Official Rythmik Audio Subwoofer thread - Page 211 - AVS Forum | Home Theater Discussions And Reviews
 3185Likes
post #6301 of 27834 Old 05-06-2012, 07:32 AM
A L Wong's Avatar
I just took delivery of a Rhythmik F12SE to add to my dual ported SVS PC12NSD
I am running a triple subs set up in a 5.1 system.
AVR is the Denon 3808 with Audyssey XT.
I am also using the AM8033C for bass correction.
I have the two ported subs in front, with both subs' phase set to 0 and connected via a Y connector to the 0 phase output of the AM8033C.
I have the sealed Rhythmik at the rear left of my sofa. I am using the LFE input and set the phase to 180. This sub is connected to the 180 deg phase output of the AM8033 as recommended by AntiMode.
I read some where here, that if connected to the LFE input, this bypass the phase and cross-over in the F12SE.
Will this interfere with the AM8033C 's calibration, which recommended the phase to be set to 180?
Should I instead use the line input of the F12, which enables the phase control?
Thank you and sorry for the long post.
A L Wong is offline
post #6302 of 27834 Old 05-06-2012, 08:21 AM
DonH50's Avatar
Quoted: 1791 Post(s)
Liked: 1325
Connect the Antimode to the LFE input.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #6303 of 27834 Old 05-06-2012, 08:41 AM
A L Wong's Avatar
So the disabled Phase control will not interfere with the AM8033C's calibration?
A L Wong is offline
post #6304 of 27834 Old 05-06-2012, 09:15 AM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 58
Originally Posted by Foreverandone View Post
Been waiting for the F12 for more than two months now, after being told to wait for another 2 months, I got impatient and got a Rel T-1 instead. However, I found Rel T-1 a little too bloomy for my taste. Anyone with experience with Rel T-1 and F12 could you let me know if I could expect tighter and deeper bass (vs. Rel T-1) from the F12? My main speakers are Vienna Acoustics Mozart Grand. The sub and speakers are only used for music. Thanks.
REL T1 was actually my first choice back when I didn't know any better. Apparently it was well though of in certain circles back in the day, but technology has moved on.
REL T Series are actually entry level product for REL and therefore do not provide value-for-money. To get quality REL product, you should consider Gibraltar line. T Series are passive radiator designs and not well designed; they may be OK for home cinema but not for music. There's a good reason sealed sub-woofers are best for music.
Additionally, F12 give you the option of using it's parametric equaliser whereas REL T Series has no such option.
BTW, my usage is 75/25 music/home cinema.
I spent quite a bit of time researching all this and finally arrived at Rythmik's doorstep. My F12SE was delivered in January and time has shown that my patience has been rewarded. It's fulfilled all my expectations and more.
Patience is a virtue
Iain- is offline
post #6305 of 27834 Old 05-06-2012, 11:08 AM
DonH50's Avatar
Liked: 1325
No, the Antimode will adjust frequency and time domain, as it says in its manual. Keep in mind most subs do not even have a phase adjustment knob, just a 0/180 degree switch and that is almost useless.
post #6306 of 27834 Old 05-06-2012, 03:19 PM
JT78681's Avatar
Quoted: 1375 Post(s)
Liked: 898
Originally Posted by Tom Riddle View Post
Any FV12 owners who can comment about their likes/dislikes about this sub? I've read so much about subs in the past month I'm absolutely at a stand still on what I should get. I cannot find any reviews on the FV12, but it appears to be a good sub from the specs and some of the comments I have read. Does it dig deep and also have good mid-bass? My main listening room is 3200 cubic feet, but if you factor in the dining and kitchen area that it opens to, it is over 5000 cubic feet. I have a Klipsch Sub-12 now and it digs deep, but I would like a little greater extension and to get away from the awful port noises it produces and its boomy bass. Any comments/suggestions would be appreciated.
This sub plays deep and extremely clean. The midbass is excellent, so far I can't seem to find a single thing I dislike about the FV12. My living room is open to a dining area and kitchen. Give it a shot and if it isn't for you then return it within 30 days for a refund, but I highly doubt you would not be satisfied.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is online now
post #6307 of 27834 Old 05-06-2012, 03:39 PM
Tom Riddle's Avatar
Quoted: 473 Post(s)
Liked: 408
Thanks for the reply. I'm still on the fence though. It seems like just when I make up my mind, I read something else that changes my mind.
Klipsch RF-7 II's, RC-64II, RS-62 II's, RS-52 II's
PSA V3600I
Marantz SR7008 with TK421 Modification
Emotiva XPA-5
Sony XBR-75x940c with Ideal-Lume Panelight
Samsung PN64F8500 (Master Bedroom)
Tom Riddle is offline
post #6308 of 27834 Old 05-06-2012, 03:45 PM
sofast1's Avatar
The F15 is only $100 more!
sofast1 is offline
post #6309 of 27834 Old 05-06-2012, 07:12 PM
JT78681's Avatar
Liked: 898
I can relate. I researched subwoofers for months before finally pulling the trigger on the FV12. Still loving my purchase.....
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
post #6310 of 27834 Old 05-06-2012, 07:30 PM
millerrh's Avatar
Originally Posted by sofast1 View Post
the f15 is only $100 more!
+1
millerrh is offline
post #6311 of 27834 Old 05-06-2012, 07:48 PM
A L Wong's Avatar
Thank you.
A L Wong is offline
post #6312 of 27834 Old 05-06-2012, 08:56 PM
Tom Riddle's Avatar
Quoted: 473 Post(s)
Liked: 408
Originally Posted by millerrh View Post
+1
Where? I just looked on their site and it was $400 more.
PSA V3600I
Emotiva XPA-5
post #6313 of 27834 Old 05-06-2012, 08:59 PM
millerrh's Avatar
Not sure where you are looking
F12: $874
F15: $974
In my book F15 is more bang for your buck.
millerrh is offline
post #6314 of 27834 Old 05-06-2012, 09:42 PM
pronghorn/az's Avatar
Quoted: 20 Post(s)
Liked: 31
F12: $874
F15: $974
Plus 3..For $100. more the F15 would be better than the F12. I think you were looking at the FV15's price.
Jeff
pronghorn/az is offline
post #6315 of 27834 Old 05-07-2012, 04:14 AM
LarryU's Avatar
Jeff
He's looking at the FV12 not the F12.
LarryU is offline
post #6316 of 27834 Old 05-07-2012, 07:09 AM
millerrh's Avatar
He said:
"Been waiting for the F12 for more than two months now, after being told to wait for another 2 months, I got impatient and got a Rel T-1 instead. However, I found Rel T-1 a little too bloomy for my taste. Anyone with experience with Rel T-1 and F12 could you let me know if I could expect tighter and deeper bass (vs. Rel T-1) from the F12? My main speakers are Vienna Acoustics Mozart Grand. The sub and speakers are only used for music. Thanks."
You sure about that? Maybe he meant FV12 instead of F12, but it's not what he wrote and was asking questions about. Could be a case of forgetting or not realizing you weren't typing the V. I did that a few times. Sort of easy to do since the models are so close in name to one another.
millerrh is offline
post #6317 of 27834 Old 05-07-2012, 07:45 AM
Foreverandone's Avatar
Thanks for your reply. Could I ask, just to understand the context, if you had a chance to audition Rel T1 at home or in store before making the decision to go with the F12SE? Thanks.
Foreverandone is offline
post #6318 of 27834 Old 05-07-2012, 07:57 AM
My object of desire is the F12, more specifically the F12SE
I want Rythmik's best sounding sub for music and the F12 is what recommended on Rythmik's website, I believe. I don't listen to music loud so power is not that important. What important to me is deep and tight bass. Am I looking at the right thing?
By the way, the object of desire has forever been out of stock. I was ready to place the order in Dec but it was out of stock then. It's back in stock briefly (maybe 10 days or so) in late Feb but I couldn't place the order in time due to traveling. And it's been out of stock ever since.
post #6319 of 27834 Old 05-07-2012, 08:03 AM
millerrh's Avatar
You are looking at the right thing. The F12 will be deep and tight. The F15 just as deep, just as tight, but with more output capability due to its bigger driver. And at only $100 more it seems like a good insurance policy in case you ever want more output. Plus, maybe they are in stock and you wouldn't have to wait. They are larger than the F12 though, so maybe that would also be a consideration.
millerrh is offline
post #6320 of 27834 Old 05-07-2012, 08:17 AM
LarryU's Avatar
I think we're talking about two different posts.
LarryU is offline
post #6321 of 27834 Old 05-07-2012, 08:49 AM
millerrh's Avatar
Probably.
millerrh is offline
post #6322 of 27834 Old 05-07-2012, 02:45 PM
Tom Riddle's Avatar
Quoted: 473 Post(s)
Liked: 408
F12: $874
F15: $974
Ah. I was looking at the fv12.
PSA V3600I
Emotiva XPA-5
post #6323 of 27834 Old 05-07-2012, 03:10 PM
mantaraydesign's Avatar
Quoted: 133 Post(s)
Liked: 33
Do Rythmik products have their logo on them because I just don't see a logo on their subwoofers. I am considering buying the FV15HP and was trying to see where they put their logo on that FV15HP.
mantaraydesign is offline
post #6324 of 27834 Old 05-07-2012, 03:11 PM
JT78681's Avatar
Liked: 898
If I am not mistaken I believe on my FV12 there is a logo on the amplifier, but none elsewhere.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
post #6325 of 27834 Old 05-07-2012, 03:18 PM
Quoted: 133 Post(s)
Liked: 33
Ah, I found this image showing the back of the FV15HP with a logo:
http://www.audioholics.com/reviews/s...iew_fullscreen
post #6326 of 27834 Old 05-07-2012, 03:30 PM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 58
Initial attraction to T1 was due to cosmetic features; small size and colour options. White finish would allow it to blend with environment so as not to be so distracting.
Finally listened to one at someone's home and was quite disappointed of SQ. Seemed a bloated mess of sound that all merged as one. Not to my liking.
Later I visited a Velodyne shop and listened to a DD15+ on demo. Very impressed of it as SQ was exactly what I was searching for. Quite keen of it until price was mentioned. So much for that,
Finally came round to Rythmik. F12 size is exactly right but not keen of black sub-woofers. Figured I would try the SE version and hope for the best. When it was finally delivered I was impressed by finish. Much better than I had though it would be and SQ is quite close to the Velodyne DD sub. I can easily live with piano black finish.
Iain- is offline
post #6327 of 27834 Old 05-07-2012, 04:03 PM
ntrain96's Avatar
The F15 is just as accurate as the F12.....but you get more headroom. And in reality IMO the F15 is actually more accurate because of the added 3-4db gained headroom. In other words, if you need the F12 to play X music at Y loudness, you have to basically double the power of the F12's plateamp for the same output as you would on the F15. That in turn means you have less dynamic headroom and more chance for distortion/clipping, especially if your sub plays at higher output levels. The only times I would recommend the F12 is if floor space and BUDGET are absolute priorities.
ntrain96 is offline
post #6328 of 27834 Old 05-07-2012, 06:11 PM
benclement11's Avatar
So I bought a turntable and had problem with the accuracy of the sub. It seemed to be picking up rumble and not behaving accurately at well. I think this is what the rumble filter is supposed to be for....my question is....is the rumble filter on the Rythmik subs the same as adding a subsonic filter? Or would I benefit from adding a subsonic filter into the chain as well?
Panasonic P60ST50-Yamaha RX-V467 receiver-Sony PS3-Velodyne SMS-1-Canton 430 mains, 455 center and 402 surrounds-Rythmik FV15HP subwoofer- Pro-ject Debut III turntable- I also have a pair of Mark K's DIY design, the ER18DXT's
My humble entertainment room
http://www.avsforum.com/t/1417652/midwest...
benclement11 is offline
post #6329 of 27834 Old 05-07-2012, 07:40 PM
Exclusively Servo
Rythmik's Avatar
Quoted: 230 Post(s)
Liked: 314
Ben,
You have an FV15HP. So use 2port mode and set the rumble filter to ON/2. If you set it to 1 port mode, you will hear a lot of record warp. You will see the cone moving in and out literally without generating audible sound.
Rythmik is offline
post #6330 of 27834 Old 05-07-2012, 07:45 PM
Originally Posted by Rythmik View Post
Ben,
That's pretty much what happened but I did have it in two port. I didn't set it to on/2 though. That doesn't disable anything the receiver is doing for x-over though does it?
To my second point...would a subsonic filter benefit me at all or is setting it to ON/2 basically doing the same thing as a subsonic filter?
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
