Help needed with connection of Energy RC-Micro sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-12-2009, 08:28 AM - Thread Starter
sparkleanimesh's Avatar
Hello all,
I just bought Energy RC-Micro 5.1 system and is yet to arrive. I was hoping to keep all my connectors ready so that I can enjoy the system as soon as it arrives. From the manual of RC-Mirco system (available on Energy's website), I see that the sub (ESW-CS8) can be connected in two different ways to the receiver.
Method 1: RCA - Sub In cable
Method 2: Speaker Level In
Although the manual says that only ONE RCA male to male cable is needed to connect from the receiver to the sub, but the connection diagram shows two RCA inputs labeled:
LINE IN/ SUB IN (Left and Right)
This is confusing. Which input does the RCA cable need to go in?
I would appreciate your replies as I am trying to order my cables ASAP.
sparkleanimesh is offline
post #2 of 4 Old 10-12-2009, 11:39 AM
warpdrive's Avatar
Quoted: 16 Post(s)
Liked: 49
Either one is fine.
The sub internally combines the signals going into L and R together.
Certified Ultra Professional AVS Special Member Class A
warpdrive is offline
post #3 of 4 Old 10-12-2009, 12:08 PM - Thread Starter
Thanks for your response. Does that mean I have to connect 2 RCA cables from the receiver to the sub? (if the sub combines L and R inputs)
post #4 of 4 Old 10-12-2009, 01:22 PM
warpdrive's Avatar
Quoted: 16 Post(s)
Liked: 49
Nope. Just one is fine.
Most receivers only have one sub output.
