Official Rythmik Audio Subwoofer thread - Page 547 - AVS Forum | Home Theater Discussions And Reviews
 3185Likes
post #16381 of 27829 Old 07-29-2014, 08:00 AM
highmr's Avatar
Quoted: 51 Post(s)
Liked: 30
Originally Posted by steveting99 View Post
If you're interested in getting both subs to work together, the Denon AVR-2310 has a single sub pre-out. Audyssey MultiEQ will set a single level and distance setting to both subs for a combined response. So the key is setting up of the HSU and Rythmik prior to running Audyssey.
You might want to consider gain matching the subs so that there is equal power output for each sub with respect to the Main Listening Position based on reference level that Audyssey will run at (75dB). This will minimize one sub working too hard while the other just sits there humming along.
An external box such as the MiniDSP (2x4) between the sub pre-out and the the subs is another consideration. You might be interested on the write-up done by AVS member neutro in the following thread here: Tutorial: Dual sub integration using the MiniDSP as it should give some ideas on what can be done in a dual sub set-up.
Placement of the subs is the key in getting smooth bass over a larger sweet spot. Have fun along the way and post back results if you can. There are quite a few clever people who hang around AVS that can provide advise.
I just received the Umik-1 mike and longer subwoofer cables and a splitter so that I can do initial setup with the 2310. Based on this thread I looked at the miniDSP and it looks interesting. I'll try to do without it first, but I think it would solve some of my problems without having to get XT32.
LCR: Hsu HB-1 MK2, HC-1 MK2..........Subwoofers: Rhythmik D15SE, Hsu VTF-2 MK4
Receiver: Denon 1712CI, 2310CI........Networking: Roku 3, WDTV Live......Other: MiniDSP 2x4 RevB
Blu-Ray: Oppo BDP-80, Sony S590.....TV: Samsung PN60F8500, Panasonic TC-50PU54
Atmos/DTS-X: 5.1.4; RSL C34E speakers; receiver TBD
highmr is offline
post #16382 of 27829 Old 07-29-2014, 08:02 AM
highmr's Avatar
Quoted: 51 Post(s)
Liked: 30
Originally Posted by rcohen View Post
2 subs with 1 sub output from your amp doesn't require a MiniDSP (although those could be good for other things).
Use the "line in" input, not LFE, so that they "delay/phase" knobs are active.
Set the crossover to the max (120hz), and use the receiver's crossover setting, instead.
With the help if the mic and REW, tune the delay and gain on each sub. (This can be tricky.)
More details: http://www.rythmikaudio.com/phase1.html
Yes, I plan to try to get them dialed in without miniDSP initially by having phase and delay active on at least one of the subs.
highmr is offline
post #16383 of 27829 Old 07-29-2014, 08:06 AM
highmr's Avatar
Quoted: 51 Post(s)
Liked: 30
Those steps sound like good advice.
I just realized you were using two different models of subs. That can be tricky, since there may be frequency-dependent phase differences between the subs. So, even if you match the phase at the crossover frequency, the subs might cancel at other frequencies.
It might be good, though.
If your frequency response is worse with 2 subs than with 1, and you aren't able to fix it, you could try playing with the various filter settings, until you find one that works best.
Yes, it could be trickier, but maybe more entertaining to try to get to work. If I end up with a notable hole in the FR with the two that is better with each one individually, that would tell me that I am having this issue and need to keep experimenting.
highmr is offline
post #16384 of 27829 Old 07-29-2014, 08:07 AM
highmr's Avatar
Quoted: 51 Post(s)
Liked: 30
Originally Posted by derrickdj1 View Post
What is being discussed is level matching. Set each sub to around 73 db at the main listening position. Then run autocalibration. Gain matching is done with identical subs. http://forum.blu-ray.com/showthread.php?t=95817
Thanks, I was confused on this difference. I will check that thread before I match either way.
highmr is offline
post #16385 of 27829 Old 07-29-2014, 08:34 AM
Liked: 5
Originally Posted by DonH50 View Post
Go to the Sweetwater site and download the CutSheet and the manual. It is a two-channel (stereo) unit with input, low output, and high output jacks for each channel. Each channel has input gain, crossover frequency, and output gain controls to allow you to match the low and high output levels. The 40 Hz low cut (high pass) filter you do not use for this application. You can also configure it to be a three-way mono unit and that is probably what is confusing. The front panel has two rows at the bottom; the top is mono (three-way crossover) operation, and the bottom row is when you use it as a stereo unit. The back panel also has two rows, but the one at the top is for stereo and the row at the bottom is for mono. If you only have one sub you will use it in stereo but sum the L/R inputs (switch on the back). I use mine in stereo since I have two subs. The Mode switch has the labels and a switch that determines which mode you are in.
The CutSheet lays it all out and the manual goes into more detail.
HTH - Don
I have a quick question. Why would I choose on the DBX 223sx crossover to engage the "Sum the Low Frequencies" option? The DBX will be connected to the Rythmik using both the Left and Right RCA low frequency outputs to the subwoofer amp panels Line In RCA inputs. Why wouldn't I let the right and left channel send its independent audio signal to the subwoofer? Is there an audio advantage to summing rather than independent signals?
Cingulate Gyrus is offline
post #16386 of 27829 Old 07-29-2014, 08:51 AM
Liked: 5
HTH - Don
One more question. If I do use LF Sum option on the crossover does that mean that Channel 2's XLR output connector is not used? I take it that LF summed will mean that both Left and Right output audio signals are combined; and the total audio signal will be sent to Channel 1's XLR output only.
post #16387 of 27829 Old 07-29-2014, 01:27 PM
rcohen's Avatar
Quoted: 1208 Post(s)
Liked: 516
It sounds like it's talking about running a mono sub signal or a stereo sub signal. If you run 2 signals to the same sub, they just get mixed (summed) together in the sub. I'd go mono to keep it simple, but it shouldn't make a difference.
Cingulate Gyrus likes this.
rcohen is offline
post #16388 of 27829 Old 07-29-2014, 04:21 PM
DonH50's Avatar
Quoted: 1790 Post(s)
Liked: 1324
+1.
With a single sub you either do the summing in the crossover and run one cable to the sub, or run two cables and sum them in the sub. Probably no difference sonically, just how many cables you want to run. I actually have my subs set up as a stereo pair. I am thinking seriously of adding another one or two subs to deal with some room nulls and those will use the summed output, or I will sum in the suub or with an external summer (latter two options more likely as I don't want to add another crossover unit), or maybe just use the regular sub output from my AVR.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #16389 of 27829 Old 07-29-2014, 07:20 PM
Liked: 5
+1.
OK. I will run a single cable from the crossover to the sub. Do you use an audio line splitter (Y connector) so that both RCA inputs on the Rythmik amp panel receive the summed audio signal?
post #16390 of 27829 Old 07-29-2014, 07:31 PM
DonH50's Avatar
Liked: 1324
No. Summing the inputs provides more gain so if, when you set it up, the gain knob is set very high, then you can use a Y and drive both inputs. Chances are you will not need it.
post #16391 of 27829 Old 07-31-2014, 12:46 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Originally Posted by jkhome View Post
No, I think you are thinking of someone else, I haven't emailed you yet. Here is a post to give a time line :
Simple Rythmik retrofit
Here's a pic of it:
Is that a pair of the newest Cardas binding posts I see on the side of the amp box?
BDP24 is offline
post #16392 of 27829 Old 07-31-2014, 08:16 AM
jkhome's Avatar
Quoted: 89 Post(s)
Liked: 48
They are the Cardas Patented posts, I did this box back in 2009. Love the binding posts, use them every chance I can. I prefer either bare wire or spade connectors, and these post really clamp down.
I just upgraded one of my systems with KEF LS50s, and the only criticism I have of the speakers is that I can't upgrade these to the patented post (without butchering up the cabinets). Just can't get my cables as tight on the OEM posts as I would be able to on the Cardas ones.
jkhome is offline
post #16393 of 27829 Old 07-31-2014, 09:58 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
I love them too. I'm looking for something else to put them on!
BDP24 is offline
post #16394 of 27829 Old 07-31-2014, 11:07 PM
rcohen's Avatar
Liked: 516
Originally Posted by Rythmik View Post
Quote:Originally Posted by NapalmV5
id be more interested in rythmik mains/towers for clean/tight/accurate full range
sealed/servo/active mains lol how about it brian ??
Well, I did have a project like that. The idea is to extend the servo operation to midrange driver while keeping the tweeter nonservo. I have done everything I could to reduce the voice coil inductance, including an alumimun phase plug which may turn out to be a bad idea. Just demonstrated the system at Danny's house (GR Research) before holiday. Since the midrange can also be used as nonservo, I have design a passive xover for the midrange drivers so that they have the same response as in servo mode. This makes the comparison of servo vs nonservo easier. To make the long story short, I do think the improvement on dynamics such as drums is very audible. However, there are some resonances above 500hz that keeps them from being perfectly flat and Danny can easily point them out even before we proceeded to measurement. It is a type of parasitic resonances that servo cannot correct. Because those resonances showed up only after I put them in enclosures, I do suspect it arises from enclosure's air spring and the air gap between phase plug and voice coil. In short, the box is technically not sealed at all. I will try out different enclosure type such as TL or vented box so those 5-1/4 midrange driver can play into 50hz/40hz without a sub. While it may not play very low, it does make the assessment of merits easier.
Interesting! I've never heard of a servo midrange before.
So, are you saying there is an audible improvement relative to passive, or even an audible improvement over active?
An active servo, ultra low distortion, high SPL speaker designed to integrate well with Rythmik subs could be very cool.
It's weird that so many speaker companies focus on full range speakers when people who really care about bass use good subs. Most of your money goes to capability that you never use.
rcohen is offline
post #16395 of 27829 Old 07-31-2014, 11:53 PM
niccolo's Avatar
Quoted: 139 Post(s)
Liked: 39
But many (most?) audiophiles are pretty leery of subs, though there are very good arguments for separating low frequency content from the mains even for music.
niccolo is offline
post #16396 of 27829 Old 08-01-2014, 08:12 AM
Liked: 5
HTH - Don
I know you guys would understand. Last night I hooked about the DBX active crossover in between my pre-amp and amp. The highs go to the maggies and the lows to the Rythmik E15HP. It now sounds sooo sweet. I had trouble sleeping last night. I would wake up thinking how awesome the music sounds. I can't wait to get home from work and listen some more. Thanks Don for teaching me about this stuff.
niccolo likes this.
post #16397 of 27829 Old 08-01-2014, 12:37 PM
DonH50's Avatar
Liked: 1324
NP. Enjoy!
post #16398 of 27829 Old 08-01-2014, 12:48 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
hi guys, what kind of sound meter are you guys using for youre rythmik subs?? is there any cheap or decent meter that you guys can recommend from ebay?thanks
caloyzki is offline
post #16399 of 27829 Old 08-01-2014, 01:28 PM
laulau's Avatar
Quoted: 77 Post(s)
Liked: 107
I've been using an old Radio Shack 33-2055 digital spl meter for years and years. It's a discontinued product but I think you can still find them on ebay.
If the RS meter were to ever die on me, I probably replace it with a "verified" Galaxy CM-140 from Cross Spectrum Labs...they aren't exactly cheap, but they're not prohibitively expensive, IMO.
Salk STRT / SongCtr-RT / SongSurr I ; Rythmik F12 (x2) (latest ver of my setup guide) ; Denon 4520CI; D-Sonic M2-800S; Oppo BDP93; Panny 65VT50; BJCables; NAS DLNA; Chromecast; Harmony One; Furman Elite-15 PFi; Omnimic & REW; CalMAN 5 HT i1D3 & i1Pro2 ::Headphones:: RPi3 w/Digi+ > AGD DAC19 > Cavalli LC > HFM HE400i & Meze 99 Classics :: CCA > Schiit Bifrost 4490 > Schiit Valhalla > Senn HD600 & HD6XX :: FooB2K > Schiit Modi2U > Schiit Magni2U > Oppo PM3
laulau is offline
post #16400 of 27829 Old 08-01-2014, 01:35 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
MiniDsp vs Rythmik built in HPF
I am currently running a 2 channel system, right now, I am using the built in HPF filter on the Rythmik's plate amp (80hz, slope ?). Assuming that I would also choose the same 80hz cutoff, I am wondering if the Minidsp would sound better than the Rythmiks HPF, basically the main comparison would be the quality of the OP amps employed in both crossovers, if its better, is it worth the $200 (shipping, taxes etc, I am in Asia ) it would cost me to get it ?
qguy is offline
post #16401 of 27829 Old 08-01-2014, 02:46 PM
DonH50's Avatar
Liked: 1324
I am using an inexpensive dbx analog crossover in my system. I toyed with the idea of using a mininDSP and will get one someday, but decided it was too much hassle just for a crossover. If I was designing a speaker system or using a multiway crossover and optimizing time and frequency response I'd get it for a crossover, but just to emulate an analog crossover seems like overkill.
I have not used the Rythmik HPF, IMO probably not worth the effort if you are going to use the same crossover. The miniDSP has decent opamps but you have to get the balanced version to have enough drive for most applications. You are also adding another A/D-D/A conversion in the process so it is more than just op-amps. If you need it to generate room compensation EQ or need more flexible filters it is great, but if all you need is a HPF and are not changing slope or crossover frequency, chances are the Rythmik is good enough. Brian talked about the built-in HPF someplace in this thread.
post #16402 of 27829 Old 08-02-2014, 02:12 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Wink
That's what it's all about! The combination of a speaker like any of the Maggies (or other high-performance/moderate cost panels, like the Eminent Technology LFT-8b's) mated with a Rythmik or GR research sub or two is THE way to go. The combination outperforms many higher priced "full-range" speakers. Buy your main speakers for their qualities above 80-100Hz, ignoring their shortcomings below those frequencies. The Servo sub/s will outperform the passive woofers in just about any speaker you can name. The Audiophile's negative opinion of subs, particularly with panel speakers, is based on conventional subs, not the over-performing Servo subs. IMO!
rcohen and Cingulate Gyrus like this.
BDP24 is offline
post #16403 of 27829 Old 08-02-2014, 06:35 AM
rcohen's Avatar
Liked: 516
q
I can't imagine that it would sound better if you use it for the same thing. If you use it to do something different, that's another matter.
I believe the MiniDSPs have EQ capability, which could make a big difference.
It's great to hear that people are having good luck with external crossovers, although I think using a pre-amp with EQ and bass management would be more straightforward. It also allows you to avoid another AD/DA conversion in the MiniDSP.
Another great route is to use a PC source with JRiver, and use flac files. JRiver is awesomely flexible when it comes to things like bass management and EQ, among other very cool features. I recently added a cheap and tiny Gigabyte Brix computer to my bedroom as my source, and it's awesome! It easily slaved to the JRiver in my home theater, and my whole audio and video library was there instantly.
http://www.newegg.com/Product/Produc...=-1&isNodeId=1
http://www.jriver.com
rcohen is offline
post #16404 of 27829 Old 08-02-2014, 06:41 AM
rcohen's Avatar
Liked: 516
What crossover frequency did you end up going with? I'd recommend experimenting between 60 and 120hz to see what works best with your speakers and room.
rcohen is offline
post #16405 of 27829 Old 08-02-2014, 08:08 AM
DonH50's Avatar
Liked: 1324
All good points, albeit the same ones I made two posts up... However, most stereo preamps do not include bass management, and EQ is not the same as a crossover. EQ tends to be much more broad and slower (lower slope) than a crossover, and without a crossover you cannot split LF and HF outputs to drive the mains and sub(s). They perform two different functions. What would be nice is if more preamps and AVRs included crossovers. I suspect the market is far too small and the group of people that would actually implement it smaller so just not worth it. Wouldn't think it be a large cost in an AVR since the DSP is already in there and they already allow "passive biamping"...
post #16406 of 27829 Old 08-02-2014, 09:47 AM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
Hello ryhtmik lovers,need some of your help. Owning lv12r and just purchased my 2nd sub mirage omni 12. And also bought spl meter. Question. Before i run my audysey i want to use my spl to get each sub to 75db then run full adysey. Should i seat from my MLP and hold the spl to get the 75db from each sub?or spl should be near from the sub?thanks.
caloyzki is offline
post #16407 of 27829 Old 08-02-2014, 12:26 PM
DonH50's Avatar
Liked: 1324
SPL should be measured at the listening position.
I have Rythmik F12's and several other subs in the house, including the Mirage. I was not at all happy with the Mirage, let us know how it works out.
caloyzki likes this.
post #16408 of 27829 Old 08-02-2014, 03:55 PM
niccolo's Avatar
Quoted: 139 Post(s)
Liked: 39
I'm currently using my Denon X2000 to cross over between my Rythmik FV15HP and my Focal speakers at 60 hz. When I run these tests tones (below), the sub seems to be producing content up to somewhere above 100 hz, based on vibration felt in the sub surround. Is it possible the test tones have lower harmonics? Or the crossover is that gradual? Or this is just an illusion?
http://www.audiocheck.net/testtones_subwooferharmonicdistortion.php
niccolo is offline
post #16409 of 27829 Old 08-02-2014, 08:23 PM
DonH50's Avatar
Liked: 1324
Based on vibration? Not sure how accurate a measure that is... In any event, crossovers are not perfect brick-wall filters that instantly go to zero on either side. A second-order crossover is about half as loud an octave away from the crossover frequency; a fourth-order slope about one-quarter as loud an octave away.
post #16410 of 27829 Old 08-02-2014, 08:30 PM
Liked: 5
I am with you brother. I use Jriver and an external hard drive with a mixture of high resolution and standard 44 by 16 resolution files. i feed it to the Emotiva Stealth preamp. DonH50 turned me on to the DBX active cross over which feeds the Maggies (1.7) and the Rythmik E15HP. With JRiver I can EQ the files just to my liking.
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
