Official Rythmik Audio Subwoofer thread - Page 574 - AVS Forum
 115Likes
post #17191 of 17259 Old 12-16-2014, 03:08 PM
tvuong's Avatar
Quoted: 304 Post(s)
Liked: 138
Originally Posted by ahmedreda View Post
You will find some in my setup pictures in my signature.
@ahmedreda
Very nice room. 3FVs must be very nice. How big is the room? Got any graph of them 3 to share?
tvuong is offline
post #17192 of 17259 Old 12-16-2014, 03:11 PM
JT78681's Avatar
Quoted: 265 Post(s)
Liked: 202
^^^^ His room doesn't look that big from what I recall when looking at pictures, so those FV's must sound absolutely amazing.....
Receiver - Denon 4311CI
Speakers - Infinity P363's, PC351, P153's
Subs - Rythmik FV15HP's
JT78681 is offline
post #17193 of 17259 Old 12-16-2014, 03:22 PM
tvuong's Avatar
Quoted: 304 Post(s)
Liked: 138
Originally Posted by tcm3 View Post
Thanks. Sweet set up! I feel like I've been given an offer I can't refuse...
Show your wife Ahmedreda's room and tell her you need two of them at the minimum
tvuong is offline
post #17194 of 17259 Old 12-16-2014, 03:29 PM
JT78681's Avatar
Quoted: 265 Post(s)
Liked: 202
He should just show her this picture and tell her there are some members who have 3-4 of them in their room.
JT78681 is offline
post #17195 of 17259 Old 12-16-2014, 03:42 PM
Quoted: 23 Post(s)
Liked: 0
That is the ultimate plan, but I think I'll try the one at a time approach. It's a bit chilly sleeping outside.
tcm3 is offline
post #17196 of 17259 Old 12-16-2014, 03:45 PM
JT78681's Avatar
Quoted: 265 Post(s)
Liked: 202
Sometimes you have to swallow your pride and spend a few nights on the couch.
JT78681 is offline
post #17197 of 17259 Old 12-16-2014, 06:34 PM
steveting99's Avatar
Quoted: 411 Post(s)
Liked: 138
Originally Posted by enricoclaudio View Post
I posted on Facebook pictures of the New F8, dual 8" driver sealed subwoofer with HX580 amp.
https://www.facebook.com/rythmikaudio
It looks pretty cool!!!
enrico,
Are there any specs on the dual 8" unit? Is the 8" driver from GR Research? I've got the F12G and really like it - but it's not enough to tame the room modes. Thinking of either getting another F12G or going with 2xF8 for a new place. Would like to know the difference between the two units.
Maranatz SR-7009(on order), Oppo BPD-93, MTV 7000D, LG LW6500, aTV, WDTV Live, Harmony 650 remote, KEF E301, MiniDSP(2x4), Rythmik F12G
Last edited by steveting99; 12-16-2014 at 06:36 PM. Reason: typo and additional text for clarification
steveting99 is online now
post #17198 of 17259 Old 12-16-2014, 06:47 PM
enricoclaudio's Avatar
Quoted: 100 Post(s)
Liked: 172
Originally Posted by steveting99 View Post
enrico,
The F8 has two DS800-3 drivers made by Rythmik Audio. There is a 8" servo driver made by GR Research, the GR SW8-16FR but this driver is for OB setup. Brian is working updating the website to publish the specifications for the F8.
Best Regards,
Enrico Castagnetti
Rythmik Audio
My Multimedia Room Gallery
enricoclaudio is offline
post #17199 of 17259 Old 12-16-2014, 07:16 PM
ahmedreda's Avatar
Quoted: 49 Post(s)
Liked: 45
Thank you.. It is 12x20x8 = 1920 cuft.. This is for all 3 starting at -20 (75db) to 0 (95db). I stopped at 95db because it was starting to sound too loud..
That was before the distance tweak. The yellow curve is after the distance tweak but it is only measured at 75db..
I have issues between 100-200hz .. may be I need the F8s
@ahmedreda
dominguez1 likes this.
ahmedreda is offline
post #17200 of 17259 Old 12-16-2014, 07:35 PM
tvuong's Avatar
Quoted: 304 Post(s)
Liked: 138
^^ This is subs only, correct? You have same problem I had where if measured with MV=0, your subs were not in the 115db range. If you change the level in REW to -3dBSF (default at -12dBSF) on the measuring screen where you key in the starting and ending frequency for measurement, you will hit 115db at 0MV assuming your subs were properly calibrated. Make sure to lower your MV to start out as it will be louder sweep.
If you crossover your speakers at 80 or 100hz, your speakers will take over from there on your FR, right? Your subs is not responsible for FR above your crossover point.
tvuong is offline
post #17201 of 17259 Old 12-16-2014, 08:24 PM
dominguez1's Avatar
Quoted: 151 Post(s)
Liked: 220
Great response...love seeing the FV's in room response flat to below 10hz. Pretty amazing for a ported sub with its relatively small size. Rythmik design FTW!
dominguez1 is offline
post #17202 of 17259 Old 12-17-2014, 04:45 AM
3db
3db's Avatar
Quoted: 52 Post(s)
I don't see any updates to your web page for teh F8. I mentioned over in Audioholics in two threads under subwoofers that you have a new subwoofer product out. People are interested in them. When will see the updates?
3db is offline
post #17203 of 17259 Old 12-17-2014, 07:54 AM
Quoted: 100 Post(s)
Liked: 172
Website is not updated yet, but check on the link below for more info and specifications.
http://www.rythmikaudio.com/DS800ci_info.html
3db likes this.
Best Regards,
Enrico Castagnetti
Rythmik Audio
post #17204 of 17259 Old 12-17-2014, 09:16 AM
Blacklightning's Avatar
Quoted: 63 Post(s)
Liked: 49
enrico,
Are there any specs on the dual 8" unit? Is the 8" driver from GR Research? I've got the F12G and really like it. Would like to know the difference between the two units.
I would also like to know the differences of the F8 and F12G. They seem to be the top Music subs out right now. With a dual subs with a crossover of 100hz, what are the pros and cons.
Blacklightning is online now
post #17205 of 17259 Old 12-17-2014, 02:55 PM
Quoted: 100 Post(s)
Liked: 172
If HT is the primary use then the F12/F12G is the best option, mostly because the ability to play content below 20Hz. For pure audiophile music and no need for subsonic frequencies then the F8 is the way to go. The F12 is only +1dB louder than the F8.
Best Regards,
Enrico Castagnetti
Rythmik Audio
post #17206 of 17259 Old 12-17-2014, 05:28 PM
Chipless's Avatar
Quoted: 49 Post(s)
XLR Pin Arrangement on H600XLR2
What is the pin arrangement on the H600XLR2 amp? I will be hooking up to a Marantz 7702, so I wanted to know if I will need to swap pins on one end (see pic below for layout on the Marantz).
Chipless is offline
post #17207 of 17259 Old 12-17-2014, 08:25 PM
Quoted: 411 Post(s)
Liked: 138
enrico,
Thanks for this info.
Looks like I'll be getting a 2nd F12G then.
post #17208 of 17259 Old 12-17-2014, 09:42 PM
DonH50's Avatar
Quoted: 281 Post(s)
Liked: 309
This is one of the very few times I disagree with Enrico (note the date). My first real sub was a servo design of my own (ironically similar to the Rythmik patent, if I'd only known -- but Brian has taken the concept much further!) It was flat to about 16 Hz, and about 6 dB down at 8 Hz. There was no HT then. I needed it to supplement the low end of my little Magnepans and figured it would help with orchestral and organ music, not a huge part of my album collection but significant. What I did not expect was how the extreme low end helped with piano, small jazz groups, and rock. The percussive transients from piano, plucked strings, and drums (natch) were clearly enhanced by the extended low end. I know because I had a steep variable HPF I used mainly to combat rumble from LP records (vinyl) and wow from tape (I had 1/4" to 1" or 2" back then). I kept moving it up and down (the range was about 8 Hz to 24 Hz) and every time I listened seriously I found myself appreciating the music (music! no HT, remember?) more with the lower settings.
So, IME, extended low end is very nice to have for music as well. - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #17209 of 17259 Old 12-17-2014, 09:55 PM
Quoted: 100 Post(s)
Liked: 172
Don, I agree with you. That's why I put the note "no need for subsonic frequencies". If you do a lot of organ music and orchestra then the F12/F12G is a need. BTW my recommendation was based on a previous conversation I had with Brian. He does recommend the F12 over the F8 if primary app is HT.
Best Regards,
Enrico Castagnetti
Rythmik Audio
post #17210 of 17259 Old 12-17-2014, 10:02 PM
DonH50's Avatar
Quoted: 281 Post(s)
Liked: 309
NP. And I wasn't clear -- I designed it for organ and orchestra, but found the extended low end benefitted jazz and other music as well, a (happy) surprise.
Moving up to the present, you can have my F12's when you pry them from my cold...
DonH50 is offline
post #17211 of 17259 Old 12-17-2014, 10:16 PM
BDP24's Avatar
Quoted: 22 Post(s)
Liked: 59
Another consideration with 8" drivers is listening volume. A pair of 8's may actually go almost as low as a 12, just not to the same SPL. Or, perhaps the dual 8's actually will play as loudly and cleanly as a single 12, with the benefit of having a little more resolution. The Infinity RS-1b's I once owned had dual woofer columns containing 8" Servo drivers, but each column had 6 drivers for increased output capability. The more models Brian offers, the harder it will be to choose between them. The good thing is that there is no wrong choice---they're all great!
BDP24 is offline
post #17212 of 17259 Old 12-19-2014, 12:11 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 38 Post(s)
Liked: 79
Give me this weekend, I will add F8 page. I've already taken out F15 as its price is too close to F15HP.
Rythmik is offline
post #17213 of 17259 Old 12-19-2014, 08:48 PM
Chipless's Avatar
Quoted: 49 Post(s)
I am sure someone knows the answers to this...please don't punish me for being stupid.
Chipless is offline
post #17214 of 17259 Old 12-21-2014, 07:55 AM
JT78681's Avatar
Quoted: 265 Post(s)
Liked: 202
^^^ Chip you might want to message Brian on here aka Rythmik with this question.
JT78681 is offline
post #17215 of 17259 Old 12-21-2014, 07:57 PM
Chipless's Avatar
Quoted: 49 Post(s)
Sounds good, I will do that and update this thread to share the knowledge once I've heard back Thanks.
Chipless is offline
post #17216 of 17259 Old 12-22-2014, 09:41 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 38 Post(s)
Liked: 79
You can check out the wiki page: http://en.wikipedia.org/wiki/XLR_connector. It is a standard now. The paragraph below "Technical usage information" is an interesting read. It says there bad been problems before the standard was a adopted. The convention is the female socket is for input and male socket is for output. But I have see some 20 years, one manufacturer used female socket output. Ours implmention follows the standard (PIN 2 is always hot) which has been a while. So if you bought a US made cable, you should be fine. If you are outside US and already have the cable, just use a multimeter to make sure the pin 2 on the female side has 0 resistance to the pin 2 of the male side.
Rythmik is offline
post #17217 of 17259 Old 12-22-2014, 09:42 AM
ah_1014's Avatar
Quoted: 22 Post(s)
Hey guys,
So I got my FV15HP's on Saturday. I crossed over the boarder and picked them up in Lewiston.
I was able to dial them in a bit and did a quick calibration (did not measure all seating areas). I have some pictures to post, but will do that when I'm not at work sometime this week.
On another note I love these monsters! That is what I'm calling them because they are monster in size and output lol. The bass is more detailed compared to my Velodyne's. This is my first time experiencing subsonic frequencies and so far I'm impressed. I was able to get to -10 on my receiver with these monsters and they kept going in comparison with the Velodyne's tapping out at about -20 regarding below 50hz frequencies.
I will definitely provide more feedback in the coming weeks. Still working on getting a flatter frequency across all listening position. I'm pretty flat in the main and the right seating. I may have to rearrange some furniture as I plan to implement the Velodyne's in the mix to provide the upper bass response as my room seems to suck those out.
The first movie that I tested was Need for Speed. If anyone has not seen that movie I recommend it. The bass is awesome a lot of low content. How low? I cannot say but walls were vibrating and I was not hearing any bass, so that tells me very low lol. And that movie had an actual decent story too.
I'm a BASS addict!
JT78681 likes this.
Television: Panasonic TC-P65VT60
Receiver: Yamaha RX-A2010
Speakers: Energy RC-70's, RC-LCR, RC-10 (4), Rythmik FV15HP (2) and Velodyne VDR-12 (3),
ah_1014 is online now
post #17218 of 17259 Old 12-22-2014, 10:06 AM
Chipless's Avatar
Quoted: 49 Post(s)
Great info, thanks Brian!
Chipless is offline
post #17219 of 17259 Old 12-22-2014, 10:39 AM
tvuong's Avatar
Quoted: 304 Post(s)
Liked: 138
Originally Posted by ah_1014 View Post
Hey guys,
I'm a BASS addict!
Are you using the Velodynes with the FVs?
tvuong is offline
post #17220 of 17259 Old 12-22-2014, 11:19 AM
coli's Avatar
Quoted: 103 Post(s)
Liked: 32
FYI: I'm basically 95% music vs 5% movie, switched from a F12G to a PV1D, and my next step is moving from bookshelf (LS50) to floorstanders (R700).
coli is offline
Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer
