Official Rythmik Audio Subwoofer thread - Page 667 - AVS Forum | Home Theater Discussions And Reviews
 4551Likes
post #19981 of 30518 Old 08-03-2015, 05:04 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 3895
Originally Posted by DonH50 View Post
Isn't CEA for car amplifiers? Subs are typically measured for output SPL... I am not very familiar with CEA specs so I must not understand.
* Look here: http://www.audioholics.com/subwoofer...p-measurements
That is for the FV15HP; you can subtract 5.5 dB'ish for the L22. Or, for the L22, at 1 m:
111.0 dB at 20 Hz
116.5 dB at 25 Hz
121.3 dB at 32 Hz
123.5 dB at 40 Hz and above (more or less)
HTH - Don
He is talking about CEA 2010 test numbers I think. Most modern DIY sub makers have at least one model with these results publish, and Databass has a ton.
gadgtfreek is offline
post #19982 of 30518 Old 08-03-2015, 05:19 AM
DonH50's Avatar
Quoted: 2119 Post(s)
Liked: 1688
Thanks, figured that out, and the link and numbers I provided are from CEA-2010 test results. I have not kept up with all the standards since letting my IHF CAC lapse...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #19983 of 30518 Old 08-03-2015, 06:27 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 266 Post(s)
Liked: 365
Originally Posted by jd10ac View Post
Is there anyway to find some output numbers on the L22? I also want to verify that at 20hz it is 2db above the highly regarded lv12. I am thinking of replacing my sealed 15" sub with the l22 and was hoping it would have similar output.
I believe you have XS30 which has two 15" drivers. Output from L22 is similar to that F15HP/E15HP, the 15" high power model.
Regarding CEA numbers, I think the most important max output data is 20hz which is the number we provide as reference. This is because 20hz is the number in practice determines the max "volume" you can set on your AVR. Once the SPL at 20hz exceed the max output, the limiter is going to kick in and that bring downs the entire frequency band subwoofer plays. 20hz is not really audible. So it needs to a lot of signal strength and that combined. At the same time, subwoofer is normally least efficient at the bottom end of FR. These two factors make the 20hz output more important.
In terms of Data-bass subwoofer testing, we feel the limitation of the test method penalize the subs that extends low and that makes the measurement looks bad. For instance, if a sealed sub is down 10db at 20hz (vs another sealed sub down only 3db at 20hz), the former is going to have better distortion number at 20hz becasue it is down at least 7db more than the other model. That is why I keep joking the best bass is no bass even from measurement point of view. The same is true for impulse response and waterfall plot.
Rythmik is offline
post #19984 of 30518 Old 08-03-2015, 09:18 AM
Quoted: 180 Post(s)
Liked: 227
Thanks for the reply, I do currently have an xs30se but was wanting to compare the L22 to the much smaller s1500 I previously had. Given the size and shape of my room I should probably be looking at the fvx15 but the much smaller footprint of the L22 has me intrigued for waf.
jd10ac is offline
post #19985 of 30518 Old 08-03-2015, 11:20 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
So I finally got around to reading this and thought it was brilliant. All along I've been thinking that the damping control increases the effort of the servo to tame ringing, when actually the opposite is true: mid and low damping tells the system to add ringing electronically because the intrinsic Q of Rythmik sealed subs is only 0.3. It's all the more impressive to think that Brian is building 0.3 Q subs and is adding ringing to simulate what many other subs on the market do by their nature: ring.
Samsung PN64H5000 (recommended settings)
Denon AVR-X4000
A little R&R: Reaction Audio CX-10 (2) | Rythmik Audio F12 (2)
And a pair of Emotiva Airmotiv 5s
Soulburner is offline
post #19986 of 30518 Old 08-04-2015, 05:19 AM
JT78681's Avatar
Quoted: 1466 Post(s)
Liked: 976
@Soulburner
That's interesting. I've been running mid dampening as of late and feel it's a good compromise between high and low. At least according to the measurements I took a while back.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #19987 of 30518 Old 08-04-2015, 05:47 AM
rcohen's Avatar
Quoted: 1377 Post(s)
Liked: 604
Any kind of frequency dependent high-pass filter is accomplished with ringing (analog or digital).
For clarity, high damping = low Q = less ringing.
The Rythmik filter switches refer to damping (1/Q).
rcohen is offline
post #19988 of 30518 Old 08-04-2015, 06:01 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 3895
Im still on 14hz, Hi damp, rumble filter Off/1.
wyld0 and Iain- like this.
post #19989 of 30518 Old 08-04-2015, 07:18 AM
Iain-'s Avatar
Quoted: 89 Post(s)
Liked: 59
What document are you referring to?
It clearly states on the PEQ page that "High Damping" switch position controls excessive "ringing", whilst "Low Damping" position has less effect on this anomaly:
http://rythmikaudio.com/amplifier_controls.html
Iain- is offline
post #19990 of 30518 Old 08-04-2015, 07:25 AM
JT78681's Avatar
Liked: 976
I think he just got mixed up when posting.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #19991 of 30518 Old 08-04-2015, 11:42 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
Same, only with no ports on my F12
post #19992 of 30518 Old 08-04-2015, 11:43 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
That's what I thought as well - but read that post I linked to:
http://forum.ascendacoustics.com/sho...3395#post33395
post #19993 of 30518 Old 08-04-2015, 07:59 PM
Exclusively Servo
Rythmik's Avatar
Quoted: 266 Post(s)
Liked: 365
I hope we are all clear on damping vs Q value.
Additional information about extension filter is at the bottom of this page.
http://rythmikaudio.com/eq.html
In PEQ that we control the boost or cut, higher Q value means narrow bandwidth.
Rythmik is offline
post #19994 of 30518 Old 08-05-2015, 12:16 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
I was just reading about bass traps to reduce ringing and it led me to a thought regarding Rythmik servo subs.
If your subs are putting out sound energy with much less ringing to begin with, does that reduce your need for bass traps to "clean up"?
Denon AVR-X4000
post #19995 of 30518 Old 08-05-2015, 06:15 AM
DonH50's Avatar
Liked: 1688
No. Bass traps do not clear up "ringing" from the sub itself, only from room modes and room boundary reflections. They can't fix the source; GIGO (garbage in garbage out).
I suspect this hypothesis, if what you read does imply that bass traps clean up the source, is because bass traps work better at higher frequencies so may absorb some of the distortion rather than letting it reflect back into the room.
DonH50 is offline
post #19996 of 30518 Old 08-05-2015, 06:16 AM
rcohen's Avatar
Liked: 604
I'm not Rythmik, but here is the answer...
Ringing can be introduced by the sub system (combination of physical and electronic aspects) and/or room resonances (modes).
It certainly helps to start with a sub that doesn't create ringing, but a room will usually introduce its own ringing (not necessarily at the same frequencies).
You can combat room ringing by properly positioning multiple subs and/or using bass traps.
Also, it is often possible to electronically combat ringing by cancelling it out via room EQ.
For best results, use a combination of all the above.
With room EQ, in some cases EQing for a flat response will coincidentally cancel out some of the ringing. In some cases, room EQ makes ringing worse.
Fancier room EQ systems (Dirac, Trinnov, Audiolense, Acourate) will optimize both frequency response and impulse response and more reliably reduce ringing.
rcohen is offline
post #19997 of 30518 Old 08-05-2015, 06:32 AM
rcohen's Avatar
Liked: 604
BTW, you can measure this stuff by checking out the waterfall and impulse response graphs in REW.
rcohen is offline
post #19998 of 30518 Old 08-05-2015, 09:10 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
I realize that subs are one of several factors, and I should have stated "if you have bass traps large enough to affect subwoofer frequencies". Probably a silly late night question because they would be huge, but you can see what I was thinking.
post #19999 of 30518 Old 08-05-2015, 09:19 AM
DonH50's Avatar
Liked: 1688
Well, my answer's the same if you are talking about the sub itself. No amount of treatment can alter distortion from the source, or the direct sound you hear. If you are talking about room modes and boundary reflections, then again to me the sub itself does not matter except a sub that has distortion (THD, IMD, ringing, whatever) may excite frequency peaks a "clean" sub would not. However, you can have a clean sub playing a signal at one of the peaks, and that frequency will still be louder (and a null is still a null, etc.)
Bass traps and other acoustic treatments are to clean up the room, not the sub.
A new slogan? Start clean, stay clean. Rythmik.
IMO! - Don
DonH50 is offline
post #20000 of 30518 Old 08-05-2015, 09:45 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 266 Post(s)
Liked: 365
you can potentially over-do with bass traps. The reason we can create 3-D sound image is becasue wall reflections (floor and ceiling too). If you want to imagine a world without room reflection at all, it is like walking into an open outdoor space. So we know we need wall reflections to create image space. The trick is how to get just the right amount.
Room EQ can also do damage to sound stage. I had heard some of the bad room EQ where the sound is very good, but the imaging is terrible. The singer voice appears to sound like 5 times bigger than their life size and the reason for that is extra ringing introduced by the EQ.
It takes time to learn the art of sound. A lot of us think if we hear the same thing as other do, then we all hear the same thing. But that is not true. I look up in the sky every night and all I see is lots of stars. My friend can point me which star is Orion and which is Sirus. We both see the same sky and yet we have different interpretation of what we see at different level of detail (or what our brain thinks).
Rythmik is offline
post #20001 of 30518 Old 08-05-2015, 10:52 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
The "sound" of a room greatly effects how music played in it, both live and reproduced, sounds. The two extremes are a gymnasium and outdoors---I've played in and dislike both, gyms having too much echo and outdoors being too dead, with no resonance. Acoustical engineers have determined the optimum amount and length of reverberation that makes for good sound in a room, and build spaces for live music performance based on those numbers. Old churches were designed and built as they were for the same reason.
For music and home theater listening, a mix of absorption (bass traps in room corners, and absorptive panels at loudspeaker first-reflection points) and diffusion (diffusers "scatter" sound reflected off them in different directions, rather than as does a mirror) makes for a good-sounding room.
BDP24 is offline
post #20002 of 30518 Old 08-05-2015, 11:05 AM
toonontherun's Avatar
Quoted: 65 Post(s)
Liked: 31
This is off topic but I see everyone talk about adding bass traps but I saw a video with Floyd Toole he said he disapproves of using them. Why?
toonontherun is offline
post #20003 of 30518 Old 08-05-2015, 11:33 AM
DonH50's Avatar
Liked: 1688
Read the two posts right above.
I personally usually prefer to take the room out of the picture and treat heavily. With absorption, this means any ambiance is in the recording and your speakers must reproduce that accurately. My current room is not large and with big planer speakers I am pretty close to near-field so it sounds great with a bunch of absorbers. In a large room I prefer a mix of absorption and diffusion as stated above. Unfortunately I have rarely had a nice big room for my stereo. One caveat is the mix may be done with a typical room in mind and not the (typically dry) mastering studio.
For subwoofers, it takes a lot of material to accomplish anything. Fundamental room nulls are almost impossible to fix; boundary reflections that are a little higher in frequency can often be improved.
DonH50 is offline
post #20004 of 30518 Old 08-05-2015, 11:59 AM
sdurani's Avatar
Quoted: 4972 Post(s)
Liked: 3432
Toole has mentioned more than once that spending money on subwoofers only to absorb much of that low frequency energy away is not his preferred approach to good bass reproduction in a room. Instead, his choice for subwoofer optimization is a combination of placement and equalization.
In the low frequencies, where problems tend to be minimum phase, fixing a problem in the frequency domain (e.g., pulling down a peak) can yield a likewise improvement in the time domain (reduce long decay time). Doing this with passive absorption is much harder.
One of Toole's examples of improving the bass using placement alone:
Sanjay
sdurani is offline
post #20005 of 30518 Old 08-05-2015, 01:39 PM
DonH50's Avatar
Liked: 1688
^^^ +1.
Another way to think of it is that peaks can no more than double the signal level (for a single mode). That's 3 dB in power. A little bit of EQ is enough to tame a peak. A null, however, happens when the signals cancel and can be infinitely deep if they cancel perfectly. In practice I have seen 20 to 40 dB nulls in rooms, meaning you would need 100x to 10,000x the power to pull them up. Not terribly practical so EQ is not terribly useful. Treating the room to kill a null requires a LOT of absorption and you end up killing everything (all the other frequencies) in an attempt to get rid of the main (fundamental) nulls, again not terribly practical. Absorption attempts to make the room appear larger by killing reflections that create the nulls, but in the deep bass region common absorption materials don't do a lot (yes they can help, but...) Practical solutions are to move the listening position out of the null and/or stick an active source at the null to counteract it (thus without needing 10,000x the power if you used just one sub at the same place as in Toole's picture). Other solutions are to use resonators or active absorbers to selectively tune out (suppress) specific null frequencies.
I have a ton of absorption in my room but mainly to smooth out higher modes and boundary reflections. The 30 Hz fundamental null I have struggled with has been reduced but is still large (10+ dB deep) even though I have thick (12") corner traps in front and virtually all other walls and ceiling covered by 4" or 6" absorbers with 2" or so air gaps. I have already moved as far away as I can, not very far... My plan for finally addressing the null is another pair of subs, which will unfortunately be on the back wall instead of in the null (unless I block off the door and live in the media room, which has certain appeal, but... )
DonH50 is offline
post #20006 of 30518 Old 08-05-2015, 02:19 PM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
The need for bass traps in listening rooms is not simply a matter of subs themselves (or woofers in full-range loudspeakers), though their number and placement certainly effects the perceived amount and quality of the bass in a room, but rather to the "modes" inherent (and undesirable) in all enclosed spaces, created by the three dimensions (length, width/depth, height) of every such room. Bass traps have been used in recording studios since the 1940's (often built into the wall structures), where Art Noxon of ASC (Acoustic Science Corp.) was installing them for years before offering them as commercial products for audiophiles, as his patented and highly-effective Tube Traps. They absorb and dissipate the excess energy (in both amplitude and time domains) resulting from the low frequencies produced by subs/woofers repeatedly bouncing between all pairs of parallel walls, the center frequency (and it's harmonics) of each mode determined by the dimensions (and multiples thereof) between each and every pair of such walls in any given room. If those bass "waves" are not dissipated, they continue to bounce between parallel walls, creating bass-"overhang", lingering audibly long after the signal has stopped. The more in amount and lower in frequency the bass created by a sub/woofer, the more pronounced the room mode problem.
Room modes are a very undesirable but unavaoidable consequence of music being played in an enclosed space. To not reduce them with the passive absorption available today (J. Gordon Holt first reviewed the ASC Tube Traps in Stereophile Magazine in the 1980's) is to deny oneself the improved music reproduction they provide. But to deny the well-known, long-ago-established existance of room modes, and the rational and need for measures to be taken to deal with them, is utter nonsense, the result of nothing less than, one assumes, ignorance. No offense! To educate oneself, simply go to the ASC website, as well the Cardas Audio site, where George discusses room dimensions and their resulting frequency-related modes. The listening room---perhaps the most important component in a sound system. Surely the most neglected!
BDP24 is offline
post #20007 of 30518 Old 08-05-2015, 02:33 PM
sdurani's Avatar
Liked: 3432
Is passive absorption the only way to mitigate room modes?
In the example above where Toole explains how to place a pair of subwoofers so that the first three width modes of a room are cancelled, you believe he is denying the existence of room modes?
Sanjay
sdurani is offline
post #20008 of 30518 Old 08-06-2015, 07:40 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 266 Post(s)
Liked: 365
Floyd Toole long time ago published papers on speaker evaluation of some 30-40 speakers and hoping to find the factors contributing to good sound. In the end he found good speakers not only need to have good on-axis frequency response, but also off-axis frequency response (or what we call dispersion pattern). The latter is becasue the wall reflections.
sevenz likes this.
Rythmik is offline
post #20009 of 30518 Old 08-06-2015, 02:54 PM
Quoted: 65 Post(s)
Liked: 31
So having dual subs is more beneficial then having one.
wyld0 likes this.
post #20010 of 30518 Old 08-06-2015, 03:48 PM
tvuong's Avatar
Quoted: 1768 Post(s)
Liked: 1061
^^ absolutely.
MrGrey likes this.
tvuong is online now
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
