JTR Captivator - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 163Likes
post #451 of 5054 Old 12-17-2010, 01:25 PM
Jeff Permanian's Avatar
Quoted: 817 Post(s)
Liked: 1733
Captivator drivers finally arrived to day. Testing and shipping.
The port plug adds 4db at 15hz but takes away 4db at 20hz.
Jeff Permanian is offline
post #452 of 5054 Old 12-17-2010, 02:27 PM - Thread Starter
RMK!'s Avatar
Quoted: 1697 Post(s)
Liked: 1627
Originally Posted by Quaxtros View Post
I thought the 2011 Captivators were made with MDF? I guess we need Jeff to chime in on this.
Nope BB ...
Anxiety is contagious, please keep yours to yourself.
RMK! is offline
post #453 of 5054 Old 12-17-2010, 02:30 PM - Thread Starter
RMK!'s Avatar
Liked: 1627
Nice, have you tried two plugs?
RMK! is offline
post #454 of 5054 Old 12-17-2010, 02:35 PM
Quaxtros's Avatar
Nope BB ...
OK, but I thought I read somewhere that Jeff needed to rework the cabinets
on the 2011 Captivator, adding additional bracing etc. because of the switch from BB to MDF.
Maybe that was for the new driver?
Quaxtros is offline
post #455 of 5054 Old 12-17-2010, 02:54 PM
mojomike's Avatar
Liked: 30
Are you sure you weren't reading something about one of the the JTR main speakers?
mojomike is offline
post #456 of 5054 Old 12-17-2010, 03:20 PM
Quaxtros's Avatar
Yes its quite possible.
Quaxtros is offline
post #457 of 5054 Old 12-17-2010, 04:49 PM
Quoted: 817 Post(s)
Liked: 1733
Sealed will definitely not work.
post #458 of 5054 Old 12-18-2010, 11:36 AM
nube's Avatar
Quoted: 76 Post(s)
Liked: 444
New specs on the JTR Captivator page, showing it IS 24mm Baltic Birch construction. As well as new sensitivity, output, and pricing! Also, I'm hoping some new pics are forthcoming since the previous one is gone.
The Captivator is a bass reflex subwoofer with a 18″ driver that is for applications needing ultra low bass extension.
* massive excursion 18″ subwoofer (30mm xmax each way, 4″ peak to peak)
* Bass Reflex Design tuned to 20hz (15hz with port plug)
* heavily braced cabinet
* huge slot port for minimal turbulence and compression
* completely front firing for versatility
optional 4000 watt RMS, 7200 watt burst amplifier with balanced XLR inputs
Foam port plug for 15hz tuning
magnetically attached grill
The optional 4000 watts amplifier is equipped with a full digital sound processor that has been optimised to the smoothest frequence response and highest possible output with minimal distortions (input overload protection and high pass filter).
Frequency +/-4.5db* 20-120hz (half space)
Sensitivity* 91db at 20hz (100db at 60hz)
Useable Output ** 127db at 20hz (136db at 60hz)
Recommended Amplification*** up to 4000 watts RMS (continous program)
Impedance 8 ohm
Dimensions 30″x20″x22.5″ (HxWxD)
Weight 128lbs (135lbs powered)
Exterior Finish Matte Black Paint
Connectors Binding Post (powered XLR)
Construction 24mm baltic birch
Warranty 5 year Manufacturer defect (ampifier 2 year)
MSRP (each) $1499
Manufacture Direct $1199
MSRP (each) $2699 (powered)
Manufacture Direct $2399 (powered)
*1 watt, 2.83 volts, half space (outdoors on the ground)
**Obtainable output with maximum recommended amplification
nube is offline
post #459 of 5054 Old 12-18-2010, 12:07 PM
gpmbc's Avatar
Quoted: 340 Post(s)
Liked: 207
The pic will still be the same as first shown in post #383. I'm pretty sure the 8 ohm impedance is a typo.
gpmbc is offline
post #460 of 5054 Old 12-18-2010, 02:57 PM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
Interesting thread. Jeff is to be commended for a hell of an offering. Actually, his entire lineup is damn impressive.
Anyway, concerning HP filters, I own both the ED piece, and now the Behringer MIC 2200. No in an effort of full disclosure, I've yet to fire the piece up and use it, however the feature set at approximately the same price as the ED is interesting.
It offers a phase reversal switch, fully parametric EQ down to 10hz., and level shifting from -10 to +4, or the other way around. Anyway, the EDs knobs are so poorly marked, I mean really poorly. I like it, it's ok. I'll know a lot more after I use the Behringer piece, but at approx. the same price, I'd initially give the nod to the Behringer solely for nice, tactile, detented controls, that are properly spaced. Throw in the level shifting and balanced I/Os and it appears a winner.
Since I've got them both, I thought I throw my 2 cents in.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #461 of 5054 Old 12-18-2010, 04:27 PM
musicaddict's Avatar
I can't decide wether to get two powered captivators with the 4000w amp or two danley th50s. I thought I saw the captivator could handle only 2400w but now I see 4000w, did the driver change to handle the more power? Does the powered version amp really output 4000watts?
musicaddict is offline
post #462 of 5054 Old 12-18-2010, 04:34 PM
cmryan821's Avatar
Quoted: 202 Post(s)
Liked: 66
Oh to have that dilemma. The 2011 Captivator is a new design and uses an 18" driver instead of the 12" driver in the older Caps.
cmryan821 is offline
post #463 of 5054 Old 12-18-2010, 04:42 PM
haskin1234's Avatar
Get two Orbital Shifters and your confusion will be gone! lol
haskin1234 is offline
post #464 of 5054 Old 12-18-2010, 06:15 PM
bmrowe's Avatar
Does anyone know, or have any guesses been made as to the make and model of the driver in the 2011?
bmrowe is offline
post #465 of 5054 Old 12-18-2010, 07:06 PM
J
J's Avatar
Quoted: 27 Post(s)
Liked: 49
I thought it was a custom eminence ?
Samsung 55 inch lcd Marantz sr5400
Parasound HCA 1500 Parasound HCA 1000
JTR OS LFU (2013)
JTR OS LFU (2016)
Paradigm studio 40's -fronts Paradigm CC Paradigm atoms -rear
J is offline
post #466 of 5054 Old 12-18-2010, 08:21 PM
Quoted: 817 Post(s)
Liked: 1733
Thanks. When comparing specs, always read the fine print to make sure your comparing apple to apples.
“In Room Avg SPL” can add 6-12db or more over outdoor, ground plane measurements
They are similar in performance although the Captivator is less than half the size, cost a bit less, 24mm baltic birch and magnetically attached fabric grill.
Yes, The Captivator handles 4000 watts continuous program and powered versions come with a 4000 watt rms (7200 watt peak) amplifier that is 95% efficient and only draws 10 amps (1/8th power, pink noise) so it can easily be used on a 15 amp circuit.
Custom driver but not Eminence, they can't get anywhere near the travel, motor strength and power handling that my subwoofer drivers have.
post #467 of 5054 Old 12-19-2010, 09:25 AM - Thread Starter
RMK!'s Avatar
Liked: 1627
It's Orbit Shifter (as an owner you should know better) but the statement is spot on.
I ran through some demo material last night and the speed, precision and sheer output of the dual OS's is simply amazing. Did WOTW, the big three scenes in Knowing, and for music, This is It, Jeff Beck (Live at Ronnie Scotts) and The new U2 live bluray.
If the Caps come anywhere close (and it appears they will) they will be among the best available subs at any price.
RMK! is offline
post #468 of 5054 Old 12-19-2010, 10:12 AM
mojomike's Avatar
Liked: 30
I hope to be able to confirm that possibly as soon as this Tuesday.
mojomike is offline
post #469 of 5054 Old 12-19-2010, 11:16 AM
Quaxtros's Avatar
That is exactly why I bought one.
Quaxtros is offline
post #470 of 5054 Old 12-19-2010, 11:28 AM
haskin1234's Avatar
[quote=RMK!;19673642]It's Orbit Shifter (as an owner you should know better) but the statement is spot on.
LOL.........I was trying to make it plural and for some reason it sounded better. I watched The Incredible Hulk (2008) for the first time last night. Was hitting 120db at reference in the LP easy and still had room to go up.......lol
post #471 of 5054 Old 12-19-2010, 11:39 AM
Quoted: 817 Post(s)
Liked: 1733
With only 200 watts the Captivator can hit 108db at 2m at 20hz.
post #472 of 5054 Old 12-19-2010, 11:42 AM
yadfgp's Avatar
Quoted: 66 Post(s)
Liked: 68
How does 1 go about ordering 1 of these fine subs? The JTR web site isn't set up like your typical retail site. Does the pricing on the site include shipping? Thanks
yadfgp is offline
post #473 of 5054 Old 12-19-2010, 11:52 AM
mojomike's Avatar
Liked: 30
Call Jeff at 847-714-6878
mojomike is offline
post #474 of 5054 Old 12-19-2010, 11:52 AM
Quaxtros's Avatar
Calling Jeff on the phone is definitely the best way to contact him!
Quaxtros is offline
post #475 of 5054 Old 12-19-2010, 11:55 AM
Quaxtros's Avatar
^^^^ LOL! You beat me to it!
Quaxtros is offline
post #476 of 5054 Old 12-19-2010, 01:02 PM
Quoted: 817 Post(s)
Liked: 1733
I'm a little old fashion. I actually communicate with my customers, make sure they are getting the right speakers, let them know availability, shipping options and whatnot. The next batch of Captivators will be ready January 8th. Prices do not include shipping.
post #477 of 5054 Old 12-19-2010, 05:37 PM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
Thanks for the reply Jeff. Even though I'm very weary of mfrs. claims, I do appreciate the heads up on being cautious with regard to specs.
I've always been impressed with the design approach, as well as what is said about your Triple 8, and Triple 12 offerings. I appreciate the brute force, large effective cone area, PA approach. I've not paid very much attention to your subs, but I have enjoyed reading anecdotal reports about their strengths, and on integrating them within one's system.
Back to being prudent about specs. I'm sure I'm not alone in being curious about this 4000 watt amp that is optional with the Captivator. I've not kept up, so I'm sorry if this has been covered, but is this a plate amp or an outboard offering? You state 4kw RMS output which is phenomenal. What is the operational voltage and line draw? Does it have a captive cord or detachable IEC cord? Perhaps a Powercon twistlock? What is the amplifier class of operation? How does one get 4kw RMS out of a 120v, 20a circuit?
In an effort of full disclosure, I'm not currently in the market for your Captivator subs. However, since the the stated output numbers are so extraordinary, the technical aspects are extremely intriguing. Unless I encounter them at a live event, I'll most likely never get the opportunity to hear them. I remember the buzz surrounding the Conquest and it's incredible output numbers.
Thanks and Good luck,
And I am sorry if these questions have been put forth already.
FOH is offline
post #478 of 5054 Old 12-19-2010, 06:09 PM
FOH
FOH's Avatar
Quoted: 39 Post(s)
Liked: 236
Jeff,
I did some additional looking around and saw the pic of the OS plate amp. Is this the same amplifier, or at least the same form factor?
Also, I do see that it has the twist-lock Power-con style mains connection, so that answers two of my questions immediately.
Thank you
FOH is offline
post #479 of 5054 Old 12-19-2010, 06:28 PM
Gooddoc's Avatar
Quoted: 3106 Post(s)
Liked: 2405
+1? Perhaps there are 2 power cords for 2 dedicated circuits? I have seen this on some power amplifiers.
Gooddoc is offline
post #480 of 5054 Old 12-19-2010, 07:19 PM
kutlow's Avatar
Quoted: 113 Post(s)
Liked: 46
2011 Captivator:
Fabric grill that is magnetically attached:
send me 2 out and if they best my 2 Danleys I'll buy them both! Whats better those or 2 Orbital Shifters?
kutlow is offline
