Looking for a $100 sub for an STR-DN1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-06-2010, 12:56 PM - Thread Starter
ShaqDan's Avatar
As the title says, I'm looking for a sub for around $100 that works with my Sony STR-DN1000. Would a Polk Audio PSW10 do the trick?
I'm a bit of an audio-n00b so will the Polk connect into the connection in the picture below? Forgive my ignorance but my last setup was an all-in-one samsung mini system. The Polk seems like it would be a perfect fit for my small apartment living room, but I need to be sure it will actually connect to the STR-DN1000.
ShaqDan is offline
post #2 of 6 Old 01-06-2010, 01:03 PM
bluesky636's Avatar
Yes, it will connect just fine.
bluesky636 is offline
post #3 of 6 Old 01-06-2010, 01:17 PM
reecew's Avatar
That polk sub would do fine for $100. But for around $150 you can get an Acoustic Audio sub which is a great budget sub. I havent been on the forums for a while but there were a few positive reviews a while back. I owned 2 of them myself before diving into the DIY realm. So thats my reccomendation for $100 subs. Heres the link http://cgi.ebay.com/New-12-Powered-S...item2eaa437754if you seach for them you might be able to find an auction and pick it up cheaper i paid $120 ea shipped for the 2 i use to own. Or if they have the best offer feature offer $120 shipped they should take it.
List your favorite BASS movies here...http://lfemovies.pbworks.com/FrontPage
reecew is offline
post #4 of 6 Old 01-06-2010, 01:23 PM
goonstopher's Avatar
Quoted: 322 Post(s)
Liked: 66
I owned the psw-10 and hated it. I would look at whatever else is suggested. Granted I am a basshead but the psw10 didn't show any sound quality, never mind volume
goonstopher is offline
post #5 of 6 Old 01-06-2010, 01:26 PM
Promit's Avatar
Quoted: 55 Post(s)
Liked: 26
At $144, you can also get the BIC V1020 from Amazon, or shopblt will probably send a BIC F12 your way for about $180. Costco carries an Energy sub for $100 that is low end but will do its duty.
I've seen a lot of disparaging remarks about Polk subwoofers around here, but have no personal experience.
Promit is offline
post #6 of 6 Old 01-06-2010, 02:03 PM - Thread Starter
ShaqDan's Avatar
Thanks for the feedback, I'll go with something else.
ShaqDan is offline
