Official Rythmik Audio Subwoofer thread - Page 612 - AVS | Home Theater Discussions And Reviews
Old 04-25-2015, 02:25 AM
Bond 007's Avatar
Quoted: 661 Post(s)
Liked: 991
Originally Posted by agg133 View Post
I ended up lowering the volume on the amp a bit and raising the avr level from -7 db to -4 db. I think it should be fine now, I pushed it real hard and didn't get any signs of trouble/bottoming out. I think I've spent enough time messing around with the small details... time to watch some movies or something. Thanks for the help.
Enjoy!
Bond 007 is online now
Old 04-25-2015, 07:27 AM
bear123's Avatar
Quoted: 722 Post(s)
Liked: 1192
Originally Posted by JT78681 View Post
Just ordered a pair of Klipsch RF-82 II's to try out. I want to hear what a horn-loaded tweeter sounds like and I figured why not while they are on sale. If I don't like them I can return them. These will be strictly for movies.
I don't think you will be disappointed in them by any means, should be a nice upgrade. I do think your money would have been better spent on the high efficiency designs offered by RA or PSA. I know Klipsch claims extremely high efficiency from their speakers, but not sure they hold up under actual testing to those claims.
bear123 is offline
Old 04-25-2015, 09:27 AM
JT78681's Avatar
Quoted: 514 Post(s)
Liked: 327
I've heard that their numbers are a little inflated. To me they sound great. Crisp clear highs and the horns seem to cover more of the listening area than my Infinity's. It's like you can't really pinpoint where the sound is coming from. To me they are not too bright nor fatiguing as others have claimed. I have no doubt that speakers from PSA or Reaction would be better I just can't afford to spend 3x the amount of what I paid for the Klipsch to have a complete system from PSA or Reaction. To my ears these speakers sound great and play nicely with my FV15HP's. One big happy family.
Receiver - Denon 4311CI
Speakers - Klipsch RF-82 II rest coming soon
Subs - Rythmik FV15HP's
JT78681 is offline
Old 04-25-2015, 02:02 PM
bear123's Avatar
Quoted: 722 Post(s)
Liked: 1192
Oh so you already have them trying them out? Cool. I also didn't realize they were that much cheaper than the ID options mentioned. If that's the case and you are happy with them, sounds like a win...congrats! Were you able to tell if they seem more efficient than the speakers you are replacing?
bear123 is offline
Old 04-25-2015, 09:07 PM
tvuong's Avatar
Quoted: 601 Post(s)
Liked: 250
JT, what levels did Audyssey set them at? -4? What was it before with your Infinity? Those horn speakers sound better with extreme toe in. Try 45 degree or play with toe in position. Also, have them at least flush with your FVs if you have not already. Horn speakers with high compression tweeter seem to sound better at louder level. Try them at reference with the gun shot scene from Open Range and tell me what you think. Be prepare to feel that shot hitting your chest.
rman222 likes this.
tvuong is offline
Old 04-26-2015, 01:25 AM
Sam1000's Avatar
Quoted: 20 Post(s)
I'm not sure if these question are already answered about H600XLR3 amp. Really interested in getting the E15 with this option.
Please be patient guys. I had a headache while trying to make this simple to understand and I'm sure I have done a lousy job describing this.
I have a pre-pro and and a preamp that I use for Ht and 2 ch system. If I use XLR3 in dual mode, what would my connections look like?
My set up is
Sherwood 972 -> 7.1 preamp
Oppo 105 -> 7.1 preamp
2 Ch. Dac -> 7.1 preamp.
Everything is routed via 7.1 preamp (Bel Canto pre6)
So from my preamp, I would connect preamp LFE out -> LFE in of the sub?
1. how would I connect my L+R to XLR3 balanced in? In this case, the only remaining balanced input left is "L source in". Do i need to use some kind of a splitter if I use XLR3 in dual mode? DO I need to use 2 splitters? first to split the signal from L+R to sub and amp and then sum the Sub signal to a single input?
2. Do I need to level match the sub for 2 CH music using Radio Shack meter+output control behind the sub? And then rely upon my processors calibration to automatically adjust the Subwoofer trim?
3. Why can't this subwoofer have 3 XLR inputs as its name imply to make life simpler?:-) 2 for Mains and1 for LFE?
Speakers: Pioneer/TAD S-1EX, S-7EX, Ascend HTM200
Pre/Pro: Onkyo PR-SC5508,Bel Canto Pre-6, Sherwood 972
Amp: D-sonic Magnum 7-3500
Source:Oppo 105, Ciunas DAC, SB Touch
Sam1000 is offline
Old 04-26-2015, 08:59 AM
JT78681's Avatar
Quoted: 514 Post(s)
Liked: 327
Yes, about -4. I want to say Audyssey set the Infinity's closer to 0. I'll have to try the toe in position. I don't have Open Range, but it's a good movie so maybe I'll buy it.
JT78681 is offline
Old 04-26-2015, 09:49 AM
DonH50's Avatar
Quoted: 461 Post(s)
Liked: 393
Yes.
Probably need to use an XLR summer to combine L+R into the sub. Also need to ensure the prepro is off when using the pre-amp, and switch sub fromn LFE to line-in, etc.
Yes. Yes.
It's the third-generation amp. Very few people try to do what you are doing so subs are not designed for this sort of complexity. You are essentially using one sub in two different systems. Making it easier for you would make it more costly for the vast majority of folk.
You might want to run the pre-amp through the AVR and see if you can really hear any difference. If not it would simplify things immensely.
Another alternative is to use an XLR switch box to switch sub inputs to the appropriate source.
HTH - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
Old 04-26-2015, 10:53 AM
Sam1000's Avatar
Quoted: 20 Post(s)
Thx Don! You are right. The preamp is complicating things quite a bit. I have mostly kept the preamp in the chain for 2CH music. No processor in any mode has drawn me into music like this DAC+preamp combo.
So, the new sub will offer me flexibility in terms of connectivity.
Will I get any SQ improvement by going to E15-H600XLR3 from D15SE which is driven by A370 plate amp?
http://www.rythmikaudio.com/D15SE.html
Sam1000 is offline
Old 04-26-2015, 12:30 PM
DonH50's Avatar
Quoted: 461 Post(s)
Liked: 393
Since I have not heard both subs, I could say if you'll hear any sonic difference, but I really doubt it unless you have a need for XLRs and/or the extra 2.1 dB of headroom. OTOH, adding a second sub can help smooth in-room frequency response. If you've the room and funds I would get a second D15SE instead.
IMO - Don
Old 04-29-2015, 09:33 AM
enricoclaudio's Avatar
Quoted: 143 Post(s)
Liked: 197
Wanted to share these pictures with you guys. A F25 paired with Tyler Acoustics Woodmere speakers in a 5.1 Mastering Studio. Pictures courtesy of Jorge Santos at Omega Mastering (www.omegamastering.com). BTW, Jorge Santos is a 5 time Latin Grammy Award winner!!!
Best Regards,
Enrico Castagnetti
Rythmik Audio
My Multimedia Room Gallery
enricoclaudio is offline
Old 04-29-2015, 09:39 AM
Bond 007's Avatar
Quoted: 661 Post(s)
Liked: 991
Cool stuff enrico.
Old 04-29-2015, 09:49 AM
cesar123's Avatar
Quoted: 144 Post(s)
Liked: 176
Wowzah! Looks awesome. And I'm really digging those diffusrion (?) panels.
Yippee-ki-yay...
cesar123 is offline
Old 04-29-2015, 10:35 AM
tvuong's Avatar
Quoted: 601 Post(s)
Liked: 250
6 foot tall speakers? It sure makes the F25 look short.
tvuong is offline
Old 04-29-2015, 11:10 AM
Quoted: 143 Post(s)
Liked: 197
What about the center channel speaker? It's a Dunlavy Audio SC-II
Best Regards,
Enrico Castagnetti
Rythmik Audio
Old 04-29-2015, 11:28 AM
DonH50's Avatar
Quoted: 461 Post(s)
Liked: 393
Now that's a mixing studio! Thanks for sharing, Enrico, and BIG kudo's to Brian!
Old 04-30-2015, 03:32 PM
KMFDMvsEnya's Avatar
Quoted: 51 Post(s)
Liked: 137
enricoclaudio, cool setup there.
Must resist urge to upgrade, must resist... Dual F25s are perfectly reasonable purchases and imagine the bass.
I noticed on the monitor, holy clipped/compressed waveforms Batman! Making my ears hurt and bleed thinking about how it sounds.
YMMV.
Best regards,
KvE
rcohen likes this.
Politics is like a corral, no matter where you are you'll always be shovelling it.
KMFDMvsEnya is online now
Old 04-30-2015, 04:00 PM
johnnymacIII's Avatar
Quoted: 93 Post(s)
Very nice!! What does it look like he has decoupling the center channel? That would work great to place my CMT-340 SE on.
johnnymacIII is offline
Old Yesterday, 01:43 AM
BDP24's Avatar
Quoted: 62 Post(s)
Liked: 69
The owner/engineer is obviously way more serious about "good" sound than any recording/mixing studio I've been in. Your typical Rock 'n' Roll studio and engineer is not trying to get an honest/uncolored/transparent recording of real instruments in an acoustic environment (a room), but more likely a "punchy" (i.e. loud) sound that nothing to do with an instrument's real sound. Compression, equalization, synthetic reverb, etc., mock audiophile concerns. And the monitor loudspeakers in those studios are the most horrendous, highly colored things you've ever heard in your life! Auratones (car speakers!)? Yamaha NS10's? Tannoy? Oy!
BDP24 is offline
Old Yesterday, 11:09 AM
DonH50's Avatar
Quoted: 461 Post(s)
Liked: 393
I've not been a lot of them but most had a wide range of gear. Mastering used high-end gear; final mix a variety. It's a problem for a lot of genres when it's expected to sound good at home, in the car, or at the club. Stuff I was involved with often was tweaked for a good home system but we'd give a listen on other speakers (including those much-maligned NS10's) to make sure it sounded OK. I liked doing the stuff targeting audiophiles, natch, but it's a pretty small niche.
Old Yesterday, 03:19 PM
BDP24's Avatar
Quoted: 62 Post(s)
Liked: 69
Exactly! That is the very essence of the "audiophile" conundrum. The vast majority of commercial recordings are already severely compromised in sound quality by the time we acquire them on LP, CD, SACD, digital files, whatever. We assemble our home systems in a valiant attempt to be able to listen to reproduced music that bears some semblance to real, live music. But when the source material has already been "processed" to the degree and in the manner in which it has, is that even remotely anymore possible? Is it, in reality, a lost cause, being already too late? OF COURSE the business men of the music world want to make as much money as possible, and to do so target the lowest common denominator---those listeners who have bought the story that a Bose system is State of the Art, but until they have such a system, will listen to music on ear buds, car radios, the sound bars under their TV's, Home Theater systems (no offence, anyone), etc. Recordings are engineered to sound as "exciting" as possible through those kinds of systems, and there is nothing we can do to reverse that engineering. The assumption in the mass-market music business is that recordings, pre-processed, would not sound as "exciting" (i.e. louder) to their target audience if not so processed. and consumers would therefore buy someone else's "product". It has turned into a "my record is louder than your record" game. The concept of a recording capturing the natural sound of music is a quaint notion, lusted after by only 1/10th of 1 per cent of music buying consumers. Until music consumers make it clear they don't want their music produced in the way it currently is (highly processed through compressors, limiters, equalizers, digitizers---and those are just the tip of the iceberg), nothing will change. Now, go play some music on your turntable/arm/cartridge, SACD player, or 24/192 download, through your tube pre-amp and Class A power amps feeding your 6 foot tall panel speakers, and make the best of a bad situation. What choice do you have?!
BDP24 is offline
Old Yesterday, 03:32 PM
DonH50's Avatar
Quoted: 461 Post(s)
Liked: 393
My TT and tube pre- and power amps are in storage and my SACD player is broke, but my six foot tall panels are still going... As are my Rythmik subs.
Sometimes you have to forget all the %$%# and just listen to the music.
Old Yesterday, 04:20 PM
rcohen's Avatar
Quoted: 611 Post(s)
Liked: 210
This is one area that I've found to be interesting as I've gotten into speakers that focus on efficiency and dynamics.
I got into it because people said it was good for movies.
One that I've discovered is that it makes over-processed commercial music sound great (especially CD/FLAC).
In the past, I've been pretty frustrated how commercial music would sound great on crappy systems, but terrible my audiophile system.
With highly dynamic speakers, the commercial music sounds great, and great recordings sound even better.
I'm not sure, but part of me suspects that it's actually the high efficiency high dynamic speaker that's the accurate one, and that the audiophile speakers have unnatural timbres that have been tailored to appeal to random niches (combined with very pretty enclosures), rather than to deliver accurate sound. Some music sounds great on them. Some sounds awful. It's kind of random since the music was presumably mastered on neutral speakers, not the random audiophile speaker that we happen to own.
BTW, these days I'm also using Dirac to tune the target curve to one that sounds natural and lifelike, as well as sounding great on my favorite music.
rcohen is offline
Old Yesterday, 05:16 PM
BDP24's Avatar
Quoted: 62 Post(s)
Liked: 69
J. Gordon Holt, in his last couple of decades, argued the case that "audiophile" speakers were tailored to provide depth at the expense of immediacy/presence/aliveness, having a depressed frequency response right in the range affecting those sound characteristics. I think of him every time I hear a pair of Vandersteens! He contended that the more "forward" sound of horns and other high-sensitivity speakers was actually more accurate than the audiophile speaker sound, and I don't disagree. But then horns have their own colorations, don't they? It is, as always, a compromise, choosing the imperfections one prefers to live with. I've been saying for a long time that high-sensitivity speakers are the way to go for movies (where it's all about dynamics---a major failing of low-sensitivity speakers), and that it's best to have a separate system for music. But you're point that they're also good for commercial music is a sound (no pun intended) one. Listening as I do to a lot of simply-recorded acoustic music (Baroque in Classical, Bluegrass and Hard/Traditional/Alt Country in Pop), I have long been an Electrostatic user. Those have absolutely no business playing movies or commercial Pop/Rock!
BDP24 is offline
Old Yesterday, 07:44 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 138
Then there are speakers that combine quality drivers with magnetic planar (Chane Arx) or ribbon tweeters (Ascend Sierra RAAL) that are sort of the jack of all trades. You can have your "audiophile" sound but also great performance with something like Audyssey for movies. Or use it for music too, if you like (I do).
Soulburner is offline
Old Today, 07:01 AM
eljr's Avatar
Quoted: 575 Post(s)
Liked: 2866
examples of which are?
eljr is online now
f12g subwoofer , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
