Official Rythmik Audio Subwoofer thread - Page 703 - AVS Forum | Home Theater Discussions And Reviews
 3360Likes
post #21061 of 28136 Old 10-16-2015, 08:58 AM
PlasmaPZ80U's Avatar
Quoted: 1971 Post(s)
Liked: 565
Originally Posted by DonH50 View Post
It's also another example of just how great Rythmik's customer service is...
+1, I experienced that first hand
Great tech support too
PlasmaPZ80U is online now
post #21062 of 28136 Old 10-16-2015, 10:37 AM
Bond 007's Avatar
Quoted: 2381 Post(s)
Liked: 1918
Hate to think what it cost them just because one insert was stripped.
Bond 007 is offline
post #21063 of 28136 Old 10-16-2015, 10:57 AM
klh007's Avatar
Quoted: 38 Post(s)
Or, How many new customers it will bring to Rythmik because of their commitment to customer service? Definitely above and beyond care.
AlexanderDelarg likes this.
Kemper Holt
klh007 is offline
post #21064 of 28136 Old 10-16-2015, 11:42 AM
Liked: 565
I'm more inclined to believe the latter. While some might consider it minor, I wasn't prepared to settle on never being able to use the feet on a brand new $600 sub.
And it's my understanding if the amp and driver are indeed working normally they will be sold separately as b-stock. The enclosure will end up as junk. I suppose fixing the insert is either not possible or simply not worth the time or effort in the grand scheme of things.
post #21065 of 28136 Old 10-16-2015, 12:39 PM
Bond 007's Avatar
Liked: 1918
Wouldnt expect you to settle.
The cost of the enclosure, shipping 2 subs to you, shipping one back, labor and time is a big expense when you consider the insert probably costs less than $1.
No wonder Rhythmik is keen to make sure it doesnt happen again.
Bond 007 is offline
post #21066 of 28136 Old 10-16-2015, 01:14 PM
Liked: 565
I agree
post #21067 of 28136 Old 10-17-2015, 07:27 AM
Liked: 565
Is there a particular technique for removing the grill from these subs? Or do you simply get each of the corners loose one at a time and then carefully pull the whole grill off?
Same for putting it back on?
post #21068 of 28136 Old 10-17-2015, 10:08 AM
Liked: 565
Also, switching from 12dB to 24dB LPF slope (and back) made a noise while the amp was in the on position. Line In L+R was connected and AVR/MiniDSP/TV/source device were on but with no audio playing when flipping the switch.
Does this mean the amp should be off when adjusting the knobs/switches?
post #21069 of 28136 Old 10-17-2015, 12:33 PM
DonH50's Avatar
Quoted: 1840 Post(s)
Liked: 1371
I don't know if the grills for your model are removable (but many others have one so can help).
When you are switching gain and filter stages in and out I am not surprised there is a pop. If it is not real loud I would not worry. It should definitely be off when plugging and unplugging cables (like any other component).
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #21070 of 28136 Old 10-17-2015, 02:03 PM
Liked: 565
Ok, thanks
It wasn't real loud but was noticeable since no audio was playing at the time. Of course, I turn off the amp before unplugging or plugging the power cord or rca cables or even when changing the MiniDSP configuration.
post #21071 of 28136 Old 10-17-2015, 03:54 PM
DonnyKerabatsos's Avatar
Quoted: 80 Post(s)
Liked: 24
Would the L12 be sufficient for a room thats a bit under 2700 cu ft? 60/40 Music/HT. Room will be closed off from other areas of the house.
DonnyKerabatsos is offline
post #21072 of 28136 Old 10-17-2015, 04:33 PM
JimWilson's Avatar
Quoted: 1304 Post(s)
Liked: 1637
That's probably stretching it a bit. You might need to consider something larger in order to get acceptable response.
DonnyKerabatsos likes this.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #21073 of 28136 Old 10-17-2015, 09:36 PM
tvuong's Avatar
Quoted: 1573 Post(s)
Liked: 907
It depends on how loud you listen. My wife thinks my 12" sub is more than enough for my secondary living room system that is at least 8000ft^3.
tvuong is online now
post #21074 of 28136 Old 10-18-2015, 01:22 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
I can't recommend enough the proper placement of two subs. Get 2 L12s
Soulburner is offline
post #21075 of 28136 Old 10-18-2015, 07:17 AM
Liked: 565
Two L12s or a L22 should do the trick... a single L12 might not cut it, especially for HT.
An LV12R should be like 2 L12s around 20Hz and in mid or high extension/damping modes should be plenty articulate for music. I have one and mid is my preference for movies. Though high might be even better for music (but not movies in my experience).
post #21076 of 28136 Old 10-18-2015, 09:12 AM
JimWilson's Avatar
Liked: 1637
Key words being "my wife".
post #21077 of 28136 Old 10-18-2015, 12:33 PM
Quoted: 94 Post(s)
Liked: 2
I just bought the rocketfish surge protector to connect all my gears. And it has some features that when the main component got shut off, all others will automatically shuts off. (Not idle/standby) question is is that features safe for my LV12R? When its off there is no red color. Or better to leave it on idle/srandby with the color red on?ty
Sent from my SGH-M919 using Tapatalk
parekoy is offline
post #21078 of 28136 Old 10-18-2015, 04:50 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
While an L22 is a beast, you don't get the ability to eliminate bass issues in your room by placing subs across the room from each other. That's why based on my experience I advocate that approach so much
Samsung PN64H5000 (recommended settings)
Denon AVR-X4000
A little R&R: Reaction Audio CX-10 (2) | Rythmik Audio F12 (2)
And a pair of Emotiva Airmotiv 5s
post #21079 of 28136 Old 10-18-2015, 06:29 PM
Liked: 565
Good point, but doesn't stacking two 12 inch subs (or L22) give 6dB more output vs. just 3dB more output with subs in opposite corners or walls of the room?
post #21080 of 28136 Old 10-18-2015, 07:32 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3128
When dealing with a larger room, subs being spread out really can help smooth the freq response. When I cut one of mine off and test the chart doesnt look great at all, but is improved nicely with two spread out. Have a 7-8db dip removed is a lot more important than the 6db you may or may not gain.
65E6P / UBP-X800
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is online now
post #21081 of 28136 Old 10-18-2015, 08:23 PM
Cain's Avatar
Quoted: 331 Post(s)
Liked: 179
Guess who has a F25 headed his way this week?
JT78681 likes this.
Cain is offline
post #21082 of 28136 Old 10-18-2015, 10:03 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
The total output gain is the same either way, but putting both of them in the same place defeats the purpose. IMO two L12s or LV12s in the same place is a waste and a single F15HP or FV15HP would have been a better choice.
Denon AVR-X4000
post #21083 of 28136 Old 10-18-2015, 10:21 PM
Bond 007's Avatar
Liked: 1918
+1
Bond 007 is offline
post #21084 of 28136 Old 10-19-2015, 07:25 AM
Quoted: 80 Post(s)
Liked: 24
That's essentially the response I got for Rythmik's customer service (great response time, even on a a weekend). They, like others above, recommended an LV12R or L22. I may still go with a single L12 for now and plan to add a second when finances allow, unless the single L12 proves sufficient for my needs. I'm not in the 2700 cu. ft. room yet, but I'll be upgrading from a DefTech Prosub 1000, so I'm sure there will be a marked improvement over what I have now.
PlasmaPZ80U likes this.
post #21085 of 28136 Old 10-19-2015, 07:40 AM
Liked: 565
+1
On second thought, you guys are right; with two matching subs you can do whatever you want, which allows for much great setup flexibility.
However, my point had more to do with someone in a situation closer to mine, where there may not be optimal placement options for dual subs and dual subs would likely end up side by side or stacked vertically. In that case, an L22 or LV12R might be cheaper and more convenient to setup.
My sub/sat and MLP placement is far from optimal, though I mainly have to deal with two peaks... so I can EQ myself out of that hole pretty well. Not best practices for sure, but the best I can do without converting my small bedroom into a small theater.
Name:	sub before and after EQ.png
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
post #21086 of 28136 Old 10-19-2015, 08:58 AM
PretzelFisch's Avatar
Quoted: 400 Post(s)
Liked: 262
In your case you might look at raising your sub off the floor. what is your ceiling height. I have seen a 70hz dip due to standing waves caused by room height more so then room length, but then it might just be a big 60hz dip your dealing with.
PretzelFisch is offline
post #21087 of 28136 Old 10-19-2015, 09:13 AM
Liked: 565
I have the dreaded square room shape: 12' by 12' by 8' high (1152 cubic feet). I believe that is what causes that awful u shaped dip between the two modal peaks. My sub is midwall on the left wall, 7 inches breathing room.
However, using four 'auto pk' filters via REW and my MiniDSP 2x4 unbalanced, I get a pretty sweet house curve. Credit goes to another AVS member for creating the filters (braveheart123).
post #21088 of 28136 Old 10-19-2015, 11:20 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
The best way to remove that wide U shaped dip is to add another sub. There is no alternative, IMO, to raw flat response. You would require just a filter or two to shape the house curve.
If you can't swing enough cash for another LV12R, then make peace with what you have atm. It should still knock your socks off in that room.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #21089 of 28136 Old 10-19-2015, 12:29 PM
Liked: 565
It's not just cash, but also no room for another sub of this size and placement options for smaller subs still far from ideal to get the full benefit from dual subs. Plus added complexity of setup/integration with everything else.
(And I've seen setups on the forum where dual subs didn't make the kind of difference the owner was expecting due to placement restrictions.)
That being said, I don't feel I'm missing anything with the current sub running at its best post-EQ. It sounds awesome. Especially with bass heavy movies like action and horror movies.
Honestly, even if I could have 2 LV12Rs optimally placed and setup/integrated I don't think the bragging rights of being able to say I only used 2 filters would justify the cost since I can't imagine the post-EQ measures looking much better than they are now.
Also, I only have one MLP and single listener only so I don't need to have optimal frequency response over a larger listening area.
post #21090 of 28136 Old 10-19-2015, 02:06 PM
MrGrey's Avatar
Quoted: 537 Post(s)
Liked: 628
Whats the point of having a sub this big if you don't give it a workout every DAMN day!. i find myself listening to OST and orchestra a whole lot more. the FV15HP is truly incredible it really brings an emotional impact to music.
Receiver - Sony STR-DH550
Fronts - Klipsch Reference Premiere RP-280F
Center
- Klipsch Reference Premiere RP-450C
Sub - Rythmik FV15HP
The Ultimate List of BASS in Movies w/ Frequency Charts
My PayPal.Me
MrGrey is offline
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
