Official Rythmik Audio Subwoofer thread - Page 655 - AVS Forum | Home Theater Discussions And Reviews
 3514Likes
post #19621 of 28527 Old 07-07-2015, 10:54 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3287
Me too. I watch HDTV in a range from -10 to -20db and blu-ray from 0.0 to -5db, to be simple. I do not care for it during HDTV, at all.
gadgtfreek is online now
post #19622 of 28527 Old 07-07-2015, 11:37 AM
DonH50's Avatar
Quoted: 1907 Post(s)
Liked: 1435
In my system there is almost no change in FR with damping but you can see the change in the impulse (time domain) response. And in the sound. Not in the extension, which I frankly cannot tell, but in the clean attack and decay or percussive sounds. Ringing and related ills are what drove me to design my own subwoofer back in the late 70's/early 80's and why I went with Rythmik today (well, about seven years ago now, hard to believe it's been that long!) It is one of those things more noticeable by its absence, and quite honestly a lot of folk hear a highly-distorted ringing sound and love it because it is so much "louder" than a true low-distortion subwoofer with good impulse response. Eventually the boom has to go (I was going to say that eventually we grow up, but pretty sure my wife and kids will quickly point out in my case "growing old" and growing up" are not equivalent and I am only half-way there. )
IME/IMO - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #19623 of 28527 Old 07-07-2015, 11:44 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3287
I was car audio back well before home theater. I always preferred the kick you swiftly bass punch vs the grab you and shake you around for a second. I more referred to it as "muddy" or "boomy" when i was younger as ringing was unknown to me. I had found that I do not like excessive ringing, obviously, even before I knew what ringing was.
post #19624 of 28527 Old 07-07-2015, 12:15 PM
tvuong's Avatar
Quoted: 1609 Post(s)
Liked: 949
Originally Posted by gadgtfreek View Post
This is all 3 14hz modes in my home (XT32) off. So Tvuong makes a good point, just adjust to 75db like I normally would, then add a db, and Hi is close to low. That would be about a +6 or 7 db increase from what i see out of audyssey intial setup.
Plus extra extension with hi along with cleaner sound = win win situation
gadgtfreek likes this.
tvuong is online now
post #19625 of 28527 Old 07-07-2015, 12:50 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3287
They are all so close, even with only boosting the normal +5db I do in Low, I bet that would not be the difference I would notice (less output) with FR that close. The Hi damping will stand out to me. 0.3 vs 0.7 Q on the VTF15 was obvious. Effectively 1.1 Q to 0.5 on the FV15HP.
I am not sure how the FV15HP performs with headroom, but with the VTF15 the lower Q you had the less output by a few db you would have, but more headroom. And obviously "more sterile" bass.
post #19626 of 28527 Old 07-07-2015, 12:58 PM
tvuong's Avatar
Liked: 949
^^ give hi a try with your listening level (-5 to ref, I believe) and see if the subs are struggling which determines if you are running out of headroom. Compression sweeps are the easiest way to know but there are only a couple real world movies that demand that type of headroom.
post #19627 of 28527 Old 07-07-2015, 01:19 PM
dc6284's Avatar
Quoted: 67 Post(s)
Liked: 4
Talking
Originally Posted by dc6284 View Post
Hey guys,
I'm already sick of my svs pb-2000. And getting ready to pull the trigger on Rythmik Fv15hp and wanted to know your thoughts on it vs the Svs pb-12 plus and pb-13...
Sense most of you own one. And know more then I. Would that be my best choice. 50/50 music/HT
Room: 18x12x8 sealed. "Like my bass"
Thanks everyone,
Dave
Went with the Rythmik FV15HP in piano finish.
Anyone have tips on hooking up setting audyssey xt32.
Avr: Denon 4520
Speakers: Klipsch,rf-82ii,rc-62ii,b-61ii,rs-62ii
Sub: Rythmik Fv15hp'se
Oppo BDP 105-D
Display: Samsung 65h7150
dc6284 is offline
post #19628 of 28527 Old 07-07-2015, 01:33 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 380
Normally I would say that the FV15HP is overkill in a 1700sq ft sealed room, but I know you're only considering ported models and say you "like your bass", so I hope it blows you away.
Soulburner is offline
post #19629 of 28527 Old 07-07-2015, 01:55 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 380
Anyone have tips on hooking up setting audyssey xt32?
There are some initial settings you'll want to set on your Rythmik before running Audyssey. They are included in the box but I'll post them here. Assuming you already have determined the best location - sub location is covered all over the forums and is easy to find instructions for. I'll assume you're using LFE-IN, as that is what I'm familiar with.
A. Set your sub gain to the 12:00 level
B. Set the extension to 14Hz
C. Set your damping to low
D. Turn the rumble filter off
E. Make sure the PEQ is off
F. Make sure the crossover is set to the highest frequency
G. Set the phase to 0
I am not sure how many ports to plug - I'll let others contribute regarding that. I'm sure it is also covered in the instructions.
With your AVR:
1. Plug in the setup mic
2. Set your subwoofers to measure to 2 (if you have 2)
3. Proceed to measure the first mic location
4. Audyssey will have you adjust the sub gain knob(s) until the screen displays 75db. Do this and continue.
5. Skip the other mic locations and calculate
6. Check the levels that it set your sub(s) to. You want to aim for around -6. If it's near the -12 maximum, turn your subs down a few clicks and try again, and make sure the screen measures the same volume for each (if 2)
7. Once you achieve near -6 as a level result, run the full set of measurements. Help with where to put the mic for all 8 measurements can be found in the Audyssey thread
After setup is complete, set any speakers that were set to large to SMALL and bump your crossover frequency to 80Hz. This you can experiment with later but it's the best starting point. You can then adjust damping to your liking and turn the rumble filter on if you're going to be near max output. You can also raise your sub level in the AVR to taste, and play with Dynamic EQ. Most people on these forums tend to raise their sub levels after Audyssey (in the AVR, NOT the sub gain knob).
post #19630 of 28527 Old 07-07-2015, 02:26 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3287
If you your version of XT32 will tell you that your sub level is too high or too low, and then let you use the on screen level meter, just set the volume as low is it will go to prompt that alert. 12 oclock will most likely be way to high. Other option is to us 9, 10, 11 oclock etc... and then calculate after one measurement and see where it set your sub. I recommend setting sub volume on the sub where the ending level result is around -7 or -8. That way a good 5 db boost still leaves you a little negative if you like to boost any. It seems a 3 to 6db boost is quite common after XT32 is complete.
post #19631 of 28527 Old 07-07-2015, 02:28 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 380
My instructions with my F12s said 12:00 so that's what I started with. However, it was too loud in my room, maxing out the trims at -12. I don't remember where they are set now but it's probably around 11:00.
post #19632 of 28527 Old 07-07-2015, 02:35 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3287
Yeah, one of my 15's is about 10 and the other is like 11.
12 is a generic suggestion most use, but there are other ways to trick it if it has the level matching meter on screen. When I try new modes on my duals, I just turn them both all the way down, it then forces me to set each one around 73-74db.
post #19633 of 28527 Old 07-08-2015, 02:29 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Hey guys,
Thanks everyone,
Dave
The only SVS competition for the Rythmik FV15HP (ANY Rythmik, for that matter) is their SB-13 Ultra.
BDP24 is offline
post #19634 of 28527 Old 07-08-2015, 07:46 AM
JT78681's Avatar
Quoted: 1401 Post(s)
Liked: 931
Do you guys think 107db at 10hz would provide any sort of sensation? Or does it take a lot more output down that low to feel anything at all? Just curious!
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is online now
post #19635 of 28527 Old 07-08-2015, 07:54 AM
DonH50's Avatar
Liked: 1435
"Any sort" -- yes. Google Fletcher-Munson.
And quit obsessing about numbers, especially at 10 Hz...
If you want to "feel" the bass, and you are not in a room null, chances are you really need to turn up the higher (sub) frequencies in the 60 - 120 Hz octave. Or buy some shakers.
basshead81 likes this.
DonH50 is offline
post #19636 of 28527 Old 07-08-2015, 07:55 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3287
In my experience the sensation sub 20 is more rattle and noise. And anything over 100db from a sub has plenty of feel.
post #19637 of 28527 Old 07-08-2015, 08:02 AM
JT78681's Avatar
Liked: 931
I'm not obsessing anymore and my measuring gear is put up. Pinky swear! I'm just curious because I've always heard that it takes a lot of output down that low to perceive anything.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
post #19638 of 28527 Old 07-08-2015, 08:23 AM
DonH50's Avatar
Liked: 1435
Yup.
https://en.wikipedia.org/wiki/Fletch...3Munson_curves
https://en.wikipedia.org/wiki/Equal-loudness_contour
DonH50 is offline
post #19639 of 28527 Old 07-08-2015, 10:49 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 380
I tried running my crossover higher than 80 to achieve this, but the sound from my subs started to become unpleasant. It sounded slower and boomier. Almost like they were straining, and my output was only around 80db. And this is with 2 F12s using LFE-IN, set to 14Hz high damping and placed in the middle of the front (12 feet from me) and back (8 feet from me) walls, configured with XT32+SubEQ. I wasn't expecting that result.
post #19640 of 28527 Old 07-08-2015, 11:21 AM
DonH50's Avatar
Liked: 1435
In that octave subs become localizable and room interaction also becomes more significant. That is, I don't think it was the subs, but how they are interacting with your room and ears. When I first got mine (also a pair of F12's) I piddled with higher settings just to see what they sounded like and they sounded like any other decent speaker up to maybe 120 Hz or (as high as I went). My room is heaviliy treated. To me, excessive volume in that octave sounds boomy no matter the source, so I suspect that is the issue rather than anything the sub itself is doing.
I have several other subs in the house, and one of them (can't recall now if it was the 12" Infinity or 10" Mirage) is really "loose" and distorted at moderately loud volume no matter the frequency, really falling apart above 100 Hz or so. Of course it really shows how much better Rythmik subs are in comparison.
I personally prefer a lower crossover point, a preference borne out by testing ages ago, so I cross over to my mains around 50 or 60 Hz. Of course, you have to have mains that work that low. Mine are rated to 35 Hz (Magnepan MG-IIIa), and will play there, but nowhere near as cleanly at higher levels as my Rythmiks).
FWIWFM - Don
DonH50 is offline
post #19641 of 28527 Old 07-08-2015, 12:08 PM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
I've noticed Home Theater enthusiasts tend to play their subs at higher levels relative to their speakers than do music listeners, but one of the biggest differences to me between live music and reproduced is how much more "physical" live music is---you're not just hearing the music with your ears, but also feeling it in your entire body. I don't know how much of that is from SPL alone (live music is much louder now than when I first started going to shows---my first was The Beach Boys in the Summer of '64!, thanks in part to much improved sound systems), and how much is from low frequencies in particular. Even with a sub cranked up, music in the home is nowhere near as physical as it is in person.
BDP24 is offline
post #19642 of 28527 Old 07-08-2015, 12:38 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3287
Thats true. We have great local bands here and we watch them a lot. You get a real good kick in the chest live.
Kinda the reason I liked my fronts in 2 channel for music vs using the VTF15's. They have punchy and fast bass from the dual 10's and the SQ is very clean.
post #19643 of 28527 Old 07-08-2015, 02:53 PM
MrGrey's Avatar
Quoted: 585 Post(s)
Liked: 724
Hey guys is it safe to use this to clean the cone of my FV15HP?
[Click image for larger version
Sent from my LG-D855 using Tapatalk
Receiver - Sony STR-DH550
Fronts - Klipsch Reference Premiere RP-280F
Center
- Klipsch Reference Premiere RP-450C
Sub - Rythmik FV15HP
The Ultimate List of BASS in Movies w/ Frequency Charts
MrGrey is offline
post #19644 of 28527 Old 07-08-2015, 03:15 PM
DonH50's Avatar
Liked: 1435
@MrGrey -- yes, very, very carefully! I would not clean the surround, or maybe just pass it over lightly. Make sure you use a clean brush.
Re. live music: IME live music is EQ'd differently and is often much louder than in the home. Not always, but often (again, IME). It is also hard to get the same impact in the recording; I suspect mic'ing and mixing has a lot to do with it, probably more than our systems (no matter how good). A lot of mics roll off well above subwoofer range, and I suspect a lot of mixes target more mundane systems that will not support "live" bass levels.
It is a rare recording that has the percussive impact of a piano's hammers, let alone drums and such. We have a grand piano my wife plays and I love hearing her practice. Of course, it usually reminds me that I need to practice, too...
DonH50 is offline
post #19645 of 28527 Old 07-08-2015, 03:27 PM
eorr23's Avatar
Quoted: 38 Post(s)
Liked: 70
I would love to audition one of their subwoofers but unforunately I live in an apartment. It's funny too because I live within 2 miles from their office in Austin TX.
eorr23 is offline
post #19646 of 28527 Old 07-08-2015, 03:42 PM
MrGrey's Avatar
Quoted: 585 Post(s)
Liked: 724
Dam if it's that delicate then i might as well leave it alone. That item in the picture is not a brush its extremely soft fiber.
Center
MrGrey is offline
post #19647 of 28527 Old 07-08-2015, 03:46 PM
DonH50's Avatar
Liked: 1435
You can go over the cone lightly.
Or just turn up the volume and shake it off.
MrGrey likes this.
DonH50 is offline
post #19648 of 28527 Old 07-08-2015, 03:56 PM
MrGrey's Avatar
Quoted: 585 Post(s)
Liked: 724
ill give it a try. i wonder how the guys at Rythmik cleans them? Bryan should know.
Center
MrGrey is offline
post #19649 of 28527 Old 07-08-2015, 05:13 PM
tvuong's Avatar
Liked: 949
I use can air.
post #19650 of 28527 Old 07-08-2015, 05:34 PM
Quoted: 313 Post(s)
Liked: 274
I never use anything other than a damp micro fiber cloth for any of my speaker cabinets and then I typically use a tad of distiller water.
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
Klipsch RP-280F / RC-62ii / RS-35 / RS-25
Dual PSA V1800s
kluken is offline
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
