Official Rythmik Audio Subwoofer thread - Page 600 - AVS | Home Theater Discussions And Reviews
 236Likes
post #17971 of 17983 Old Today, 12:11 AM
falconxr6's Avatar
Rythmic, you need to do something about your distributor in Australia. Seriously, he is god damn useless!
falconxr6 is offline
post #17972 of 17983 Old Today, 01:47 AM
Liked: 0
Originally Posted by BDP24 View Post
markvegas---If you read back through all the entries here, you'll find the topic of ground loop and light dimmer hum problems just like yours, and solutions for them. They seem to be common in systems hooked up to cable feeds, and of course rooms with those damn dimmers. DonH50 has provided some information and advise on low-noise dimmers in the past few months. It takes a while to read through this whole Rythmik forum, but it's time wisely invested!
Thanks for the info on the cheater plug as a means to test as this did solve the problem (all hum totally gone including when using dimmers!!
I fully agree after doing much more reading that I will be returning those cables...
As for long term solution to replace cheater plug, this was recommended that I try by Rythmik to replace my cheater plug for permanent solution: Emotiva CMX-2
I have ordered the CMX-2 and will test then report back.
markvegas is online now
post #17973 of 17983 Old Today, 02:10 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 81
Only 2 plugs
The CMX-6 looks good, but they need to give more space to those plugs. Some of the bigger AC adapters will hog 2 outlets on that thing.
Soulburner is online now
post #17974 of 17983 Old Today, 04:04 AM
BDP24's Avatar
Quoted: 52 Post(s)
Liked: 67
Originally Posted by Soulburner View Post
Only 2 plugs
The CMX-2 addresses the problem of "ground-loop hum" (caused by DC offset), the CMX-6 does not. It would appear that the CMX-6 is a six-outlet version of the two-outlet CMX-2, but it's actually not. They are made for different needs and applications.
BDP24 is online now
post #17975 of 17983 Old Today, 04:30 AM
Liked: 0
The CMX-2 addresses the problem of "ground-loop hum" (caused by DC offset), the CMX-6 does not. It would appear that the CMX-6 is a six-outlet version of the CMX-2, but it's not. They are made for different needs and applications.
Exactly. I need the extra "DC Offset" capabilities to eliminate my hum.
Question... There is no actual surge protection built-in, it says it does have the following:
Load (total for both outlets):
15 amps continuous rating. Magnetic circuit breaker allows for short-term inrush current of up to 250% of rated load.
I have two different in-wall surge protection outlets that I could plug the CMX-2 into (will plug both FV15HP's into this CMX since they are located next to each other which is temporary as I only have mirrored sub-preouts and will separate them in future when I get new receiver with XT32/SubEQ).
Here are the two outlets I have and wonder if I should use either of them or if you think it will degrade the AC Power thus affecting either or both subs performance:
Panamax MIW-SURGE-1G Single Gang In-Wall Surge Protector
or
Leviton 5280 15-Amp, 125-Volt, Decora Plus Duplex Surge Suppressor Receptacle, Straight Blade, Industrial Grade, Self Grounding, Brown
post #17976 of 17983 Old Today, 04:34 AM
Liked: 0
or
I also just read the following and it seems relevant to understanding whether or not two FV15HP's connected to a single CXM-2 would be overload for either of these two surge protection outlets...
What I read:
Learn the circuit mental ability of the main outlet you are using, along with the power requirements of the items you plan to plug directly into your Emotiva CMX-2 Precision AC Line Restoration and Common Mode Filter System. If the requirements from the items exceed the lap capacity, you are over-filling the circuit and creating a fire hazard.
post #17977 of 17983 Old Today, 04:44 AM
BDP24's Avatar
Quoted: 52 Post(s)
Liked: 67
The common wisdom amongst my crowd (hardcore perfectionist Hi-Fi guys) is that power amps (which the Rythmik subs contain, of course) are better plugged straight into the wall, not into a surge protector. They have a reputation for slightly choking the power-supply needs of amps, reducing ultimate dynamics and "slam". But that's from guys who want to eek the very last drop of performance out of their gear, possible danger-be-damned. If you live somewhere with lightning storms, etc., the risk may not be worth the difference, if any, to you.
BDP24 is online now
post #17978 of 17983 Old Today, 04:47 AM
BDP24's Avatar
Quoted: 52 Post(s)
Liked: 67
What I read:
I don't know what "lap capacity" is, but that statement suggests that it is a property of a house's wiring, not of the CMX-2. The question, therefore, is, do two Rythmik H600 amps exceed the lap capacity, whatever that is, of one outlet of your house's wiring/circuit? I doubt it.
BDP24 is online now
post #17979 of 17983 Old Today, 10:43 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 81
That is the most ridiculous thing I've heard in a while. Why call it the same product? Give it a different model number for crying out loud.
post #17980 of 17983 Old Today, 11:57 AM
BDP24's Avatar
Quoted: 52 Post(s)
Liked: 67
You mean a different prefix? 'Cause they do have different model numbers (-2 and -6), but the same prefix (CMX).
BDP24 is online now
post #17981 of 17983 Old Today, 12:22 PM
laulau's Avatar
Quoted: 28 Post(s)
Liked: 58
Learn the circuit mental ability of the main outlet you are using, ...
I'm no EE, but what the hell does that mean? "circuit mental ability"? Really?
Googled that quote and it seems that safeextensioncord.info is the only website containing those words and it says the same thing about several of the power strips mentioned on their site, so it is not CMX-2 specific. Actually, that website looks like nothing more than a click bait and/or Amazon shill site masquerading as helpful info. I would certainly view any "technical information" gleaned from there with a suspicious eye.
On the other hand, it's on the Internet, so it must be true...
YMMV.
Apologies for being OT.
Salk SongTowers-RAAL / Salk SongCenter-RAAL / Salk SongSurrounds; Rythmik F12 (x2) (My Setup Guide); Denon AVR-4520CI; D-Sonic M2-800S; Oppo BDP93; Panny 65VT50; Schiit Audio Valhalla; Sennheiser HD600; Blue Jeans Cables everywhere; Schiit Audio Fulla; RHA MA750 IEMs
WDTV Live Hub; Xbox 360; Chromecasts; Harmony One; Furman Elite-15 PFi; Salamander Designs Synergy; Omnimic v2 & REW; CalMAN 5 HT; i1 Display Pro 3; i1 Pro2
laulau is offline
post #17982 of 17983 Old Today, 03:01 PM
Liked: 0
YMMV.
In regards to quoting what I read, I must admit did not spend anytime determining the qualifications of the person who posted nor spent much time trying to interpret it's meaning... thought it would be interesting if someone who knows more than I would comment and I appreciate the responses.
post #17983 of 17983 Unread Today, 07:13 PM
BDP24's Avatar
Quoted: 52 Post(s)
Liked: 67
DonH50, where you at?!
BDP24 is online now
f12g subwoofer , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
