Official Rythmik Audio Subwoofer thread - Page 527 - AVS Forum | Home Theater Discussions And Reviews
 3381Likes
post #15781 of 28190 Old 05-29-2014, 02:59 PM
JT78681's Avatar
Quoted: 1382 Post(s)
Liked: 912
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #15782 of 28190 Old 05-29-2014, 03:09 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
Originally Posted by JT78681 View Post
It gets pretty crazy, I've performed a few REW test tone sweeps and with just the two going I've hit 120dB @ 15hz eek.gif
jbrown15 is offline
post #15783 of 28190 Old 05-29-2014, 03:11 PM
JT78681's Avatar
Liked: 912
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #15784 of 28190 Old 05-29-2014, 03:14 PM
coli's Avatar
Quoted: 203 Post(s)
Liked: 42
Got my F12G delivered today!
First impressions:
This thing is infinitely easier to handle than the F15 due to the lighter weight.
Very easy to take it out of the box!
Of the 4 screw in base, only 1 is straight, 2 are slightly off, while 1 is very off. I had to use a hammer on the spike to make it mostly straight. The feet better not fail on me in the future...
coli is offline
post #15785 of 28190 Old 05-29-2014, 03:19 PM
JT78681's Avatar
Liked: 912
First impressions:
You should let Brian know about that.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #15786 of 28190 Old 05-29-2014, 06:08 PM
steveting99's Avatar
Quoted: 1804 Post(s)
Liked: 616
Great to hear that you've got your F12G. So far, the count is 2 as far as the number people who's got F12G. Still waiting for mine...
How does it sound compared to your previous Rythmik F15 sub? Planning to use both would be an interesting combination. I assume you got the F12G because you wanted to cross over at a higher frequency with your KEF LS50s in direct mode? I've got the E301s and they seem to do better with a high cross over as well. Manual says start from 90Hz... rolleyes.gif
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #15787 of 28190 Old 05-29-2014, 06:46 PM
coli's Avatar
Quoted: 203 Post(s)
Liked: 42
It'll be a few days before I can comment on the sound. Also, since the room is now much larger, it's probably not directly comparable.
I bought based on Danny's supreme confidence on audio circle that a lighter cone just sounds better wink.gif I will find out.
coli is offline
post #15788 of 28190 Old 05-30-2014, 12:51 PM
Maccur's Avatar
Quoted: 22 Post(s)
Liked: 31
Anyone have experience with the F15HP? I'm looking to upgrade from a velodyne HGS 10 series II. I listen to a good deal of music and music DVDs. But also want to increase my thump for movies.
Maccur is offline
post #15789 of 28190 Old 05-30-2014, 02:39 PM
gmclor's Avatar
I just received two of the F15HPs one week ago. I think they're awesome! I've still got some experimentation to do to get them ideal, and they're not broke in yet either. The heartbeat from Dark Side was incredible (as was the rest of the album). Movie wise, I've run them with Horton Hears a Who, and Frozen both of which had some spectacular rumble and boom.
I'm coming from a single 8" sub though, so it's night and day for me. I have no experience with your HSG...
My room is 19 x 19.5 x 9.5 with a large side opening to another huge area. What size room are you dealing with?
gmclor is offline
post #15790 of 28190 Old 05-30-2014, 03:08 PM
Maccur's Avatar
Quoted: 22 Post(s)
Liked: 31
Thanks for the reply. The living room is about 22 x 13, with a 10 x 10 area off one of the long walls. Ceiling is 8 feet.
Maccur is offline
post #15791 of 28190 Old 05-30-2014, 06:07 PM
JT78681's Avatar
Liked: 912
I think I might roll the dice on an Onkyo 818 just for XT32. I'll hold on to my current Denon just in case the Onkyo gives me any fits. Both subs are equidistant to the MLP, so sub eq isn't necessarily needed and the 818 pumps out more wattage than my current receiver. It will be half the price of the higher tier receivers I'm interested in getting.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #15792 of 28190 Old 05-30-2014, 07:45 PM
tvuong's Avatar
Quoted: 1578 Post(s)
Liked: 911
^^ are you sure that's what you want to do? Wattage is not a spec I want to use to make decision on a receiver. Are you going to ask yourself what if I got that x receiver with subEQ? Knowing you, you will smile.gif honestly, I wouldn't do that. It's too much of a lateral move. Buy it once and buy it right the first time. You know that.
tvuong is offline
post #15793 of 28190 Old 05-30-2014, 08:00 PM
JT78681's Avatar
Liked: 912
I hear ya it's just a substantial increase in price. Pretty much double. My goal is XT32 and this seems like the most cost effective route.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #15794 of 28190 Old 05-30-2014, 08:05 PM
tvuong's Avatar
Liked: 911
^^ you upgraded to the FV which is more than double the LV12, then add another FV so double your avr budget is nothing in comparison. I would keep your Denon and add a miniDSP. You should be happy with that combo.
tvuong is offline
post #15795 of 28190 Old 05-30-2014, 08:10 PM
coli's Avatar
Quoted: 203 Post(s)
Liked: 42
So I currently have the F12G right behind me, after XT32, the integration with the front 2 speakers is basically perfect. There is no localization of the sub at all. This is with a 100hz crossover too picked by the avr...
coli is offline
post #15796 of 28190 Old 05-30-2014, 11:18 PM
Exclusively Servo
Rythmik's Avatar
Quoted: 247 Post(s)
Liked: 333
I do like lighter cone drivers. But a lot of members on this forum will tell you that cone mass does not matter. I guess they got the idea from cars that cars with heavier weight may have the same handling as lighter cars. But what they haven't thought is "weight" is relative. Try put 3 heavy guys in the back seat and then try the handling again. It always becomes worse. If adding weight can make handling worse, what happens when the weight is actually reduced?
Rythmik is offline
post #15797 of 28190 Old 05-31-2014, 04:24 AM
Avgass's Avatar
Liked: 35
There are a couple of articles floating around on the subject. It's more likely the guys who think cone mass is not related to speed found these to be convincing. I must admit I had always thought light=fast as this seems intuitive, but the science posited would suggest that light only really equals efficient. I'm open to being schooled otherwise. The reading I've come across on the topic...
http://www.diy-audio.narod.ru/litr/WooferSpeed.pdf (old)
or
http://www.planetaudio.com.au/articles/the-fast-bass-experiment-are-heavy-woofers-slow/ (new)
Avgass is offline
post #15798 of 28190 Old 05-31-2014, 06:54 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 247 Post(s)
Liked: 333
or
Audio has a long history and some very historical discussion were lost. For instance. I had a collection of Speaker Builder magzine when I was younger. I had read them more than 5 times. Later I begin to read AES and I threw those magzines away when I moved to a new house. One of the articles (date back 80's) was companies like SEAS or Scanspeak have this practice that their midrange driver and their midbass/bass driver are often introduced as a family. If you look at the spec, the cone material is the same, the basket is same, the only thing different is cone mass (when I say cone mass it is cone plus voice coil, there is no point of using feather weight cone mass and then put a ton of weight on voice coil) plus other thing. If they use both drivers in "midrange application", it was found the midrange driver always sound better than the midbass/bass driver used as midrange driver. THIS FACT is amusing because people from different background of training tried to explain this from different angles. People don't know eletronics will see it as "energy storage" and less weight is less energy storage . Those with eletronics background will say lower mass means low Q and lower Q means less ringing (if there is no ringing then it means shorter RC time). Those with servo background will say it has a better Mms/(BL)^2 vs inductance ratio and therefore better "cone control" (which means you can improve sound by reducing cone mass, or increasing BL value, or reducing inductance). But they are all the same thing, one related to another, but different angles.
BTW, today, I have forgotten most articles I read from Speaker Builder magzine, but that article with real world experiment is different.
Rythmik is offline
post #15799 of 28190 Old 05-31-2014, 07:00 AM
JHAz's Avatar
Quoted: 306 Post(s)
Liked: 271
or
that's pretty much it. the reason a 911 is faster than a much lighter go-kart is because of the size of the motor. Heavier cone needs heavier everything - voice coil, spider, former, and all that weight needs(or is part of) a bigger motor to make it move fast, and then you need more power to the motor, but it'll move plenty fast enough. If not it will go nonlinear (not louder enough) at the loud end of it's power capability. It won't "slow down" and start playing a 50 Hz tone instead of a 30 Hz tone.
FWiW, a million years ago when I was into car audio (although I was still looking for sorta-audiophile, not just huge bass sound) a guy posted that he installed a 15 in a box and ran his entire sound mono into the sub. No woofers/mids, no tweeters. Sounded fine to him. Probably rolled off severely above 3KHz or so, probably had a huge peak right below the rolloff, but he didn't care. Still could hear the cymbals and sibilants up in the 2K to 5 KHz range adequately. While it wasn't moving as far for the highs, that woofer (like a guitar amp speaker) was moving 25 times faster at 5KHz than at the top of a reasonably extended sub band at say 200 Hz (at least at the same voltage input, aiui)..
JHAz is offline
post #15800 of 28190 Old 05-31-2014, 08:23 AM
DonH50's Avatar
Quoted: 1870 Post(s)
Liked: 1396
The "heavy" vs. "light" cone debate has been around forever. It is one parameter among many, and must be balanced appropriately. In addition to the inertia and driving force required, there are other things like thermal distortion and cone distortion (cone flexing in response to drive and air pressure). Extreme examples can help illustrate the latter: a cone made from a sheet of paper is very light but will flex (distort) if you blow on it hard let alone drive it by a decent amplifier. A cone made of concrete or thick lead would not flex under any conceivable driving force but moving the thing would be almost impractical and controlling its movement an extreme challenge. In between we have the reality of design trades leading to practical drivers. All about balance, or optimal trades among compromises...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #15801 of 28190 Old 05-31-2014, 08:39 AM
coli's Avatar
Quoted: 203 Post(s)
Liked: 42
Alright, got the F12G-SE setup properly with placement and XT32. The sub is behind me. Couple observations:
Integration with the speakers is perfect. No localization whatsoever at the listening position. What subwoofer? LOL
Definitely got a lot less <20hz output than the F15 according to UMIK measurement, as expected. Higher measured distortion down there as a result.
Spikes definitely reduce distortion, especially >40hz. As expected.
Sub can rattle with the spike on tile, especially doing noise test. Sandbag solves everything here.
The enclosure vibration was quite a lot compared to the F15, the enclosure strength doesn't seem to be sufficient when running the AVR's 75db noise...
I kinda wish there's feet base on the amp side, so I can experiment with upward firing placement... Also, Brian, you need better quality control for the feet base/screw-in, they are not leveled enough and they need to be screwed/glued in themselves to the enclosure. I had to "pull" a base out a bit...
coli is offline
post #15802 of 28190 Old 05-31-2014, 08:39 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 247 Post(s)
Liked: 333
Don, I agree. However, I am just surprised that people investigate the problem using the wrong methods. For instance, some look at impulse response. But impulse response is same frequency response (or step response). I have a DSP system that converts frequency response (with phase) to impulse or backward. If the article author wanna see the impact of cone mass to impulse response, he may just use frequency response and make the article shorter. The difference of these mass difference is very subtle and yet look at all the speaeker measurement with noisy background and poor resolution. That is why we keep going back to the same conclusion -- there is no difference.
Rythmik is offline
post #15803 of 28190 Old 05-31-2014, 08:41 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 247 Post(s)
Liked: 333
Sorry about that. I will discuss this with supplier.
Rythmik is offline
post #15804 of 28190 Old 05-31-2014, 10:35 AM
Jahjd2000's Avatar
Quoted: 48 Post(s)
Liked: 79
I moved the E15HP to the left side of my media console, which took care of a null in the 50-60 region that existed when the E15 was corner loaded. I watched a few movies last night and bass was solid (I'd recommend Lone Survivor if you haven't seen it yet.--great movie and impressive bass track).
This graph reflects: Audyssey on , dynamic EQ and volume off, no smoothing, and speakers off.
Based on my graph above, do you think I would benefit from a mini DSP? I'm planning to add at least another E15HP...assuming it would further smooth my FR and provide additional headroom.
Dolby Atmos 5.1.4
Denon x6200
Ascend Acoustics Towers and Horizon Center (NrT)
RSL 34CE in-ceilings (4)
Rythmik E15HP
Jahjd2000 is offline
post #15805 of 28190 Old 05-31-2014, 11:14 AM
DonH50's Avatar
Liked: 1396
Thanks, hard to imagine something we would not agree on, Brian! Except maybe living in CO vs. TX... smile.gif
I have done impulse and frequency response testing on speakers but I think frequency response and large-signal testing (sweeps and checking distortion at various frequencies over various drive levels) is most revealing. For a system, I like using impulse response to check overall time/phase results (but little else, maybe check for ringing), but for an individual driver find it interesting but not terribly useful. It presents a driver with way more bandwidth than seen in an actual system and tends to be much more stressful (and unrealistic) than frequency response/distortion testing. And, going back and forth from time to frequency domain is easy with a DSP, but when measurements are involved it gets real tricky real fast. Aliasing, frequency binning, record length, resolution (in time and amplitude), etc. are all considerations it could take a PhD to understand completely. Fortunately for all of us, you just happen to have one... biggrin.gif
I agree that making measurements on speakers is very challenging. You know all this, but you need very wide dynamic range instruments and microphones, and some way to ensure the results are from the driver/speaker and not the mic, preamp, etc. We are lucky to have an anechoic chamber available at a local university and though I am not a speaker designer it is nice to know it is there. For most folk, a fast (gated) measurement at close range is about the best that can be done. Until you hit fairly high levels of distortion it is probably hard to see much, and the average person is unlikely to be able to determine the influence of cone mass vs. other variables. Pretty sure I could not, simply not something I have done (at least not for decades, since B&W did their laser interferometry studies of cone modes, something we also explored in my graduate acoustic courses). Those types of analysis clearly show the impact of cone material on performance but are not the sort of thing most of us can do at home.
DonH50 is offline
post #15806 of 28190 Old 05-31-2014, 09:28 PM
coli's Avatar
Quoted: 203 Post(s)
Liked: 42
Measurements are useful to a degree, however, I have not been able to find a measurement for imaging/openess. These tends to be very important with music. XT32 does nothing to help in this area. The only thing that helps is placement and toe-in. The difference is night and day, yet you won't see it in frequency response, phase, nor distortion charts...
Nowadays, I trust my ears over measurements.
enricoclaudio likes this.
coli is offline
post #15807 of 28190 Old 05-31-2014, 09:50 PM
darkhobbit's Avatar
My F25 arrived today and all I can say is wow. The people in this thread seem to be fixated on the FV15 HP, which is great sub, but the combination of power and the defined sound of a sealed box that the F25 delivers are something else entirely. Though the footprint is notable, which I liken to having a mini-fridge in the living room, it is well suited to the level of clean bass that this sub effortlessly dishes out. I'm amazed the F25 hasn't received more exposure. As much as you all cherish your FV15 HPs, the F25 is something that should not be overlooked, especially considering the recent amp upgrade that is now stock with the unit.
darkhobbit is offline
post #15808 of 28190 Old 05-31-2014, 10:04 PM
Prime316's Avatar
Quoted: 179 Post(s)
Liked: 204
Yeah, the gushing over the FV15 does go way overboard a lot around these parts. I'll bet it is a great sub but there are many others out there also.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 2
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #15809 of 28190 Old 05-31-2014, 10:12 PM
basshead81's Avatar
Quoted: 191 Post(s)
Liked: 5466
I am going out on a limb, but the fact that the F25 is out of stock more then it is available probably has something to do with it no?
JT78681 likes this.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #15810 of 28190 Old 05-31-2014, 10:28 PM
darkhobbit's Avatar
That could have something to do with it. I waited 2 months until mine arrived, but it was well worth the wait. The clear output of this unit when set to high damping (Q of .5) is unreal. I've never experienced a sub that hit notes as cleanly and effortlessly as this one does at high volume. The sound quality of Rythmik's sealed subs has been praised heavily on this thread. The F25 offers that quality and packs significant output to boot. It's the best of both worlds, and I simply could not be happier with this sub. Anyone interested in a higher end Rythmik sub that has the space should seriously consider the F25. The high damping will blow your mind in a completely different way than the +2db gain in volume that the FV15HP offers.
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
