Official Rythmik Audio Subwoofer thread - Page 466 - AVS Forum | Home Theater Discussions And Reviews
 3231Likes
Old 02-17-2014, 08:24 PM
niccolo's Avatar
Quoted: 140 Post(s)
Liked: 39
Originally Posted by newc33 View Post
Thanks for the info!
I actually own dual fv15hps and there amazing. Exactly why the lv12r is sitting unplugged. I think I'll just wait till I get my receiver and do it that way
Sounds epic. I have a hard time justifying one FV15HP, especially paired with a very modest setup, so leaning LV12R, but the forum is gradually wearing down my budget resolve, so we'll see what I eventually end up getting.
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
Old 02-17-2014, 08:29 PM
enricoclaudio's Avatar
Quoted: 1104 Post(s)
Liked: 1133
Ya thanks I can't wait! Especially for x32 n sub eq
You are gonna love the X4000. I upgraded last year from an Onkyo 809 to a Marantz SR7008 and it worth every $ I paid for it. Audyssey XT32 + SubEQ HT did an amazing job with my two F12SEs.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
Old 02-17-2014, 08:38 PM
tvuong's Avatar
Quoted: 1549 Post(s)
Liked: 878
Originally Posted by enricoclaudio View Post
The Yamaha does not have pre outs but the Denon X4000 does. So when you have the X4000 just run a RCA cable from the Center channel preout to the Line IN of your LV12R and you will get the same result as speaker level inputs.
How does he connect his center speaker then?
tvuong is offline
Old 02-17-2014, 08:44 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
split the pre-out using a Y-jack
qguy is offline
Old 02-17-2014, 09:02 PM
tanbyte's Avatar
Quoted: 29 Post(s)
Originally Posted by JT78681 View Post
Growing up as a kid I always loved the cheesy Godzilla movies. The one that came out a few years ago was so so in my opinion. Just not that good, but I'm actually excited about the new one coming out this year. It looks a little more dark and more of a thriller. Check out the trailer if you haven't already.
It certainly does. I like the last bit of the trailer the best where right after the dinosaur roar there a slight bit of good LFE.
tanbyte is offline
Old 02-17-2014, 09:10 PM
Liked: 1133
He doesn't need to split the signal from the pre out because he will be driving his center channel with the X4000 internal amp. As far I know he does not have external amps so pre outs are available.
Old 02-18-2014, 08:19 AM
DonH50's Avatar
Quoted: 1797 Post(s)
Liked: 1333
Originally Posted by niccolo View Post
Since the LV12R lacks high-level inputs, is there a workaround to be able to drive it off an amp that doesn't have pre-outs or a sub out? In the near-term, I've been thinking of driving a subwoofer off the high-level output on my Audioengine A5+ powered speakers, that way I can control the system volume through the A5+s.
You can find speaker-to-line-level converters (attenuators) that would allow you to use the L/R speaker outputs to drive the sub. Parts Express used to have them but I have not looked recently; Monoprice and other electronic supply houses may also have them. They are more common in car audio systems. I have seen them called "high-low" converters.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
Old 02-18-2014, 08:27 AM
BeeMan458's Avatar
Liked: 813
Sounds epic. I have a hard time justifying one FV15HP, especially paired with a very modest setup,....
As the voice of unreason, allow me to encourage, not one but two FV15HPs. It all is going depend on what you want/expect out of your system. If you want to walk away after each viewing and know you've been ridden hard and put away wet with a smile on your face (horse talk so don't go there), then get a pair of FV15HPs. If you want to have some bass, that won't rock your world, get a pair of LV12Rs. Just saying, there's a reason for budget subwoofers and it's not because they're as good as the good stuff.
What do you want? That's what you should get.
(i wish there was a way to share what we experience during a showing)
In my opinion, if folks were to hear what we hear, the conversation would end. A couple nights ago, I rescreened "Dark City" (my opinion, the pre-cursor to "The Matrix"), and there's no doubt the bass was head-and-shoulders above theater sound.
It's a personal call where they want to go, where they want to be when deciding which subwoofer system to go with.
BeeMan458 is offline
Old 02-18-2014, 12:21 PM
JT78681's Avatar
Quoted: 1377 Post(s)
Liked: 902
How large is your room? Is it sealed or open? Also, how far will the MLP be from the subs?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 02-18-2014, 12:33 PM
niccolo's Avatar
Quoted: 140 Post(s)
Liked: 39
Open floorplan, so I have ~4500 cubic feet to pressurize. Conversely, I definitely don't listen/watch movies at reference levels, and my expectations are thoroughly in check.
Rythmik FV15HP sub
niccolo is offline
Old 02-18-2014, 12:45 PM
JT78681's Avatar
Liked: 902
My living room is not large, but is completely exposed. I have a FV15HP right now nearfield by my main listening position hooked up to a Rocketfish Wireless Transmitter/Receiver kit. Sounds excellent and I don't have a 25 ft subwoofer cable to deal with. This provides clean solid bass with lots of tactile feel to my couches. It will do for now until I can save up enough cash for possibly a second FV15HP a year or so from now. I just wanted you to know that you can get away with one sub for now if nearfield.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 02-18-2014, 01:25 PM
niccolo's Avatar
Quoted: 140 Post(s)
Liked: 39
I see in your signature you have or had a pair of LV12Rs. How would you compare them to the single FV15HP?
Also, how is the nearfield placement for music? Especially for classical music, it seems like it might be sub-par.
Appreciate your thoughts!
Rythmik FV15HP sub
niccolo is offline
Old 02-18-2014, 01:41 PM
JT78681's Avatar
Liked: 902
I currently have all three. It's not really fair to compare them to a subwoofer that cost 3x as much smile.gif They are great subs, but it would be too much to ask them to compete with the challenges my room poses. I do miss the smoothness that the duals provided from seat to seat, but they just cant hang with the power and extension of the FV15HP. Funny you should ask about music I have actually yet to jam out to anything with the FV15HP.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 02-18-2014, 04:09 PM
BeeMan458's Avatar
Liked: 813
Old 02-18-2014, 07:52 PM
newc33's Avatar
Quoted: 753 Post(s)
Liked: 928
When I placed my fv15hps nearfeild I gained about 8 dbs which was awzome but the sound was muddy and lacked depth and detail.
I also had the corner loaded in front which I lost about 5 dbs and the sound was better clearner and more detailed.
Then I moved them closer to the center on each side of the TV and lost another few dbs but the quality of sound was amazing! I opted for this as a final desision.
One thing to note was the when located next to my TV my subs shook the room and gave tighter chest thump action better despite the db loss. I found this very interestimg.. one way to describe it would be that it "felt" louder.
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
Quad PSA T18s!!!!!!
newc33 is online now
Old 02-19-2014, 06:04 AM
3db
3db's Avatar
Quoted: 157 Post(s)
Liked: 40
Originally Posted by BeeMan458 View Post
The LV12-R is a great sub for the money. It has both good extension and good articulation and is very difficult to beat in its price class. For terms of articulation, I would pit the LV12-R against any sealed sub and not worry that it's going to get trampled. However, it still has limitations that its price class prevents from overcoming. One can do easily do a lot worse than an LV12-R
Receiver: Yamaha RX-V1800/Yamaha RX-V1500
Display Samsung UN65KU6491 65"/Vizio SV-470M 47"
BluRay/CD: Yamaha BD-S681/Sony BDP-S360; Turntable ProJect Xpression III
Speakers PSB: Mains Image T-45/Alphas; Center Image 8C/100C; Srnd Image 1B/Alpha Mites
Subwoofer: Rythmic LV12-R/PSB Subsonic 5
Media Player WD + 3TB USB drive/Iomega + 1TB internal drive
3db is offline
Old 02-19-2014, 06:10 AM
BeeMan458's Avatar
Liked: 813
My quoted comment was humor. I wouldn't be in a hurry to put the LV12R against better quality subs as yes price/performance does limit it's capabilities and yes, one easily could do worse as in my opinion, agreeing with you, the LV12R is the top dog in it's price class.
Old 02-19-2014, 06:22 PM
S Russ's Avatar
I see you've updated your signature :D
PSN: sick_ap2
XBL: Th3Chosen0ne
S Russ is offline
Old 02-19-2014, 07:32 PM
JT78681's Avatar
Liked: 902
Very observant wink.gif but you missed the new avatar :|
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 02-19-2014, 08:28 PM
BeeMan458's Avatar
Liked: 813
Mmmmmmmm! Rythmik FV15HP. Mmmmmmmm!
Old 02-19-2014, 09:45 PM
rak306's Avatar
Quoted: 416 Post(s)
Liked: 154
on the rythmik site, the 8" custom install kit is listed as "Four DS800-3 drivers and two HX300 in sealed configuration for a pair of subwoofers after discount", shouldn't that be "... two HX600 .."
rak306 is offline
Old 02-19-2014, 09:51 PM
rak306's Avatar
Quoted: 416 Post(s)
Liked: 154
I mean HX580
rak306 is offline
Old 02-20-2014, 08:07 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 230 Post(s)
Liked: 314
Thanks. Corrected.
Rythmik is offline
Old 02-20-2014, 11:39 AM
robcentola's Avatar
I did it! Just ordered an F12! She's going to be pissed! Well, until she feels the warmth of deep bass!
Site says back-order. Anyone know how long one should expect to wait?
So stoked!
robcentola is offline
Old 02-20-2014, 11:44 AM
Liked: 1133
So stoked!
The F12 Black Oak will be back in stock between the end of March and binging of April. We do have F12 Matte Black in stock, though.
Old 02-20-2014, 12:01 PM
robcentola's Avatar
Oh man. I don't know if I can wait that long :(
I should just go for what's in stock. If I REALLY cared about how it looked, I would of had Salk match my speakers.
This is hard. What to do??????
Old 02-20-2014, 12:09 PM
DonH50's Avatar
Liked: 1333
Patience is a virtue.
Great things come to those who wait.
Nothing great can be had in little time.
Black matte looks good.
robcentola likes this.
DonH50 is offline
Old 02-20-2014, 12:20 PM
robcentola's Avatar
Agreed
Agreed
Agreed
Agreed
Old 02-20-2014, 12:52 PM
AlexanderDelarg's Avatar
Quoted: 151 Post(s)
Liked: 170
My LV12R is matte black and I really like how it looks in my HT.
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | DirecTv | Roku 2 | Monoprice 12AWG |
AlexanderDelarg is offline
Old 02-20-2014, 12:55 PM
BeeMan458's Avatar
Liked: 813
Here's an image of an Oak FV15HP. Maybe someone can post an image of a matte finish.
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
