HELP Definitive Supercube 1 No Sound - AVS Forum | Home Theater Discussions And Reviews
Old 01-01-2010, 06:03 PM - Thread Starter
dryheat8590's Avatar
I have a definitive technology supercube 1. The sub light is on so it has power but it just stopped working. It is connected to a Yamaha Av model # RX-V663
Any suggestions as to cause or tips on what to check would be greatly appreciated. Thanks in advance to everyone
dryheat8590 is offline
Old 02-28-2011, 05:19 PM
jpindel's Avatar
I have the same problem here. Did you ever find a resolution?
jpindel is offline
Old 01-13-2012, 08:42 AM
avsmem's Avatar
I have similar problem with SC1 connected to the LFE of AVR4308CI. However, I can feel/hear the bass if I listen to x.1 (5.1) recorded format CD/DVD, or movie. Any suggestion/help is greatly appreciated.
Updates: I figured it out! On the receiver, select "LFE + Main".
avsmem is offline
