Official Rythmik Audio Subwoofer thread - Page 661 - AVS Forum | Home Theater Discussions And Reviews
 3194Likes
post #19801 of 27848 Old 07-18-2015, 10:41 AM
KMFDMvsEnya's Avatar
Quoted: 237 Post(s)
Liked: 395
If it is in the budget kluken have you considered the F25?
That model is sealed and sports dual 15" drivers with output that is close to the FV15HP.
Dimensions are rather close to the F15HP in respects to width and depth; clearly it is taller but gaining so much more.
I purchased a DIY 15" kit a few years ago and my only regret was not waiting a little longer and pay the extra for the HP amp. That or the FV15HP kit but finances did not allow for it and wanted a subwoofer up and running again in time for my b-day.
There are a great selection of subwoofers to choose from various companies and my experience with my Rythmik has been great, just that pesky upgrade bug wants more, and the feedback for SVS and HSU are also very positive.
For what it is worth, there have been very few individuals who have been dissatisfied to the extent that they spoke poorly of the product or returned it outside of a potential defect. Biggest complaint usually is those wishing they had gone with the FV15HP.
Best regards,
KvE
Politics is like a corral, no matter where you are you'll always be shoveling it.
KMFDMvsEnya is online now
post #19802 of 27848 Old 07-18-2015, 10:43 AM
tvuong's Avatar
Quoted: 1544 Post(s)
Liked: 875
^^ start a new thread about the two subs you are shopping for. If you ask here, guess what I will recommend? Not because I am bias but it's hard to get another sub once you have Rythmik.
tvuong is offline
post #19803 of 27848 Old 07-18-2015, 10:52 AM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
You are unlikely to hear the difference between -3 dB at 14 Hz or 19 Hz. You are more likely to hear the difference a good servo design offers in the way of cleaner bass. Chances are you would be happy with either sub. Back when I was researching, I decided I would be happier with Rythmik, but YMMV. - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #19804 of 27848 Old 07-18-2015, 12:47 PM
wyld0's Avatar
Quoted: 23 Post(s)
Originally Posted by enricoclaudio View Post
From Denon in order to get XT32 + SubEQ HT you have to look for "Audyssey Platinum" which is present on former model X4000 (discontinued), last year and still on production X4100W and newer model X4200W and up. From Marantz the SR7008 (the one I have) and SR7009 have XT32 + SubEQ HT as well. Below $1000 you can get a refurbished unit from Accesories4less with one year warranty or a new Marantz SR7008 (Amazon)
http://www.accessories4less.com/make...airplay/1.html
http://www.accessories4less.com/make...-150wpc/1.html
Ordered the 7008. Price was great and hopefully the free 3 year warranty is worth something. Gonna go ahead and pick up another FV also. The projector will just have to wait.
Sent from my SM-N910V using Tapatalk
wyld0 is offline
post #19805 of 27848 Old 07-18-2015, 01:58 PM
Quoted: 303 Post(s)
Liked: 269
That I knew, but I was looking for the Rythmik fans/owners to tell me if I was missing something or have they seen the F15HP deliver really goo deep tight lows. It was less about the comparison and more about vetting the claims of 14Hz out of a sealed sub and only being down 2db. Everything I have read is that the roll off of sealed subs starts around 30Hz, so I am struggling to see how 14Hz is only down 2db.
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
Klipsch RP-280F / RC-62ii / RS-35 / RS-25
Dual PSA V1800s
kluken is offline
post #19806 of 27848 Old 07-18-2015, 02:20 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
Two things:
1. Sealed subs "roll off" slower than ported subs, so will often have more output in the teens where ported subs roll off rapidly
2. The servo helps quite a bit. This is a trick that other companies can't claim to have
Soulburner is offline
post #19807 of 27848 Old 07-18-2015, 02:24 PM
DonH50's Avatar
Liked: 1325
The frequency response is a complex function of driver and enclosure parameters as well as the room in which it operates. I don't know where or what you read but it is wrong. There is nothing intrinsic to a sealed enclosure design that says it will roll off at 30 Hz. Or anywhere else; it is a function of the design (and room). There are plenty of sealed and ported subs that roll off above and below 30 Hz. One intrinsic characteristic is that a ported (vented) sub will roll off more rapidly below the port tuning frequency than a sealed sub so below the lower corner frequency a sealed sub will have a little more output than a ported sub. Above, a ported sub will have more output, all else being equal.
There are response curves on the Rythmik site.
In my room my pair of F12's go down to about 10 Hz.
DonH50 is offline
post #19808 of 27848 Old 07-18-2015, 08:35 PM
enricoclaudio's Avatar
Quoted: 1102 Post(s)
Liked: 1127
Hi guys,
Just to let you know that Jim Wilson review of the Rythmik Audio F8 have been posted on Home Theater Shack!!
http://www.hometheatershack.com/foru...f8-review.html
Enjoy!!
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #19809 of 27848 Old 07-18-2015, 10:31 PM
falconxr6's Avatar
I have 2 F12's and the get the most low frequency output what should the damping be on? Low, mid or high? My cutoff's are on 14 hz.
Yamaha RX-A3060 AV Receiver Emotiva XPA-3 Emotiva A-300 Focal Aria 906 with SS900 stands Focal Aria CC900 Centre Energy Bipole Rears REL 2 x T9i Subwoofers Oppo UDP-203 BluRay Logitech Harmony Ultimate Remote Philips 65inch 7101/79 UHD LED Display
falconxr6 is offline
post #19810 of 27848 Old 07-18-2015, 11:23 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
If you're set to 14 you're already getting the lowest extension. Damping will affect the control of the driver and in turn how much definition you hear in the bass.
post #19811 of 27848 Old 07-19-2015, 03:10 PM
Exclusively Servo
Rythmik's Avatar
Quoted: 230 Post(s)
Liked: 314
First the disclaimer. Standard spec of frequency response is +3/-3db range. So the -2db is based on that spec, which is -5db from the top of the FR curve. But it is still better than almost all sealed subs Data-bass site has tested. For instance, one of the tested sub is down -16db at 14hz. Please note a lot of sealed subs without using this +3/-3db spec cannot claim that they have 20hz extension.
So now back to the answer to your question. As soul burner has pointed out, it is because of servo. That is the shorter version of the answer. The longer version of the answer is how servo 1) alters the frequency response, and 2) addresses the challenge of having low extension and still sound good (not boomy).
Servo controlled subs compare the servo feedback signal to the power amp input signal and then output more power if it finds the woofer does not move fast enough, or output reverse throttle when it finds woofer moves too fast. So it is not just one direction control. This help the subwoofer to actively reject external interference acted upon the woofer. For instance, the box spring is one of such external force. So is the internal standing wave of the enclosure. Servo will have much less value if it cannot be analyzed formally. Without that, servo will be used as a "patching", or trial-and-error, or an adhoc technique. In fact, in early days, servo design was done that way. One of the former Genesis engineers told me that was how Arnold did their servo design in their early servo subwoofers, trying a different resistor value or capacitor value at a time and see if the output was better.
So after formal analysis of servo control design, I have found it behaves like changing the T/S of the driver. The frequency response is just like real world sealed subwoofer (with large diameter driver and large motor) from top to bottom. This is very different from the result of using EQ to achieve extension becasue the amount of EQ will be enormous at the bottom end and the designer needs to do a cut-off point decision. That is one of the reason you have seen other nonservo sealed subwoofers cannot go -5db down at 14hz. It will be just too much EQ. Another very important capability of servo is that we can "clone" the frequency response. That is why you will see our sealed subs all have very similar extension curve regardless driver diameters. That is by design.
Second part of how servo can do better is related to this comment "best bass is no bass". You can say this is sarcasm. Making low extension actually expose the sound quality weakness of low bass. In time domain, reproducing a 10hz signal takes 4 times as long as that of a 40hz. If there is a ringing, the ringing at 10hz will last 4 times longer too. That means there are 4x more reason that the sound can be bad. So instead of exposing the subwoofers to that problem, many designers just cut back the extension to avoid problems. We allow our subwoofers to go that low because we are able to control the impulse response to almost no ringing. In our frequency response plot, we publish both amplitude and phase response curves. No other manufacturers do that. What we want to show is our sealed subwoofers have the minimal phase shift among all sealed subwoofers. For instance, our F15HP as about 100 degrees phase shift from the microphone. Now in reality is F15HP has even lower phase shift because we are able to calibrate microphone with our servo signal (yah, we can claim no other manufacturer can do that) and found our measurement grade microphone, which is flat down to sub 10hz, has 18 degrees phase shift at 20hz and 45 degrees phase shift at 10hz. An ideal sealed subwoofer has 2nd order roll-off, which has 90 degrees phase shift at the corner frequency. So our sealed subwoofers are not far from that ideal case. In addition, when the subwoofer is -14db down, you can expect the phase shift to 180 degrees or even more.
Some may challenge that while we have low extension, how much output can the subwoofer do, sort of hinting the extension is not useful at all. Real life sound does not have a lot of sub-sonic components. For instance, I have been observatory telescope dome. When I watch movies with similar scenes, what I want to hear is the reverberation is as realistically believable when the door is opened or when the dome is turn. That does not need a lot of subsonic energy. But it is important to align the subsonic signal (which is the reverberation) with the rest of the sound so that it sounds well integrated and believable. But any subwoofer with limited extension makes the dome sound smaller than what it is. Same thing is motorcycle throttle/exhaust noise. There are just too many examples. And lastly if the movies have too many artificial LFE signals that makes the sound boomy, we have rumble filter and other controls to cut back the extension.
KMFDMvsEnya, wyld0, shadyJ and 2 others like this.
Rythmik is offline
post #19812 of 27848 Old 07-19-2015, 05:56 PM
12B4A's Avatar
Quoted: 275 Post(s)
Liked: 157
While Brian has already responded using solid technical explanations why Rythmik's subs can do what they claim, I just wanted to add (as a customer) that I've measured in room (10x12) down to 10hz with a single L12. Using the Low-Music switch setting, I had an average level setting of 84dB from 10-200hz with a peak of 86dB around 23hz while 14hz was at 83dB. Qualitatively speaking, I can say that it's remarkably clean as well to reinforce what Brian was driving at with the "lack of ringing" paragraph. Whenever I now hear thunder off in the distance (not that I hadn't heard thunder before), I instantly associate it to my experience when I had 10-20hz tones going through the L12 for the first time. I had never experienced a sub that had that kind of LF acoustic energy before without what I now know to be smearing, sloppy distortion.
Life is Lambertian
12B4A is offline
post #19813 of 27848 Old 07-19-2015, 06:17 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
Now that is impressive. Show me another budget sub that can do that! Heck, even $$$ subs struggle with that!
post #19814 of 27848 Old 07-19-2015, 06:20 PM
Quoted: 303 Post(s)
Liked: 269
12B4A and Rythmik (Brian),
Thank you both so very much as well as the others on here. It s funny as when I started this upgrade to my home theater I wanted to just get 2 new SVS PC-Ultras, then I decided I did not want the tall cylinders and looked at the PB-ultra, but the damn price was nuts so I started looking for alternatives. Of course then I went the sealed vs. ports route. I quickly narrowed my choices down HSU, PSA and Rythmik. Eliminated HSU and then the attraction of Tom at PSA was appealing, but I really like what I keep learning and reading about Rythmik and the servo.
In my modest 15Wx20Lx8H how much difference would the F15HP be from the FV15HP be? I read some of these blind tests that sealed vs. ported and people can't tell?
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
Dual PSA V1800s
kluken is offline
post #19815 of 27848 Old 07-19-2015, 06:44 PM
DonH50's Avatar
Liked: 1325
There's no good way to predict the response in your room as it depends upon placement and how loudly you like to play. Spec-wise an FV15HP offers about 5.5 dB more output, nearly twice as loud in the bass region, but that only matters if you actually need/want the extra output. The FV15HP will roll off faster than the F15, natch, and arguably have a bit higher distortion though the servo largely obviates that difference. Never any worry about port noise with a sealed sub, but frankly a (any) decent ported sub is only going to have audible port noise in very special cases (typically a tone hitting right at the or near the port frequency). Within their frequency and power range I really doubt anyone could tell if you had an F15, F15HP, or FV15HP. For my system, using planer magnetic speakers (Magnepans), low distortion and the ability to integrate cleanly with "fast" main speakers was paramount so Rythmik was an easy choice.
The first sub I owned, and last before Rythmik, was a home-brew servo sub of my own design. I couldn't afford commercial as a college kid, and frankly was not impressed with their sound. Interestingly enough, after a lot of research, the design I utilized was very similar to the Rythmik design. Brian has taken it further, naturally, and has modern drivers and electronics (and the patent, wish I had patented my design ).
FWIWFM - Don
DonH50 is offline
post #19816 of 27848 Old 07-19-2015, 06:46 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
The difference is that the FV15HP will be able to put out +5.5db more at 20Hz than the F15HP. It also gives you the option to plug one or two ports depending on your room and/or preferences.
According to the exhaustive research I did before making my purchase, you should not be able to tell a difference in sound quality between the two above the port tune frequency, especially with the servo.
Anyone have a different take?
The reason I went sealed (F12s) was due to their smaller size, getting all the benefits Rythmik has to offer yet not giving up too much over the bigger subs. I will never utilize 110db output. I can put small tables with plants over them for aesthetic/SAF reasons
wyld0 likes this.
post #19817 of 27848 Old 07-19-2015, 07:20 PM
Quoted: 303 Post(s)
Liked: 269
I guess I need to figure out how ugh SPL I hit when I really crank my movies up. Once I di that I can make sure sealed would work.
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
Dual PSA V1800s
kluken is offline
post #19818 of 27848 Old 07-19-2015, 07:20 PM
Exclusively Servo
Rythmik's Avatar
Quoted: 230 Post(s)
Liked: 314
I had a typo in my previous post (what I meant was low extension, not low excursion, that makes the dome sound smaller).
My recommendation for customers has been very sensible. If you don't have strong opinion about sealed vs ported and is quite happy with the ported sub you have now (just want to get more articulation and musicality), then our FV15HP will be good choice. In one port mode with 14hz high damping, its phase shift, measured by group delay, is almost as good as nonservo sealed subs such as Paradigm Sub 2, which has similar extension as FV15HP. On the other hand, if a customer tells me he never likes ported subs, then there is no need to even convince him to try ported subs.
wyld0 likes this.
Rythmik is offline
post #19819 of 27848 Old 07-19-2015, 11:17 PM
tvuong's Avatar
Liked: 875
What is your normal listening volume and do you run your bass hot? Are you more into music or movie? Your room is 2400^3ft, so it's not that big. Is the room completely sealed off or open to other part of your house? Whatever you are buying, try to get a pair.
tvuong is offline
post #19820 of 27848 Old 07-20-2015, 04:36 AM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2513
EQ can shape the response to whatever one wants as long as you are below the subs maximum output capabilities. You can make any sealed sub flat to 10 Hz with eq at low SPL. It does not change at what level the sub will start to compress.
bear123 is offline
post #19821 of 27848 Old 07-20-2015, 04:41 AM
bear123's Avatar
Liked: 2513
I think you are right on the money with this statement. There are plenty of people who prefer sealed subs because they buy into the notion that they are tighter or crisper or whatever, but blind testing has debunked this time and again. If Brian were to set up the FV15HP properly in a room and it was eq'd exactly the same as the F15HP, I would bet no one could reliably tell the difference between the two on music, especially if the knowledge of whether their preferred alignment was playing was withheld from them.
bear123 is offline
post #19822 of 27848 Old 07-20-2015, 04:45 AM
bear123's Avatar
Liked: 2513
Your room is similar in size to mine. Yours is 2400 ft^3, mine is 2525(17x16.5x9). I get around 13 dB of room gain at 10 Hz, which means that my FR is completely flat down to 10 Hz with dual sealed subs with no eq applied at all. So whatever subs you buy should be able to reach your output requirements down low as long as they can do so in the 20-30Hz region. I don't think you will be able to tell a sound quality difference between good quality, well designed ported subs and good sealed subs. However, sealed subs will have better extension and more output at very low frequencies(below 12-15 Hz) compared to most ported subs. And you eliminate the possibility of any port noise or chuffing.....ever.
bear123 is offline
post #19823 of 27848 Old 07-20-2015, 04:56 AM
Quoted: 303 Post(s)
Liked: 269
Room has a single 30 inch opening at the back near listening position. I tend to listen a tad loud, but never measured in detail. On the Denon I tend to watch movies at -10db on the volume, I tried my RS SPL meter last night set to slow response and MAX (holds highest reading over previous 1 second) and watching some heavy LFE parts of a movie with volume to -16db (gf was complaining ;-) ) I saw it get to 116 db (at MLP). I do run the sub about 6db hot. I do find that on my PC-Ultra the gain is just short of being halfway so I am clearly not pushing that amp. I do plan on getting a pair of whatever I select. My anal process is because I don't want to make a mistake and have to eat shipping both ways.
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
Dual PSA V1800s
kluken is offline
post #19824 of 27848 Old 07-20-2015, 05:01 AM
Quoted: 303 Post(s)
Liked: 269
Thanks again, I am not very anti-ported, I just want o get the best tightest deepest sound. You have been extremely helpful and I should be making my decision by tomorrow as I need to get whatever I decide on shipped this week. The funny thing is no matter what I buy I suspect it will be better than my PC-Ultra, although I have been very impressed with how good it sounds. My only complaint with the PC-Ultra is that being bottom firing in the corner it has a tad of boominess to it, no where near as bad as my old PC-Plus 20-39
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
Dual PSA V1800s
kluken is offline
post #19825 of 27848 Old 07-20-2015, 05:04 AM
bear123's Avatar
Liked: 2513
Room has a single 30 inch opening at the back near listening position. I tend to listen a tad loud, but never measured in detail. On the Denon I tend to watch movies at -10db on the volume, I tried my RS SPL meter last night set to slow response and MAX (holds highest reading over previous 1 second) and watching some heavy LFE parts of a movie with volume to -16db (gf was complaining ;-) ) I saw it get to 116 db. I do run the sub about 6db hot. I do find that on my PC-Ultra the gain is just short of being halfway so I am clearly not pushing that amp. I do plan on getting a pair of whatever I select. My anal process is because I don't want to make a mistake and have to eat shipping both ways.
-10MV, 6 dB hot = 111dB minimum requirement from subs(115-10+6). This does not include bass redirected from the rest of your speakers, which can add up to another 5-6 dB of output requirement to play everything that could possibly be thrown their way for movies.
I would suggest dual F25's or there is a good chance, imo, that you will be leaving some LFE on the table.
With only one small opening, you should still get the benefits of a sealed room. I have an open stairwell in my room as well.
bear123 is offline
post #19826 of 27848 Old 07-20-2015, 05:30 AM
Quoted: 303 Post(s)
Liked: 269
F25 is a bit too tall for the room. I looked at them and they look sweet, also would need a moving crew to haul them around ;-)
As much as I like the appeal of sealed I do realize I would never likely hear the difference, so I will likely do ported just to maintain the headroom. the FV15HP is about the max size I want to so, at 26 inches deep it barely leave me enough clearance.
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
Dual PSA V1800s
kluken is offline
post #19827 of 27848 Old 07-20-2015, 06:41 AM
JimWilson's Avatar
Quoted: 1267 Post(s)
Liked: 1564
Having owned an E15HP - which is virtually identical in output and capability to the F15HP - and having heard an FV15HP at a GTG I have a good understanding of what both can do. With that in mind, I would say lean heavily toward the FV. While the F15HP will have a lot of output and depth, the FV goes to a different level. The thing is an absolute beast, there's simply no other way to put it. Given that you like to listen at elevated volume levels that favors the FV.
Driver orientation doesn't contribute to 'boominess', so that won't be what caused your issue. Something else was to blame.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #19828 of 27848 Old 07-20-2015, 06:44 AM
Quoted: 303 Post(s)
Liked: 269
Thanks. Yeah that seems to be a common theme I read I think you guys are convincing me ;-)
I read somewhere that down-firing in a corner can lead to some boominess.
Panasonic 65VT60
Denon x7200WA
Oppo BD-103
Dual PSA V1800s
kluken is offline
post #19829 of 27848 Old 07-20-2015, 07:07 AM
JimWilson's Avatar
Liked: 1564
Actually, if anything that orientation tends to "clean up" the sound. With the driver not firing directly at your ears the harmonics are somewhat masked, making them less offensive. The affect is subtle, of course, but for some it may be audible. All things being equal, I prefer down-firing myself.
post #19830 of 27848 Old 07-20-2015, 08:06 AM
tvuong's Avatar
Liked: 875
The gain on your sub being half way has nothing to do to denote 'not pushing that amp'. When you run Audyssey calibration, your AVR calibrates your sub with sub trim to set your sub to 75db (reference level) whether the gain on your sub is half way, 1/4 or 3/4 way. My room is sealed and is a bit bigger than yours (~2500ft^3) and I have a pair of FV15's which is plenty loud and deep.
tvuong is offline
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
