Official Rythmik Audio Subwoofer thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 3123Likes
post #91 of 27596 Old 01-24-2010, 11:25 AM
monomer's Avatar
Originally Posted by tegage View Post
I found the following sweep in wav format: 20, 25, 31.5, 40, 50, 63, 80, 100, 125 Hz.
I ripped them with Zune and downloaded to my Zune HD. When I first ran them, I had a significant drop at 50 Hz, but them I realized that I had my Polk Lsi15's running. I unplugged those and the drop mostly went away. So I went in the receiver's setup (Onkyo 807) and upped the cross-over to 80 Hz (although the LSi's do a good job of mid-bass). Unfortunately, that didn't keep the Lsi's from playing lower that 80Hz - it seemed to raise the HPF, but not to 80Hz. I'll play some more today, but right now I am low at 20Hz and pretty flat from 25 Hz up to around 60Hz.
I suggest in addition to single freq tones you also try an actual sweep so you get an idea of the broadness (or narrow) of the nulls you are hearing. You can go here and download an MP3 file of a slow 10-200Hz sweep from Bass Mekanik for $.89 (its #109 on my screen listing)... or you go here and install SigJenny (a freeware signal generator) and play and create your sweep wav files. Was that 50Hz drop interaction between your mains and the sub or just your mains (between each other)? Try only the mains by themselves to determine if it is due to placement of the mains. Also was this 50Hz drop after you ran Audyssey (proper phasing between sub and mains were set)? Its important to remember that a cross-over is not a "brick-wall" but only identifies the mid (50/50) cross-over point. Your mains will still have a significant effect (albeit decreasing) down to an octave below the cross-over, just as the sub will have an effect (also decreasing in significance) to around an octave above the cross-over. If you set you crossover to 80Hz then the region of cross-over is ~40-160Hz. Have you tried the sub in another location yet?
"For deep bass, the listener is not really listening to the speaker, but rather, is listening to the room as it is being played by the speaker."
Juicy
Doggie Jabber
monomer is offline
post #92 of 27596 Old 01-24-2010, 01:16 PM
enricoclaudio's Avatar
Quoted: 1071 Post(s)
Liked: 1094
Hi Brian, I live in Houston. It is possible to pick up a pair of D15SE subwoofers directly in to your workshop?
Enrico Castagnetti @ Rythmik Audio
Media Room: SPEAKERLESS | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet + Duet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #93 of 27596 Old 01-24-2010, 01:18 PM
lewdogg's Avatar
Originally Posted by Rythmik View Post
1) shipping delay:
I have to apologize for the customers whose sub delivery got delayed this week. I was trying to finish a few tasks so that my suppliers can get them done before their upcoming 2 weeks break starting Feb 7th. If I missed the deadline, the whole shipment will be delay by at least 2 weeks and more likely 3 weeks.
2) availability
In terms of enclosure availability, I am basically out of enclosures and drivers to build F12 subwoofers. Both of them will be available in 6 weeks. Also I am out of black oak F15 enclosures. Black matte F15's are available.
Is this common with all online subwoofer manufacturers? It seems Rythmik, SVS, Epik, and eD are all backordered for many of their subwoofers. Is last year's inventory about gone so most places are out of stock?
lewdogg is offline
post #94 of 27596 Old 01-24-2010, 01:32 PM
monomer's Avatar
My guess is that when you are small and have to use your own money up-front to purchase components in batches large enough to warrant a pricing break (a long enough production run to make it worthwhile for the supplier to tool up) you are guessing at what is going to be in demand in the coming months and if your guess was a little off, you will sell out of one thing before having sold many of the other things to make back enough money to quickly place another large order with your suppliers... so there are delays. Plus, I would assume one would like to reduce their stock down by year's end to make doing taxes and inventorying easier. But hey, this is all just pure guessing on my part... maybe its as simple as everyone got an ID sub or two for Christmas. Anyway, just thought I'd spend some time here speculating as long as you are waiting on a more accurate response from Brian.
Juicy
Doggie Jabber
monomer is offline
post #95 of 27596 Old 01-24-2010, 02:59 PM
lewdogg's Avatar
Was my assumption as well...just thought it was odd that it seems to be the same for many others, not just Rythmik. Not being in the market for a sub until now, I wasn't sure if this was common-knowledge at this time of the year or if it was something else.
Thanks for your help.
lewdogg is offline
post #96 of 27596 Old 01-24-2010, 05:49 PM
Exclusively Servo
Rythmik's Avatar
Quoted: 230 Post(s)
Liked: 313
I have to say we are all at the hands of this unpredictable economy that some months are slow and some months are better. In our case, it is a planning error and bad habit of perfectionist. I learnt a lesson from it and I will do better next time. Don't read too much into it.
Rythmik is offline
post #97 of 27596 Old 01-24-2010, 06:03 PM
sdurani's Avatar
Quoted: 4383 Post(s)
Liked: 2811
You can place them a few inches apart. I recommend against puting them feet apart.
Well, there goes my Rythmik coffee table idea. Time to come up with a plan B.
Sanjay
sdurani is offline
post #98 of 27596 Old 01-25-2010, 08:25 AM
tegage's Avatar
Quoted: 44 Post(s)
Liked: 24
I'm not sure since I did not run the sweeps with just the mains. I will do that.
Yes, I had run Audyssey
I figured that was likely the case. I've been using a SPL meter for years to set speaker levels, but I've never run sweep before so this has been a learning experience for me. I am making progress, however, and the sound has noticeably improved.
I did try a second location, but got similar results. I'll have to make/buy a long sub cable before I can try more locations.
Also, I think I'll run Audyssey once more and take some measurements since I am not sure that I hadn't adjusted the cross-overs subsequent to the last run.
LG 65EF9500
Oppo BDP-103
Polk LSiM703, LSiM704C, LSiM 702, LSi 7
Rythmik D15SE sub
Outlaw 975
Outlaw 7125
tegage is offline
post #99 of 27596 Old 01-28-2010, 04:12 PM
FlavioSupra's Avatar
I am contemplating replacing my dual SVS PB13-Ultra subs with dual Rythmik D15SE subs because I need some more floor space and my wife thinks the SVS boxes (as she calls them) are ugly. The D15SE has a much smaller footprint then the PB13-Ultra (in rosenut) and the gloss black will match better with the Mythos speakers.
How much output will I lose at the bottom end?
My room is appr. 8000 cu.ft.
My main speakers are Def Tech Mythos ST playing as full range speakers.
For movies I always listen at reference level and when I listen to music I also like to play it loud.
Dune Solo 4K | Humax 5100C | Onkyo 5509 | Behringer DCX2496 | 6x Crown XLS 1500 | 2x Crown XLS 1000
DarbeeVision Darblet | Philips HDP2510 | iVisions Frame 4K 16:9 300cm
2x Magnepan MG1.6/QR | 2x Magnepan SMGc SE | 4x Dual Exodus Audio Shiva-X 105l Sealed
Sundown Audio X-15 150l Ported | Earthquake Sound SubZero-12 PR | Buttkicker LFE
FlavioSupra is offline
post #100 of 27596 Old 01-28-2010, 07:12 PM
lewdogg's Avatar
Anyone have a clue when the new series of amps will be released?
lewdogg is offline
post #101 of 27596 Old 01-28-2010, 09:03 PM - Thread Starter
jpmst3's Avatar
Quoted: 97 Post(s)
Liked: 233
You will lose some significant output down low. Above 30Hz it should be close, but you can't compete against larger ported boxes with small sealed.
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #102 of 27596 Old 01-29-2010, 07:33 AM
panzer's Avatar
Quoted: 24 Post(s)
I have a question on the d15se, looking at the back on the websight, I don't see a life input, I will be using my receiver sub out, wich input on the sub would I use, and what would be the settings on the back of sub, thanks
panzer is offline
post #103 of 27596 Old 01-29-2010, 07:38 AM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
Either L or R line level input.
rick240 is offline
post #104 of 27596 Old 02-02-2010, 12:26 AM
polarbare's Avatar
Quick question - been reading around for a bit, and I can't seem to find a definite answer, is there any reason to go with the F12SE vs the F15SE (or vice versa)? Is the F12 any "faster" and better for music (as opposed to home theater) and the F15 just able to reach lower? Or is it merely a size constraint/room compatibility/cost issue?
One other thing - the F15SE is only available through the Rythmic website, whereas the F12SE is only available through the Ascend website. Just an indication of supply at each location?
Last edit I presume the F12SE's on the Ascend website have the A370PEQ amplifier.
polarbare is offline
post #105 of 27596 Old 02-02-2010, 01:58 AM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
The difference between the two is essentially just their output capabilities. Some have said that the F12 has a bit better sound quality.
The Ascend site needs to be updated. Any Rythmik sub is available via Ascend and vice versa.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #106 of 27596 Old 02-02-2010, 09:12 PM
Upgrader's Avatar
Quoted: 38 Post(s)
At http://www.rythmikaudio.com/F12.html it says that all products are on back-order. The post on this thread by Rythmik says they will have stock in 6 weeks. Does that mean to check back around mid-March?
Upgrader is offline
post #107 of 27596 Old 02-03-2010, 01:51 PM
powbob01's Avatar
Everything looks to be in stock now.
powbob01 is offline
post #108 of 27596 Old 02-03-2010, 02:07 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
From the Rythmik site on the F12 page
We are currently out of these subwoofers. The new ones will be available in early March.
rick240 is offline
post #109 of 27596 Old 02-03-2010, 03:22 PM
stevec325's Avatar
Looking at the freq response chart for the F12 signature, it looks like it really drops off above 80Hz. And, it's way down at/above 100Hz. Any thoughts as to how that will integrate with mains crossed at 80Hz? I was under the impression that you needed "usable" output up to around 140-160Hz, even crossing at 80Hz to overlap a full octave.
Thoughts? Comments?
-steve
My HT Setup - updated 12/25/2012
"...and all the science, I don't understand. It's just my job, five days a week."
stevec325 is offline
post #110 of 27596 Old 02-03-2010, 04:20 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
Thoughts? Comments?
My reading of that chart says that it is down 3-4 db at 100Hz and down about 10db at 160 Hz.
rick240 is offline
post #111 of 27596 Old 02-03-2010, 04:29 PM
tegage's Avatar
Quoted: 44 Post(s)
Liked: 24
OK, I moved the mains a bit (not much), turned off the PEQ and set the bass extension at 14/high and then I re-ran Audessey.
The results seem much better - in fact I'm wondering if during my initial setup I got something out of order. Anyway - with the sub and mains, it looks like this:
20Hz, 0
25Hz, +1
31.5Hz, +2
40Hz,+7
50Hz, +4
63Hz, +9
80Hz, +8
100Hz,+15
125Hz, -3
With only the sub, it looks like this:
20Hz, -1
25Hz, 0
31.5Hz, 0
40Hz, 0
50Hz, -4
63Hz, -15
80Hz, -9
100Hz,-20
125Hz, -25
So, this time around things are reasonably flat except at 100, which is solely due to the Lsi15s (Mains).
The whole system is sounding very good to me. I've been listening to a lot of music, and the sound is incredible. To be fair, I added the Lsi15s at the same time and I think they are incredible, but prior to this change, I never used my old Velodyne for music - it sounded too mushy - the Rythmik sounds good.
I watched Taken the other night and was pleased with what I could "feel" during a couple of the action scenes. I will report more back as I watch more movies.
LG 65EF9500
Oppo BDP-103
Rythmik D15SE sub
Outlaw 975
Outlaw 7125
tegage is offline
post #112 of 27596 Old 02-03-2010, 05:38 PM
powbob01's Avatar
When I looked before instead of the order now button there was an out of stock quote. I guess that changed.
powbob01 is offline
post #113 of 27596 Old 02-03-2010, 06:54 PM
mookie b's Avatar
Quoted: 16 Post(s)
Liked: 26
Did anyone here compare the F12 with the SVS SB12?
mookie b is offline
post #114 of 27596 Old 02-03-2010, 08:10 PM
stevec325's Avatar
Does that seem OK for drop off at the upper end?
-steve
post #115 of 27596 Old 02-04-2010, 08:56 AM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 58
I'm keen to see how the new 370PEQ amplifiers, supposedly with extended frequency range to 180 HZ, will integrate with GR Research 12" driver (F12G).
Iain- is offline
post #116 of 27596 Old 02-04-2010, 09:56 AM
monomer's Avatar
20Hz, 0
25Hz, +1
31.5Hz, +2
40Hz,+7
50Hz, +4
63Hz, +9
80Hz, +8
100Hz,+15
125Hz, -3
20Hz, -1
25Hz, 0
31.5Hz, 0
40Hz, 0
50Hz, -4
63Hz, -15
80Hz, -9
100Hz,-20
125Hz, -25
Did you remember to apply the correction factors to your SPL readings above?... if not and its a RS meter, then your response is even flatter than you think. There's a chance that 100Hz peak can be attenuated by further 'tweaking' of the speaker positions (meaning the mains only) if they are interacting with each other (due to distance both between them and to you) and if not then it must be cause by a room reflection or a mode and some room acoustical treatments might then be in order. Looks like you've got a good starting point and are now beginning to hear what the 'real' Rythmik sounds like.
Juicy
Doggie Jabber
monomer is offline
post #117 of 27596 Old 02-04-2010, 11:12 AM
tegage's Avatar
Quoted: 44 Post(s)
Liked: 24
It is a RS meter, but I wasn't aware that there are correction values.
A quick google uncovered them, the with the corrections, I have:
20Hz, +7.5
25Hz, +6
31.5Hz, +5
40Hz,+9.5
50Hz, +6.5
63Hz, +10.5
80Hz, +9.5
100Hz,+17
125Hz, -2.5
Other than the spike at 100 and drop at 125, am I correct that in typical home setup, what I have up to 100 Hz is pretty good/normal?
LG 65EF9500
Oppo BDP-103
Rythmik D15SE sub
Outlaw 975
Outlaw 7125
tegage is offline
post #118 of 27596 Old 02-04-2010, 11:59 AM
monomer's Avatar
20Hz, +7.5
25Hz, +6
31.5Hz, +5
40Hz,+9.5
50Hz, +6.5
63Hz, +10.5
80Hz, +9.5
100Hz,+17
125Hz, -2.5
Though you can use EQing to flatten it even more those types of EQs work on one "sweet spot" only, which is great if you listen solo from the same position only because you can dial it in just for that one location without caring about what the effect is upon any other listening position in the room... HOWEVER, if you listen to music together with others or watch movies with friends and family or like to change positions when listening music or watching movies then EQing for a single "sweet spot" just doesn't get it. I like Audyssey because it tries to find the best compromise across all listening positions (considers the effect on a larger listening area)... creating sort of a "sweet area" so to speak. Under those conditions, YES! your results are quite good as your ears have already verified and you should be proud. However, this IS 'the hobby of audio'... so the nitpicking is never done... all we ever succeed at doing is raising our standards to the next level. Once your pocketbook has recovered sufficiently, it will be time to visit forums on acoustical room treatments...
Juicy
Doggie Jabber
monomer is offline
post #119 of 27596 Old 02-08-2010, 07:51 PM
mattldm's Avatar
Hey Brian,
I've been really enjoying my F12.
Have you ever thought of going the other size direction and building a F10 for those with sub size constraints?
I agree! I would be interested in a smaller version, maybe a 10"
In fact right now im thinking of DIY'ing a 10-12" sub with the A370PEQ amp just to have a smaller sub to fit where I want it to go!
mattldm is offline
post #120 of 27596 Old 02-25-2010, 02:14 PM
porksoda's Avatar
I would be interested in comments to this as well... and throw in paradigm sub 12 / 15
porksoda is offline
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
