Paradigm Sub 1 and Sub 2 - AVS Forum | Home Theater Discussions And Reviews
 32Likes
post #1 of 1644 Old 10-28-2009, 08:44 AM - Thread Starter
mmiles's Avatar
Quoted: 465 Post(s)
Liked: 214
This new product looks to be a bass beast. Soundstage did a mini reveiw and ranked the SUB 2 [$7.5K] right there with the JL Audio G213 Gotham [$11K].
When will these subs be available?
Mike Miles
mmiles is offline
post #2 of 1644 Old 10-28-2009, 08:48 AM
shiznit's Avatar
shiznit is offline
post #3 of 1644 Old 10-30-2009, 04:13 PM
osofast240sx's Avatar
were in a HT would you put that thing, it would block the screen
osofast240sx is offline
post #4 of 1644 Old 10-30-2009, 05:08 PM - Thread Starter
mmiles's Avatar
Quoted: 465 Post(s)
Liked: 214
There is always room somewhere.
Mike Miles
mmiles is offline
post #5 of 1644 Old 11-07-2009, 10:56 PM
matjet's Avatar
Does anyone know how Paradigm Sub 1 compares to Paradigm Signature sub 25? I was planning on purchasing two Signature sub 25's, but I am thinking about changing my order to two Sub 1's. Sub 2 is too large for my space , so it is not an option, unfortunately.
matjet is offline
post #6 of 1644 Old 11-09-2009, 11:49 AM
go for 2 sub 1's
post #7 of 1644 Old 11-09-2009, 03:58 PM
peterpioli's Avatar
I'm looking for a subwoofer with a max size of about the size of the Elemental Designs A7-450 or a bit taller. Price is not as important and having the best home theater performance possible. I just want one subwoofer, so please don't suggest buying two of this or three of that.
Any thoughts on whether the Sub 2 would outperform the Elemental Designs A7-450, or Mark Seaton's Terraform XL? I realize the Sub 2 is much more expense, but I'm just looking at performance right now. Anything else I should be looking at that might outperform the Sub 2 for home theater?
peterpioli is offline
post #8 of 1644 Old 11-09-2009, 04:53 PM
matjet's Avatar
Originally Posted by osofast240sx View Post
go for 2 sub 1's
Why do you like 2 sub 1's over two signature sub 25's?
matjet is offline
post #9 of 1644 Old 11-09-2009, 05:32 PM
i know for sure that in car audio 6 8" woofers will out perform 1 15" woofer. its will be lower and tighter.
post #10 of 1644 Old 11-09-2009, 08:21 PM
zora's Avatar
Quoted: 48 Post(s)
Liked: 51
Not necessarily - when will these myths end
oneeyeblind likes this.
zora is offline
post #11 of 1644 Old 11-09-2009, 10:08 PM
im talking from experience with my personal setups.
post #12 of 1644 Old 11-09-2009, 10:55 PM
BRAC's Avatar
Have you considered the difference in amps? There is almost twice as much power on tap inside the Sub 25.
DaveWilsonoffic likes this.
BRAC is offline
post #13 of 1644 Old 11-10-2009, 06:02 AM
nope i have not seen the specs of the sub 1
post #14 of 1644 Old 11-17-2009, 11:45 AM
the_phew's Avatar
I still haven't seen any reviews on the Sub 1. Is it not actually shipping yet?
the_phew is offline
post #15 of 1644 Old 11-18-2009, 02:41 PM
mbfleming's Avatar
Liked: 52
mbfleming is offline
post #16 of 1644 Old 11-18-2009, 03:36 PM
Originally Posted by mbfleming View Post
Has this pdf been posted yet?
http://www.paradigm.com/images/refer...ineVersion.pdf
nope sounds like a monster.
post #17 of 1644 Old 11-19-2009, 07:27 AM
the_phew's Avatar
Thanks for posting that link mbfleming!
112 dB @10Hz. Can you say cardiac arrest?
the_phew is offline
post #18 of 1644 Old 11-19-2009, 01:27 PM
ls200p's Avatar
How do you get that information sheets?
ls200p is offline
post #19 of 1644 Old 11-19-2009, 07:31 PM
mbfleming's Avatar
Liked: 52
I used google to search for "paradigm sub2" and that link was on the third page of the search results:
http://www.google.com/search?hl=en&c...&start=20&sa=N
I saved a copy of the pdf in case it gets removed. Must have been a leak.
post #20 of 1644 Old 11-20-2009, 09:45 AM
peterpioli's Avatar
Are there any other subs that will produce 112 dB @10Hz?
post #21 of 1644 Old 11-20-2009, 09:48 AM
peterpioli's Avatar
Does anyone know the bass output measurement of this sub at 20Hz? I would like to compare with other subs on Craigsub list.
post #22 of 1644 Old 11-20-2009, 03:35 PM
spyboy's Avatar
Liked: 47
I just wanted you to know that Craig Chase made his measurements the hard way. Outdoors at 2 meters.
Lugging heavy and large subwoofers outdoors and setting up the microphone and other equipment isn't something most people ever do.
Virtually all of the measurments you see posted were made indoors.
Finding comparable measurements isn't going to be easy.
spyboy is offline
post #23 of 1644 Old 11-21-2009, 09:34 AM
peterpioli's Avatar
I wonder if the Sub 2 will have more output than an Elemental Designs A7-900 subwoofer?
post #24 of 1644 Old 11-21-2009, 09:49 AM
a bit more but who in the world has room for a 400lbs A7-900.
post #25 of 1644 Old 11-21-2009, 01:07 PM
peterpioli's Avatar
If the Sub 2 has more output than the Elemental Designs A7-900 AND have the advantage of being small, the Sub 2 will be the sub to beat, even if it is more expensive.
post #26 of 1644 Old 11-21-2009, 01:38 PM
spyboy's Avatar
Liked: 47
So, you are crowning the Sub 2 the ultimate subwoofer? How about this?
http://dvice.com/archives/2009/07/revels-ultima-r.php
For the $7,500 there are all kinds of subwoofer solutions. Using the Craigsub list has its disadvantages. Lots of the models have changed or completely discontinued.
There is a new generation of subwoofers that will never be tested in the same way as those on the Craigsub list.
People on this forum have a large number of choices if they are going to spend that kind of money. A Seaton Terraform XL is on people's list.
spyboy is offline
post #27 of 1644 Old 11-21-2009, 04:32 PM
peterpioli's Avatar
I'm not crowning anything, but if someone's looking for a sub of reasonable size with lots of output, the Sub 2 looks like it will be tough to beat.
post #28 of 1644 Old 11-21-2009, 05:25 PM
i'm not crowning anything, but if someone's looking for a sub of reasonable size with lots of output, the sub 2 looks like it will be tough to beat.
+1
post #29 of 1644 Old 11-22-2009, 09:09 AM
spyboy's Avatar
Liked: 47
But what you actually said is:
"If the Sub 2 has more output than the ED A7-900 (original version), and have (sic) the advantage of being small, the Sub 2 will be the sub to beat, even if it is expensive."
The key words are "the sub to beat". You can back off that statement as far and as fast as you want. Meanwhile, the real action is with the Danley DTS-10.
spyboy is offline
post #30 of 1644 Old 11-22-2009, 05:00 PM
Sidewayz's Avatar
Actually the key words are "if" and "will be" meaning that he is hypothesizing about a potential outcome. You are the one that is trying to draw a conclusion from someone elses guess and it would seem you are trying to put words in his mouth about something he said hypothetically and not factually.
Sidewayz is offline
