JTR Captivator - Page 145 - AVS Forum | Home Theater Discussions And Reviews
 160Likes
post #4321 of 5053 Old 05-15-2013, 02:14 AM
AJ72's Avatar
Quoted: 134 Post(s)
Liked: 157
Mine is set at about 18Hz for the HPF (port tune is around 20Hz for mine). It will just be a guess for your line level but mine was at about +4dB. Do a bit of A/B testing to see what you prefer. Highly recommend Getting the Dayton V2 omnimic. Not as hard as it seems with advice here to help then youll really know where you stand re output.
AJ72 is offline
post #4322 of 5053 Old 05-15-2013, 05:17 AM
Archaea's Avatar
Quoted: 3076 Post(s)
Liked: 2691
The analog dial on the HPF knob of the mic2200 is generally accurate on mine. It is labeled frequency low cut and should be set to just about right at the frequency you want. I have mine at 20hz with the Crown XLS-5000. I had it a click or two under with the EP4000 because that amp wasn't powerful enough to bottom out the drivers even with no HPF engaged. The crown has enough power to make the driver lose control below port tune where the ported cabinet is no longer helping resist driver excursion. My line levels are just 0'ed out,(knob on the far right) - but again the Crown doesn't need any help getting loud. The mic2200 can be used for dual parametric EQ when you daisey chain the channels - that's how I'm using it. I'm giving it a bit of a boost at 30hz range and a bit of a boost at 70hz range - but that is tailored for my room and sub position. Your boost or cut frequencies may be completely diffferent. The omnimic is a sound recommendation to make the most of your HPF and parametric EQs.
If you read the last 10 pages of this thread or so you'll definitely see some setup advice for the mic2200.
POSITION OF THE SUBS and LISTENING POSITION MAKES SUCH A HUGE DIFFERENCE!!!!
here is an older test I ran
http://www.avsforum.com/t/1375633/ep4000-vs-inuke-dsp-3000-w-2-jtr-captivators-and-an-omnimic-which-amp-is-better
In that test I had to cut 70hz by about 10dB, I moved the subs to optimal position and now I actually boost a couple db at 70hz to keep a flat frequency response line. My current FR chart is flatter than my original go listed in the thread above - but with only two bands it still isn't as flat as what the Inuke can do with it's 8 bands of parametric EQ. I simply like the extra power in the crown over the Inuke - so that's why I'm still using the mic2200/crown combo. I'd prefer the Inuke DSP 3000 with an omnimic over a EP4000/mic2200/omnimic personally, but you'll need measuring gear to set it up correctly.
That should explain why we can't just throw parametric EQ settings at you and hope it works - you need to tailor the sound to you room and listening position using measuring gear like an omnimic or REW.
Archaea is offline
post #4323 of 5053 Old 05-15-2013, 12:40 PM
goonstopher's Avatar
Quoted: 322 Post(s)
Liked: 66
I dont plan on using the EQ - Just want to know how high to set the gain to boost the level
goonstopher is offline
post #4324 of 5053 Old 05-15-2013, 02:32 PM
Archaea's Avatar
Liked: 2691
leave the mic2200 gain at 0 most likely. instead adjust through your AVR subwoofer trim or LFE trim. Ideally your AVR trim on the subwoofer should be negative rather than positive. I've heard experts say ideally between 0 and -6 for AVR subwoofer trim is your goal. It really shouldn't matter much either way on this particular point.
Archaea is offline
post #4325 of 5053 Old 05-15-2013, 08:33 PM
ratm's Avatar
Quoted: 40 Post(s)
Liked: 39
Originally Posted by Archaea View Post
leave it at 0 most likely. instead adjust through your AVR subwoofer trim. Ideally your AVR trim on the subwoofer should be negative rather than positive. I've heard experts say ideally between 0 and -6 for AVR subwoofer trim is your goal. It really shouldn't matter much either way on this particular point.
mines at -2.5. Anything else and my house will fall apart.
ratm is offline
post #4326 of 5053 Old 05-15-2013, 08:47 PM
Archaea's Avatar
Liked: 2691
my wife and kids were out today and twice I cut my sytem loose -- once this morning before work, and then tonight for a while.
I broke out into a stupid grin this morning listening to dubstep --- it's fantastic that my captivator subs still force me to smile nearly 2 years into ownership.
Then tonight in the breakout session I had an empty cardboard box sitting on the concrete a few feet away and to the side of one of the subs. I'd just unloaded that box from a lot of DVDs I purchased from a person at work who was letting them go for about a buck a piece. When I cranked up the music and the bass was hitting heavy I noticed the box was rotating slowly on the concrete slab (tiled) basement floor. LOL. vibrating a cardboard box on concrete! Truly! There just aren't very many subs that can do that! cool.gifbiggrin.gif
Hksvr4 likes this.
Archaea is offline
post #4327 of 5053 Old 05-16-2013, 05:02 AM
AJ72's Avatar
Quoted: 134 Post(s)
Liked: 157
Thats awesome! I am now the proud owner of dual Caps! Thats awesome too!
Hksvr4 likes this.
AJ72 is offline
post #4328 of 5053 Old 05-16-2013, 05:54 AM
Hksvr4's Avatar
Quoted: 33 Post(s)
Liked: 37
Same here. Still love the cap after 2yrs of owning it. Every time I have the opportunity, I crank the ba-jesus out of it.
Hksvr4 is offline
post #4329 of 5053 Old 05-16-2013, 10:50 AM
ratm's Avatar
Quoted: 40 Post(s)
Liked: 39
Try this if you want to crush some dubstep (0:55 mark is where the awesomeness happens). I told Carp to use it for his next GTG. This ought to just destroy is house. Come to think of it, Popalock's as well. I only have a single Cap and it just is insane...
eek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifeek.gifcool.gifcool.gifcool.gifcool.gifcool.gifsmile.gifsmile.gifsmile.gifsmile.gifsmile.gif
Archaea likes this.
ratm is offline
post #4330 of 5053 Old 05-26-2013, 12:23 PM
siriusproper's Avatar
perhaps someone can help to clarify my understanding of the benefits of multiple subs. specifically the Cap S2.
1) sealed sub-woofers are designed for for lower extension, but provide less output...?
2) so adding another or more sealed sub-woofers provides more output at the same extension...? lower extension...? or some combination of the two..?
3) is it linear, or at least predictable...? going from 2-3, and 3-4, so on will provide linear results?
4) is there a cut-off where there is nothing more to gain by adding more S-2's?
siriusproper is offline
post #4331 of 5053 Old 05-26-2013, 01:12 PM
nube's Avatar
Quoted: 76 Post(s)
Liked: 443
The S2 is an amazing sub. It's expensive, but worth every penny! I'll try to answer your questions in order:
1) Yes, while this is not a law, if the same driver is compared in a sealed configuration and a ported configuration, the general trend is for sealed subwoofers to have greater output below the tuning frequency of the ported box. There are caveats, though - the sealed sub will often not have as flat a frequency response as the ported (down to the tuning point of the ported box), and will rely upon some combination of EQ and room gain (greater in smaller rooms, generally) to make up the output deficiencies compared to the ported box. In the S2 and most other high-end sealed configurations, this is done through the use of a DSP equalization profile built into the amp (and often not user-customizable).
Plus, tuning a ported or horn design really low (much below 20hz) requires an ENORMOUS box. The tradeoff for efficiency (more output higher up in the range) is box size, generally. TLDR: at 20hz tuning, a ported box will have more ouput than a sealed box, but will drop off significantly faster (by design) below that tuning frequency than a sealed box.
2) & 3) Adding more of the same exact sub with the same exact frequency response and power does nothing to change the response characteristics of the subs themselves. However, every doubling of the exact same subs adds double the output within the coupling range - at all frequencies where the wavelength(s) in question is less than the distance between the speakers. So, 2 subs is double the output of 1 at coupling frequencies. 4 is double 2, etc. Adding multiple subs also will often help smooth out the room cancellation or excitement modes to eliminate big dips/peaks in response within a room. This varies with the amount and placement of subs, so trial and error is important in getting it right with multiple subs.
4) You never stop gaining by doubling the number of subs, but the point of diminishing returns is reached when you meet your required level of output at desired frequency response. This varies by person, but many are happy with two S2s, though some may require 3 or more to hit that sweet spot.
I think this is approximately right, although I'm no authority on the subject. Good luck, and let us know how many you end up going with!
nube is offline
post #4332 of 5053 Old 05-26-2013, 02:45 PM
logicators's Avatar
Liked: 26
As per Jeff, when compared with a ported cap with 2.4K amp, S2 provides equal output above 20 Hz and substantially more output below that.
When compared with the OS, it provides 6 db less output above 20 Hz and provides 6 db more output below that.
Unless you have a huge room the primary benefit of multiple S2s would be smoother frequency response not output, because it's unlikely that you will use the full output capabilities of a single S2.
In my room a single S2 gets flat to 5 Hz at reference at my MLP which is 9 feet away and the drivers are barely moving.
logicators is offline
post #4333 of 5053 Old 05-26-2013, 09:13 PM
i spoke to Jeff of JTR Speakers, and he suggested 2 S-2's for me. based on what i described to him of the room i could have, he said 2 could hurt the house. but hurt seems so ordinary.
post #4334 of 5053 Old 05-26-2013, 09:46 PM
thanks. i hope to use this information to build a reasonable HT/Music system.
post #4335 of 5053 Old 05-27-2013, 07:39 AM
logicators's Avatar
Liked: 26
post #4336 of 5053 Old 06-17-2013, 07:11 PM
basshead81's Avatar
Quoted: 234 Post(s)
Liked: 6458
So I have been lookingn at those captivator s1000's with the 18" radiator in the for sale section. 1000.00 seems like a good deal, but there has to be a reason why they are still for sale? Would they work well with 2 PSA XV15's in the same room? I can not find any specs on them. Would somebody be so kind to post the specs?
basshead81 is offline
post #4337 of 5053 Old 06-17-2013, 07:40 PM
RON82ND's Avatar
So I have been thinking over these past couple weeks of what to do and am really leaning towards the cap 1000 passive with an amp and mic2200 . I am a little worried for I am so green when it comes to half of what you all talk about but figure get the correct equipment and learn. I have a pioneer vsx 1522 with no sub eq and that is my biggest concern on learning to eq it in my 24x17x9 room that is mainly used for ht. I would like to spend 2 to 2.5 k but am a little over my head I believe would I be better off going with a fv15hp either way it will be placed nearfield.
RON82ND is offline
post #4338 of 5053 Old 06-17-2013, 07:45 PM
Hksvr4's Avatar
Quoted: 33 Post(s)
Liked: 37
The caps will have more output in all areas over the 15s you have now. You will also need a external amp for the caps. You can ask the seller how much power he's running on them. Or email Jeff at jtrspeakers.
Hksvr4 is offline
post #4339 of 5053 Old 06-17-2013, 07:54 PM
Hksvr4's Avatar
Quoted: 33 Post(s)
Liked: 37
From the look of the website, jtr doesn't have a passive 1000 cap. Passive means you need an external amp to power the sub.
Jtr only has a powered (built in amp) cap 1000, which is easier for you because it would be easier to set up. I mean you can request what ever you want and Jeff will build it.
Hksvr4 is offline
post #4340 of 5053 Old 06-17-2013, 08:07 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
When you look at the specs for the Captivator 1000, if you look closely at the bottom there's a notation that you can get a passive Cap for $1199. So Jeff does offer one.
jbrown15 is offline
post #4341 of 5053 Old 06-17-2013, 08:16 PM
basshead81's Avatar
Quoted: 234 Post(s)
Liked: 6458
I know I will need a amp and I figured they would have more output than my xv15's...However I was curious what the tuning point was on them and how well they would work WITH my xv15's?
post #4342 of 5053 Old 06-17-2013, 09:03 PM
jbrown15's Avatar
Liked: 1995
I think the port tune is 17.5hz. I think they would work okay with your XV15's, I'm guessing you'd place the XV15's near field and have the Cap's up front in your room?
jbrown15 is offline
post #4343 of 5053 Old 06-17-2013, 10:15 PM
basshead81's Avatar
Quoted: 234 Post(s)
Liked: 6458
Yup...Thats exactly what Im thinking! I already have the XV15's nearfield and they slam hard, but Im on a quest for 120db in the 15hz area. I need another 5-7db output to acomplish this. do you think the cap1000's will get me there?
post #4344 of 5053 Old 06-17-2013, 10:45 PM
jbrown15's Avatar
Liked: 1995
Are we talking if you were to upgrade them to the newest drivers or just use them with the old ones?
jbrown15 is offline
post #4345 of 5053 Old 06-17-2013, 11:06 PM
basshead81's Avatar
Quoted: 234 Post(s)
Liked: 6458
Just use the old ones...my other option was to pick up that xv30 b stock. that should get me another 3-6db, but i thought dual cap's with a crown amp would yield more output?
post #4346 of 5053 Old 06-17-2013, 11:25 PM
jbrown15's Avatar
Liked: 1995
Just use the old ones...my other option was to pick up that xv30 b stock. that should get me another 6db, but i thought dual cap's with a crown amp would yield more output?
I believe the Cap's would give you more output, I seem to recall reading somewhere that they can hit 116db at there port tune from a 1m ground plane measurement. So you'd subtract 6db to roughly geta 2m number right. And I think they would pick up about 6db room gain.
I'm not 100% sure though so someone jump in and correct me if I'm wrong.
I would shoot RMK! a pm, I think he had dual older style passive Caps before upgrading to dual Orbit Shifters. So he could give you a little insight as to what you could expect from them.
jbrown15 is offline
post #4347 of 5053 Old 06-17-2013, 11:31 PM
basshead81's Avatar
Quoted: 234 Post(s)
Liked: 6458
If thats the case then they should get me there alone. That would be 119-120db in room around the port tune. What makes me leary is those caps have
been for sale for 6mo. I am trying to figure out why nobody has bought them?
post #4348 of 5053 Old 06-17-2013, 11:42 PM
jbrown15's Avatar
Liked: 1995
I honestly think its just because they aren't the latest and greatest versions. I have also thought about grabbing them on an occasion or two. But the cost for having them shipped all the way out to me would be a bit of a deal breaker.
I'm quite surprised they haven't been picked up too, especially at the current price!
jbrown15 is offline
post #4349 of 5053 Old 06-18-2013, 06:02 AM
Hksvr4's Avatar
Quoted: 33 Post(s)
Liked: 37
Those caps are nice and a good deal but shipping will kill the good deal. Although the caps are small for their size, it is also big in comparison to other subs. Some would have space or WAF issues.
Hksvr4 is offline
post #4350 of 5053 Old 06-18-2013, 10:27 AM
Jedirun's Avatar
Liked: 49
Those passive caps are about a 1/3 of the cost of buying the current passive version new. I am sure shipping would be a couple of hundred dollars, but that would still be a huge savings for some amazing subs.
Jedirun is offline
