Official Rythmik Audio Subwoofer thread - Page 712 - AVS Forum | Home Theater Discussions And Reviews
 3517Likes
Old 11-05-2015, 05:56 AM
rcohen's Avatar
Quoted: 1322 Post(s)
Liked: 575
Originally Posted by Richard Berg View Post
I prefer the accuracy of sealed subs, and the placement flexibility (room correction) of 2x smaller subs vs 1x larger sub.
So it seems like the best choices are L22 or F15HP. They have about the same output capability. Yet the L22 is way cheaper!
Besides the extra space required**, are there any sonic tradeoffs? I don't have a good intuition for the pro/con of paper drivers. (my mains are very large, so covering the 80-120Hz region as with F15G's paper option is not a concern)
**can the dual driver models (L22 / F25) be placed horizontally?
Yes, those subs can be placed horizontally. At low frequencies, it doesn't cause the kind of interference problems that you get with normal speakers.
I'm not sure if this is what you're saying, but 2 drivers in a single unit has no advantage over a single driver in terms of fixing room modes. You need a separate unit with separate placement to accomplish that. Multiple drivers only provides more output than a single driver. Specifically, doubling the driver area and doubling the power (a second amp for the second driver) gives about 6db more output.
rcohen is offline
Old 11-05-2015, 07:04 AM
Richard Berg's Avatar
Quoted: 38 Post(s)
I understand the physics. I don't understand the business model Specifically, F15HP vs L22.
What makes the single-driver cabinet more expensive? Why should anyone pay 50% more for a sub with 28% less cone area?
Maybe this isn't a fair comparison -- can't assume "all else being equal" -- but it's unclear what those inequalities are.
Richard Berg is offline
Old 11-05-2015, 07:08 AM
1MediaGuy's Avatar
Quoted: 22 Post(s)
Liked: 8
Originally Posted by checker9 View Post
I will have to get it up a flight of stairs. Also, the best place in the room, as measured, for a subwoofer is in particular sport that without moving major furniture, I would need to be able to lift the subwoofer above my waist to walk to the spot.
If I get one, I plan to buy it in person. I will make sure I can handle it as needed before buying. I am driving about 125-150 miles each way to get one, so I want to explore the idea before driving there in case it turned out that I could not handle it as I will need to do and then it would turn out to be a wasted trip.
I was able to easily get mine up the stairs with no help. I simply kept it in the box and toppled it up the staircase end over end. I also had a corner to turn that was pretty easy. The box is big and the unit weighs a little over 100lbs but pushing it over was a breeze.
However, I would recommend someone helping you.
∙·Sony VPL-HW40ESDenon x2100wEnergy RC-70Energy RC-LCREnergy RC-10Rythmik FV15HP·∙
1MediaGuy is offline
Old 11-05-2015, 07:14 AM
rcohen's Avatar
Liked: 575
Gotcha. I don't know.
The web site describes the L22 as "entry" level, and it has a different amp and different drivers, but the specs do look similar, don't they?
rcohen is offline
Old 11-05-2015, 08:47 AM
PlasmaPZ80U's Avatar
Quoted: 1999 Post(s)
Liked: 570
Originally Posted by Bond 007 View Post
Originally Posted by PlasmaPZ80U View Post
Regarding all those (ditto related) posts, I need to point out that I asked about separate frequency and damping controls not because I wanted to buy a premium Rythmik sub or upgraded amp (if even possible) nor because I wasn't satisfied with the single combined control on my LV12R.
I asked a technical question because I was curious about how damping and frequency response are related.
So, getting replies that either told me to get 1 or 2 FV15HPs or to not worry about such things and just enjoy my LV12R were to me not helpful to me as the only reason I asked the question was for a clear, direct, straightforward answer.
And I greatly thank those who did directly answer it, including a few Rythmik sub owners and of course, Brian.
However, as a future (polite) suggestion, if I ask a technical or academic question, I'm asking because I want to know the exact (or close enough answer), not because I'm looking to make a purchase/upgrade or because I'm dissatisfied with what I presently have. Hope this clarifies what I'm trying to achieve when I ask such questions.
And I don't consider it over thinking things... I just have a very technical, analytical mind.
This isnt the first time or first thread that you have gotten that sort of response. Think about it.
I have thought about it but let's just say my conclusion is very different from what I believe you have in mind. That's all I'll say as I don't want to offend anyone.
PlasmaPZ80U is online now
Old 11-05-2015, 09:16 AM
Bond 007's Avatar
Quoted: 2498 Post(s)
Liked: 1980
Understood.
Although this is a tech forum many of the questions are of a practical nature. Questions that require a lot of technical explanation and an engineering degree to understand arent for the most part practical.
As Ive told you before there is an Audio Theory part in AVS. With such a technical and analytical mind as yours you would be right at home there (just dont ask them the best way to open the subwoofer box or take the grill off).
Don has a good point. Perhaps you should pursue an engineering degree to satisfy your mind.
PlasmaPZ80U likes this.
Bond 007 is online now
Old 11-05-2015, 10:12 AM
Liked: 570
Understood.
I was going to edit my post to say that I agree there is better place for such technical questions (to avoid cluttering an owners thread which is better suited to more general and setup based questions).
So, I agree with that. Oddly enough, I did study electrical engineering for a year before switching to a business degree. I guess my interest in such things falls somewhere between general user and engineer.
Old 11-05-2015, 11:14 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
To understand audio, one doesn't need a degree in electronics or related field. Physics till A levels is enough. Maths also does give a helping hand.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
Old 11-05-2015, 11:17 AM
Bond 007's Avatar
Liked: 1980
That depends on how well you want to understand it.
Old 11-05-2015, 11:21 AM
Quoted: 38 Post(s)
I'd suggest that psychoacoustics (loudness curves, localization, masking) are even more important.
Old 11-05-2015, 01:05 PM
Quoted: 311 Post(s)
Liked: 273
Enough to get things going the way they must and not should. Engineer I am, though not in electronics.
Old 11-05-2015, 01:27 PM
Quoted: 341 Post(s)
Liked: 50
I finally tested out my Dual FV15HP.. these things rock and shake the house.. (mad max fury road) was first movie i tested... we have glass figurines in the curio cabinet; they almost tipped over
blackjack616 is offline
Old 11-05-2015, 02:54 PM
JimWilson's Avatar
Quoted: 1371 Post(s)
Liked: 1795
Dual FV15HP's? I predict a short life for those figurines...
BDP24 likes this.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
Old 11-05-2015, 03:03 PM
12B4A's Avatar
Quoted: 315 Post(s)
Liked: 187
Almost? I suggest +3dB.
Life is Lambertian
12B4A is online now
Old 11-05-2015, 03:19 PM
Quoted: 341 Post(s)
Liked: 50
I have it set at 0DB right now... I couldn't imagine 3DB during mad max fury road..
these subs are monsters.
Old 11-05-2015, 06:17 PM
DonH50's Avatar
Quoted: 1907 Post(s)
Liked: 1436
+1. You don't need an engineering degree for a basic understand that will help immensely in understanding how things work and what things don't.
OTOH, my grad acoustics class started with wave equations and multi-dimensional integral-differential calculus. The good stuff was at the back of the book, after all the high-level theory. Prereqs included advanced EM classes, physics courses, and transmission line theory in addition to an undergrad degree.
FWIW, Brain Ding (the man behind Rythmik) has a PhD in EE.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
Old 11-05-2015, 07:35 PM
meli's Avatar
Quoted: 181 Post(s)
Liked: 42
I'd also be interested if someone would like to chime-in about the sonic differences between the F15HP vs L22.
Or between the L22 and F12, which are about the same price as each other.
meli is offline
Old 11-05-2015, 09:11 PM
DonH50's Avatar
Liked: 1436
Chances are nobody has had both subs to compare (except for Brian and Enrico). The differences are largely in the better drivers (speakers) and amplifiers (more features, different amplifier topology) in the higher-priced units. I suspect sonic differences, especially with a servo design, are subtle. There is also form factor to consider, natch.
meli and PlasmaPZ80U like this.
Old 11-06-2015, 01:02 AM
Quoted: 311 Post(s)
Liked: 273
If there is any sonic difference between theses subs, they are poorly designed. The difference should only be in their playback capabilities (output, extension, FR, -3dB point) not in the sonic signature.
Old 11-06-2015, 05:05 AM
meli's Avatar
Quoted: 181 Post(s)
Liked: 42
Thanks. That would then bring us back to the other posters' comments; how to justify (from a marketing position, if nothing else) the large price discrepancy between the F15HP and the L22 when they measure so similarly.
meli is offline
Old 11-06-2015, 05:13 AM
12B4A's Avatar
Quoted: 315 Post(s)
Liked: 187
Don't forget the finishes. They do add value even if it's not audibly functional.
Life is Lambertian
12B4A is online now
Old 11-06-2015, 05:53 AM
DonH50's Avatar
Liked: 1436
This has been debated before; look back through posts or search the thread. Features and form factor were the main reasons IIRC. The drivers and amplifiers cost more. Not sure why the debate, nor why Brian needs to justify them to us; if you don't like 'em, don't buy 'em!
smurraybhm and BDP24 like this.
Old 11-06-2015, 06:31 AM
meli's Avatar
Quoted: 181 Post(s)
Liked: 42
I'm not sure I'd call it a debate. More like a friendly discussion (hence the term discussion board). If nothing else, it's interesting from a marketing perspective, how to market two subs that measure similarly but are priced differently. I'm sure appearance, such as the finish, does account for some of the difference, but that pitch is not obvious from their web site. So perhaps there are other differences I'm not aware of.
meli is offline
Old 11-06-2015, 06:35 AM
DonH50's Avatar
Liked: 1436
Drivers (speakers) are different.
Amplifiers are different.
Old 11-06-2015, 07:23 AM
kbuzz's Avatar
Quoted: 27 Post(s)
Im considering the purchase of a used Rythmik. Does anyone know If I am correct in that there 3 year amp coverage and 5 year driver. And that the warranty is transferable?
kbuzz is offline
Old 11-06-2015, 08:10 AM
enricoclaudio's Avatar
Quoted: 1173 Post(s)
Liked: 1238
I was in the market last week for a new set of powered monitors for my Pro Tools 12 + Logic Pro X rig. After I decided for the Apogee Duet for Mac because the ESS Sabre32 DAC then the search for the right monitors started....All came down to Focal vs Dynaudio. I was between Focal CMS 65 and Dynaudio BM6 MKIII. I put Focal out of the contest and decided for Dynaudio but before to pull the trigger on the BM6 MKIII I started to look at the BM5 MKIII. The difference between the two models is basically on the amp. The BM6 MKIII amp is Class AB and the BM5 MKIII is Class D. Both speakers have the same drivers but there is a price difference of $180 per speaker. Knowing the differences between Class D and Class AB amps I decided to go with the BM5 MKIII and save that money. Glad I did it because after further inspection I noticed that the BM6 MKIII only have one XLR input while the BM5 MKIII has XLR (balanced) and RCA (unbalanced). Also the cabinet on the BM6 MKIII is bigger so it won't fit on my desktop. The BM5 MKIII sounds Amazing btw, and I'm really happy with my purchase...
Now why I'm telling this story to you guys, well in my case the decision was based on connectivity options and speaker size because knowing that there will be not too much difference in sound quality between the two amps the sound quality part was not a concern. Now back to subwoofers, we have the same dilemma between the F15HP and the L22 and between the F12 and L12. I think Brian mentioned this several times before: sound quality wise the F15HP and the L22 are pretty close, so close that you can match them in the same room. Same thing for the F12 and the L12. So at the end everything boils down to speaker size, finishes available, connectivity option and of course money. For the L22 and L12 there are NO amplifier upgrades (no XLR, no speaker level inputs), no PEQ and no Piano Black finish. Also we won't offer the L12 nor the L22 as CI Kits. While the L22 has the same output at 20Hz as the F15HP the L22 only goes down to 18Hz while the F15HP goes down to 14Hz. Same thing for the L12 and F12 but also the F12 has +1dB more output at 20Hz compared to the L12.
Here is a comparison chart that I made to help see the differences between the models discussed:
meli, PlasmaPZ80U, DonH50 and 4 others like this.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
Old 11-06-2015, 08:22 AM
kbuzz's Avatar
Quoted: 27 Post(s)
Now why I'm telling this story to you guys, well in my case the decision was based on connectivity options and speaker size because knowing that there will be not to much difference in sound quality between the two amps the sound quality part was not a concern. Now back to subwoofers, we have the same dilemma between the F15HP and the L22 and between the F12 and L12. I think Brian mentioned this several times before: sound quality wise the F15HP and the L22 are pretty close, so close that you can match them in the same room. Same thing for the F12 and the L12. So at the end everything boils down to speaker size, finishes available, connectivity option and of course money. For the L22 and L12 there are NO amplifier upgrades (no XLR, no speaker level inputs), no PEQ and no Piano Black finish. Also we won't offer the L12 nor the L22 as CI Kits. While the L22 has the same output at 20Hz as the F15HP the L22 only goes down to 18Hz while the F15HP goes down to 14Hz. Same thing for the L12 and F12 but also the F12 has +1dB more output at 20Hz compared to the L12.
This is a very timely post for me since I just sent Rythmik a message regarding a used out of amp warranty F12 versus a new L12. So if im reading this post right -forgetting looks and connectivity options and a negligible size differential -- aside from the PEQ, there would not be a great gap/gulf in real world sound between and F12 and L12. And particularly the case for a mostly music system where slightly higher output is not a concern?
kbuzz is offline
Old 11-06-2015, 08:28 AM
Quoted: 38 Post(s)
I spoke to Brian last night. Differences are:
  • Paper drivers in the L22 are lighter, so "faster". I assume this means less power is required for a given excursion amplitude. So the servo mechanism should have more headroom to respond/correct the waveform, as long as you're not near max SPL.
  • Aluminum drivers in the F-series are stiffer, considerably less prone to breakup / distortion near max SPL.
  • F15HP amp has PEQ, L22 does not.
  • Overall, he recommends the F15HP if you are extra picky about accuracy, or if you need to blend in with a 2-channel music system that lacks PEQ, or if the L22 is too large.
  • I specifically asked if the performance differences would disappear at lower volumes. He said yes, when not operating near max SPL, you'd need fancy instrumentation to tell a difference.
  • I also asked if the L22 could be placed horizontally, to mitigate the size issue. He said that would be fine, sonically.
I won't be pushing these subs to their limit (I find >100dB is more "uncomfortable" than "exciting"), so the L22 seems like the obvious choice.
Old 11-06-2015, 08:49 AM
Bond 007's Avatar
Liked: 1980
Id be more curious as to why someone would get the F8 instead of the L22 for the same price.
Old 11-06-2015, 08:52 AM
Quoted: 38 Post(s)
Here are the frequency/phase charts for both subs with max damping enabled (Q = 0.5)
Nothing that can't be fixed by adding a 2nd L22
(seriously, it's only a bit more expensive than a single F15HP, while also smoothing out in-room response)
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
