Official Rythmik Audio Subwoofer thread - Page 542 - AVS Forum | Home Theater Discussions And Reviews
 3585Likes
post #16231 of 28699 Old 07-07-2014, 07:44 AM
basshead81's Avatar
Quoted: 216 Post(s)
Liked: 5865
You are not handicapping anything...if the surge can not keep up it will trip. I run all 3 of my subs on individual rat shack surge strips with no issuse even at spirited levels(128db).
basshead81 is offline
post #16232 of 28699 Old 07-07-2014, 07:55 AM
JT78681's Avatar
Quoted: 1411 Post(s)
Liked: 933
This is what I figured. Thanks for chiming in.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #16233 of 28699 Old 07-07-2014, 09:24 AM
JT78681's Avatar
Liked: 933
Originally Posted by purplerain View Post
You should have the sub(s) plugged into its own outlet and its own surge protector....
Spoke directly with Rythmik for the answer.
Sorry just now saw this. Very interesting. Did they say why?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #16234 of 28699 Old 07-07-2014, 09:34 AM
purplerain's Avatar
Quoted: 42 Post(s)
Liked: 27
The surge protector has to have the power to handle the sub that you are using. When I called, I told them about my single FV15HP and how I wanted it protected. They advised me on having it plugged into its own outlet and making sure the surge protector you get, is the fit (power handle) for your sub (if you so chose to use one). The Panamax model I picked, was specifically for that purpose.
*ENTERTAINMENT PURPOSES ONLY - PIONEER KRP-500M*
(2) Monitor Audio RX6 towers - (1) Monitor Audio RX center - (2) Monitor Audio RX FX surrounds - (1) NAD T758 AVR - (1) Velodyne Optimum 8 Sub
purplerain is offline
post #16235 of 28699 Old 07-07-2014, 05:09 PM
B0dyK0unt's Avatar
Just trying to do some prep before my new fv15hp shows up so I can hit the ground running. Should I be starting my initial setup using the LFE input, or should I plan on starting with line in inputs (and if line in, just use either left or right or get a 1female-to-2male adapter and use both). I found a rythmik install guide URL, but it actually just said to do either (did not mention preferred)... Figured I'd ask what most folks do. I'm sure I'll have more questions, but thought I'd start there in case I need to buy the adapter before the sub gets here.
If it matters, my mains are PSB image t6 and center PSB image c5 and nth subzero surrounds. I am thinking crossover will be around 60 or 80 hz across the front and probably 80 in surrounds and wides.
Thx.
B0dyK0unt is offline
post #16236 of 28699 Old 07-07-2014, 07:34 PM
tvuong's Avatar
Quoted: 1629 Post(s)
Liked: 958
^^ I use this long Y cable. They also have 6 and 15' long
http://www.amazon.com/gp/aw/d/B00DI8...110_SY165_QL70
I would use line in in your case starting out with phase knob at zero, crossover at 80hz
Edit: now that I am thinking about the LFE .1 channel from movie sound track can go up to 120hz, not sure if crossover at the Rythmik sub needs to be at 120hz?
tvuong is offline
post #16237 of 28699 Old 07-07-2014, 07:37 PM
B0dyK0unt's Avatar
Thanks. Will give it a shot.
post #16238 of 28699 Old 07-07-2014, 08:08 PM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
If you're going to use your AVR for bass management, LFE bypasses these unnecessary controls. There's an additional difference between using line-in and LFE, but I don't recall what it is. My impression is most folks are using their AVRs for bass management and using LFE-in, am I mistaken about that?
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
post #16239 of 28699 Old 07-07-2014, 08:18 PM
B0dyK0unt's Avatar
For clarification, I will be using the AVR bass mgmt (an onkyo 818). Using LFE in vs Line in on the fv15hp seems to still be up in the air.
post #16240 of 28699 Old 07-07-2014, 09:52 PM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
According to Rythmik, "The trade-off between using LFE IN and LINE IN (with AVR/12 LPF switch position) is the perceived background noise level." I wonder if Brian could clarify this, i.e. why do the two vary in perceived background noise, which has higher background noise, and is there some distinction between *perceived* background noise and actual background noise?
Apologies if this has already been answered earlier in this voluminous thread--if so, maybe someone else can share the answer?
Rythmik FV15HP sub
niccolo is offline
post #16241 of 28699 Old 07-07-2014, 10:15 PM
steveting99's Avatar
Quoted: 1835 Post(s)
Liked: 633
B0dyK0unt,
I use the LFE input on the PEQ3 amp because there is more flexibility with crossover settings. This proved to be useful when dialing in to get the smooth transition at the crossover. Somewhere in this massive thread, Brian has mentioned that the range of LFE input is greater than the line in. By memory, the line in is limited up to 80Hz while the LFE can go up to 200Hz crossover.
The simple logic is that more flexibility the better.
Engaging the LFE input also ignores the line in (believe it was mentioned in previous posts). The only reason I can think of using line in is in pure direct mode by the AVR. In this mode of operation, there is no bass management being carried out and the full signal range is being sent to both the power terminals and pre-out terminals. As my front left and right has limited output in the low frequencies and I'd want to pass this over to the Rythmik sub, I'd then use the line in and set the crossover, phase accordingly. I'm planning to try out this experiment sometime latter on.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #16242 of 28699 Old 07-07-2014, 10:41 PM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
Originally Posted by steveting99 View Post
B0dyK0unt,
My understanding is that line-in activates the redundant equalization controls on the sub amp that are normally taken care of by the AVR, provides a greater potential frequency window for the sub as you suggested, and according to Brian, has some effect on perceived background noise, though what or by what mechanism or why *perceived* isn't clear to me, I imagine Brian will clarify shortly.
Rythmik FV15HP sub
niccolo is offline
post #16243 of 28699 Old 07-08-2014, 05:38 AM
JT78681's Avatar
Liked: 933
Use LFE. Let your receiver do it's job and take care of the cross-over, bass management etc.......
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #16244 of 28699 Old 07-08-2014, 05:51 AM
JT78681's Avatar
Liked: 933
Also, guys don't be afraid to play around with the PEQ on the amp. I am currently running single port mode 14hz/low dampening with a 3db boost at <60hz. Simply put it sounds amazing. If your room is large and open try out two port mode if your only running a single FV15HP. The increase in bass is noticeable versus one port mode.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #16245 of 28699 Old 07-08-2014, 06:35 AM
tvuong's Avatar
Liked: 958
One still can use bass management from the avr when sub line in is used. Be aware that Line in activates the phase and crossover knobs. I have heard that using line in has cleaner signal pass thru and that one can adjust the phase/crossover if needed after auto calibration.
tvuong is offline
post #16246 of 28699 Old 07-08-2014, 11:26 AM
DonH50's Avatar
Quoted: 1917 Post(s)
Liked: 1447
Line in adds another gain stage for the filter and thus increases the noise slightly. I cannot hear any difference at my LP but I suppose you might if you stick your ear at the sub...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #16247 of 28699 Old 07-08-2014, 11:29 AM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
Interesting, I thought it must be the other way around, since Brian suggested experimenting with line-in in lieu of LFE (even if one is using AVR bass management and crossing over low, as I am).
Rythmik FV15HP sub
niccolo is offline
post #16248 of 28699 Old 07-08-2014, 11:55 AM
DonH50's Avatar
Liked: 1447
Line in allows you to add another crossover, increasing the slope (out of band rejection), and fiddle with the phase in case the AVR did not get the delay right to line the signals up (in phase) at the crossover frequency. Those circuits add noise (and distortion), though I think the added noise/distortion is in the mud. With your ear at the sub you might hear a little more hiss. Hard to tell at my age. I can't hear any difference in the noise floor at the listening position.
post #16249 of 28699 Old 07-08-2014, 01:39 PM
B0dyK0unt's Avatar
Thanks all. Sounds like I will start with the LFE input, but can play around with Line In if I dont get good results (although, I know myself, and probably wont completely rest until I try both).
post #16250 of 28699 Old 07-08-2014, 08:10 PM
Exclusively Servo
Rythmik's Avatar
Quoted: 261 Post(s)
Liked: 357
Noise and distortion are also affected by bandwidth. The noise can come in at active devices (like OP amps), passive devices (like resistors with thermal noise), and even interconnect. Distortion is mainly generated by active devices. All of these are used in AVR, subwoofer, and the interconnect between them. So having a wider bandwidth on the subwoofer may not be a good thing. So instance, if there is distortions created by circuitry after the DAC inside AVR, or noise picked up by the interconnect that falls into the frequency band say, between 100hz and 300hz, the line-in signal path will filter them out while the LFE in will not. BTW, most customers may not noitce this subltey while others may. Therefore I encourage everyone to try both.
Rythmik is offline
post #16251 of 28699 Old 07-08-2014, 09:02 PM
tvuong's Avatar
Liked: 958
There is a conflict in this matter. I read Brian's comment as LFE input is not as good as line in. The question I had was if line in was used with a sub 80hz crossover, what happens to 81-120hz from the LFE channel from a movie sound track? Am I losing those frequency content? I assume yes?
tvuong is offline
post #16252 of 28699 Old 07-09-2014, 05:16 AM
JT78681's Avatar
Liked: 933
This is what I would assume too based on Rythmik's website. Non issue for me because I use LFE.
Frequency Response 14 - 200 Hz (-2 dB @ 17 Hz, -6db@14hz) with LFE inputs 14 - 90 Hz ((-2 dB @ 17 Hz, -6db@14hz) with LINE IN inputs
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #16253 of 28699 Old 07-09-2014, 05:27 AM
DonH50's Avatar
Liked: 1447
Whether LFE is better than line in or the other way around depends upon the AVR and overall SINAD (signal to noise and distortion) performance of the chain. Without a lot more knowledge it is impossible to say which is better in any given case. IMO it does not really matter but as Brian says try both and see which you like.
The LFE bandwidth also depends upon the AVR's setting. In practice I am not sure there is much LFE content above 80 Hz; anecdotal evidence from various posts on this site lead me to suspect not much. My very brief trials a few years ago indicated that, for me, rolling off the LFE above 80 Hz did not change the sound noticeably (i.e. I did not notice the change on the few scenes I checked). But, I do not know. If the AVR sends all LFE bandwidth to the subwoofer channel and you roll it off in the sub, then yes that half-octave is lost (note that it will be rolled off over 80 Hz, it does not get chopped off right at 80 Hz). If the AVR is set to roll off the sub at 80 Hz, it depends upon how the AVR handles the LFE content. Again without direct measurements of my own, what little research I have done and reading here on AVS seems to indicate some AVRs redirect the LFE (along with other bass content) above the crossover to the L/R speakers, while other do simply roll it off. Again I do not know for sure. Almost all the diagrams I could find all showed LFE going only to the subwoofer and not to the mains. Some AVRs use a global low-pass setting that rolls off the LFE channel along with the mains; others use a separate LPF for the LFE signal.
As I said, for me the difference between line in and LFE in was not noticeable so, if you are concerned about the higher-frequency LFE content, use the LFE input. Better yet try them both and report what you find. I'd be curious if your findings are the same as mine; I honestly do not know what others might find.
post #16254 of 28699 Old 07-09-2014, 08:03 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 261 Post(s)
Liked: 357
I know several members have mentioned this matter. But when I look at that, I immediately know it is the margin that engineers put in. Whenever possible, engineers always try to design in some margin. When you have a special effect (naturally recorded or synthesized), it will not have a natural bandwdith of 80hz or 120hz. So there needs to be a crossover done on these signals: signals below a particular frequency goes to LFE, the rest goes to other channels (so that we can differentiate if the explosion is from the front or from the back). If it is done correctly, the engineer will pick a crossover point below even say 80hz so that there will be enough frequency band for the response to roll-off (instead of cliff-like roll-off).
Rythmik is offline
post #16255 of 28699 Old 07-09-2014, 04:00 PM
eljr's Avatar
Quoted: 1066 Post(s)
Liked: 8062
when is the F25 due back in stock?
any changes when it is back?
sorry if this has been spoken to already I have not followed the thread.
eljr is offline
post #16256 of 28699 Old 07-09-2014, 04:15 PM
enricoclaudio's Avatar
Quoted: 1190 Post(s)
Liked: 1253
The F25 with dual DS1501 drivers and HX800XLR3 amp will be back in stock by mid August. Also we may bring the H550PEQ3 amp back as an option for the FV15HP.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #16257 of 28699 Old 07-09-2014, 04:28 PM
eljr's Avatar
Liked: 8062
what are the features and benefits of the H550PEQ3 amp if that were to be available as an option?
eljr is offline
post #16258 of 28699 Old 07-09-2014, 04:37 PM
Liked: 1253
Benefits of the H550PEQ3 amp has been discussed in this thread in the past. Check on post #6640
post #16259 of 28699 Old 07-09-2014, 05:06 PM
DonH50's Avatar
Liked: 1447
All the features of the 600, hair less money and a hair less power, but respectively more power supply filter capacitance. I'd choose it.
post #16260 of 28699 Old 07-09-2014, 05:16 PM
eljr's Avatar
Liked: 8062
thank you for the reply
are there any reviews of the f25 that you or anyone else can link me to?
eljr is offline
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
