Official Rythmik Audio Subwoofer thread - Page 1002 - AVS Forum | Home Theater Discussions And Reviews
 4295Likes
post #30031 of 30038 Old Today, 04:05 PM
Alan P's Avatar
Quoted: 4951 Post(s)
Liked: 3580
Originally Posted by tvuong View Post
I am not familiar with this. Can you detail how?
When you disable Audyssey, the Graphic EQ option (under the Audio menu) should no longer be greyed out. Go into the GEQ setup screen and you should see a "Copy" menu option...at least that is how it works on my Denon 4520.
Alan P is offline
post #30032 of 30038 Old Today, 04:10 PM
tvuong's Avatar
Quoted: 1712 Post(s)
Liked: 1005
^^ thanks Alan. I will take a look on my x4000.
tvuong is online now
post #30033 of 30038 Old Today, 04:38 PM
PlasmaPZ80U's Avatar
Quoted: 2126 Post(s)
Liked: 639
Originally Posted by torii View Post
i think a tad warmer...but yamahas can be tweaked very easily.
Thanks, I think my plan of trying Denon first and having Yamaha as a close 2nd in case I'm not happy with the Denon is a good plan. I would really like to be able to use XT32 but if it behaves in terms of boost eq like my current EQ options than it won't be usable for me.
I know YPAO volume on the Yamahas is like Dynamic EQ on the Denons. Does it require YPAO to be on to work just like Audyssey must be on for Dynamic EQ?
Also, can anyone link me to the official thread for the RX-A870/1070 and 860/1060? I have some questions about the various 'flavors' of YPAO.
PlasmaPZ80U is offline
post #30034 of 30038 Old Today, 05:05 PM
torii's Avatar
Quoted: 1178 Post(s)
Liked: 604
I have a yamaha aventage 8xxx and I disable all the "stuff" and leave it like that...mainly pure direct for music...didnt really dive in on this avr as I picked it up for a steal and sits in my garage.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5 Subs: Velodyne HGS 12, VA 1512, Rythmik FV15HP
torii is offline
post #30035 of 30038 Old Today, 05:10 PM
Timothy1180's Avatar
Quoted: 638 Post(s)
Liked: 153
What's funny how people describe audio. Warm means what? Fuzzy, muted highs and thick bass? A fellow avs guy came last month to hear my canton. He was like wow they are so thick and warm. It's amazing. Lol. Canton are sharp and clinical. He thought warm was good highs.
People use these to describe audio but don't really understand meaning.
Yamaha and onkyo have similar sound. Detailed sound with full of life.
Audyssey flattens the sound to much. Takes the excitement out of it. Best thing you can do is turn audyssey off and eq yourself. Marantz 7011 sounds exactly like denon 4300 after audyssey eq.
Yamaha has the best eq to adjust. Yamaha just needs to strengthen preout gain to over 3v rms. It would be perfect after that!
Audyssey is great for people that can never figure out how to setup their system. It'll take you 90 percent of the way there. Will never get you to perfect though.
A onkyo or integra with no eq with just ch level adjust will sound better then most audyssey avrs. Why they really dropped audyssey. Was no advantage to keeping. Other then a marketing move to say we have it.
Pioneer also does a great job customizing eq. They've been doing it same way for over a decade. Pioneer was criticized for years for being to bright or clinical. So they adjusted to sound more like a denon or marantz. They really changed in 2014 year. Since that change the pioneer elite line has been on a steady decline. The sc68 or sc57 is much better then sc99 or lx901.
Timothy1180 is online now
post #30036 of 30038 Old Today, 07:39 PM
Marc Alexander's Avatar
Quoted: 2008 Post(s)
Liked: 1743
Originally Posted by PlasmaPZ80U View Post
Is the Denon significantly warmer than those Yamahas?
The latest Yamaha I owned was the RX-V3800 and I found the amplifier section superior to Denon's (it is 10 lbs heavier than a X4x00). I have not owned an Aventage.
Pioneer and Onkyo are now partnered. Pioneer uses class D amplification so they are the most energy efficient. In the past I found Onkyo/Integra's amplifier sections as good or better than Yamaha. Initially when Onkyo dropped Audyssey they did not want to supply the DSP horsepower to do both Atmos and Audyssey simultaneously. I think it was a mistake because their initial solution was inferior and they lost market share to D+M and Y. I have no idea what their REQ solution looks like today.
TMK I would rank the Auto REQs accordingly.
Room Perfect
Trinnov
Dirac
Anthem ARC
Audyssey XT32
Yamaha YPAO/Onkyo/Pioneer
I hope they fix the Audyssey app quickly. Being able to limit Audyssey to the room's model region (i.e. <500Hz) is a welcome advancement drawing it much closer to ARC.
Marc Alexander is online now
post #30037 of 30038 Old Today, 08:38 PM
Quoted: 638 Post(s)
Liked: 153
Really processing ability isn't why onkyo dropped audyssey. They were looking for a reason to drop them for a few years. If you go and listen to a onkyo rz900 or rz1100 it's far superior to 5009 and 3010. I've had all 4. They are all good in their own way. Audyssey just didn't help in anyway unless you have really poor speakers that need a bunch of eq.
Arcam and anthem are decent products but are a waste of money. Think of it this way. Anthem is a rel sub. Arcam is a jl sub. Yamaha is a rythmik. Onkyo is a seaton. Integra is a jtr.
Denon is a svs. Marantz is a hsu.
Marc you should try a new aventage.
On a different note I'm getting better and getting stronger. Wife got me a marantz 7011. Wanted to cheer me up. Lol. I do like it but I hate to tell her that I don't want to keep it. Honestly it sounds good but closer to my Yamaha 1060 then my others. Does sound similar to denon 4200 that I just sold.
post #30038 of 30038 Old Today, 10:19 PM
tvuong's Avatar
Liked: 1005
In my case of the x4000, the GEQ is only available when I select GEQ for MultEQ XT32. If I select off for MultEQ XT32 (turn Audyssey OFF), the GEQ is still grayed out. When you copy, is your speaker selection set to 'All' or 'Each' or 'Left/Right'? On your posted graphs earlier, is the red = Audyssey, blue = GEQ?
This gives me a reason to pull out my Umik-1, which I haven't touched for months, and run a few REW sweeps to compare Audyssey flat and the copied GEQ curve. Thanks.
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
