need eq to boost the bottom. Ported subs are not really the answer for useable 10hz response.
mojomike is offline
Old 12-07-2010, 11:24 AM
HT_New_Guy's Avatar
Are there any subs that do this?
Old 12-07-2010, 11:58 AM
MKtheater's Avatar
Quoted: 1592 Post(s)
Liked: 1122
Yes, the Danley DTS-10 and I think the Orbit Shifter. I think maybe the Terraform does as well. You have to pay to play or DIY.
Marantz 7702 Atmos
MKtheater is offline
Old 12-07-2010, 02:05 PM
spyboy's Avatar
Liked: 47
It is ironic that I have seen at least a handfull of FR plots of the Seaton Submersive with response to under 10 hz. The thing is, those FR plots were always taken at about 78 db. I always asked for the plots at 100, 105, and 110 db, but don't remember anyone every following up with the requested plots.
One would also want THD plots at 100, 105, and 110 db so you would know if you are getting ~80% THD at 10 Hz and 105 db, (assuming the Submersive could actually deliver 10 Hz at 105 db).
spyboy is offline
Old 12-07-2010, 02:11 PM
mojomike's Avatar
Liked: 30
A sub such as the Submersive is going to depend on the type of room gain that you get from a smallish, sealed room to provide useful output at 10hz. Otherwise, you would need multiple Submersives and a good deal of eq. It's just physics. You can't fight it.
mojomike is offline
Old 12-07-2010, 03:21 PM
spyboy's Avatar
Liked: 47
What happened to the Captivator? Wasn't it a sealed design originally? Now it seems that sacrificing sub 20 Hz performance for greater 25Hz> performance is the direction things are going. Might as well get an SVS PB-13 Ultra with the 1,000 watt SLEDGE amp and run it in 20 hz mode.
spyboy is offline
Old 12-07-2010, 03:32 PM
mojomike's Avatar
Liked: 30
The original Captivator had an 18" passive radiator with a 12" active driver. The new Captivators are ported with a massive 68 lb 18" driver.
The difference between a Captivator and a PB-13 is that the Captivator will have the output of at least three PB13's.
mojomike is offline
Old 12-07-2010, 03:47 PM
spyboy's Avatar
Liked: 47
OK, ported with a massive 18 inch driver tuned to 20 Hz.
It's comical that some companies are striving for uber output to below 10 Hz and others are winning the war with little response below 20 hz and uber output above 20 Hz.
Can't wait to hear from the 3 people who are buying the new Captivator.
spyboy is offline
Old 12-07-2010, 03:59 PM
mojomike's Avatar
Liked: 30
The Captivator I'm waiting on is tuned to 15hz. Apparently, any ordered from this point on will be tuned to 20hz unless Jeff decides to offer different variations. I will be offering up my impressions of the sub compared with my PB13 once I get my hands on it and am able to give it a proper shakedown.
mojomike is offline
Old 12-07-2010, 07:34 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
Well bein a hobby guess ya gotta have somethin to do. Once you have 20hz and up handled then there is 10hz to 20hz and lastly 10hz on down. What a lot of people don't realize (I know you do) is that you can have output down to 10hz and below but if it's not substantial then it's meaningless in the real world. Then, the other part of the equation is if a movie even contains it then it also has to be recorded at a significant level. I have 2) DTS 10s nearfield and not high passed so I get plenty of shakin up goin on. I'm lookin forward to my 15hz tune Cap to even out room response. It should be interesting. I doubt my local IMAX is hitting below 20hz and I still enjoy it. It goes into smaller degrees of what deeper and deeper bass starts to contribute to the enjoyment factor. It takes a LOT more cone area to get those last few hertz. Get close and be happy or be lucky enough to have a room with lots of gain (MK Theater) or IB or lots of watts and drivers - almost always a compromise.
gpmbc is online now
Old 12-08-2010, 06:40 PM
Jeff Permanian's Avatar
Quoted: 661 Post(s)
Liked: 1393
Actually, the DTS-10 can't: recommended processing.....15hz HP@24db/butterworth. All vented speakers and tapped horns need a high pass filter just below tuning because there is no acoustic load below tuning (think of a car engine in neutral). The Obrit Shifter LF has a sealed rear chamber so it can play down into the single digits.
I just placed the order for foam plugs for the Captivator's port which will be included with the Captivator. For 15hz tuning, simple install the foam plug and if you have a powered version then install the foam plug and switch the dsp mode on the amplifier.
Jeff Permanian is offline
Old 12-08-2010, 07:04 PM
mojomike's Avatar
Liked: 30
Cool! Tuneable like my PB13. I presume that the 15hz tuned mode with the plug in place will still have sufficient "breathing"?
mojomike is offline
Old 12-08-2010, 07:26 PM
Sidewayz's Avatar
Geeze spyboy, whats with the hate-on for JTR? When I called about Captivators, they were all sold and awaiting material so new ones could be built. Those 3 people must have bought alot of subs!!
Sidewayz is offline
Old 12-08-2010, 07:53 PM
MKtheater's Avatar
Liked: 1122
[quote=Jeff Permanian;19617183]Actually, the DTS-10 can't: recommended processing.....15hz HP@24db/butterworth. All vented speakers and tapped horns need a high pass filter just below tuning because there is no acoustic load below tuning (think of a car engine in neutral). The Obrit Shifter LF has a sealed rear chamber so it can play down into the single digits.
I never used a HP on my dts-10's and never had any problems with any material well behond reference levels. I can see it in huge rooms.
Marantz 7702 Atmos
Old 12-08-2010, 07:59 PM
mojomike's Avatar
Liked: 30
With all due respect, MK, with you having two of them in your small sealed room, your DTS-10's were loafing along even beyond reference levels.
mojomike is offline
Old 12-08-2010, 08:04 PM
MKtheater's Avatar
Liked: 1122
It is only small due to the low ceilings. I do realize that but to say the DTS-10 can't will depend. I do understand about the OS but that would need major EQ to get the 10hz range even with midbass area, or, put it in my room.
Marantz 7702 Atmos
Old 12-08-2010, 11:06 PM
Quoted: 661 Post(s)
Liked: 1393
The Orbit Shifter's roll off works extremely well at mating in with room gain. In RMK's room we had solid output down to 7hz, raw, no eq:
Old 12-08-2010, 11:50 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
With mention of port plugs are slot vents no longer in use?
gpmbc is online now
Old 12-09-2010, 07:38 AM
Quoted: 661 Post(s)
Liked: 1393
Each Captivator only comes with one plug to plug one side of the vent. It is not recomended to plug both sides.
Old 12-09-2010, 08:28 AM
MKtheater's Avatar
Liked: 1122
That looks very nice. What is the natural rolloff and at what frequency does it happen? My room has tons of gain from 30hz and down. To put it this way, it created a 15 db peak at 18hz with my dts-10's or a 5 db peak with the best placement(of course I can't use them in this spot). When I get tired of playing around with my CS subs and JBL speakers my next project was going to try Seaton cat's, triple 12's, or Danley SM60F's with OS's. Seaton's would be tuff though as I would have to run XLR cable all over.
Jeff, you have always been a friendly guy and made some awesome products, good job and keep it up!
Marantz 7702 Atmos
Old 12-09-2010, 08:47 AM
mojomike's Avatar
Liked: 30
You are totally crazy, man! I love it.
mojomike is offline
Old 12-09-2010, 10:33 AM
Quoted: 661 Post(s)
Liked: 1393
2011 Captivator:
Fabric grill that is magnetically attached:
Old 12-09-2010, 10:41 AM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
That looks sweet! Send it out send it out send it out
gpmbc is online now
Old 12-09-2010, 11:05 AM
Quaxtros's Avatar
Quaxtros is offline
Old 12-09-2010, 11:06 AM
mojomike's Avatar
Liked: 30
What he said!
mojomike is offline
Old 12-09-2010, 11:27 AM
TnTBigman's Avatar
That does look sweet.
You'll rarely hear anyone say, "I wish I'd gotten less Sub."
$ubwoofer$ and premium mango tree cultivar$
TnTBigman is offline
Old 12-09-2010, 11:32 AM
mojomike's Avatar
Liked: 30
Yes, sweet in a beastly "I'm going to destroy the room" kind of way.
mojomike is offline
Old 12-09-2010, 11:52 AM
Quoted: 661 Post(s)
Liked: 1393
So, apparently, when walls flex a lot, the drywall crumbles around the drywall screws
Old 12-09-2010, 12:11 PM
gpmbc's Avatar
Quoted: 312 Post(s)
Liked: 197
Damn it, I wondered what those little remnants were scattered about the room
gpmbc is online now
