Official Rythmik Audio Subwoofer thread - Page 550 - AVS Forum | Home Theater Discussions And Reviews
 3185Likes
post #16471 of 27834 Old 08-07-2014, 07:00 PM
steveting99's Avatar
Quoted: 1785 Post(s)
Liked: 612
Originally Posted by Sean Spamilton View Post
FWIW, it's my understanding the AVR would set the correct distance and level regardless of whether he uses the LFE IN or one of the LINE IN's - as long as he's got the crossover on the sub all the way up. The AVR will set it's crossover point where it detects the lower end of his speakers range to be (or where the user subsequently sets it), and will only send the signal below the crossover point to the subs. (I realize crossovers are not a brick wall which is why one would have the crossover knob turned all the way up) In my case I have to use the LINE INs as using the LFE input disables the phase and crossover knobs - (and I need to adjust the phase in my particular situation).
I'm crossed over at 80 (on the AVR, the sub crossover is at max) using the LINE inputs, and there doesn't seem to be any ill-effects:
Sean,
That's a great looking graph! Wonder how the waterfall / spectrograph looks like? Is this with the sub + the center channel only or left+right, left only or right only? Are you using multiple subs, room treatments and Audyssey XT32 to get that smooth response? How is the seat to seat variance like? Would have liked to see up to 300Hz to see at least an octave up above the crossover point. Based on your speaker specs and your graph, you can crossover from 50Hz up to 90Hz and have a smooth splice. Have you considered a low shelf filter with a rise of say 2 to 3dB per octave from say 100Hz down? Some like this based on the Fletcher-Munson loudness curves.
jnick1 has advised his sub being the LV12R. Using the LINE IN, the upper frequency is 100Hz.
As jnick1 is interested in a relatively high crossover (100Hz and up), he would be better off using the LFE IN (which he's confirmed in the following post). That's because using the LFE IN, the upper frequency is 300Hz. Refer to Rythimk's specs here: http://www.rythmikaudio.com/LV12R_specs.html
The quest for jnick1 (as well as for me) is to get a response similar to what you've got.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #16472 of 27834 Old 08-07-2014, 07:54 PM
Sean Spamilton's Avatar
Quoted: 339 Post(s)
Liked: 364
Originally Posted by steveting99 View Post
Sean,
I only have experience with plotting the FR response actually. I did have a look at the waterfall graph, but didn't really know how to read it. From the little I've gleaned in that respect I don't think it decays quickly enough - but at least I have a pretty FR from 10 to 100. I should have read further back in the thread as far as I didn't realize Jnick wanted such a high crossover. I'm surprised as anything over 100 would make the subs localizeable so I assume he's running stereo subs - anyways I'll read back so I have a better idea anyways of what's going on in the thread .
After 100 my FR doesn't look as hot - there's some serious nulls that I'll need to experiment more / consider room treatments / buy a mini DSP to deal with. I'd be happy to show you to 300 but you'll have to wait a little while as I'm fairly busy this weekend getting ready for a 3 week trip to Ireland.
FWIW I use XT32, and have dual subs. It took a lot of experimentation and moving subs around to figure out the best spot for them (in my case at the front wall 4/5 location and the back wall 4/5 location. The sub at the rear's phase is set to 180 (thus my need to use the Line In) - which I discovered through experimentation works quite well in my environment. Although altering the distance / delay in the AVR is preferred so I understand, the phase setting works best in my case. I measured my subs around my room until I found the best place for them without audyssey - then ran the room correction, which did help tame a peak and bring a null up somewhat. That response is measure with the sub and the right (or left) front speaker I believe. As far as the Fletcher-Munson curves, I assume that's what is commonly referred to as a house curve? - wouldn't running the subs 3db hot accomplish a similar effect?
Cheers!
Sean.
Sean Spamilton is offline
post #16473 of 27834 Old 08-07-2014, 08:39 PM
jnick1's Avatar
Quoted: 56 Post(s)
Hey guys,
Just want to clarify that I DONT want a high crossover. I was told to run YPAO and it will tell me what my crossover should be. When I ran YPAO it said the crossover was 100Hz. That's where the number came from. In all honesty, I have no idea what it should be. I always was under the impression that the crossover should be 80Hz. However the LV12R documentation says to set the dial maxed, to 120Hz and my receiver thought I needed it at 100Hz. Any input is definitely appreciated.
And again, not sure where I said it, but I am most definitely using LFE IN for the sub connection .
Also note that I am only running one sub.
Yamaha RX-V675 | Primus 363s fronts | Primus 163 rears | Primus 351 Center | Rythmik LV12R Sub
jnick1 is offline
post #16474 of 27834 Old 08-07-2014, 08:42 PM
Bond 007's Avatar
Quoted: 2371 Post(s)
Liked: 1907
Originally Posted by jnick1 View Post
Hey guys,
Leave the LV at 120. Listen at 80-100 in the AVR and use what sounds best.
Bond 007 is offline
post #16475 of 27834 Old 08-07-2014, 08:54 PM
niccolo's Avatar
Quoted: 139 Post(s)
Liked: 39
Hey guys,
You are conflating two different things. Since you are using bass management in your AVR, you don't need to also impose a crossover in your sub. So by maxing out the dial on your sub, you're just allowing anything the AVR sends to the sub to get through, which is a good thing.
As for the AVR setting, the usual wisdom is that you can raise the crossover your room correction software suggests, but you're generally not advised to lower it. That said, if you're not really cranking the sound, you're probably safe to experiment with 80 hz instead of the 100 hz it recommended, and see how the sound compares, whether it affects subwoofer localization, etc. But you shouldn't feel bad about 100 hz, lots of folks choose a higher crossover like that, and as long as you're not having localization issues with the sub, it may actually result in better home theater sound.
Benq W1070 projector w/ Chief RSM mount with custom interface bracket
119" Da-Lite Cinema Contour with High-Contrast (gray) Da-Mat screen
Denon X2000 receiver fed by Panasonic DMP-BDT210 Bluray player
Focal Chorus 700-series towers and center, JMLab Tantal 500-series bookshelf rears
Rythmik FV15HP sub
niccolo is offline
post #16476 of 27834 Old 08-07-2014, 09:48 PM
Quoted: 339 Post(s)
Liked: 364
Hey guys,
Ok well if you're using the LFE in as was mentioned it doesn't matter where you've got the dial on your sub. The phase and crossover on your sub is bypassed in this case.
Regardless of whether you use LFE in or LINE in - YPAO is telling you where it thinks you need to cross your subs over in the receiver. Forget about your subs for the moment. Regardless of whether you even have a sub - it's measuring what the lowest frequencies it thinks should be sent to your speakers, which is 100hz. It does this as that's what YPAO thinks is the LOWEST frequency your front speakers will handle. It will (ostensibly) automatically set it to 100 after having run YPAO. Don't adjust it down afterwards in the receiver. In any case what that means is that the receiver will divide the signal in half, sending everything over 100 to your speakers (at which YPAO has decided the ideal crossover point is/ lowest frequency your fronts can handle) and 100 and below to your sub. Again as you're using the LFE in it doesn't matter where you've got the knob on the sub at. If you WERE to use the Line in (which you would only do if you needed to have the sub do the aforementioned frequency routing - {which you don't because your receiver is doing it} OR you wanted to use the phase knob - which is really only recommended after you've exhausted every other option to achieve a satisfactory frequency response) you would then set the crossover frequency knob to max just to make sure it's not interfering with the signal coming from the receiver. To be clear your receiver is routing only 100hz and down one way or the other after running YPAO - but you wouldn't want to use line in and have the crossover knob set to 60 - as basically the sub would create it's own crossover point and you'd lose everything between 60 and 100. If you set it to 120 it would function properly (basically it wouldn't do anything which is what you'd want).
Do you have dual subs you're trying to equalize?
EDIT: Reading back through the thread it seems you've done it correctly. The best way for you to know just how effective YPAO has been, or your placement has been with your sub(s) is to use REW with a measurement mic. You could probably do a rough estimate of your success with a rat shack meter - but it would be WAY easier if you had a usb mic such as the Umik or UMM-6 to use with REW. REW has a room simulator where you set the distance of your room (length x width) and place your subs into the simulator to get a simulated curve. You don't need the mic to run the simulator and it might be helpful if you're looking for ideas for placement. Otherwise get the actual measurement mic - not only will you actually KNOW what's going on in your room but it's fun to boot
post #16477 of 27834 Old 08-08-2014, 09:00 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 230 Post(s)
Liked: 314
I also agree with what you have done. I need to emphasize it is OK to use line inputs. Everyone should try it. There are other posting against it because LFE inputs, on the other hand, simplifies control. But once becoming familiar with bass management, one really has to hear the difference before deciding which way is the right away to go.
Rythmik is offline
post #16478 of 27834 Old 08-08-2014, 11:43 AM
laulau's Avatar
Quoted: 77 Post(s)
Liked: 107
...When I ran YPAO it said the crossover was 100Hz. That's where the number came from. In all honesty, I have no idea what it should be. I always was under the impression that the crossover should be 80Hz. However the LV12R documentation says to set the dial maxed, to 120Hz and my receiver thought I needed it at 100Hz.
I don't have any hands-on experience with YPAO, but can't help but think that if YPAO is choosing a 100Hz xover for your Primus P363's, then something is wrong. Those speakers are supposedly flat down to 38Hz so you'd think that YPAO would be detecting the lower F3 somewhere close to that. Could be that you're getting a bunch of odd reflections where you currently locate the microphone or perhaps you've got a bad mic (unlikely but possible). You might want to re-locate the microphone, hang a blanket on any hard walls, re-position drapes on any windows, etc., then re-run YPAO until it chooses a xover closer to the 38Hz that your speakers are capable of. Once you achieve that, then you can experiment with xovers (anything equal to or higher than what YPAO chose) until you find something you like. ...IMO.
Salk STRT / SongCtr-RT / SongSurr I ; Rythmik F12 (x2) (latest ver of my setup guide) ; Denon 4520CI; D-Sonic M2-800S; Oppo BDP93; Panny 65VT50; BJCables; NAS DLNA; Chromecast; Harmony One; Furman Elite-15 PFi; Omnimic & REW; CalMAN 5 HT i1D3 & i1Pro2 ::Headphones:: RPi3 w/Digi+ > AGD DAC19 > Cavalli LC > HFM HE400i & Meze 99 Classics :: CCA > Schiit Bifrost 4490 > Schiit Valhalla > Senn HD600 & HD6XX :: FooB2K > Schiit Modi2U > Schiit Magni2U > Oppo PM3
laulau is offline
post #16479 of 27834 Old 08-08-2014, 12:08 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
I just got my spl meter. Now what? Do i need to use my spl to tweak my speakers to get to 75db and lv12r too? Then run my audysey? Or tweak all of them after audysey?
caloyzki is offline
post #16480 of 27834 Old 08-08-2014, 04:04 PM
Quoted: 339 Post(s)
Liked: 364
Here's a link to a guide on how to measure your frequency response using a SPL meter:
http://forum.blu-ray.com/showthread.php?t=38765
TBH - that seems like a TON of work.. I'd (personally) focus on my subwoofer response up to 100hz and leave the rest to YPAO.
The idea then would be to play back and measure at the main listening position (MLP) a series of test tones from 10 or so to 100hz - and take note of the response fluctuations at each frequency. If there are 10 measurements you would want the least amount of variation between each measurement. So if the sub was in position A and you had major variations (55db at 40hz, 80db at 65hz) vs position B where you had smaller fluctuations (70db at 40hz, 73db at 50, 68db at 60hz etc) then that's where you'd want to place your sub.
I'm probably doing a poor job of explaining it - make sure to read the guide I linked - failing your endeavors with the SPL meter just go buy a USB mic to measure with REW (it's much easier - and there's a whole thread here on AVS dedicated to helping people get up and running with their new mics).
The previous poster brings up a good point about YPAO - your P363s should indeed play MUCH lower than 100hz - perhaps you can measure your frequency response at the MLP using your SPL meter and just the front speakers (without having the sub on) to verify that they are playing back those lower frequencies (they should be). Try moving your speakers out from the wall an inch or two, and toeing them in or out ... a matter of inches can make a major difference!
post #16481 of 27834 Old 08-09-2014, 02:01 AM
docbrazen's Avatar
Been living with my FV15HP for 2 months now and I can honestly say it has been the best audio upgrade I have done. Having a subwoofer makes movies and TV shows so much more visceral. I find it funny a lot of my guest think it's an end table because it's so large and also because I keep it nearfield to the sofa. Luckily my decor is dark so the black oak matches nicely.
My next upgrade is probably going to be an audio cabinet of some sort so I can move my PS3, HTPC, AVR, Harmony Smart Control hub and make room for a center speaker. I'm having a heck of a time finding a good audio cabinet though. Already bought one cabinet and returned it because it was so ugly looking. Found Salamader Designs on the internet, but boy are they pricey when compared to everything else in my Ikea equipped living room. What is everyone else using for an audio cabinet/rack?
docbrazen is offline
post #16482 of 27834 Old 08-09-2014, 04:50 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Doc---Take a look at the Solid Steel racks at Music Direct. There are a few of the 5 Series that they are selling at close-out prices. Really well designed and built (except perhaps for the 3/4" MDF shelves), and good looking.
BDP24 is offline
post #16483 of 27834 Old 08-09-2014, 07:57 AM
rcohen's Avatar
Quoted: 1208 Post(s)
Liked: 517
Hey guys,
Usually, the receiver suggests a crossover frequency where it measures your speakers roll off of -3db. This could happen based on the speaker or the placement. 100hz is a totally reasonable value. The only way to tell what's really going on is to measure it with a program like REW and a measurement mic, and have a look. Alternately, you can try different crossover frequencies to see what sounds best. Just make sure you have the phase aligned at the crossover frequency.
rcohen is offline
post #16484 of 27834 Old 08-14-2014, 07:00 PM
LowellG's Avatar
Quoted: 523 Post(s)
Liked: 203
Has anybody here ever personally compared a FV15HP to a PSA XS30? I still wonder if I am missing anything. I am looking for more chest thump. My move reference is the opening scene in Battle LA for about the first 2-3 minutes. Or many movie scenes with a .50 cal gun.
Lowell
The MarvelAtmos Home Theater: http://www.avsforum.com/forum/19-ded...e-theater.html
LowellG is offline
post #16485 of 27834 Old 08-15-2014, 05:57 AM
JT78681's Avatar
Quoted: 1375 Post(s)
Liked: 898
I don't think anyone in here has experience with both. I would try asking this in the PSA thread as well.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is online now
post #16486 of 27834 Old 08-15-2014, 07:52 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5205
The FV15hp is going to excel in the 12-30hz range, the XS30 is going to excel in the 40-120hz range. Chest thumping bass is normally around 80hz. If you want more bass in that area perhaps you should start by measuring your response and make sure you are not sitting in a null.
basshead81 is offline
post #16487 of 27834 Old 08-15-2014, 08:24 AM
LowellG's Avatar
Quoted: 523 Post(s)
Liked: 203
Ugh. Looks like I'm going to have to break down and buy all the equipment to run REW. I watched a tutorial on YouTube the other night and it doesn't look like a simple program. I am still not sure what to buy or what all I need
However I am glad to hear that maybe the problem. I really didn't want to take the loss on my PSAs.
Bad thing is my room size does not leave a lot of options for placing subwoofers
LowellG is offline
post #16488 of 27834 Old 08-15-2014, 08:38 AM
bkeeler10's Avatar
Quoted: 296 Post(s)
Liked: 175
It's actually not that hard to get going with basic measurements in REW. Especially if you have a computer with an HDMI output - then all you need is a $75 microphone from miniDSP and a little bit of time to set it up.
bkeeler10 is online now
post #16489 of 27834 Old 08-15-2014, 09:38 AM
tvuong's Avatar
Quoted: 1544 Post(s)
Liked: 874
^^ +1 but get the mic from crossspectrum around $100 instead.
tvuong is online now
post #16490 of 27834 Old 08-15-2014, 10:40 AM
LowellG's Avatar
Quoted: 523 Post(s)
Liked: 203
I found the umik-1. USB. Is that the one. Where does the hdmi fit in and that's all I need.
LowellG is offline
post #16491 of 27834 Old 08-15-2014, 11:03 AM
bkeeler10's Avatar
Quoted: 296 Post(s)
Liked: 175
HDMI is the easiest, cleanest way to get REW's test signals into your AVR or pre-pro. So just configure one of your AVR's HDMI inputs for your computer, then make the connection between your computer and the AVR.
Good point made about getting the mic from Cross Spectrum. Apparently they have a more complete calibration, including calibration all the way down to single-digit frequencies. Probably worth the extra bit of cost.
post #16492 of 27834 Old 08-15-2014, 12:57 PM
LowellG's Avatar
Quoted: 523 Post(s)
Liked: 203
I already have my receiver connected to my HTPC through HDMI. So I guess I'm good to go with that Mic. Is that Mic the one you're calling a cross spectrum
LowellG is offline
post #16493 of 27834 Old 08-15-2014, 01:54 PM
tvuong's Avatar
Liked: 874
^^ you are all set then. I also use HTPC with HDMI as source. Just download and install REW from Hometheatershack and buy the crossspectrum MIC. I have the UMIK-1 from crossspectrum.
post #16494 of 27834 Old 08-15-2014, 05:22 PM
Liked: 612
Get a calibrated mic from Cross Spectrum Labs here: http://www.cross-spectrum.com/
AVS member Jerry Austin has generously written a step-by-step guide here: Simplified REW Setup and Use (USB Mic & HDMI Connection) Including Measurement Techniques and How To Interpret Graphs
The guide contains a few gems of information in general. There is some basic assumptions and equipment you'll have beforehand, this includes:
(1) A windows laptop/PC with a HDMI and USB port;
(2) HDMI and USB extension cable(s); and
(3) Boom stand mic.
Once you're familiar with REW, it is a very useful measurement tool.
post #16495 of 27834 Old 08-15-2014, 06:01 PM
LowellG's Avatar
Quoted: 523 Post(s)
Liked: 203
(3) Boom stand mic.
Thanks to all for the advice so far.
So the difference with cross-spectrum is the USB drive with the frequencies for $20 extra over buying the UMIK-1 direct from miniDSP?
Also, so if you use my HTPC connected to my Denon X4000 and projector I will only need an extra long USB cable, correct?
Lowell
LowellG is offline
post #16496 of 27834 Old 08-15-2014, 06:09 PM
rcohen's Avatar
Liked: 517
Cross Spectrum is the way to go, because it includes a 90 degree measurement file. That's worth the extra $20.
rcohen is offline
post #16497 of 27834 Old 08-15-2014, 06:14 PM
tvuong's Avatar
Liked: 874
Yes, long extra USB extension cable that allows you to place your mic at MLP. The crossspectrum one is individually calibrated for the unit you buy, 90% measurement and can measure down to single digit hz which makes it worth over the miniDSP one.
post #16498 of 27834 Old 08-15-2014, 06:31 PM
LowellG's Avatar
Quoted: 523 Post(s)
Liked: 203
Just ordered one from Cross-Spectrum. Thanks for all the help again. Hope to be calibrating by next weekend.
Lowell
LowellG is offline
post #16499 of 27834 Old 08-15-2014, 07:06 PM
tvuong's Avatar
Liked: 874
^^ Nice. Please post graphs. Which subs do you have again?
post #16500 of 27834 Old 08-15-2014, 07:09 PM
LowellG's Avatar
Quoted: 523 Post(s)
Liked: 203
I have 2 PSA XS30s. So I should probably post the graphs in the PSA thread.
Lowell
LowellG is offline
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
