Official Rythmik Audio Subwoofer thread - Page 531 - AVS Forum | Home Theater Discussions And Reviews
 3188Likes
post #15901 of 27836 Old 06-09-2014, 10:02 PM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
No SQ differences. The F15's cost a little more, are a little larger, and play a little louder. If you've the room and budget I'd just get the F15's. That said, my room is similar in size and my pair of F12's is more than adequate to induce panic attacks.
johnnymacIII likes this.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #15902 of 27836 Old 06-09-2014, 10:42 PM
johnnymacIII's Avatar
Quoted: 160 Post(s)
Liked: 51
Thanks for the quick reply, Don.  I'm going to go with the F12s.  I could use the extra room and the $200 can go toward DIY absorption panels.
johnnymacIII is offline
post #15903 of 27836 Old 06-10-2014, 02:25 AM
rcohen's Avatar
Quoted: 1208 Post(s)
Liked: 518
Output differences with various models:
http://www.rythmikaudio.com/products1.html
It does matter, IMO.
rcohen is online now
post #15904 of 27836 Old 06-10-2014, 12:34 PM
DonH50's Avatar
Liked: 1325
Of course it does, if you need the higher output. In this case the room is not large, is sealed, he's putting in two subs, and the difference in output between the F12 and F15 is only 2 dB. I suggested F15's but I would not hesitate to pick up a pair of F12's and apply the difference to room treatment. I do not subscribe to "the biggest sub wins" school of thought. The F15's were too large for my setup and I am nowhere close to exceeding the output of my F12's.
Your Mileage Will Vary - Don
realjetavenger likes this.
DonH50 is offline
post #15905 of 27836 Old 06-10-2014, 02:09 PM
Quoted: 160 Post(s)
Liked: 51
After calling Rythmik and explaining my scenario, I was reassured that 2 f12s would be more than enough.  The guy I spoke to said that he had a 3000 cubic foot room and 2 f12s.  He set his dial just under the halfway point and his receiver still knocks it down -12.  He told me that 2 f15s would be overkill.
It's nice to see a company not try to sell you something you don't need.  I was also told that I will get a 10% discount for ordering 2 subs.  Very nice.  Unfortunately I will have to wait 'till the end of July to get the black oak though.
post #15906 of 27836 Old 06-10-2014, 02:34 PM
enricoclaudio's Avatar
Quoted: 1101 Post(s)
Liked: 1127
Yes, that was me. I'm running two F12SE's in a 2800 cf room. Volume in the subwoofers is set at 11 and Audyssey still setup levels at -12. I like to run my subwoofers hot so I set the level in the receiver at -6, so even that I still have plenty of headroom to work with.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #15907 of 27836 Old 06-10-2014, 07:22 PM
Quoted: 160 Post(s)
Liked: 51
Thanks again Enrico.  I appreciate the quick call back.
post #15908 of 27836 Old 06-10-2014, 09:07 PM
DonH50's Avatar
Liked: 1325
DonH50 is offline
post #15909 of 27836 Old 06-11-2014, 06:41 AM
JT78681's Avatar
Quoted: 1376 Post(s)
Liked: 899
I wonder what Brian's best seller is to date since Rythmik opened. rolleyes.gif
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #15910 of 27836 Old 06-12-2014, 08:59 AM
JT78681's Avatar
Liked: 899
Has anyone tried applying a boost to the low end using the PEQ on the amp itself? Any tips or advice would be much appreciated.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #15911 of 27836 Old 06-12-2014, 09:08 AM
Liked: 1127
Sometimes I do a 60Hz boost (+1.5dB) using the PEQ. The PEQ in my subwoofers is already set at 60Hz, +1.5dB and mid Bandwidth. It's OFF most of the time but I like to turn it ON when listen to jazz and Latin music. It give you a little extra punch on percussion and drums
post #15912 of 27836 Old 06-12-2014, 09:21 AM
JT78681's Avatar
Liked: 899
How do you know on the knob what frequency you are setting the boost to as there are no numbers? Same with the gain I believe. I'm trying to figure out the best way to only boost the low end say +6db 30hz down.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #15913 of 27836 Old 06-12-2014, 09:39 AM
Liked: 1127
Every dot on the frequency knob is 10Hz. Starting from 20Hz the next dot clockwise is 30Hz and the one at 12 o'clock is 40Hz.
The max you can boost is +3dB (PEQ Gain knob at 7 o'clock) and the max you can cut is -12dB (PEQ Gain at 5 o'clock)
post #15914 of 27836 Old 06-12-2014, 09:49 AM
tvuong's Avatar
Quoted: 1544 Post(s)
Liked: 875
^^ what about the bandwidth knob, Enrico? What is the Q range from min to max?
tvuong is online now
post #15915 of 27836 Old 06-12-2014, 10:13 AM
JT78681's Avatar
Liked: 899
What frequency range do you have your low shelf filter boost applied to again?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #15916 of 27836 Old 06-12-2014, 10:17 AM
JT78681's Avatar
Liked: 899
If I wanted to apply a +3db boost 30hz and under what whould I set the bandwith to? Also, if after Audyssey calibration I boost the sub trim +3db and then apply this boost 30hz and down will that essentially give me a +6db boost under 30hz and only +3db above that? Sorry for the redundancy!
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #15917 of 27836 Old 06-12-2014, 10:21 AM
tvuong's Avatar
Liked: 875
I have my low shelf centered at 60hz with 6db boost since it is a gradual rise. So it rises a little at 60 from flat then reach 6db rise down low to 10hz in my room. The Q value determine the slope of the rise which is why I asked Enrico about the Rythmik bandwidth knob.
post #15918 of 27836 Old 06-12-2014, 11:52 AM
Liked: 0
Hi,
I am trying to figure out the subbage I need for my large room. It is approx 5400 cf and in my walkout basement (cement floor). My history of subs I have tried in this room include the following (in order):
  • One F15 (I loved the sound for music - but the output was a bit weak for HT)
  • Two SVS PB12s (the output wasn't bad - but the sound was not very detailed compared to the F15)
  • Various other choices (many I shouldn't have tried) that didn't work
  • Two LV12Rs (better output than the one F15 - and better sound for music than the SVS PB12s. However, to make them sound best for music, I lose the depth).
I am sold on the sound, quality, and customer service of Rythmik. My first thought was two D15SEs, They look nice - and would sound like the F15 - but I would have 2 of them. If not sufficient, I could go with dual F15HPs. However, the price starts to get up there. I know that one FV15HP would provide more output than any 2 sealed subs. I am just not sure if it would satisfy me for music - and if one would be enough for my room (most say you need two subs to even out the response in sich a large room).
I talked to both Enrico and Brian both before and after my purchase of the LV12Rs. While they were supportive of dual sealed subs in the past, they both seem to favor one FV 15Hp at this point.
I spend most of my time listening to music - mostly jazz lately. My TV and HT watching is not a high percentage - maybe 30 to 40%. I find sound quality the nost important. while I need enough output - I am not one who plays at extreme levels. My setup consists of an Onkyo 5009 receiver and Def Tech BP8060s with matching center and surrounds.
Any help is appreciated!
JRMNorth is offline
post #15919 of 27836 Old 06-12-2014, 12:45 PM
DonH50's Avatar
Liked: 1325
By "lose the depth" do you mean they (the pair of LV12R's) do not sound as low? They go pretty deep, so I suspect placement may have more to do with it than their -3 dB corner.
The room is a big factor in output over frequency, and sub placement a big factor in what and how you can compensate for the room.
DonH50 is offline
post #15920 of 27836 Old 06-12-2014, 12:50 PM
tvuong's Avatar
Liked: 875
I would go ported in your room size and probably the reason Rythmik recommended the fv15hp. I don't use mine much for music but when I do, they sound fantastic. Since you like the sound of the lv12r, the fv15hp will serve you as it has more output than the dual lv and has the same sound quality if not better.
post #15921 of 27836 Old 06-12-2014, 01:48 PM
JT78681's Avatar
Liked: 899
I'm thinking about trying out the Anti-Mode 8033S-II. Seems like it's a solid EQ for one or multiple subs and it will automatically apply boosts at different frequencies if you desire. What do you guys think?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #15922 of 27836 Old 06-12-2014, 01:59 PM
tvuong's Avatar
Liked: 875
^^ from what I read and seen graphs, xt32 with subEQ is better than antimode. MiniDSP is usually recommended.
post #15923 of 27836 Old 06-12-2014, 02:18 PM
JT78681's Avatar
Liked: 899
Well if this is the case then I might as well save my coin for a new receiver. It's between the Denon X4000 and Onkyo TX-NR1010. I know the Denon is a fantastic receiver, but I know the Onkyo is too. Just not sure if the X4000 is worth $200 more than the TX-NR1010.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #15924 of 27836 Old 06-12-2014, 03:42 PM
tvuong's Avatar
Liked: 875
^^ I buy the Onkyo for $200 less.
post #15925 of 27836 Old 06-12-2014, 06:23 PM
badgerpilot's Avatar
Quoted: 73 Post(s)
Liked: 43
Get the Onkyo. I just replaced my TXNR1007 with the TXNR3010, love it!
badgerpilot is offline
post #15926 of 27836 Old 06-12-2014, 07:23 PM
Liked: 0
I appreciate all of your suggestions.
To respond to DonH50s question - the two LV12Rs do not go as deep as the F15 I previously had. I had the F15 set to 14hz - so that is expected. I just miss the deep bass it provided. I expect the FV15HP will come close. I was mostly wondering if one FV15HP would be able to provide fairly even bass in such a large room. Or, if two subs would be needed.
John
JRMNorth is offline
post #15927 of 27836 Old 06-12-2014, 08:29 PM
DonH50's Avatar
Liked: 1325
If one sub did not before, a bigger one will not now. "Even bass" depends more upon the room and subwoofer placement than the sub itself.
DonH50 is offline
post #15928 of 27836 Old 06-12-2014, 09:26 PM
steveting99's Avatar
Quoted: 1785 Post(s)
Liked: 612
JT78681,
Be aware that Onkyo has had a history of HDMI issues. There is a thread for the TX-NR1010 at AVS: Onkyo TX-NR1010
While not well documented, the TX-NR1010 seems to have sub EQ HT which is great.
I'm just concerned about the reliability of Onkyo's at the moment. If you end up with a lemon at great discount, it's still a lemon at the end.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #15929 of 27836 Old 06-12-2014, 10:35 PM
Exclusively Servo
Rythmik's Avatar
Quoted: 230 Post(s)
Liked: 314
John
Indeed, the extension and damping control of LV12R is not same as F15 or FV15HP. To get high damping, the extension will give up 2hz or so. John must have very good memory of how F15 sounded with 14hz extension. It means the choice is either FV15HP use 1 port set to 14hz high damping to get as close to F15 14hz high damping as possible, or get two F15HP (less cost effective).
Rythmik is offline
post #15930 of 27836 Old 06-12-2014, 10:38 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
Have you cosidered a F25 since majority of your listening is music? This setup will give you the most headroom above 40hz and still offer good deep bass performance. I believe the FV15hp would have the advantage below 20hz, but still should have good output down low. If you were more into HT I would say FV15HP all day in that size room and still may not be a bad idea just in case you start enjoying more blu ray tracks.
JT78681 likes this.
basshead81 is offline
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
