Official Rythmik Audio Subwoofer thread - Page 616 - AVS | Home Theater Discussions And Reviews
 303Likes
post #18451 of 18475 Old Yesterday, 08:05 AM
tvuong's Avatar
Quoted: 649 Post(s)
Liked: 281
Originally Posted by Rythmik View Post
Tvuong, I think you meant turn down the volume on the sub and then rerun the auto calibration. This way, AVR will find the gain of sub is a bit low and therefore increase the trim level and sending stronger signal to SUB.
Other things one can do include, try to set crossover higher so that higher frequency signals can be send to SUB. That will increase the sensitivity of auto on circuit. For instance, if AVR set crossover to 40hz, there won't be as much signal to SUB compared to the case if AVR set it to 80hz.
You are right, as always. I got it mixed up.
tvuong is online now
post #18452 of 18475 Old Yesterday, 08:26 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 81 Post(s)
Liked: 106
For those wants to check L12 frequency response, here they are.
The phase information below 10hz for the last two plots are riddled with noise as the mic signal is too weak in that frequency range due to FR roll-off.
L22 will have the same frequency response which will not be repeated here. We have plenty L22 available now, ready to ship. L12 will be a while. Supplier is preparing a container load.
Rythmik is offline
post #18453 of 18475 Old Yesterday, 08:34 AM
Aliens's Avatar
Quoted: 488 Post(s)
Liked: 667
I did a lot of listening to the FVX15 last night and some this morning and could either way; open port or closed. I did feel with one closed things seemed "tighter" and more "controlled". Open gave a deeper bass and more body "feel," or what most people are accustomed to when listening to a sub. It would have helped so much more if I had someone plugging and unplugging for me so I could've listened uninterrupted. Once I get a good candidate from NF I'll give it another go. For now I think I'll keep one plugged. My old sub was ported so this provides me with a different sound from what I was used to. Last night I was in the experimental mode; tonight I'll be listening to other BDs just for the pleasure of listening.
My main demo disc last night was Michael Jackson's, This Is It. That is a well-mastered BD with tremendous bass. I played a few BD concerts, but some don't provide the kind of bass that creates the "puff" out of the ports that others do.
Aliens is online now
post #18454 of 18475 Old Yesterday, 08:52 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 81 Post(s)
Liked: 106
Originally Posted by rak306 View Post
The SW-08-16FR has an Re of 11.6 ohms. So can the HX300 drive 4 or them?
Or put another way with the HX300 power amp: 1) which would play with less distortion, 3 drivers or 4 drivers at the same acoustic output? 2) which would play louder with the same distortion?
You are correct that SW08-16FR has Re of 11.6. You can drive up to 4 drivers. The main limit is clipping. In burst mode, the 4 driver solution will provide you more output. But in steady mode, both 3 drivers and 4 drivers give you about the same output.
Rythmik is offline
post #18455 of 18475 Old Yesterday, 08:54 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 81 Post(s)
Liked: 106
I got a couple of feedback from customers and posted them on our web site under FVX15 reviews. One of them had used a pair of JL F113 before. FVX15 does not give you typical ported sub sound unless you really push it hard.
Rythmik is offline
post #18456 of 18475 Old Yesterday, 08:59 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 81 Post(s)
Liked: 106
Brian,
I understand the desire for a lighter weight cone - less power needed. But I don't understand the need for higher Qts for OB operation. Can't the servo amp change the effective Qts just like it does the other TS parameters? (e.g. On your HF amps, you have a 3 position switch that changes both the low end cutoff freq and the system Q - I think.)
I have just posted L12 plots. While that is sealed operation, OB operation has similar characteristics.
The music mode is what you will get with low Qts system and the HT mode is what you will get with high Qts system. Notice the response difference at 20hz. Frankly speaking it is not an apple to apple comparison becasue there is an extra rumble filter that rolls off below 18hz for HT and for music mode, the corner frequency is more like at 12hz. But the basic response contours are correct. So compare the roll-off FR at 12hz in music mode with the roll-off at 20hz at HT mode and that will give you the difference between low Qts and high Qts. High Qts can give you more output in the passband towards the cut-off corner frequency point. The difference can be quite dramatic. With servo, you get the raw output charateristic of high Qts driver, but you get the control of whatever Qts value you'd like to get in the actual FR plots.
Rythmik is offline
post #18457 of 18475 Old Yesterday, 11:35 AM
Liked: 3
Thanks Brian. And thanks again for working with me when I tried to order a few weeks ago.
lowayne is offline
post #18458 of 18475 Old Yesterday, 03:22 PM
goldark's Avatar
Quoted: 72 Post(s)
Greetings, fellow Rythmik owners. I'm thinking about moving an LV12R into a small office in a desktop setup. The room is small (10x8x8).
Is this a bad idea that would prevent me from having tight bass? I've heard some things about sealed subwoofers being better for smaller rooms, but would a medium-sized ported subwoofer like the LV12R overpower a room like my office? They'll be mated with a pair of KEF Q100's if that makes a difference at all.
goldark is offline
post #18459 of 18475 Old Yesterday, 03:47 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 163
Not at all. It will just be underutilized
Soulburner is online now
post #18460 of 18475 Old Yesterday, 04:37 PM
goldark's Avatar
Quoted: 72 Post(s)
My old sealed Velodyne in my office died, so the 2 options I'm considering are move the LV12R into the office and get a FVX15 for the living room, or keep the LV12R where it's at and get an L12 for the office.
I'm thinking I gotta go big or go home.
goldark is offline
post #18461 of 18475 Old Yesterday, 05:32 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 163
Is it just for music? If it were my office, I'd get an L12. Small footprint, and I wouldn't feel like I'm not utilizing it's potential.
post #18462 of 18475 Old Yesterday, 05:59 PM
goldark's Avatar
Quoted: 72 Post(s)
Yes, it's just for music. It's tempting either way. I could spend $1000 and grab the FVX15 and upgrade both rooms in the process, or just $500 and have my office be set, wondering if I made a mistake. The only downside is in a room that small, the LV12R would take up a decent amount of space.
goldark is offline
post #18463 of 18475 Old Yesterday, 06:39 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 163
Or, get a 2nd LV12R and smooth the bass in your main room, and get an L12 for the office.
post #18464 of 18475 Old Yesterday, 06:52 PM
merrymaid520's Avatar
Quoted: 26 Post(s)
Liked: 27
Question...
I own dual rythmiks. One is the D15se and other is E15. Is it possible to run two different sources (2ch preamp output & output from HT receiver) into the two RCA line ins on the rythmik amp? Only one source of course would be played at a time.
merrymaid520 is online now
post #18465 of 18475 Old Yesterday, 08:25 PM
mlundy57's Avatar
I've been off this board for awhile and have obviously missed a bunch. What is an L12? I don't see that model on the Rythmik web site.
For comparison I have an F12 in my living room.
Mike
mlundy57 is online now
post #18466 of 18475 Old Yesterday, 08:51 PM
mlundy57's Avatar
HX300-8OB Question
I have recently finished building a pair of open baffle H-Frame bass modules using three SW-8-16FR drivers and an HX300-8OB amp per module.
The way I have my system set up I have two preamps, a Marantz AVR for movies and a Jolida Tube preamp for music.
Each preamp is connected to an inline filter with a by-pass circuit. The main signal is filtered through a capacitor to limit the low frequencies seen by the midrange/tweeter unit. The filtered signal is then connected to the power amp. The by-pass circuit sends a full range signal to the sub.
Both preamps will be connected to different inputs of the same power amp. The by-pass circuits will be connected to the sub.
Is it possible to connect one of the by-pass circuits to the sub with the RCA input and the other with the XLR input? Both preamps would not be on at the same time. The Marantz would be on when watching movies or TV and the Jolida would be on when listening to music.
Mike
post #18467 of 18475 Old Yesterday, 09:19 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 163
Mike
Think of it as an "economy" version of the F12, built similarly to and priced slightly under the LV12R.
post #18468 of 18475 Old Yesterday, 09:34 PM
mlundy57's Avatar
Thanks. How much under? I was getting ready to get an LV12R for my daughter but an L12 might be a better fit for her room.
post #18469 of 18475 Old Today, 08:04 AM
BB1111's Avatar
So is the F8 intended to be a "mid-bass module"? I cannot find any reviews on it, and it's not even listed in the products section of the website.
Would this be a compliment to something like a FV15HP?
BB1111 is offline
post #18470 of 18475 Old Today, 08:51 AM
Bond 007's Avatar
Quoted: 682 Post(s)
Liked: 1026
If you click on "subwoofers" the F8 is listed.
Bond 007 is online now
post #18471 of 18475 Old Today, 09:29 AM
johnnymacIII's Avatar
Quoted: 109 Post(s)
I currently have a LV12r. However, I was thinking of upgrading to a FV15hp. My room is 13x18x8 (enclosed).
I was thinking of upgrading only because I love the clean and quick sound of the high setting on my LV12r, but it doesn't work for me in movies. I don't feel the bass as much. For example, in the Incredible Hulk when he is being hit by the sound cannons, I felt it on medium, but nothing on high. I'm not sure if it's because of the compromised extension or if it's because of the high damping setting. Could someone chime in on this.
Do any of you use the high damping setting paired with the low extension setting on the FV15hp and how does that work for you in movies or is a q of 1.1 the way movies are supposed to sound and should I just be using that setting?
johnnymacIII is online now
post #18472 of 18475 Old Today, 10:29 AM
AlexanderDelarg's Avatar
Quoted: 89 Post(s)
Liked: 117
How does the Hulk scene sound on low? I keep mine on low for my HT and love it. Of course, going to a FV15hp would be awesome.
Epson Pro Cinema 6030 | OPPO BDP - 103 | Pioneer Elite VSX 70 | Definitive Technology PM 1000 (L/R) | PC 2000 (C) | SR8040BP's (7.1) | Rythmik LV12R | Carada Criterion Brilliant White 118" | URC MX 780 & MRF 350 | ATS Acoustic Panels | Sanus AV Rack | DirecTv | Roku 2 | Monoprice 12AWG |
AlexanderDelarg is offline
post #18473 of 18475 Old Today, 10:42 AM
JT78681's Avatar
Quoted: 538 Post(s)
Liked: 344
Fantastic
Receiver - Denon 4311CI
Speakers - Klipsch RF-82 II's, RC-62 II, RB-61 II's
Subs - Rythmik FV15HP's
JT78681 is offline
post #18474 of 18475 Old Today, 04:12 PM
Liked: 0
Which amp would I need, and how would I hook up a sub to a pair of XLR studio monitors?
This is my source.
DooberKnob is online now
post #18475 of 18475 Old Today, 04:22 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 163
This has me thinking. If you wouldn't mind commenting on this:
When we look at the frequency response charts of ported vs sealed subs, what we see is that port tuning on a sub gives a good boost usually around 20Hz, plus or minus a few. In theory, you could EQ the ported sub down so that both showed similar output at that frequency range. However, would they still sound different? Is there something about the "ported sub sound" that we can't see from looking at the FR?
f12g subwoofer , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
