Official Rythmik Audio Subwoofer thread - Page 583 - AVS | Home Theater Discussions And Reviews
 149Likes
post #17461 of 17480 Old Yesterday, 12:18 PM
JT78681's Avatar
Quoted: 299 Post(s)
Liked: 222
Originally Posted by Soulburner View Post
Say you're a music lover, and you have a system with the LV12R. You then swap it out with the F12. What do you notice?
Music might be a little better with the F12, but if you watch movies you will definitely be missing that tactile feel you got from the LV12R. Just my 2 cents...
Receiver - Denon 4311CI
Speakers - Infinity P363's, PC351, P153's
Subs - Rythmik FV15HP's
JT78681 is online now
post #17462 of 17480 Old Yesterday, 12:19 PM
JT78681's Avatar
Quoted: 299 Post(s)
Liked: 222
Originally Posted by Red99 View Post
So is something going to replace the FV15HP since its on a clearance sell?
No, the FV15HP is just on sale it is not being phased out or replaced by anything.
post #17463 of 17480 Old Yesterday, 12:28 PM
PretzelFisch's Avatar
Quoted: 62 Post(s)
Liked: 159
That was there sale price till 1/29 I think. have to check facebook
PretzelFisch is online now
post #17464 of 17480 Old Yesterday, 07:57 PM
steveting99's Avatar
Quoted: 493 Post(s)
Liked: 151
Originally Posted by VarianSyn View Post
Morning,
So after a few days of research and trying to gather up all the information I could, I was talked into purchasing a Rythmik Sub for my living room from a friend. I was leaning heavily towards SVS (PB1000) and HSu(VTF2Mk4), but he's swayed me. I'm considering the LV12R and looking for some recommendations for the room state and size. I've attached a picture of what the general shape of the room is, with the rough measurements. The ceilings are 10 feet tall with exposed beams. This is where the family spends most of it's time, 90% movies / television / games, 10% music.
After spending a few days reading the whole thread and taking some information from my friend, I'd definitely like to give Rythmik a try. Just as I myself haven't dealt with them, I'm trying to get the collective thought. Thanks ahead of time folks
VarianSyn,
Your sketch is a bit hard to read - possible to enlarge it to be more legible?
Are you asking where to place the LV12R? Your room volume looks to be on the large side - what are the room dimensions? I.e. front to back, side to side and floor to ceiling?
Once you've got the sub, an easy method to determine the best placement is to carry out the sub crawl. Do a search on this thread or Google to find a link to the Axiom Audio's youtube video.
Do you have a receiver with bass management and room equalization? Go through the setup and the receiver decide the minimum crossover frequency between the speakers and sub. Look at your speaker technical details and check that the crossover is higher than what your speaker manufacturer recommends the minimum frequency to be. You can always go to a higher crossover depending on it sounds in the room.
Finally check that your crossover is smooth. This is a bit more involved and best left to last. You can do a search here in AVS called sub distance tweak to find out more.
Maranatz SR-7009, Oppo BPD-93, MTV 7000D, LG LW6500, aTV, WDTV Live, Harmony 650 remote, KEF E301, MiniDSP(2x4), Rythmik F12G
steveting99 is online now
post #17465 of 17480 Unread Yesterday, 11:53 PM
VarianSyn's Avatar
Originally Posted by steveting99 View Post
VarianSyn,
Hmmm, it was a larger size before I attached it. I mocked it up on my phone on the go, that may be the issue. Apologies. I've attached another one. Hopefully it's better.
But the ceilings are also 10 feet high, beams exposed and already has sound treatments in place. Side walls are 26 feet long, front viewing wall is 14ft 3in, back wall is the same. We've essentially cut the room in half at the fireplace with the seating being 10-11feet from the viewing area. My theater was easy, but being as I've never dealt with Rythmik before I figured I'd stop by to ask some recommendations for this particular room shape / size. My buddy pleaded a good case to me about purchasing the LV12R or possibly two over the PB1000 and VTF2MK4. I was going to go with what I know, but I figured I'd take one of his suggestions. Which led me here, to get some insight from the owners and also company voices. Being as I'd like to know if it'd be enough to potentially fill that room.
090072 - The near is ending.
VarianSyn is offline
post #17466 of 17480 Unread Today, 01:13 AM
Quoted: 493 Post(s)
Liked: 151
Your footprint is 370.5 sq. ft. (26'x14.25') and with 10'ceilings, the room volume comes out to a little over 3,700 cu. ft. That's a good sized room and the sub will 'see' the entire room volume. A single ported 12" sub such as the Rythmik LV12R is going to struggle to fill out all that volume. Any 12" ported sub will struggle with a large room volume; i.e PB1000 and VTF2MK4 will also struggle to fill out your room volume.
I'd check with Brian/Enrico at Rythmik on what they recommend for your room, but some here will suggest that you might want to consider the FV15HP (on sale now for a limited time) which is designed for large rooms up to 4,500 cu. ft. in volume.
To deal with room modes at least a pair of subs are needed. Don't make the same mistake as I did by getting a single sub and trying to shoe horn a smooth response within the room - it just doesn't work. I'm about to order the 2nd sub from Brian to smooth out the bass response in the room and get better seat to seat consistency.
Last edited by steveting99; Today at 01:27 AM. Reason: additional text for clarity
post #17467 of 17480 Unread Today, 01:21 AM
Soulburner's Avatar
Quoted: 184 Post(s)
Liked: 37
I would hope that the F12 would be more than "a little better" for $874. IMO, if the F12 was at $799 it would make a little more sense as there is such a big difference in price right now. It makes me question what I'm getting for my extra $300. Great products regardless, I'm going to end up with one of them eventually.
Soulburner is offline
post #17468 of 17480 Unread Today, 01:31 AM
Hendri Cen's Avatar
Liked: 0
Hello Enrico Castanegtti and Brian Ding,
Since i received no response from your email, so i try to contact you through this web.
I think you knew already what my sub woofer issue.
Would you please let me know when exactly that you will send the part for change? and please describe what parts anyway?
As you know my sub type is D15 Direct Servo subwoofer - Signature Edition.
Thank you very much for your attention.
Awaiting for your soonest response.
Hendri Cen
Hendri Cen is offline
post #17469 of 17480 Unread Today, 02:16 AM
laulau's Avatar
Quoted: 27 Post(s)
Liked: 57
Well, a quick review of the specs and quick guides reveals some obvious differences:
F12
1. A smaller physical size - which may factor into any WAF/placement issues.
2. A robust aluminum cone on the driver.
3. Higher quality driver with a cast aluminum basket.
4. High quality Class AB amplifier.
5. Lower extension (14Hz for the F12 vs. 19Hz for the LV12R).
6. Defeatable rumble filter.
7. More flexibility in the crossover slope choices.
8. Higher degree of damping available - Q 0.5, 0.7 and 1.1 vs. 0.8, 0.9 and 1.1 (the lower the Q value, the less ringing).
9. Parametric EQualization controls.
10. High Level inputs.
Only you can decide if the differences add value to you. For some people they do, for some they don't, I suppose.
HTH.
Soulburner likes this.
Salk SongTowers-RAAL / SongCenter-RAAL / SongSurrounds; Rythmik F12 (x2); Denon AVR-4520CI; D-Sonic M2-800S; Oppo BDP93; Panny 65VT50; Schiit Audio Valhalla; Sennheiser HD600; BJC everywhere
WDTV Live Hub; Xbox 360; Chromecast; Harmony One; Furman Elite-15 PFi; Omnimic v2 & REW; CalMAN 5 HT; i1 Display Pro 3; i1 Pro2; Salamander Designs Synergy
laulau is offline
post #17470 of 17480 Unread Today, 02:48 AM
Soulburner's Avatar
Quoted: 184 Post(s)
Liked: 37
Right, I understand all that. I'm more talking about if you did an A/B, what would you hear? I can expect potentially a smoother, slightly more controlled and "tighter" sound. But, how much? I'd love for someone who has heard both to put it into words. I'm not sure many people have though.
Samsung, Sony, Denon, Infinity, EMP, Velodyne and SVS
Samsung PN64H5000 Recommended Settings
post #17471 of 17480 Unread Today, 05:42 AM
kliiez8's Avatar
I have three questions. Q1: If I buy an FV15HP now and decide to purchase another one in less than a year, are any discounts available? Q2: Is there any added benefit to getting the XLR version if I intend to add a second FV15HP down the road? Q3: Does the sub come in a rosewood or cherry finish? I seem to recall an unboxing video that showed rosewood or cherry finish on the FV15HP, but I could just be suffering from old age
Karl
kliiez8 is online now
post #17472 of 17480 Unread Today, 06:23 AM
JT78681's Avatar
Quoted: 299 Post(s)
Liked: 222
If you bought one now and didn't buy another for 2 years the 10% discount to returning customers would still apply. I see no benefit in getting the XLR version just because you intend on adding a second FV15HP as some point in the future. The only finishes offered are black matte, black oak, and piano. You can contact Salk Sound and they could build you a custom cabinet, but that might be a little pricey or just buy the DIY kit from Rythmik and find someone local who could build you a cabinet.
post #17473 of 17480 Unread Today, 06:28 AM
JT78681's Avatar
Quoted: 299 Post(s)
Liked: 222
Might have a hard time with that unless Brian can chime in. I don't recall any Rythmik owners who have had both the F12 and LV12R. Laulau explained the differences quite well above. Basically superior driver, superior amplifier, smaller footprint, digs deeper.....
post #17474 of 17480 Unread Today, 06:49 AM
tvuong's Avatar
Quoted: 386 Post(s)
Liked: 153
The 10% discount for returning customer has no time limit. If one buys 2 subs at the same time, the 10% applies to BOTH sub.
tvuong is online now
post #17475 of 17480 Unread Today, 06:58 AM
Quoted: 62 Post(s)
Liked: 159
I have both. If you listen to music f12 with its adjustments is amazing while the lvr12 is great for movies with it's extra spl at 20. beyond that they are in two different rooms so it's hard to describe differences.
post #17476 of 17480 Unread Today, 07:09 AM
kliiez8's Avatar
@JT78681 and @tvuong thanks for the info!
Karl
post #17477 of 17480 Unread Today, 07:26 AM
JT78681's Avatar
Quoted: 299 Post(s)
Liked: 222
Well I stand corrected!
post #17478 of 17480 Unread Today, 07:44 AM
enricoclaudio's Avatar
Quoted: 114 Post(s)
Liked: 183
Hi guys. Here some pictures of the different finishes we do for the F8!!!
Black Oak, Black Matte and Piano Black with grill on
Black Oak, Black Matte and Piano Black without grill
Piano Black rear panel
rcohen and JT78681 like this.
Best Regards,
Enrico Castagnetti
Rythmik Audio
My Multimedia Room Gallery
enricoclaudio is offline
post #17479 of 17480 Unread Today, 07:51 AM
DonH50's Avatar
Quoted: 328 Post(s)
Liked: 330
Oooh, triplets, nice!
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #17480 of 17480 Unread Today, 08:40 AM
rcohen's Avatar
Quoted: 365 Post(s)
Liked: 129
I love your piano finishes with the shiny, translucent grilles and black drivers.
They are stunning in real life.
I was actually shocked how nice they looked.
I don't think the web site does them justice.
rcohen is online now
Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer
