Official Rythmik Audio Subwoofer thread - Page 549 - AVS Forum | Home Theater Discussions And Reviews
 3083Likes
post #16441 of 27440 Old 08-04-2014, 02:18 PM
niccolo's Avatar
Quoted: 138 Post(s)
Liked: 39
Originally Posted by niccolo View Post
My understanding is I'm supposed to run Audyssey in one-port mode on my FV15HP and then, if I choose, convert the sub to two-port mode, because running Audyssey in two-port mode may lead to boosting of the missing ultra-low frequencies. Is that right? Isn't it a problem because two-port mode produces different sound and Audyssey won't have optimized for that?
This got buried in this fast-moving thread...
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
post #16442 of 27440 Old 08-04-2014, 02:28 PM
JT78681's Avatar
Quoted: 1319 Post(s)
Liked: 834
^^^Sometime's a bump is necessary
niccolo likes this.
Display - LG 65EF9500
Receiver - Denon 4311CI
Speakers - Klipsch RF-82 II's, RC-62 II, RB-61 II's
Subs - Rythmik FV15HP's
JT78681 is offline
post #16443 of 27440 Old 08-04-2014, 04:04 PM
DonH50's Avatar
Quoted: 1713 Post(s)
Liked: 1242
Once you run Audyssey as directed, any changes after that are for preference. The idea is to let Audyssey do its thing but leave you some wiggle room to adjust to taste. Same idea as running with the gain knob a little low so you can dial the bass up a little more if you wish.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #16444 of 27440 Old 08-04-2014, 04:54 PM
niccolo's Avatar
Quoted: 138 Post(s)
Liked: 39
Interesting. You see why I ask, right? It's one thing to turn up the volume on the bass a little, it's another to change the frequency response of the sub, which is what you're doing by switching from 1-port to 2-port mode.
It's interesting that the concern is that running Audyssey in 2-port mode might lead Audyssey to boost the lowest frequencies, because presumably with most subs on the market, which don't go as low as the FV15HP does in 1-port mode, Audyssey isn't amping up those ultra-low frequencies (which would put tremendous stress on subs not designed to go that low).
So while this diagnosis seems to apply to not using the parametric EQ on the Rythmik before running Audyssey, I'm not clear on why it dictates running Audyssey in 1-port mode if one plans to use the sub in 2-port mode.
Educate me, more knowledgeable AVS denizens! Appreciated.
Rythmik FV15HP sub
niccolo is offline
post #16445 of 27440 Old 08-04-2014, 05:40 PM
rcohen's Avatar
Quoted: 1159 Post(s)
Liked: 490
Ideally, you would run room correction with the same setup you use to listen, but Audyssey needs to automatically detect the -3db natural rolloff point for your sub. If it doesn't properly detect that, it will try to boost where it shouldn't. If this happens, you may need a steeper rolloff setting for measurements, so Audyssey can detect the proper -3db point. The best bet is to measure the freq response before and after, to see if Audyssey did something weird.
Dirac lets you manually dial this stuff in.
rcohen is online now
post #16446 of 27440 Old 08-04-2014, 06:25 PM
niccolo's Avatar
Quoted: 138 Post(s)
Liked: 39
But if you're using two-port mode, presumably you want Audyssey to detect the natural rolloff *in two-port mode*, right? Am I missing something?
Rythmik FV15HP sub
niccolo is offline
post #16447 of 27440 Old 08-04-2014, 06:35 PM
rcohen's Avatar
Liked: 490
Yes, I'd think that would work fine, since the natural rolloff should be plenty steep. I saw someone warning about high damping, but not 2-port mode.
That said, when I auditioned an FV15HP, I much preferred the 1-port mode.
post #16448 of 27440 Old 08-04-2014, 07:44 PM
DonH50's Avatar
Liked: 1242
I do not remember the reason but Brian explained it in this thread, a search might help. It had something to do with Audyssey not properly measuring the lowest frequencies and thus applying unnecessary boost or something like that. Mine are sealed so I didn't really pay attention.
DonH50 is offline
post #16449 of 27440 Old 08-04-2014, 08:11 PM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
24 dB/octave implies fourth-order response, which can be achieved using two inductors (L's) and two capacitors (C's). For a LPF, you could start with a series L, then C to ground, then another L in series, then a final C to ground. For a HPF swap L's and C's. There are other ways but it has been a while since my filter design class. Choice of filter response is another variable (Butterworth, Bessel, Chebyshev, Elliptical, etc.) that affects amplitude response (roll-off, peaking, ripples in passband and/or stopband, and such) and phase response (linear or not, behavior through pass and stop bands, etc.)
Without op-amps a passive filter potentially has lower noise and distortion, assuming you are far away from saturating the inductors (i.e. they are run at low current, typical for line-level filters), but without active buffers the passive design is more sensitive to the source and load impedances since they will impact the filter's response. A common assumption is a low-impedance source and high-impedance load; a good company will specify the assumed source and load impedances beyond which the filter's response is no longer valid. The passive design will also have more loss, though some "active" designs may use unity-gain input and output buffers with a passive filter network inside (one of the buffers could be a gain stage, natch). It is usually easier to adjust the frequency corner of an active design (depending upon the filter topology you can do it with a single control; passive requires you to adjust L's and C's). Most passive designs I have seen are fixed at a single frequency determined by design.
Active or passive will work fine when properly designed and integrated. I have tended to use active as I appreciate the buffers to isolate source and load and you don't have to worry about the inductor's saturating or ringing. Of course, active circuits can ring too... L's tend to get large at audio frequencies, but passive does need a power supply. You can usually adjust an active design's frequency corner (and sometimes other parameters like gain, filter Q/bandwidth, etc.) though some active designs are fixed-frequency. And so forth, many trades.
For a 24dB low-pass, one is already built into the Rythmik plate amp---no need to make or buy one. For a 24dB high-pass, Marchand told me today that he can make the passive model 46XLR-A with that slope for $350. The 12dB version is $199. Bargains! For those big SoundLabs---the couple of times I've heard them (admittedly at shows, in huge rooms), the bass was very "wooly". It may be that the problem mating a pair of subs with them is their own loose bass, not a lack of integration between them and the subs. For that reason, and I may be in the minority here, I would actually try them crossed-over at 180Hz to a pair of the GR/Rythmik OB subs, using three of the 16 ohm drivers per side on one A370 amp. Easier on the panels and their amp, tighter bass.
BDP24 is offline
post #16450 of 27440 Old 08-04-2014, 08:46 PM
DonH50's Avatar
Liked: 1242
I wanted more flexibility in setting the crossover (mine is not at 80 Hz) and the little dbx gave me what I wanted (and I had it anyway). It also ensured the HPF and LPF frequencies were identical, something harder to do with the knob on the sub (I have the equipment to determine it, but am lazy, and it is easier for me to measure the transfer function of a line-level box than set up my measurement mic and sweep the sub). Seems like there was another reason or two I went that route but it has been several years now and I don't actually recall all the reasons why. The quick guide for my 370PEQ2 is a little confusing on how the crossover controls and low-pass filter/slope controls play together. At one time I had it all figured out... It implies the HPF is fixed at 80 Hz and I do not recall if that is affected by the crossover knob (I''m thinking not but don't remember). I am not even sure how I left mine set; I think I had to use AVR/12 and set the crossover to max on the sub since I wanted to be able to use the phase control knob (which I believe is disabled in the LFE setting, the one I would have used) and the PEQ.
Ages ago with smaller panels I decided stereo subs were the way to go and have stuck with that (probably irrationally) ever since. Old habits... I am seriously considering adding another pair of Rythmiks to smooth my room response but (a) have treated the snot out of my room so it's fairly flat and (b) have one more kid to get through college (plus still helping out his older brother).
Marchand makes good stuff... I was thinking of going that route but needed the flexibility of variable frequency. The dbx was a gift and a unit I was familiar with so I took that route instead. Whilst kicking myself for not holding on to my old ARC crossover, or grabbing the Bryston I passed up decades ago.
Cingulate Gyrus likes this.
DonH50 is offline
post #16451 of 27440 Old 08-04-2014, 10:52 PM
niccolo's Avatar
Quoted: 138 Post(s)
Liked: 39
Most folks seem to prefer one-port. It just occurred to me that in my somewhat cavernous space, the ultra low frequencies might not be doing as much for me, and the extra oomph of two-port mode might be welcome. But really, only one way to find out, I'll play around with this when I get a chance.
niccolo is offline
post #16452 of 27440 Old 08-05-2014, 03:57 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Ooh, the Bryston is awesome. It oughta be, for what they charge for it! For years I was dead set against any active electronics between amps and ESL's (because of their transparency), and so had a simple passive 6dB/octave R/C on the input jacks of my power amp. I'm much less dogmatic in my advancing years, more pragmatic.
BDP24 is offline
post #16453 of 27440 Old 08-05-2014, 04:27 AM
rcohen's Avatar
Liked: 490
Yeah, I'd say turn Audyssey off so it doesn't interfere, and experiment with the ports and filter settings to see what you like.
If you don't hear much difference in your room, go with the more efficient settings.
After you have your favorite, re-run Audyssey.
post #16454 of 27440 Old 08-05-2014, 06:09 AM
DonH50's Avatar
Liked: 1242
Unless something is broken, and despite ESL's (or Magnepan's) low distortion compared to other speakers (relatively, sometimes), the distortion added by even a long chain of electronics before the amp is in the mud. The amplifier normally dominates the distortion of the electronics chain, and it is still normally an order of magnitude or two lower than the speakers themselves.
DonH50 is offline
post #16455 of 27440 Old 08-05-2014, 06:35 AM
JT78681's Avatar
Liked: 834
I've experimented a lot with both modes. If you have a large space to fill and only have a single FV15HP I highly recommend 2 port mode. It has noticeably more output and you can run the sub hotter without having to worry about running into any port noise. With that said, I now have dual FV's and run both in single port mode low dampening with a +3db boost at <60hz using the PEQ on the amp. My living room is >5000 cu ft completely exposed to an upstairs loft and formal dining room.
JT78681 is offline
post #16456 of 27440 Old 08-05-2014, 07:53 PM
niccolo's Avatar
Quoted: 138 Post(s)
Liked: 39
For what it's worth, in order to get Audyssey to set the sub at -5, after which I raised it to -1, the sub gain is actually a little below midnight, so it's not like I'm running things particularly hot. Since that's the case, is there any benefit to 2-port over 1-port mode, to outweigh the downside of less ULF content?
niccolo is offline
post #16457 of 27440 Old 08-05-2014, 08:15 PM
JT78681's Avatar
Liked: 834
20hz and up 2 port offers better composure and more output. I recommend 2 port if you have a large space to fill and like the bass hot, but only run 1 FV. Now if you have duals you have more headroom and can run single port mode. *Disclaimer this was the route I took in my particular situation and it worked best for me. I don't have a dedicated theater room.
JT78681 is offline
post #16458 of 27440 Old 08-05-2014, 08:43 PM
niccolo's Avatar
Quoted: 138 Post(s)
Liked: 39
Well, I currently run my sub 4 db hot and I'm undecided between that and 3 db hot, so I don't know that I meet your criteria for liking it hot. And I don't play at reference levels. At non-reference levels, with plenty of headroom in 1-port mode, is there any benefit to 2-port? I'm still struggling to get my head around that.
niccolo is offline
post #16459 of 27440 Old 08-05-2014, 10:45 PM
rcohen's Avatar
Liked: 490
I found that 1-port mode dug deeper and made the bottom octave more detailed, especially when combined with 14-hi damping.
They bring up good points, though, that if you run out of headroom, 2-ports and more efficient filter settings may be better for your room.
post #16460 of 27440 Old 08-06-2014, 06:32 AM
JT78681's Avatar
Liked: 834
If your not listening at reference level and only running +4db hot you should be golden (unless you are getting port noise). Why miss out on that 12hz content if your happy with what you hear right now? The only way to satisfy your curiosity about 2 port mode is to try it out for yourself. How big is your room I forget?
JT78681 is offline
post #16461 of 27440 Old 08-06-2014, 02:07 PM
jnick1's Avatar
Quoted: 56 Post(s)
Originally Posted by bear123 View Post
Plug the YPAO microphone into the jack on your AVR and run its room correction. It finds the crossover for you. You don't need an SPL to set the level on your sub. Just try the gain around half way and run YPAO. If it sets your sub around -6 to -8, you are golden. If it sets it much lower than that, lower the gain a little bit and rerun YPAO. If it sets your sub to close to 0 or above, raise the gain and rerun YPAO until it sets the sub near -6 to -8. After YPAO, raise the subwoofer trim level 3 to 6 dB to taste.
When funds permit, do get a Umik-1 mic and a miniDSP for about $200 total. It will help you transform your in room frequency response from looking like a scary roller coaster to a nice flat line.
So I FINALLY got around to setting everything up this past weekend.
I plugged in the YPAO mic and set it on a tripod, ear level, in the middle of the seating area; near where the coffee table would be. I figured this would give the best overall sound for all guests on any part of the couch. I set the receiver to a volume level of 0.0dB.
I initially set the Rythmik sub to 50% volume (or the dial at 12 o'clock). This brought the sub to +8.5dB!
I re-ran the test two more times and in the end, the sub volume dial is at roughly 75% or (3/4 o'clock). This got me to -6.0dB. I then hooked up the Radioshack SPL and dialed in all the speakers to 73dB, with the center at 75dB. I then increased the subs level to -3.0 on the Yamaha software (leaving the volume dial at 3/4 o'clock). It also set the crossover to 100Hz. With that said, I then matched the physical crossover dial on the sub to 100Hz, instead of 120Hz. Is that correct? Or should I leave the sub dial maxed no matter what?
With those settings, I'm sitting at a listening level of -15dB or so on the receiver, which puts the volume at a proper theater level, IMO.
Does this setup or configuration sound right? I think I'm going to bump the sub up a bit more. Which way should I do so? Increase it through the Yamaha software, or should I increase the physical dial on the sub? In the room, you can hear the bass, but you don't feel it as much as you do when on the floor above!
Thank you!
jnick1 is offline
post #16462 of 27440 Old 08-06-2014, 02:13 PM
niccolo's Avatar
Quoted: 138 Post(s)
Liked: 39
Totally agree empirical experience is ultimately what's relevant, just trying to calibrate my expectations to better understand what I might be listening for when I do experiment.
I don't get much if any port noise, though I do get those delayed puffs of air out of the open port after serious ULF scenes, e.g. the helos in Lone Survivor. But that's perfectly normal.
I have an open floorplan space that's probably around 4800 cubic feet, so a lot of volume for the sub to pressurize.
The one additional thought I had on two-port versus one is that when the sub driver is moving 2 inches to send out some 14 hz content, almost by definition that seems like it should be temporarily impeding its ability to properly produce content a bit higher in the frequency spectrum. But I'm not knowledgeable enough to know whether my hunch is actually true in practice.
Rythmik FV15HP sub
niccolo is offline
post #16463 of 27440 Old 08-06-2014, 04:21 PM
bear123's Avatar
Quoted: 1665 Post(s)
Liked: 2431
@janick 1. Sounds like you should be able to bump your sub trim another 2-3 dB in your avr sub trim setting with no issue. If it still lacks bass , you may need to adjust placement or phase.
I would leave the sub crossover disabled, especially if you ran YPAO in that configuration. I would not change the crossover on the sub without the need to do so determined by careful measurement with REW.
bear123 is offline
post #16464 of 27440 Old 08-07-2014, 03:43 AM
steveting99's Avatar
Quoted: 1778 Post(s)
Liked: 605
Thank you!
jnick1,
You should be using the LFE input on the Rythmik, this allows the AVR to set the correct level and distance based on where you placed the mic in YPAO. Look at post 16,132 Official Rythmik Audio Subwoofer thread and the write-up (Dialing-in subwoofer when using AVR_Rythmik PEQ3 amplifiers.doc) that AVS member laulau did for a friend. While this is written mainly for Audyssey setup, it would apply just as well for YPAO.
Which model of Yamaha do you have? My understanding of YPAO is that only the top end Yamaha unit eq the sub (crudely at 3 fixed frequencies with 1/3 octave adjustments). Other AVS members such as Bond007 who's familiar with Yamaha AVRs can advise more on this. So it's best to carry out a low frequency sweep (15Hz to 300Hz) using REW to see where YPAO is making a difference - if any. There is a PEQ available on the Rythmik plate amp, use it to cut the big peak bass frequency (based on REW measurement) and smooth out the bass. Remember not to boost nulls as this is asking for trouble.
The great thing about the MiniDSP is the ability to use 6 PEQ filters and easy integration with REW. Use the Room EQ fuction in REW and make a curve you like. Then export the settings to a text file, which can be directly read into the MiniDSP. You must have a bass measurement done by REW to play with this feature.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
Last edited by steveting99; 08-07-2014 at 03:49 AM. Reason: typo and additional clarification.
steveting99 is offline
post #16465 of 27440 Old 08-07-2014, 09:32 AM
Sean Spamilton's Avatar
Quoted: 326 Post(s)
Liked: 354
Originally Posted by steveting99 View Post
jnick1,
You should be using the LFE input on the Rythmik, this allows the AVR to set the correct level and distance based on where you placed the mic in YPAO. Look at post 16,132 Official Rythmik Audio Subwoofer thread and the write-up (Dialing-in subwoofer when using AVR_Rythmik PEQ3 amplifiers.doc) that AVS member laulau did for a friend. While this is written mainly for Audyssey setup, it would apply just as well for YPAO. I've got my crossovers set to 80 and there seems to be no ill effects in that area:
[/IMG]
FWIW, it's my understanding the AVR would set the correct distance and level regardless of whether he uses the LFE IN or one of the LINE IN's - as long as he's got the crossover on the sub all the way up. The AVR will set it's crossover point where it detects the lower end of his speakers range to be (or where the user subsequently sets it), and will only send the signal below the crossover point to the subs. (I realize crossovers are not a brick wall which is why one would have the crossover knob turned all the way up) In my case I have to use the LINE INs as using the LFE input disables the phase and crossover knobs - (and I need to adjust the phase in my particular situation).
I'm crossed over at 80 (on the AVR, the sub crossover is at max) using the LINE inputs, and there doesn't seem to be any ill-effects:
Sean Spamilton is online now
post #16466 of 27440 Old 08-07-2014, 10:44 AM
jnick1's Avatar
Quoted: 56 Post(s)
I am using the LFE IN on the Rythmik LV12R. I'm using a Yamaha RX-V675.
Yamaha RX-V675 | Primus 363s fronts | Primus 163 rears | Primus 351 Center | Rythmik LV12R Sub
jnick1 is offline
post #16467 of 27440 Old 08-07-2014, 10:51 AM
JT78681's Avatar
Liked: 834
Hey man how are you liking the Infinity's?
JT78681 is offline
post #16468 of 27440 Old 08-07-2014, 11:44 AM
jnick1's Avatar
Quoted: 56 Post(s)
Couldn't be happier! I was surprisingly shocked at their clarity. I'm sure you can get much better speakers for $$$, however these are fantastic.
When I lived with my parents, I set my dad up with Infinity 251, 143s and 163s. I thought that sounded good and was expecting a similar sound. However, these definitely sound much clearer and cleaner. We actually have a relative from Scotland over to visit and he wanted to check the system out. He said it's better than any Cinema he's been to. Of course it's all relative, but in a nutshell, I love em'!
Now I just want to fine tune the sub a bit more and I'll be a very happy camper!
jnick1 is offline
post #16469 of 27440 Old 08-07-2014, 12:03 PM
JT78681's Avatar
Liked: 834
For what they cost and the performance they offer they are really hard to beat. I have no desire to upgrade my speakers for a long time.
JT78681 is offline
post #16470 of 27440 Old 08-07-2014, 12:32 PM
jnick1's Avatar
Quoted: 56 Post(s)
Indeed...I'm extremely happy with the decision to go with these, and I got every one on sale to boot!
jnick1 is offline
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
