Official Rythmik Audio Subwoofer thread - Page 544 - AVS Forum | Home Theater Discussions And Reviews
 4704Likes
post #16291 of 30689 Old 07-15-2014, 06:19 AM
JT78681's Avatar
Quoted: 1478 Post(s)
Liked: 1005
Originally Posted by JT78681 View Post
If you can get Audyssey to be at -6 (-5 is fine too if only boosting +4db) after calibration that's perfect. Does it sound good to you boosting +4db to achieve a -1 result after everything is said and done? If so, you should be golden. All that matters when everything is said and done is that it sounds good to your ears. I prefer to take advantage of the PEQ settings on the amp as opposed to boosting in Audyssey after calibration. I have a +3db boost applied at <60hz and bandwith set mid-way. My Rythmik's sound fantastic in my open >6000 cu ft living room.
I lied. I have a +3db boost applied at <80hz.
JT78681 is offline
post #16292 of 30689 Old 07-15-2014, 08:05 PM
Exclusively Servo
Rythmik's Avatar
Quoted: 266 Post(s)
Liked: 365
Originally Posted by niccolo View Post
Sure, the sub sounds great at -1 dB on the AVR and a notch below midnight on the sub gain. But what I'm wondering is if there's any logical way to deduce a sweet spot for the amp setting, e.g. can one generalize about a desirable window? There are various combinations of AVR and sub gain that will yield that same SPL, so I'm looking for some insight into why some might be better than others and which might be optimal.
There is really no standard answer to ths. The reason is there are just too many different choices in each step in the sound reproduction chain: 1) microphones, how many are there, how they are placed? Ambiance microphone?, close-mic, or far mic (I have seen one live concert where one mic is on each drum in the drum set) 2) mixing studio, how they are mixed into two channels, which mic has higher weight/volume?, 3) mastering studio, this is where the determination of what does on to the production version. Engineer can EQ up and down till they feel the sound is near perfect. How do they know the bass is correct? They will basically listening to it in a room similar to yours or mine and make a decision if the bass needs to trim down and 4) finally that sound track is reproduced with your speakers in your room. Each mastering studio have their own winning recipe. In addition, if your system has a pretty wide range of sweet spot, you can vary the bass energy by 6db and still enjoy it (simply because our hearing is least sensitive to bass energy). If the system has very narrow range of sweet spot, then you may even turn up or down bass volume on a track to track basis. Hope this makes you feel better that you can be creative.
Rythmik is offline
post #16293 of 30689 Old 07-15-2014, 10:12 PM
steveting99's Avatar
Quoted: 1840 Post(s)
Liked: 640
^Brian,
Some Rythmik owners have turned their subs on the side such that the fins on the amp are oriented horizontal rather than vertical to allow proper heat dissipation. Recall in previous posts that you were not comfortable with this arrangement and asked owners to take care that their amps don't get very hot, else the protection circuit might kick in.
Is this still the case or the new amps allow for both vertical or horizontal arrangement and still allow heat to dissipate?
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #16294 of 30689 Old 07-16-2014, 12:17 AM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
To be clear, I wasn't asking what the optimal bass SPL is, I was asking how to think about what the optimal of the many AVR and sub gain combinations that yield the *same* SPL might be.
So far, the answer seems to be that, once any desired bass boost has been applied in the AVR, the AVR sub setting should be below zero, but not too far from it. This allows sufficient headroom for the signal output from the AVR to the sub. But assuming that any AVR setting is feasible for a desired SPL (since the sub gain can be adjusted, albeit in steps), it's not clear to me whether -1 is better than -5 is better than -10, for example. Am I being more clear?
niccolo is offline
post #16295 of 30689 Old 07-16-2014, 03:44 AM
Bond 007's Avatar
Quoted: 2627 Post(s)
Liked: 2090
Nothing real complex here. -5 is a happy medium.
Bond 007 is offline
post #16296 of 30689 Old 07-16-2014, 06:04 AM
DonH50's Avatar
Quoted: 2176 Post(s)
Liked: 1765
There are all sorts of trades in optimizing the gain structure of an amplifier chain for noise and distortion. It can get to be a rather hairy analysis for something like the RF to audio chain in a radio, or antenna to display in a radar. In practice, for this application, it really doesn't matter because unless you are at either end of your adjustment range it will sound virtually the same. I would shoot for the AVR's sub trim (level) to be no more than 1/2 the maximum setting or so when set how you finally want the sound and call it done. That is, if the range is +/-10 dB and your setting is someplace within +/-5 dB you'll be fine. If it is +6 or -7 you'll still be fine (note I said said "finally" so that is after you have added any gain to make it "hotter"). I would try to stay 3 dB away from either end to provide at least a little headroom in the level circuits.
IMO - Don
derrickdj1 and Bond 007 like this.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #16297 of 30689 Old 07-16-2014, 07:21 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 266 Post(s)
Liked: 365
-1db to -5db is good. I wouldn't recommend to go as far as -10db. Signal from AVR has a "noise floor" based on which manufacturers measure signal/noise ratio. If you have -10db vs 0db on AVR, it means the former has 10db lower signal to noise ratio. I would assume this has more impact on entry level AVR becasue in order to save money, the designer can even implement that gain stage in digital domain which means the quantization noise can be higher.
Rythmik is offline
post #16298 of 30689 Old 07-16-2014, 06:28 PM
Quoted: 480 Post(s)
Liked: 401
Received my two FV15HPs today and after going through a set of SVS SB13 Ultras and HSU ULS-15s, I must say Rythmik has a winner. These are fabulous subs, just wish I had tried them first (my back is killing me).
Balthazar2k4 is offline
post #16299 of 30689 Old 07-16-2014, 11:13 PM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
Because...?
IMO - Don
What is the range?
Great, appreciate the factual information, i.e. one is trading off signal/noise ratio at the bottom end and headroom at the upper end.
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
post #16300 of 30689 Old 07-16-2014, 11:14 PM
niccolo's Avatar
Quoted: 141 Post(s)
Liked: 39
What did you perceive to be the shortcomings of the other pairs of subs?
Rythmik FV15HP sub
niccolo is offline
post #16301 of 30689 Old 07-17-2014, 04:13 AM
Quoted: 480 Post(s)
Liked: 401
The SB13s produced powerful, punchy bass, but lacked the extension I was looking for. The ULS-15s were punchy and had the deep extension I wanted, but lacked output. The FV15HP even though vented gives me the best of both worlds. It is controlled, powerful, and offers all the extension I need in my room. Love them!
post #16302 of 30689 Old 07-17-2014, 06:53 AM
DonH50's Avatar
Liked: 1765
What is the range?
The range of trim level settings in your AVR.
DonH50 is offline
post #16303 of 30689 Old 07-18-2014, 07:34 PM
98Harley's Avatar
Oh my goodness, I have just got to comment, it's Friday night and I'm watching a movie on cable called Gravity. Now I have never had a sub woofer before, hated that thumping sound I would hear in cars on the street, but after reading here decided to try one of these Rythmik E15's and wow !! I cranked it up and the walls started to shake, paused to fix pictures and then resumed finding my pants vibrating against my legs and I could really feel this movie in my bones, against my skin, totally distortion free and absolutely incredible, it was like a ride at a carnival or something, and unlike anything I have ever experienced before. I really don't know what to say except wow !! and what a difference between reading about this and experiencing first hand.
PS: I got this sub primarily for music and boy does it perform well there, but this movie effect was just astounding and I find it to be so multipurpose full now, just incredible in both realms.
98Harley is offline
post #16304 of 30689 Old 07-18-2014, 08:18 PM
B0dyK0unt's Avatar
Got the fv15hp, but have only had little time to play around with it. Initial feed back is wow! This f'r puts out some bass. I'll be playing around with it for weeks before settling on a setting I am sure. Only tried 14hz low damping one port setting using line in. Have a little bit of subwoofer buzz that I need to figure out (probably some ground loop from what I've read). Also, as for placement, having a couple of spikes/nodes at a couple of frequencies (35 and 55-60) just by trying different spots with Sub crawl, but I'm sure I can figure out what is best after tweaking. I was dorking around with the phase knob on back, and had a question...... Do I need PEQ=on for the phase knobs to be working? I am using line in vs LFE (mainly chose line in vs lfe due to less subwoofer buzz using line in). I have not tried a cheater plug yet due to safety concerns, but might. My guess is that peq does not need to be turned on to use phase knob?
B0dyK0unt is offline
post #16305 of 30689 Old 07-18-2014, 09:04 PM
tvuong's Avatar
Quoted: 1789 Post(s)
Liked: 1083
No. Using line in activates the phase and crossover knobs.
tvuong is offline
post #16306 of 30689 Old 07-18-2014, 09:13 PM
rcohen's Avatar
Quoted: 1394 Post(s)
Liked: 629
Yep.
If you haven't already, once you learn how to tune it (placement, EQ, time/phase alignment), there is yet another level to discover.
rcohen is offline
post #16307 of 30689 Old 07-18-2014, 09:13 PM
B0dyK0unt's Avatar
post #16308 of 30689 Old 07-20-2014, 12:03 PM
dazzdax's Avatar
Dual subwoofers co-located
Hi all, I have four F-15's that are co-located in pairs. What would happen if the upper subwoofer (which sits on top of the other one) is rotated 90 degrees to the left or the right in respect of the lower subwoofer?
I'm trying to give the subwoofers (all four of them) different locations. So by turning the upper subwoofers to the left of to the right by 90 degrees maybe I could get them into slightly different locations.
I would like to hear your opinions.
Chris
dazzdax is offline
post #16309 of 30689 Old 07-20-2014, 12:56 PM
rcohen's Avatar
Liked: 629
Chris
Since bass is mostly omnidirectional, it probably won't have much effect. Sometimes rotating can change things some, and sometimes for the better.
If you have a closed rectangular room, try the REW room simulator to experiment with ideas on layouts for 4 subs:
http://www.roomeqwizard.com
Here are a few suggestions to try:
1) One in each corner, time aligned (most power, canceling some room modes)
2) At 1/4 & 3/4 positions on the front and back wall, time aligned (cancels additional room modes)
3) At 1/4 & 3/4 positions on the front and back wall, but invert polarity for the back pair, and add delay to the back pair of a bit less than 1 ms/ft for the length of the room (Double Bass Array - cancels most room modes)
rcohen is offline
post #16310 of 30689 Old 07-20-2014, 11:15 PM
derrickdj1's Avatar
Quoted: 984 Post(s)
Liked: 722
Four locations is not possible with the subs stacked. They are co-located so, you basically have two large subs.
derrickdj1 is offline
post #16311 of 30689 Old 07-21-2014, 11:52 PM
Danne2's Avatar
dazzdax
Midwall placement has been documented as one of the very best positions of subs. Best if you can have all four subs on their own wall, but if you want to stack them, front/back or left/right wall is also good. Always use opposing walls, if just going with two walls.
If you do sidewalls midplacement, do not set XO higher than 80Hz due to localization, but honestly I don't think you will localize a F15 even at XO=100Hz, but this is something you can try out.
My recommendation is not to invert polarity for a backwall sub, you might get it look better at the XO freq, but it might get worse at other freq., it has not worked out for me to do it like that. If you set a distance to the sub in your AVR, set the distance to the sub farthest away, then the phase on that sub could be 0 on the sub phase dial. Then you delay the sub that is closer to you at MLP on the sub phase dial. If subs are at the same distance you can have both subs at 0 and just play with the AVR phase/distance adjustment.
Not sure if you already have, but just in case, with more than one sub you really need a measurement mic and a SW (like REW) to make the best call on placment and phase adjustments, no matter how golden year you are, you are likely to get a much better integration by doing simple freq. sweeps and see what happens when you play around with placement and settings.
Good luck!
Danne2 is offline
post #16312 of 30689 Old 07-22-2014, 06:46 AM
rcohen's Avatar
Liked: 629
Originally Posted by Danne2 View Post
dazzdax
Good luck!
This varies from room to room, but I have not had good luck with center wall placement with a sub on 4 walls (not enough power and poor frequency response). On the other hand, center wall placement on the front and back walls gives me pretty good natural frequency response. Corner placement gave me the best results overall, because I have a large room, and benefit from the extra power. As long as there are no nulls, I can EQ the rest flat. In a smaller room with no headroom issues, I think that the center wall or 1/4 3/4 placement may be better. It comes down to experimentation. (My room is longer front to back.)
The interesting thing about the double bass array stuff is that it can cancel out more room modes and create a much larger sweet spot. It's critical to set the delay and gain at the back to coincide with bass from the front wall hitting the back wall to cancel out the reflection. If you don't do that, it will cause problems. I haven't tried this myself, but others have had good results, and the REW room sim predicts good results for me. Someday, I will have to try it, to see if it's worth the power sacrifice:
Double Bass Array (DBA) - The modern bass concept!
I have found that low distortion subs like the Rythmiks can handle higher crossover frequencies without too much localization problems. If you use careful placement, going above 80hz can have definite frequency response benefits. For example, if you're struggling with room modes from the front to back axis in the 80hz range, you can put subs in the front and back to cancel them out (even without that polarity inversion/delay stuff). Even with great full range mains, they won't have that benefit, so a 100-120hz crossover point can help in that case. More details:
http://www.soundandvision.com/conten...nd-tell-part-1
http://www.harman.com/EN-US/OurCompa...s/multsubs.pdf
rcohen is offline
post #16313 of 30689 Old 07-22-2014, 08:26 PM
Sean Spamilton's Avatar
Quoted: 371 Post(s)
Liked: 431
Joining the Rythmic Club
Whelp, just placed my order for two LV12Rs for my living room / home theater. I'm looking forward to getting them set up and running some frequency response tests on them! They should be here by next Tuesday - not bad for 140 lbs shipped to Toronto from Texas. Thanks to Brian for the quick shipping (same day).
Sean Spamilton is offline
post #16314 of 30689 Old 07-23-2014, 05:29 AM
JT78681's Avatar
Liked: 1005
Congrats and welcome to the family. I had dual LV12R's before and for their price they are hard to beat. How big is your room?
JT78681 is offline
post #16315 of 30689 Old 07-23-2014, 08:31 AM
Liked: 5
I do not normally post on Internet forum boards. My wife said that I needed to give you guys this feedback. I have been playing the trumpet for about 45 years. My passion is audio. As a birthday/Father's Day gift my wife gave me the green light to put together a speaker system that is used primarily for music, and secondarily for movies. I love planar dynamic headphones, such as the hifiman HE-6. Therefore, the 1.7 magnepans were on my short list. I was concerned that their weakness would be the bottom end of the frequency range, so I began lurking here on the subwoofer, bass, and transducer forum of AVS. I need to thank you guys. I would never have heard of the Rythmik audio subwoofer if it hadn't been for people posting here on this forum. Buying an audio component without having a chance to audition it first is a risk. Based on people's forum comments I took a chance and purchase the E15HP. Some people raised concerns about blending a magnepan speaker with subwoofer. They used phrases like, "the magnepan speaker is too fast to blend with a subwoofer." Nevertheless, I took the chance. All I can say is that I have been, "blown away," by this combination of speakers. The magnepan 1.7 are almost eerie in terms of their ability to provide a large soundstage that it is as clear as a window. The Rythmik E15 provides a visceral, or tactile experience, and richness that cannot be described. It is exciting not just to listen to music but to also "feel the music in the air" and the air pressure on my skin. I use a crossover at about 45 Hz. The gain or volume I vary depending on how musically processed, or bass heavy, the musical selection is that I am listening to. Again, I want to thank you guys for posting on this forum. You turned me on to a great product.
Cingulate Gyrus is offline
post #16316 of 30689 Old 07-23-2014, 09:01 AM
tvuong's Avatar
Liked: 1083
^^ excellent. Very glad you took your time to post. Thanks to you and your wife
Cingulate Gyrus likes this.
tvuong is offline
post #16317 of 30689 Old 07-23-2014, 09:07 AM
Quoted: 371 Post(s)
Liked: 431
Thanks! - My room is about 1700 cubic feet, but it opens up to a kitchen, so all together about 2300 cubic feet. I had dual PC12s before that worked fairly well for the space, but expect the dual LV12Rs to do a comparable job. It will be interesting comparing the servo technology to SVSs dsp speakers - though it will have been a week or two between speakers by the time I get them set up and properly integrated so my memory won't be particularly accurate.
post #16318 of 30689 Old 07-23-2014, 09:58 AM
JT78681's Avatar
Liked: 1005
Superb post for it being your first and probably last.
JT78681 is offline
post #16319 of 30689 Old 07-23-2014, 10:30 AM
JT78681's Avatar
Liked: 1005
I had mine in an open room over 5000 cu ft and they performed well, but that size of a room is asking a lot from them. I had to upgrade to FV15HP's and now I'm not looking back.......
Sean Spamilton likes this.
JT78681 is offline
post #16320 of 30689 Old 07-23-2014, 11:21 AM
DonH50's Avatar
Liked: 1765
Small world! I have Maggies (and have for decades), a pair of Rythmiks, and play trumpet (dep in several bands around the area, play in the local philharmonic, and help moderate the Trumpet Herald, an online forum for trumpet players).
Congrats! - Don
DonH50 is offline
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
