Official Rythmik Audio Subwoofer thread - Page 545 - AVS Forum | Home Theater Discussions And Reviews
 3023Likes
Old 07-23-2014, 07:01 PM
steveting99's Avatar
Quoted: 1772 Post(s)
Liked: 600
Originally Posted by Cingulate Gyrus View Post
... The Rythmik E15 provides a visceral, or tactile experience, and richness that cannot be described...
Depending on placement of the E15 and where you sit, there could be some unevenness in the bass, i.e. lots of peaks and dips via room modes. I'm finding out the hard way with just a single F12G.
If you're willing to experiment with E15 placement and where you listen, you may get a slightly smoother bass response, but not completely deal with the standing waves issue.
Been thinking of how to deal with room modes and the best way is to get second sub. In your case it would be another E15 and put together a dual sub setup. The logic is getting a more even bass response over a larger sweet spot and have some extra head room which can deal with the peak transients in the recordings.
Pondering about getting another Rythmik F12G. I believe there's a 10% discount for returning customers, which does help the wallet...
Cingulate Gyrus likes this.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
Old 07-23-2014, 07:11 PM
JT78681's Avatar
Quoted: 1306 Post(s)
Liked: 824
I don't think we're going to hear from that fine gentlemen again.
JT78681 is offline
Old 07-24-2014, 08:46 AM
Liked: 5
I have a few questions about getting the most out of the Rythmik E15HP. On the Rythmik handout that comes with the subwoofer it emphasizes that one of the most important settings to manipulate is, "phase." Rythmik recommended either a 1 o'clock or 10 o'clock setting to begin with depending upon whether your speakers are sealed or ported in design. Honestly, I could not tell much of a difference no matter what the phase knob was set to. On the front wall I have my magnepan 1.7 speakers, which are about the same distance away from me as the subwoofer. The subwoofer is located on the back wall of the room, in the corner, to the right of my listening position. Is it because the main speakers and subwoofer are about the same distance from the listening position that the phase control adjustment has little noticeable impact on bass response? My 2nd question concerns the use of the PEQ settings. There are 3 rotary variables that can be adjusted within this section of the amp. Are these 3 additional settings manipulating a single frequency? If so, I would probably need to do a very sensitive frequency analysis to determine whether any one particular frequency range required either amplification or attenuation. I guess the concept for this PEQ setting is that based on a particular room, with its nulls and nodes, the specific listening position may have certain frequencies canceled out? Thanks for your help guys.
Cingulate Gyrus is offline
Old 07-24-2014, 08:59 AM
JT78681's Avatar
Liked: 824
^^^^I was wrong
Display - LG 65EF9500
Receiver - Denon 4311CI
Speakers - Klipsch RF-82 II's, RC-62 II, RB-61 II's
Subs - Rythmik FV15HP's
JT78681 is offline
Old 07-24-2014, 09:03 AM
rcohen's Avatar
Quoted: 1142 Post(s)
Liked: 484
Start with the PEQ at 0.
Do you have a receiver with auto-calibration and bass management? I have my phase set to 0, and use my receiver set the delay for me, for phase.
If not, adjust the phase so that you get the maximum output at the crossover frequency. You can accomplish that by using a test tone at the crossover frequency and an SPL meter, or (better yet) by using frequency analyzer software on a PC or laptop with a measurement mic, like Room EQ Wizard. As an alternative, there are SPL and frequency analyzer apps available for smartphones/tablets.
With the PC route, here is a good measurement mic: http://cross-spectrum.com/measuremen...ated_umik.html
Ideally, you would use measurements to guide EQ, whether auto-EQ in a receiver or using the PEQ. You can also do it by ear if there is something you like.
BTW, you mentioned that you were crossing over at 45hz. I'd recommend starting at 80hz and tuning from there. I'd consider between 60-120hz typical good values. It is important to get the phase and EQ set well for the best results.
rcohen is offline
Old 07-24-2014, 09:04 AM
rcohen's Avatar
Liked: 484
...phase...
More details:
http://www.rythmikaudio.com/phase1.html
rcohen is offline
Old 07-24-2014, 09:36 AM
niccolo's Avatar
Quoted: 138 Post(s)
Liked: 39
Are there SPL/frequency apps for the iPhone folks recommend? Do the apps generate their own test tones/sweeps, eg that could be played through the system via airplay?
I get that a proper mike setup is better, but thought this might be a useful way to dip my toes into room evaluation.
niccolo is offline
Old 07-24-2014, 09:49 AM
Sean Spamilton's Avatar
Quoted: 321 Post(s)
Liked: 354
I've seem to recall someone telling me those phone apps have a pretty hard time of measuring low frequencies. Your best bet IMO would be to at least buy an inexpensive radio shack(if your in the states) sound meter. Here's a useful site with various frequency tests and sweeps, beginning with a sub test (10 to 200hz). If you can figure out a way to play it back over airplay it would be useful (assuming you don't have a way of hooking up your ipod / laptop / pc to your AVR)
http://www.audiocheck.net/audiotests...cychecklow.php
Sean Spamilton is offline
Old 07-24-2014, 09:55 AM
Liked: 5
I use an Emotiva amp/preamp combination to drive the subwoofer and magnepan speakers. Unfortunately the "Stealth" preamp does not have bass calibration. I use unbalanced RCA outs from the preamp to the line in of the subwoofer. I went with a crossover at 45 Hz for 2 reasons. The magnepan are rated 40 Hz-20,000 Hz. So I thought I wanted to be about 10 Hz above the low frequency cut off. I also put on acoustic bass tracks and listened for where there seem to be least distortion in the sound (the distortion in sound I interpreted to represent overlap in frequency coverage). That led me to the 45 Hz crossover. I will play some more with the phase control to maximize output. But I am telling you I can have as much volume output as I want with the 600 W monster of a subwoofer. I'm surprised the neighbors across the street don't start jammin to the music. With regard to the PEQ settings I might just do the microphone PC-based frequency analysis, but frankly I don't know how this could get much better.
Old 07-24-2014, 10:05 AM
rcohen's Avatar
Liked: 484
I haven't tried them. I agree that the built-in microphone is the most worrisome part, since it's not designed for that. It might be good enough for tuning phase, where accuracy isn't a concern. I've seen some kits that let you use USB measurement mics, but at that point, you may be better off with a PC.
Getting a calibrated USB mic opens up a lot of doors, including free software like REW.
I've had the best results so far using Dirac for room correction and EQ. It's easy to use and get good results, but it's fairly expensive.
rcohen is offline
Old 07-24-2014, 10:08 AM
rcohen's Avatar
Liked: 484
The point of maximizing the output is to get the phase aligned at the crossover frequency, so your sub and speakers don't cancel each other out at the listening position. It's to get the best sound, not wake your neighbors.
I'm sure your Maggies sound great, but at those low frequencies, I bet your Rythmik sub sounds better (once you get it set up right, which can be a bit tricky).
Do you have a way to do a high-pass crossover on the Maggies? If not, setting the sub to match the natural rolloff is reasonable - just not as ideal as doing a proper crossover above the natural rolloff.
rcohen is offline
Old 07-24-2014, 10:34 AM
Liked: 5
Great points. Unfortunately my preamp does not have crossover settings. I rely upon the subwoofer to create the crossover point. I find if I go too much above 50 Hz male voices on the television coming through the system sound too "thick." Also, if the crossover is too high at times it'll pick up with a, "thud" like percussive sound, at the initiation of a spoken/sung word.
Old 07-24-2014, 10:56 AM
rcohen's Avatar
Liked: 484
That makes sense.
Do you have your signal running through the Rythmik before getting through the Maggies, to take advantage of the high pass filter built in to the sub's crossover? If not, you might be doubling up the bass frequencies when you go above your speakers' natural rolloff.
You could insert the sub between a pre-amp and a separate amp, in a record monitor loop, or run the speaker wires through the sub.
You can get great results this way. It just takes some tweaking. Of course, a measurement mic and software like REW makes it easier.
rcohen is offline
Old 07-24-2014, 11:39 AM
rcohen's Avatar
Liked: 484
Thought I'd share some measurements. Bass is with 4x F25s in corners. 100hz crossover. The room needs sound treatment, although Dirac + 4 subs tames the room surprisingly well.
ID:	178362   Click image for larger version
rcohen is offline
Old 07-24-2014, 11:47 AM
Liked: 5
Wink
That makes sense.
I run both the Maggies and the subwoofer off the preamp. Both speakers get a full range signal. I used balanced outs to the amp and maggies, and RCA unbalanced outs to the E15HP subwoofer. I think you are right, that is why I need to be careful about the crossover for the subwoofer, as they are likely to double up on the low frequencies. For that reason, I rely on my ear to tell me where to set the crossover so that male voices seem natural, and acoustic bass has the least distortion. By using a crossover point of 45 Hz allows for minimal duplication of those low frequencies. On those occasions when I listen to heavily processed pop music I move the crossover back up to about 80 Hz. The room air on those occasions feels "compressed" and my skin actually feels the music. A good example of this would be using the tune by Lordes, "tennis court." There is a whole octave at the bottom of that tune that I never knew existed before I used the subwoofer. I use Verizon FIOS. I am telling you, even their Music Choice stations sound fantastic through the system. Who would've thought!
Old 07-24-2014, 11:50 AM
rcohen's Avatar
Liked: 484
I've had better results running "full-range" speakers through a crossover, rather than sending them a full-range signal. You should do whatever sounds best to you, but IMO, crossing them would be worth a try.
rcohen is offline
Old 07-24-2014, 12:06 PM
Liked: 5
I like the way you think. So you are saying if I use the speaker taps on the power amp and run speaker cables to the subwoofer in, followed by speaker cables from the speaker terminals out from the subwoofer to the Maggies, I could use the crossover in the subwoofer to grab the low frequencies for itself, and send the higher frequencies above that to the full range magnepans. Using this method I would not have a doubling up on those low frequencies where there is some overlap between the subwoofer and the full range speakers. This way I could experiment with raising the crossover higher than I have it and letting the subwoofer have more of "a go" at those low frequencies. Would that work with the Rythmik? It has just a low pass feature, not a high pass.
Old 07-24-2014, 12:35 PM
rcohen's Avatar
Liked: 484
You would need to use a crossover with a high-pass filter. I'm not sure what Rythmik has in that dept, since I'm using my pre-amp for that. It looks like it may vary by which Rythmik amp model and which inputs/outputs you use.
rcohen is offline
Old 07-24-2014, 01:13 PM
tvuong's Avatar
Quoted: 1503 Post(s)
Liked: 837
What speakers are you using? Do you have graph of L or R or C speaker with subs?
tvuong is online now
Old 07-24-2014, 01:56 PM
DonH50's Avatar
Quoted: 1692 Post(s)
Liked: 1227
I run the output of my AVR through an inexpensive dbx (professional) crossover set around 50 - 60 Hz (forget where I left it). Maggies distort heavily when presented with large bass signals; the Rythmik does not. In the decades I have owned Maggies and similar speakers I have always found substantial audible and measured improvements letting a good sub handle the deep bass, starting with my very own servo design back in the late 70's early 80's. That includes ESLs, or just about any conventional speaker, for that matter -- the only pair I owned that did OK sub-less was my IRS 2; a pair of early model B&W 801's did OK as well. Planer speakers are worse because by and large they simply do not have the area and excursion to deliver the much larger output low bass demands (look at a Fletcher-Munson loudness curve, remembering 10 dB is 10x the power).
Many Rythmik models include a HPF as well as LPF you could use. I have not really tried it.
Letting the sub and main speakers overlap in the low bass has virtually always led to worse sound in my experience, including muddy bass and the like. That has been worse for large panel mains, again IME.
I'd personally roll off the 1.7's up around 60 - 80 Hz, at least 1/2 to 1 octave above their low end rating, and let the sub do its thing. I suspect you'll be happily surprised by the result.
FWIWFM - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
Old 07-24-2014, 02:12 PM
rcohen's Avatar
Liked: 484
They are Triad Platinums that I got cheap from an estate sale.
Rythmik got most of my speaker budget.
The graphs I posted show L & R overlaid, crossed with the subs at 100hz.
With the 10" woofers, the Plats can handle lower crossover frequencies well enough, but I run into problems with nulls when bass only comes from the front.
My frequency response was awful without at least one sub in the front and one in the back. 4 subs just gave me more headroom (big room) and better seat-to-seat consistency.
rcohen is offline
Old 07-24-2014, 02:52 PM
Liked: 5
FWIWFM - Don
I love your thoughts. So what you were saying is buy an external crossovers device and use that on the speaker cable output from the main amp going to the Maggis. I didn't know that there was such a device. Do you have any recommendations on a particular product.
Old 07-24-2014, 03:08 PM
rcohen's Avatar
Liked: 484
A more straightforward solution would be to get a receiver with bass management, if you aren't able to use the built-in crossover in the Rythmik. If you go with an external crossover, an active (line-level, not speaker-level) crossover is preferable, if possible with your setup.
rcohen is offline
Old 07-24-2014, 03:51 PM
tvuong's Avatar
Liked: 837
My Klipsch towers were measued flat to 25hz in my room but I prefer crossing them over at 80hz not only to have my FV15hps handle the low but also to release load off my Denon receiver. There is benefit to have a higher crossover.
Old 07-24-2014, 09:01 PM
DonH50's Avatar
Liked: 1227
No, an active crossover between the preamp and amplifier. I thought you were using an external amp? If not, there is (probably) no practical way to run an active bi-amp configuration, sorry. I must have misread your system. If you are using an AVR that has a subwoofer output, that would do.
You could make or buy an external passive speaker-level crossover but that is not what I had in mind.
For the record, Magnepan says to run them full-range. I disagree based upon my ears and my test equipment. YMMV - Don
DonH50 is offline
Old 07-25-2014, 03:49 AM
dazzdax's Avatar
Hi folks, I try to blend 4 F-15 subwoofers with Soundlab electrostatic speakers. What would be the right steepness for a low pass filter: 12dB or 24dB/octave?
Do planar speakers have a natural roll off of about 6dB/octave?
Chris
dazzdax is offline
Old 07-25-2014, 06:23 AM
Liked: 5
I see what you are saying. I went to the musician friends website and see that they have a variety of active cross over products. My preamp uses XLR balanced outs into the power amp. I could easily insert one of these active crossover products at that point in the chain and see if I can hear the sonic benefit. Do you still incorporate the active crossover in your audio system? I see that magnepan indicates letting the maggies run full band width. With that said, what you point out about doubling up on the bass frequencies between the subwoofer and speakers makes a lot of sense to me. You say you cut the maggies off at about 60 hertz? You don't think adding the crossover degrades the audio signal (since the internals in the crossover are relatively inexpensive)? I respect your opinion, and thank you for taking the time to think about my questions.
Old 07-25-2014, 07:20 AM
JT78681's Avatar
Liked: 824
I like this little tid-bit they threw in on the Rythmik website about the FV15HP. To me it's not small, but I guess in comparison to some of the other offerings it is. Also, impressive that for it's size it can push close to 100db at 12.5hz.
FV15HP is the smallest in size (but highest in output) among the top 3 commercial ported subwoofers tested at data-bass 12.5hz output comparsion. Even at 16hz comparison, we are the number 6 highest output.
JT78681 is offline
Old 07-25-2014, 08:44 AM
enricoclaudio's Avatar
Quoted: 1039 Post(s)
Liked: 1055
If you want to insert an active crossover or DSP in the chain I would strongly recommend to look at something different than pro audio active crossovers or speaker management systems. Most of cheap pro audio active crossovers like DBX DriveRack has a FR of 20Hz to 20KHz which cut off all subsonic frequencies on the subwoofer. The Behringer CX3400 is better in terms of FR (5Hz to 20KHz) but it's not reliable. I have a full closet with more than 30 Behringer products including preamps, mixers and active crossovers that went back in less than two years.
I think options like miniDSP Balanced 2x4 ($125) or the more expensive miniDSP Dirac Live DDRC-22A ($899) are a better option than a pro audio crossover.
rcohen and Cingulate Gyrus like this.
Enrico Castagnetti @ Rythmik Audio
Media Room: Polk LSiM705s, LSiM706C, LSiM703s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet + Duet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
Old 07-25-2014, 09:14 AM
Liked: 5
Thanks for you feedback. The crossover would not impact on the connections to the subwoofer. I use the unbalanced outs from the preamp to go directly to the E15HP. The subwoofer would see the full range of audio signal. I would use the crossover to serve as a bridge between the balanced outs from the preamp and the power amp, which drives the maggies. I would use the filter so that the maggies did not see the frequencies beneath, lets say 70 hertz. Therefore, there would not be a doubling up on those frequencies between the subwoofer and the main speakers. Could I use an active crossover like a Behringer product for that goal without sacrificing audio quality to the maggies?
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
