Official Rythmik Audio Subwoofer thread - Page 652 - AVS Forum | Home Theater Discussions And Reviews
 3185Likes
post #19531 of 27834 Old 07-01-2015, 08:43 AM
JT78681's Avatar
Quoted: 1376 Post(s)
Liked: 899
Originally Posted by tvuong View Post
^^ I have heard lots of big boy subs including pair of cap2400, 3 SubmersiveHP, 8 DIY 18"SI's, 3 Triaxes, and most recent a pair of Deep Sea Sound 24". All of these has more output than my FV only if they were running 6 to 10db hot at close to reference MV. They were really pounding and pressurizing the room. My FV pair can really damage my room and the room next to it plus everything below it if I crank them to reference. In my opinion, the FV pair should be enough for most people minus most AVSer's (you are one of them). Remember the FV is categorized as for extreme large room by audioholic, so a pair of FV should be plenty for your room. If I were you, I wouldn't upgrade to the Echo18 and find yourself upgrading again as you have been doing. Why takes a small step? What if after getting the Echo18, there is a FV18hp, Echo218? Upgrade again? These forums are great but very bad for the wallet if one does not draw a line.
I thought I responded to this, but I guess I never did. So let me get this straight your telling me that unless I listen at very high volumes or run the Echo 18 very hot it will have no advantage in output over an FV15HP? It has more displacement a bigger cabinet and a more powerful amplifier.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #19532 of 27834 Old 07-01-2015, 09:07 AM
tvuong's Avatar
Quoted: 1544 Post(s)
Liked: 874
Originally Posted by JT78681 View Post
Okay I'll take your word for it and try it. Anything special I should change or adjust in the generator? Obviously I will check the sub cal.
1. Set both sub trims in Avr to 0 as starting point.
2. Set Avr master volume to 0.
3. Turn off aud.
4. Open REW spl tool and click the red button. Drag this window to a spot on screen so you can see it.
5. Select hdmi out 4 in REW preference.
6. Open REW signal generator and select pink noise, sub cal with -30db FS RMS level.
7. Click the green play button and observe the spl in REW spl window. I assume you already place one sub in the middle of your room by now with umik directly in front of the middle of the driver cone. Adjust the sub volume knob till achieving 90 or 91db (hdmi out 4, which is the lfe channel, is 10db higher than speaker). When I mentioned achieving 80 to 82db in my earlier post is when you use an external spl meter. Put sub 2 in that same spot and keep the umik untouched, do the same till achieving that same value as sub1 recorded earlier. Note that the spl value in REW (or an external spl meter) will be fluctuating by a db or 2. Try your best to get both sub (one by one) at that same level.
8. Place both subs to where they are supposed to be, run aud first mic position and select calculate and save.
9. Check your sub trim levels and report back.
JT78681 likes this.
tvuong is online now
post #19533 of 27834 Old 07-01-2015, 10:26 AM
klh007's Avatar
Quoted: 37 Post(s)
Originally Posted by BDP24 View Post
When did things go so wrong Bear? Illiteracy seems to be rampant---is it the educational system itself that is to blame, or rather the students and their parents, or perhaps even our culture? Is it true of the whole world, or just the U.S.? Examples of words which are pronounced the same but are spelled differently and have different meanings: their/there/they're, your/you're, to/too/two, here/hear, stare/stair, no/know, break/brake, past/passed, threw/through, week/weak, whose/who's, meet/meat. I frequently see these words used indiscriminately, obscurring the thought the writer is attempting to express, possibly confusing the reader. Oh, there are many more, that's just what comes to mind. Hey, this is fun---join in everyone!
Your list of words misused is on point, when reading I find myself slowed/stopped when the wrong word is used with a totally different meaning and having to go back to see the context and then understand what they really meant.
Kemper Holt
klh007 is offline
post #19534 of 27834 Old 07-01-2015, 12:08 PM
JT78681's Avatar
Liked: 899
^^^ Alright class dismissed...
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #19535 of 27834 Old 07-01-2015, 01:48 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
Hey guys, should I use the included rubber feet on carpet or are those only for hard floors?
Can I just let them sit on carpet without any feet?
Soulburner is offline
post #19536 of 27834 Old 07-01-2015, 02:23 PM
JT78681's Avatar
Liked: 899
I don't use mine and find that it makes it much easier to move them around on the carpet. I'm pretty sure they are only for hard floors.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #19537 of 27834 Old 07-01-2015, 02:33 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
Yeah I definitely wouldn't put them on until they are in their final resting places. I'm wondering though if the hassle of putting spikes on them is worth it.
post #19538 of 27834 Old 07-01-2015, 02:40 PM
JT78681's Avatar
Liked: 899
What is the benefit of having them on?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #19539 of 27834 Old 07-01-2015, 06:00 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
I have them on my speaker stands so they have a stable footing. On a sub I'm not sure.
It's amazing how low Audyssey sets my subs. At the 75db calibration, it put them at -10. I had to put them up to 0 with DEQ on just to get normal bass with music.
Comparing high and low damping now.
post #19540 of 27834 Old 07-01-2015, 06:48 PM
JT78681's Avatar
Liked: 899
You will be tinkering for awhile.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #19541 of 27834 Old 07-01-2015, 07:18 PM
JT78681's Avatar
Liked: 899
@tvuong
I pulled both subs out to the middle of the living room, placed the mic at the MLP right in line with the cone and set both subs to about 90-91 db. I'll run calibration in a bit when the wife goes to sleep to see what both sub trims are set to. I had to set the mic at the MLP because at first I had it on a tripod directly in front of the cone dead center and it was making me turn down the gains on the subs to about the 7 to 8 o'clock position to achieve a 90-91db response (way too low).
*Update
Just ran Audyssey and this is what my levels are at now. Great advice tvuong!
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #19542 of 27834 Old 07-01-2015, 07:40 PM
MrGrey's Avatar
Quoted: 480 Post(s)
Liked: 497
Hello everyone,
Ive noticed that with my FV15HP the Line-in bass sounds better than the LFE in, an ill explain what i mean by better. everything is calibrated and the wires are fine no damage.
First off with movies, i have my crossover at 120hz for fronts and center, with the LFE-IN the bass is directional i can tell where it coming from its overly excessive but enough to make it a problem that cant be ignored, even with the default -6 level [ ON MY SONY STR-DH550 AVR -6 IS LOWERING VOLUME] for the sub after calibration in the AVR even with 50hz or 80hz for the fronts excluding the center crossover it still doesn't sound right and lowering the volume on the sub even more is not an option since it produces little to no bass being lowered. also with music is sounds horrible with the LFE-IN no matter what crossover i use, i tried it all of them from 40hz-200hz but with the LINE-IN it blends together so freaking good and is heavy and accurate. an help will be welcomed especially Rythmik Pro's with the FV15HP.
Receiver - Sony STR-DH550
Fronts - Klipsch Reference Premiere RP-280F
Center
- Klipsch Reference Premiere RP-450C
Surrounds - Don't ask lol
Sub - Rythmik FV15HP
MrGrey is offline
post #19543 of 27834 Old 07-01-2015, 09:58 PM
laulau's Avatar
Quoted: 77 Post(s)
Liked: 107
Originally Posted by MrGrey View Post
Hello everyone,
Sorry, I don't have the FV15HP and I'm not familiar with the Sony AVR, but just to get things started...
1. Your fronts are spec'd to be flat down to 32Hz, why are you crossing them over at 120Hz? Lower your crossover to the sub if you don't want to be able to localize the sub's output.
2. When you do your calibration, do you set the front speakers to Small? The Small setting enables the AVR output to the sub.
3. When you use the LFE-in on the sub, the sub's Crossover and Phase controls are inactive, therefore you have to make sure those settings are correctly set in your AVR.
See the link in my sig to a document that might be helpful (you'll have to figure out which Sony settings are equivalent to Audyssey's).
Salk STRT / SongCtr-RT / SongSurr I ; Rythmik F12 (x2) (latest ver of my setup guide) ; Denon 4520CI; D-Sonic M2-800S; Oppo BDP93; Panny 65VT50; BJCables; NAS DLNA; Chromecast; Harmony One; Furman Elite-15 PFi; Omnimic & REW; CalMAN 5 HT i1D3 & i1Pro2 ::Headphones:: RPi3 w/Digi+ > AGD DAC19 > Cavalli LC > HFM HE400i & Meze 99 Classics :: CCA > Schiit Bifrost 4490 > Schiit Valhalla > Senn HD600 & HD6XX :: FooB2K > Schiit Modi2U > Schiit Magni2U > Oppo PM3
laulau is offline
post #19544 of 27834 Old 07-01-2015, 10:33 PM
MrGrey's Avatar
Quoted: 480 Post(s)
Liked: 497
1. OK i Dropped the two fronts down to 50hz and left the center at 80hz.
2. when the sony avr calibrates it automatically defaults to large for all speakers so after its done i switch it back to small.
3. i did, its all correct i calibrated over 10 times since got this sub trying to marry it with my speakers.
4. Ive used that document i even have it printed out, it was my guide from the start.
it still sounds the same its not full and powerful like it should be so i switch it back to LINE-IN and watched the same scene in film called ''THE MAZE RUNNER'' at 01:05.00 into the movie and its a world of difference i really feel the action of the massive objects dropping and moving in the scene but when using the LFE-IN all of it is gone, i feel and hear bass but its not even close.
Center
MrGrey is offline
post #19545 of 27834 Old 07-01-2015, 10:35 PM
Exclusively Servo
Rythmik's Avatar
Quoted: 230 Post(s)
Liked: 314
Hello everyone,
The LFE input has a bit higher bandwidth which also allow noise to go through and crossover knob does not have function with LFE inputs. That is why you will get same result no matter how you turn the knob. But in short, if LINE-IN works better, then I will stay with LINE-IN.
MrGrey likes this.
Rythmik is offline
post #19546 of 27834 Old 07-01-2015, 10:37 PM
MrGrey's Avatar
Quoted: 480 Post(s)
Liked: 497
Yes i understand about the crossover knob sorry if i made it seem like i was using it along with the LFE-IN. i will stick with the LINE-IN, am i missing anything from doing so? because my god it sounds like heaven
Center
MrGrey is offline
post #19547 of 27834 Old 07-02-2015, 02:32 AM
steveting99's Avatar
Quoted: 1785 Post(s)
Liked: 612
^MrGrey,
Might want to do a REW low frequency sweep with your setup to make sure what you're hearing is real and not imaginary.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #19548 of 27834 Old 07-02-2015, 04:55 AM
JT78681's Avatar
Liked: 899
@MrGrey
50hz seems pretty low. Don't make your speakers work harder than necessary if you don't have to. Do you get localization with all speakers crossed at 80hz?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #19549 of 27834 Old 07-02-2015, 07:15 AM
tvuong's Avatar
Liked: 874
@tvuong
*Update
Right on. Now set them both to -6.5 or -0.5 if you want to run them 6db hot. Measure and post your sub FR.
post #19550 of 27834 Old 07-02-2015, 07:24 AM
JT78681's Avatar
Liked: 899
Will do! I definitely want to run some sweeps to see if it improved my response, but more importantly see if my distortion is better now that they are both contributing equally.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #19551 of 27834 Old 07-02-2015, 07:36 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5207
That does not matter...bass is a product of sound pressure level. So if you have two different subs that are capable of meeting your listening levels, then no you would not notice any difference from the more powerful sub unless you turn it up louder(being the lesser sub is at its limits) or off set the calibration by running it sub hotter. 115db is a 115db, if both subs can hit that level cleanly then they both will sound just as loud. So again, unless your current subs are struggling to keep up with the levels you listen at, you are not going to notice a difference.
JT78681 likes this.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
post #19552 of 27834 Old 07-02-2015, 07:48 AM
JT78681's Avatar
Liked: 899
Thanks now this is more clear to me.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #19553 of 27834 Old 07-02-2015, 07:49 AM
MrGrey's Avatar
Quoted: 480 Post(s)
Liked: 497
Originally Posted by steveting99 View Post
^MrGrey,
i have done that so many times, i used audiocheck.net there is nothing imaginary going on here.
Center
MrGrey is offline
post #19554 of 27834 Old 07-02-2015, 08:02 AM
JT78681's Avatar
Liked: 899
@MrGrey
In addition to my question above where is your sub located? Up front next to your mains? If so, you should not be getting localization. I have both of my FV's next to my towers using a crossover of 100hz and I cannot tell where the bass is coming from.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #19555 of 27834 Old 07-02-2015, 08:02 AM
MrGrey's Avatar
Quoted: 480 Post(s)
Liked: 497
@MrGrey
with the LINE-IN i can go all the way up to 120hz without any localization but with the LFE i can tell easily. if you recommend 80hz ill keep it that way.
Center
MrGrey is offline
post #19556 of 27834 Old 07-02-2015, 08:04 AM
MrGrey's Avatar
Quoted: 480 Post(s)
Liked: 497
@MrGrey
Yes right next to my mains, the funny thing is that only with LFE-IN i can localize it but not with LINE-IN, with LINE-IN i can go all the way up to 120hz easy.
Center
MrGrey is offline
post #19557 of 27834 Old 07-02-2015, 08:07 AM
JT78681's Avatar
Liked: 899
If line-in sounds better then stick with that and an 80hz crossover. Run through some material and make sure you are not getting any localization. I wonder if this is something wonky with your receiver when you use lfe-in?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #19558 of 27834 Old 07-02-2015, 08:29 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
I was trying different crossover frequencies last night. With LFE I start to localize the bass at 100Hz, and that's with 2 of the best music subs located at the center of the front and back walls, so if you drew a line between them it would go right through me. I ended up sticking with 80.
I haven't tried line in.
post #19559 of 27834 Old 07-02-2015, 08:33 AM
MrGrey's Avatar
Quoted: 480 Post(s)
Liked: 497
i am running The Dark Knight Blu ray right now and its insane allot better than lfe in with no localization. idk maybe but after all it is a $200 Sony STR-DH550 so how much can you expect from it?. i will wait for the onkyo TX-NR747 that receiver looks like a great buy that will last for a very very long time.
Center
MrGrey is offline
post #19560 of 27834 Old 07-02-2015, 09:09 AM
tvuong's Avatar
Liked: 874
MrGrey, the fact that line in sounds a whole lot better tells me your Sony Avr set sub distance/phase wrong when you use LFE in. Theoretically, line in is a bit cleaner but not from what you are describing. If you don't crossover more than 80 or 90hz, I would keep it as is especially if is sounds like 'heaven'
The reason it was more localized with LFE v.s line in when you had the 120hz xover was with line in, your FV rolls off at ~90hz which is why you can't tell where the bass was from (you were missing bass range between 90-120hz). With LFE in, the FV rolls off ~200hz and if your Avr does not filter it out at that frequency, your sub was playing up to 200hz, definitely localized. Most Avr has an LFE bass setting default to 120hz. Not sure how Sony does it.
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
