Official Rythmik Audio Subwoofer thread - Page 575 - AVS Forum
 115Likes
post #17221 of 17248 Unread 12-22-2014, 11:29 AM
ah_1014's Avatar
Quoted: 21 Post(s)
Originally Posted by tvuong View Post
Are you using the Velodynes with the FVs?
I am currently. Only two of the Velodynes though. It was tough getting them to play nicely. It took a few hours of phase adjustments. But I still think there is a lot more room for improvement.
Television: Panasonic TC-P65VT60
Receiver: Yamaha RX-A2010
Speakers: Energy RC-70's, RC-LCR, RC-10 (4), Rythmik FV15HP (2) and Velodyne VDR-12 (3),
ah_1014 is online now
post #17222 of 17248 Unread 12-24-2014, 10:03 AM
JT78681's Avatar
Quoted: 264 Post(s)
Liked: 202
For those of you who have receivers with Audyssey, specifically XT32, do you set your gain on your sub(s) to acheive 75db or 80db prior to running through the calibration process? Also, do you bump your center channel up any after calibration? If so, by how much?
Receiver - Denon 4311CI
Speakers - Infinity P363's, PC351, P153's
Subs - Rythmik FV15HP's
JT78681 is offline
post #17223 of 17248 Unread 12-24-2014, 10:23 AM
enricoclaudio's Avatar
Quoted: 100 Post(s)
Liked: 172
I set the gain on my subs at 78dB prior to Audyssey, then after calibration I increase the subwoofer level in my receiver by +6dB (hot). For movies my center channel is +3dB over what Audyssey set for the center channel. For music I don't use my receiver (Marantz SR7008), I do use for music a Parasound Halo P5.
Best Regards,
Enrico Castagnetti
Rythmik Audio
My Multimedia Room Gallery
enricoclaudio is offline
post #17224 of 17248 Unread 12-24-2014, 10:25 AM
tvuong's Avatar
Quoted: 301 Post(s)
Liked: 138
JT, Do you not use the gain match technique? I used to bump my center a couple db but after using the subs distance tweak to flatten the dip at xover point for my center, I no longer need to as it is crisp and clear now. You will need REW to use the subs distance tweak though.
tvuong is online now
post #17225 of 17248 Unread 12-24-2014, 11:04 AM
JT78681's Avatar
Quoted: 264 Post(s)
Liked: 202
I do yes at the beginning of calibration it asks me to lower the gain on each sub to acheive 75db, but I shoot for closer to 80db. Seems like most of the reading I have done people start at about 80db for the subs and adjust from there after calibration. That's what I shoot for and then boost both about 6db.
JT78681 is offline
post #17226 of 17248 Unread 12-24-2014, 11:12 AM
tvuong's Avatar
Quoted: 301 Post(s)
Liked: 138
If you use gain match and the reading is 80db in the first Aud step, you should be ok. What does Aud set your subs trims at?
post #17227 of 17248 Unread 12-24-2014, 11:32 AM
JT78681's Avatar
Quoted: 264 Post(s)
Liked: 202
-11
JT78681 is offline
post #17228 of 17248 Unread 12-24-2014, 11:45 AM
tvuong's Avatar
Quoted: 301 Post(s)
Liked: 138
^^ same value for both subs? even you aimed at 80db on the first Aud step, aud set your trim at -11 which makes it at 75db at this trim level. That first step is just to make sure you are within the +-12 sub trim range.
post #17229 of 17248 Unread 12-24-2014, 11:49 AM
JT78681's Avatar
Quoted: 264 Post(s)
Liked: 202
Yeah both subs showed -11 after calibration.
JT78681 is offline
post #17230 of 17248 Unread 12-24-2014, 12:10 PM
tvuong's Avatar
Quoted: 301 Post(s)
Liked: 138
^^ your subs must be at exact same distance to MLP then if both of the gain on your subs are at the same spot. In my case, using gain match, Aud never set subs trim to be the same, usually they are about 0.5 to 1.5db difference.
post #17231 of 17248 Unread 12-24-2014, 12:11 PM
JT78681's Avatar
Quoted: 264 Post(s)
Liked: 202
Both subs are equidistant to the MLP.
JT78681 is offline
post #17232 of 17248 Unread 12-24-2014, 12:13 PM
JT78681's Avatar
Quoted: 264 Post(s)
Liked: 202
When are you going to come to Austin on business, so you can stop by with a mic and REW? Your not too far from me.
JT78681 is offline
post #17233 of 17248 Unread 12-24-2014, 12:14 PM
tvuong's Avatar
Quoted: 301 Post(s)
Liked: 138
^^ work has not sent me there.
post #17234 of 17248 Unread Yesterday, 10:59 AM
tvuong's Avatar
Quoted: 301 Post(s)
Liked: 138
For those that are interested in seeing one port and two ports open, here is the comparision in my room running both sweeps at -15MV. Both with 14hz/low dampening. I am not seeing output gaining with two ports but rolling off at 20hz.
Name:	1port and 2 ports comparision.png
post #17235 of 17248 Unread Yesterday, 07:42 PM
JustABrah's Avatar
Quoted: 75 Post(s)
Liked: 67
Is this one or two fv15hp?
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
JustABrah is online now
post #17236 of 17248 Unread Yesterday, 07:55 PM
tvuong's Avatar
Quoted: 301 Post(s)
Liked: 138
^^ 2
post #17237 of 17248 Unread Today, 06:30 AM
JT78681's Avatar
Quoted: 264 Post(s)
Liked: 202
^^^^ Very strange considering Josh said in two port mode the output is higher everywhere above 20hz. I definitely felt the stronger output with both ports open versus one plugged. This is intriguing....
JT78681 is offline
post #17238 of 17248 Unread Today, 07:25 AM
tvuong's Avatar
Quoted: 301 Post(s)
Liked: 138
^^ for me, the 20hz roll off is a no no regardless of how much more output it gains.
post #17239 of 17248 Unread Today, 07:28 AM
JT78681's Avatar
Quoted: 264 Post(s)
Liked: 202
Well yeah but you should be getting strong output down to at least 16hz.
JT78681 is offline
post #17240 of 17248 Unread Today, 07:57 AM
tvuong's Avatar
Quoted: 301 Post(s)
Liked: 138
^^ per my graph, I do not get anything with useful output under 20.
post #17241 of 17248 Unread Today, 08:01 AM
JT78681's Avatar
Quoted: 264 Post(s)
Liked: 202
I know I'm saying that seems kind of pecuilar. I'm not doubting your graph.
JT78681 is offline
post #17242 of 17248 Unread Today, 08:20 AM
derrickdj1's Avatar
Quoted: 132 Post(s)
Liked: 156
The room comes into play in 1 vs 2 ports open. If the room is small there may be sufficient room gain that explains the 1 port open vs the 2 port open graph. I don't know what type of HPF or type of XO slope that is being employed for the 2 graphs. All this may also explain what is happening between the two graphs.
Klipsch RF 7 based HT 7.4, Pioneer SC 35, Acurus 200 Five, Dayton 18 Ultimxa Dual Sub Cab(2), Dayton 18 Ultimax Large Vented Sub Cab (2), on Berhinger I Nuke DPS amps, Aura Bass shakers, Samsung BDP F 7500, Asus/My Book Live HPC 4 TB
Yaquin VK 2100 amp, McIntosh XR 5 speakers, Samsung BDP F 7500
derrickdj1 is online now
post #17243 of 17248 Unread Today, 08:35 AM
PretzelFisch's Avatar
Quoted: 41 Post(s)
Liked: 158
I am trying to choose black oak vs matte finish does anyone have photos of the matte they can share?
PretzelFisch is online now
post #17244 of 17248 Unread Today, 08:58 AM
JT78681's Avatar
Quoted: 264 Post(s)
Liked: 202
Go to Google images and type in Rythmik LV12R black matte.
JT78681 is offline
post #17245 of 17248 Unread Today, 10:36 AM
Liked: 0
Newbie here - new owner of an E15HP - man this is a great sub.
costerdock is online now
post #17246 of 17248 Unread Today, 10:42 AM
JT78681's Avatar
Quoted: 264 Post(s)
Liked: 202
What newbie and the proud new owner of an E15HP and no pics? Shame.....
JT78681 is offline
post #17247 of 17248 Unread Today, 10:51 AM
Liked: 0
Thanks - I'd like to post a shot - but I have to have a few more posts to my credit to be able to post links and images.
I picked up Cloverfield on Blu-Ray - to test it out - man - I was grinning the entire time. My room is about 1K SQ ft - very small - this sub replaces a Cambridge Soundworks Basscube 10 - which sounds like a motor boat - whereas the Rythmik - is extremely clean - I'm like - is it working? Then wham!
post #17248 of 17248 Unread Today, 02:14 PM
Ataru074's Avatar
Just decided on my sub... I ordered a F15HP right now to replace a HSU STF2.
can't F* wait for the brown santa to show up at the door. :-)
Ataru074 is online now
Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer
