Official Rythmik Audio Subwoofer thread - Page 1000 - AVS Forum | Home Theater Discussions And Reviews
 4837Likes
post #29971 of 30894 Old 06-18-2017, 09:26 AM
sherr127's Avatar
Quoted: 90 Post(s)
Liked: 26
Originally Posted by Bruce Watson View Post
Not a big surprise that your expectation was not met. Two (small subs) are almost always better than one (large sub) in small rooms. Because room modes. It's very hard to place a single sub so that you don't have one or more peaks / dips in the main listening position's frequency range below about 80 Hz. But two subs can usually minimize the problem. This is especially true if you have some software (Audyssey MultEQ XT32 and SubEQ HT, or better) to automate the process.
Thats what i'm thinking too especially one of the pb13 i put it nearfield just 5" from my back.Btw i'm using Denon 7200wa for calibration.
sherr127 is offline
post #29972 of 30894 Old 06-18-2017, 09:32 AM
sherr127's Avatar
Quoted: 90 Post(s)
Liked: 26
Originally Posted by torii View Post
what kind of spl we talking? or just using ears?
I only checked with my spl meter,set it at 78db..volume knob at 12 o'clock and avr trim at -1.0.
I will check the graph with rew when my umik1 arrive in a few days.
sherr127 is offline
post #29973 of 30894 Old 06-18-2017, 09:50 AM
PlasmaPZ80U's Avatar
Quoted: 2318 Post(s)
Liked: 716
I should add that too much of a house curve can make midbass weaker relative to low bass. So, try a flatter response if you haven't already done that.
Also, check for any big dips/nulls in the midbass region and play with different crossover settings/sw dist tweak.
Of course, placement is the number one thing to check, especially before using any boost PEQ or the like.
And make sure the many settings on amp are set to your liking. I prefer LFE input so that the built-in lpf is disengaged.
Good luck
SBuger and sherr127 like this.
PlasmaPZ80U is online now
post #29974 of 30894 Old 06-18-2017, 09:53 AM
Liked: 716
Yeah, 5 inches from ears, nearfield will give you a ton more tactile response and midbass slam/chest thump. Farfield less so unless you crank up the sw trim or volume enough to compensate.
post #29975 of 30894 Old 06-18-2017, 09:59 AM
torii's Avatar
Quoted: 1562 Post(s)
Liked: 852
well at 78 db I doubt you would feel anything
sherr127 likes this.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5 Subs: Rythmik FV25HP, Rythmik FV15HP
torii is online now
post #29976 of 30894 Old 06-18-2017, 10:32 AM
sherr127's Avatar
Quoted: 90 Post(s)
Liked: 26
Good luck
Thanks for a very good advice Plasma
sherr127 is offline
post #29977 of 30894 Old 06-18-2017, 10:34 AM
sherr127's Avatar
Quoted: 90 Post(s)
Liked: 26
Can i crank the sub volume more than 12 o'clock or thats the maximum setting?I cant crank much from avr because it already reached -1.0.
sherr127 is offline
post #29978 of 30894 Old 06-18-2017, 10:51 AM
enricoclaudio's Avatar
Quoted: 1513 Post(s)
Liked: 1668
Yes you can. I run my subwoofers at 82dB and speakers at 75dB measured at MLP. The volume on the subwoofers is set at 1 o'clock. Just so you know, each click on the volume knob is 1.5dB.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL, Sierra 2s & Lunas | Rythmik F12SE (x2) | Emotiva XMC-1 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Bluesound Node 2 | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #29979 of 30894 Old 06-18-2017, 10:58 AM
sherr127's Avatar
Quoted: 90 Post(s)
Liked: 26
Great.What is the maximum volume i can dial at sub's volume nob?3 o'clock?
sherr127 is offline
post #29980 of 30894 Old 06-18-2017, 11:08 AM
TVMAN1991's Avatar
Quoted: 65 Post(s)
Liked: 54
are there any measurements available at all for the LV12R?
Trying to compare it to RBH 12I
TVMAN1991 is offline
post #29981 of 30894 Old 06-18-2017, 11:28 AM
Liked: 1668
3 o'clock is fine but in a room like yours if you are not satisfy with a pair of FV25HPs, then you should look for some other issues like subwoofer placement and nulls at the MLP. Even a hearing test should be in your short list...
post #29982 of 30894 Old 06-18-2017, 11:46 AM
Liked: 716
http://www.rythmikaudio.com/LV12R_specs.html
BTW, I have the LV12R and have had it for nearly 2 years. Zero regrets getting a Rythmik over others including the RBH, HSU, SVS, Outlaw, etc. In fact, I did initially narrow it down between LV12R and I-12. I went with the Rythmik because of its proven reputation on AVS and because of the 3 year amp warranty plus reasonable costs for amp repairs out of warranty. The I-12 was significantly cheaper at the time and that was tempting but if anything happened with the amp it would be significantly more $ to fix.
To this day, my LV12R sounds so good it surprises me and puts a smile on my face. In fact, it sounds much better and different from what I've used to expect from a sub and I had the Dayton SUB-1200 before it.
From what I've heard the I-12 is still a nice sounding option and looks nicer. However, I can't imagine it sounding as good as a Rythmik since it doesn't have direct servo nor the bass extension/damping setting that can change the very nature of the sound with a simple 3 position switch.
post #29983 of 30894 Old 06-18-2017, 12:28 PM
Timothy1180's Avatar
Quoted: 924 Post(s)
Liked: 277
Sherr127 you should use the line in and by pass audyssey. Make sure you have dynamic eq off as well.
Is the fv25 in same spot as one of the pb13?
Just for reference the pb13 is one of the worst subs for mid bass. Be lucky to see 118-120db with pb13. The fv25 will hit 126-129 db in midbass. Fv25 should be better then 3 pb13.
I have my pair of fv15hp at 2 o'clock on gain using line in with y adapter. I hit well over 125db from 40-60hz. Pb13 can't even match fv15hp.
Maybe something is wrong with your setup or subs. Post some pictures and let everyone see what you're doing.
Timothy1180 is online now
post #29984 of 30894 Old 06-18-2017, 12:31 PM
Quoted: 924 Post(s)
Liked: 277
Also wanted to ad your room is very small and 2 fv25 should be amazing.
I had a Psa Xv30f in a office that was a little bigger then your room at it was insane. Bass from 120-130 db.
Your room is 11' by 15' by 9'?
post #29985 of 30894 Old 06-18-2017, 01:36 PM
bscool's Avatar
Quoted: 760 Post(s)
Liked: 595
So you comparing 1 sub that is located how many feet away(6',8',10'?) vs one that you had 5" from your back?
If that is the case I would say that is why they are not even close. I know from trying just 1 Um18" sealed nearfield behind my seat I have never had that kind of effect from multiple 15" and 18" spread throughout my room.
Put your new sub behind your seat like you had your SVS and it should be a better comparison.
HTPC, Sony 40es, 120" Silver Ticket, 7702mkii, Sunfire Amp 225w, JBL 590, JBL 520
PSA XS30, Seaton Submersive, 2 Um-18 8cf sealed, Outlaw Ultra x 12, Kappa Pro 18LF, BFM Tuba 60 horn, B&C 18TBW100 6cf 41hz, 34hz, 28hz tune
iNuke 3000 & 6000 DSP's, Crowson Motion Actuator
bscool is online now
post #29986 of 30894 Old 06-18-2017, 02:45 PM
sherr127's Avatar
Quoted: 90 Post(s)
Liked: 26
Yes,its the same spot as one of my pb13.In my room with 1 nearfield,dual pb13 hit more than 125db from 40-70hz.
My current rrom size now is 11 x 15 x 9.5 until my new ht room completed around october with the size of 16 x 24 x 9.5.
p/s: i would love to show the pictures but i dont know how to transfer it with my handphone.
sherr127 is offline
post #29987 of 30894 Old 06-18-2017, 02:58 PM
sherr127's Avatar
Quoted: 90 Post(s)
Liked: 26
Thats make sense,thank you for clarification.
I will try to locate 1 fv25 nearfield today,if that is still not enough then only i will add another fv25 in front.
I know i will get the slam/chest thump that i'm looking for with just 1 fv25 nearfield..why i'm not thinking it that way in the first place..sigh...tq again.
Marc Alexander and bscool like this.
sherr127 is offline
post #29988 of 30894 Old 06-18-2017, 03:37 PM
Bass and Hi-Fi Enthusiast
citsur86's Avatar
Quoted: 1563 Post(s)
Liked: 742
Also, @sherr127, what calibration are you using? (Audyssey XT32, YPAO, MCACC?)
citsur86 is online now
post #29989 of 30894 Old 06-18-2017, 06:36 PM
stash64's Avatar
Quoted: 289 Post(s)
Liked: 104
Originally Posted by jamiebosco View Post
I recommend Sorbothane bumpers from amazon or ebay, 1.5" or 2" diameter and 30 or 50 duro - depending on the weight of the speakers. This stuff stops nearly all vibration transferring to your speakers
I've used them in the past under the feet of BD players and even amps, but the material is so "sticky" that I would not want to use them under a speaker with a gloss finish. I think it could damage the finish over time.
Sean
stash64 is offline
post #29990 of 30894 Old 06-18-2017, 08:39 PM
sherr127's Avatar
Quoted: 90 Post(s)
Liked: 26
Denon 7200wa ( audyssey xt32 )
sherr127 is offline
post #29991 of 30894 Old 06-19-2017, 12:44 AM
jamiebosco's Avatar
Quoted: 101 Post(s)
Liked: 174
I used them for 12 months under my QA Concept 20s and they left a very faint mark but nothing worth worrying about. Ive had them under my PSA speakers and after nearly a year there is no marks on the speakers at all, perhaps I've been lucky!
jamiebosco is offline
post #29992 of 30894 Old 06-19-2017, 04:12 PM
Desmond7's Avatar
Quoted: 32 Post(s)
Liked: 0
How many clicks would it take for the FV15HP to match the new FV18?
Desmond7 is online now
post #29993 of 30894 Old 06-19-2017, 04:26 PM
torii's Avatar
Liked: 852
depending on the voltage/gain of your gear....I have maxed 100% gain/volume knobs before...I would rather tweak my subs settings in avr/pre and max my amps...but some amps I have to turn down due to noise or distortion or just plain being able to blow them up.
torii is online now
post #29994 of 30894 Old 06-21-2017, 05:21 AM
tvuong's Avatar
Quoted: 1797 Post(s)
Liked: 1100
@Rythmik , curious why line in rolls off around 90hz versus 200hz from lfe? I am sure there are folks wanting to xover higher than 90hz (120hz in my case) that also want to be able to use the phase knob. Is it the design choice or the limitation of line in? Thanks.
tvuong is online now
post #29995 of 30894 Old 06-21-2017, 05:56 AM
JT78681's Avatar
Quoted: 1483 Post(s)
Liked: 1006
You still haven't received your FV25?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #29996 of 30894 Old 06-21-2017, 11:31 AM
torii's Avatar
Liked: 852
nope
torii is online now
post #29997 of 30894 Old 06-21-2017, 11:42 AM
Marc Alexander's Avatar
Quoted: 2710 Post(s)
Liked: 2550
nope
Did you get the shipment notification/tracking# ?
What are your settings on the FV15HP BTW?
Marc Alexander is offline
post #29998 of 30894 Old 06-21-2017, 11:55 AM
torii's Avatar
Liked: 852
no...last I heard I requested a custom powercord and brian said no problem but would delay shipment a couple days...
i use my 15hp in 1 port mode and its not dialed in that great right now, but attached is where its set now.
torii is online now
post #29999 of 30894 Old 06-21-2017, 12:53 PM
citsur86's Avatar
Liked: 742
Did you have a big and wide mountain peak centered at 60hz in your response? Your PEQ settings are applying about a -6db reduction centered around 60hz, but spanning very wide (high bandwidth).
torii likes this.
post #30000 of 30894 Old 06-21-2017, 01:00 PM
torii's Avatar
Liked: 852
honestly I forget, went out and bought a minidsp and fv25 and just waiting to go thru hell again with rew
torii is online now
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
