Official Rythmik Audio Subwoofer thread - Page 718 - AVS Forum | Home Theater Discussions And Reviews
 3386Likes
post #21511 of 28197 Old 11-14-2015, 12:36 AM
Shydow's Avatar
Quoted: 14 Post(s)
Originally Posted by tvuong View Post
In case you missed, JT has 2 FV15hps to achieve the 108db in his room.
I hadn't noticed him saying it directly, but given the size of his room I reckoned dual subs were at play. I'll be looking into dual subs if/when I move into the new space I'm considering, at which point I'll be sitting between 5,000-6,000 cubic feet. Right now I'm only at ~2100 cubic feet.
Again, my idea here is to get more than enough for now, so that it goes back to being more than enough when I double up down the road
Sharp LC-46E77UN
Xbox One Elite Edition
Denon AVR-X4100W
Rythmik FV15HPse
Harman Infinity Primus P363 FL/FR | Harman Infinity Primus PC351 C
Spherex OmniPolar SL/SR
Shydow is offline
post #21512 of 28197 Old 11-14-2015, 05:55 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 247 Post(s)
Liked: 333
Originally Posted by sevenz View Post
I've used and tested both HSU and Rythmik 15" subs in my system before and my impressions are both produces good subs. Note that the FV15HP is at a slightly higher price point. Out of the 2, my ears prefer the Rythmik. Frankly, u wont go wrong with either. =)
IMHO, my decision route would be like this:
1) if i can only fit 1 single sub in my room and absolutely no intention to add a 2nd sub, and budget is not a concern, i would lean towards the FV15HP.
2) if i plan to add 1 more sub in future, however dont want to spend too much (but the price of 2x HSU subs is ok), i would lean towards the HSU.
If budegt is an issue, we have less expensive FVX15 model. It uses exactly the same enclosure and tuning of FV15HP. It also has metal cone driver.
Rythmik is offline
post #21513 of 28197 Old 11-14-2015, 06:48 AM
bear123's Avatar
Quoted: 1719 Post(s)
Liked: 2527
Originally Posted by checker9 View Post
Unless Rythmik releases other numbers, or the LV12R is officially tested, that is all one has to compare. And both have fairly flat frequency responses, so why is it going to be behind 2-3 dB at 20Hz then be higher 2-3 dB in the mid bass, when both are claimed to be flat to 19 Hz. (Rythmik has the LV12R listed at +-2dB from 19 to 100+Hz, a 5 to 6dB flip would be outside that.)
Because the frequency response that the sub has been eq'd to at low level has almost nothing to do with its maximum output capability at various frequencies. No sub made will have maximum output at 80 Hz only 2 dB above its 20 Hz output. The vast majority of subs have double to triple the output at 80Hz than at 20 Hz, including ported subs. SVS sub are noted for having exceptionally good low frequency output compared to their mid and upper bass output when comparing them to other similar subs. For example, the PB12-NSD has nearly the same 20 Hz output as Hsu's VTF15H, yet the Hsu sub more than doubles the PB12's output above 30 Hz. This old version of the PB2000 hit 103 dB at 20 Hz, but only 108 at 80 Hz.
Any sub can be eq'd very flat at low level; again, has nothing to do with output.
bear123 is offline
post #21514 of 28197 Old 11-14-2015, 06:56 AM
JT78681's Avatar
Quoted: 1382 Post(s)
Liked: 912
Originally Posted by Shift View Post
@ 108db you should "feel" it buddy, even at 10hz and duals at that. You should get 'sum' tactical feel.
I know you have a good size room which means more headroom to fill, but sitting 12' away you are basically sitting on your subs brotha.
So it looks like I'm closer to 106 maybe 107db at 10hz. It's been awhile since I looked at my last set of measurements. I use mid dampening.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #21515 of 28197 Old 11-14-2015, 06:59 AM
JT78681's Avatar
Liked: 912
@Soulburner
Nice response!
Soulburner likes this.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #21516 of 28197 Old 11-14-2015, 09:46 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 247 Post(s)
Liked: 333
And yet no one has explained how this exactly happens. The reason is PB2000 uses a driver with high BL value and yet very heavy cone. It is the heavy cone that makes the inertia problem worse. Now why does it have a heavy cone? It uses a lot of turns of coil. This is a tricky that every company knows. But it comes with a price.
There has been discussion of whether cone mass is audible. I think it is. But from frequency response, one can actually tell if the cone mass is heavy. The sub has lower midbass output is the one with high moving mass. If one listens to enough of those and then compare that to those with lighter cone mass, it is easier to draw conclusion if the cone mass makes audible difference.
sevenz likes this.
Rythmik is offline
post #21517 of 28197 Old 11-14-2015, 11:35 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
Inertia won't be a problem if BL and Mms are kept proportional to each other. The former depends on the later.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #21518 of 28197 Old 11-14-2015, 01:19 PM
Quoted: 339 Post(s)
Liked: 50
I love bass like really like it thats why i got 2 FV15HP…. My SUBS are set at about 12-1 and on my AVR is 5db, is that to hot?
the subs move like crazy… i turned my vol up to 75% on my AVR and my wife literally told me she thought we were having an earthquake because the fireplace started to rattle
blackjack616 is offline
post #21519 of 28197 Old 11-14-2015, 01:34 PM
tvuong's Avatar
Quoted: 1579 Post(s)
Liked: 911
^^ you want to increase the volumes on the subs so that Avr sets them into the negative range (-6 or so).
tvuong is offline
post #21520 of 28197 Old 11-14-2015, 01:37 PM
tvuong's Avatar
Liked: 911
What frequency range is mid bass, Brian? I keep hearing different range from different folks thanks.
tvuong is offline
post #21521 of 28197 Old 11-14-2015, 05:05 PM
PlasmaPZ80U's Avatar
Quoted: 1973 Post(s)
Liked: 566
I'm finding a flat response from 19Hz to 105Hz or so sounds very strong without the need to run sub trim hot at all. And I listen at MV: -30 and under.
What does that mean exactly? That flat response sounds stronger than house curves or that midbass is what makes it sound strong at moderate/modest volumes? Trying to make sense of why I perceive flat response as stronger than a house curve that biases deep bass over midbass.
PlasmaPZ80U is offline
post #21522 of 28197 Old 11-14-2015, 05:35 PM
Exclusively Servo
Rythmik's Avatar
Quoted: 247 Post(s)
Liked: 333
One can increase the BL value by a shorter coil (meaning shorter winding length), or tighter magnet gap, or larger magnet. Adding more turns in voice coil means wider magnet gap.
Another effect of high mass is when Mms is high the kinetic energy of cone movement is also higher. We all know where that energy goes to.. It goes to the enclosure and then spread. You have EE background. The cone mass is modelled as an equivalent capacitor in T/S parameters. To be more precisely, the equivalent capacitor is Mms/(BL)^2. In addition, that capacitor and voice coil inductance form a LC network. We need to also keep that LC network resonace frequency the same which means while we play this scaling game on BL and Mms, our inductance cannot change or it is no longer a perfect scaling. So increasing BL by having more turns (which alwasys increase voice coil inductance) always come up short in the end. Not to mention if we make Mms 50% higher, we also needs to make enclousre weight 50% higher (or 50% denser) to be a perfect scale system, isn't it? This is because the enclosure is the one receives the reaction force from cone movement.
Soulburner and BDP24 like this.
Rythmik is offline
post #21523 of 28197 Old 11-14-2015, 05:51 PM
trmoore2's Avatar
Quoted: 109 Post(s)
Liked: 48
Adding an 18" DIY sub with my 15" Rythmik?
I have a 15' x 20' dedicated home theater room. I already have the a Rythmik 15" sealed subwoofer (F15HP) that works fantastic for music.
I'm looking for a little more oomph for movies. I'd prefer not to add two additional subs to the room, so I'm considering building an 18" Dayton Ultimax with a Crown XLS 2002 amplifier (bridged for 2100 watts).
Has anyone tried this? I'm looking more for powerful tactile bass for movies, than smooth integration for music.
Thanks in advance!
Main Speakers: Revel F208's. Center: C208
SUB#1: Rhythmik F15HP. SUB#2: Stereo Integrity HST18 w/ Crown XLS2502
Marantz SR7009, Emotiva XPA-5
Projector: Sony HW55-ES, Carada 134" screen
trmoore2 is offline
post #21524 of 28197 Old 11-14-2015, 06:06 PM
Bond 007's Avatar
Quoted: 2394 Post(s)
Liked: 1919
Thanks in advance!
Theres a DIY section at AVS also.
Bond 007 is offline
post #21525 of 28197 Old 11-14-2015, 06:24 PM
sevenz's Avatar
Quoted: 65 Post(s)
Liked: 46
yea, that's another option
sevenz is offline
post #21526 of 28197 Old 11-14-2015, 06:34 PM
DonH50's Avatar
Quoted: 1873 Post(s)
Liked: 1398
Thanks in advance!
If it is a replacement for the Rythmik, post in the DIY forum and you'll get lots of help.
If in addition to your Rythmik, I'd just get another F15HP.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #21527 of 28197 Old 11-14-2015, 09:13 PM
trmoore2's Avatar
Quoted: 109 Post(s)
Liked: 48
I have posted in the DIY forum, but I am hoping i can get more bass for less money by building my own. Just curious if anyone has mixed their subs? I'm not looking for perfection, just more oomph.
trmoore2 is offline
post #21528 of 28197 Old 11-14-2015, 10:16 PM
DonH50's Avatar
Liked: 1398
Then why post in this thread? Yes, you can got more SPL (I assume that is your definition of "oomph") for the dollar by building your own, and arguably comparable sound quality (though without the benefits of servo), if done properly.
Many people have mixed sub manufacturers and types. Integration is often harder but with a little effort and work with REW or similar measuring tools it can be done. It is a popular topic and has been discussed in this and other threads. Phase alignment requires either a continuous phase control like on your Rythmik and/or some sort of DSP-based solution.
post #21529 of 28197 Old 11-14-2015, 11:52 PM
Quoted: 311 Post(s)
Liked: 273
Very well said and I get your point.
post #21530 of 28197 Old 11-15-2015, 07:39 AM
bear123's Avatar
Liked: 2527
Plasma, this is an excellent FR, one of the better ones that I have seen. My opinion on why this sounds so good to you especially from a mid bass standpoint, is that you appear to have very good integration with your mains around the crossover. The majority of folks, it seems to me, struggle to maintain a flat response in the 80-200 Hz region, and yours(although you are not showing out to 200), seems exceptionally good in this region. A house curve in the lower frequencies is not going to affect the impact you get from mid bass/music etc. It is simply meant to increase LFE impact on movies when played back at lower volumes.
PlasmaPZ80U likes this.
bear123 is offline
post #21531 of 28197 Old 11-15-2015, 08:39 AM
Quoted: 51 Post(s)
Liked: 5
Hi everyone- I have been looking closely at the E15HP or the FV15HPse (love that piano black finish!). I'm leaning sealed despite a large space to fill because 1) the fiance is not into a ton of base, and 2) because we are currently in a condo, so the neighbors are a factor.
I've scoured numerous threads in this forum for insight into these two subs, and everything is largely positive. So, I'm wondering if anyone has hands-on experience with either or both and is willing to give me some feedback on the two? It sounds like both are extremely clean thanks to the servo technology, but I still want some rumble/chest thump, which is why in this instance the choice between sealed vs. ported is difficult!
These two Rythmik subs, as well as two 15" subs from a certain "phonetic alphabet" competitor (alpha...echo...gamma) are the front runners, so anything to separate the 4 would be greatly appreciated!
At this point I feel like it's picking nits, and I could throw a dart and be extremely happy. I know any of these subs will be great for me, so that's kind of a great position to be in! Thanks in advance.
adeszko is offline
post #21532 of 28197 Old 11-15-2015, 09:15 AM
Liked: 566
Thanks... to clarify that's an LFE/sub only measure. Though the CC+sub and L+R+sub are pretty flat in this frequency range shown (80Hz crossover). Frequency response well past 120Hz is another story.
post #21533 of 28197 Old 11-15-2015, 09:18 AM
Liked: 566
Is the port made of plastic or mdf? How thick?
And what's the gray insulation like material at the end?
Just curious...
post #21534 of 28197 Old 11-15-2015, 09:30 AM
Liked: 566
While this is based on different filters in high bass extension (not mid like in the pic you quoted), it shows CC+sub and L+R+sub to 200Hz. They are not equalized, as the PEQ in my AVR sounds bad and I have yet to upgrade to an $800 or so model with Audyssey MultEQ XT32 and Sub EQ HT.
Name:	high bass extension CC+sub.png
ID:	1059313   Click image for larger version
Name:	high bass extension L+R+sub.png
ID:	1059321   Click image for larger version
Name:	high bass extension sub only.png
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
post #21535 of 28197 Old 11-15-2015, 11:03 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 380
I would say that there are no bad choices here, and both companies would give you great subs for your money, with the difference of course being the servo and amp controls. But in my opinion, your wife's opinion of bass and having neighbors are not factors to consider when deciding between ported or sealed. That's just going to determine the levels that you listen at. You may also want to look into Audyssey's Low Frequency Containment feature.
Get a ported sub if you want a boost in the 20-25hz region and have the space for its increased size. Get a sealed sub if you want maximum low frequency extension, and/or need your sub to be smaller. Because of the servo and other factors, there should be almost no sound quality differences between Rythmik subs above 30hz.
Soulburner is offline
post #21536 of 28197 Old 11-15-2015, 11:36 AM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3170
Originally Posted by JT78681 View Post
I'm positive I measured. It takes a lot of power down that low for it to be perceivable.
Me and you are in the same boat, with dual FV15HP's. I am dealing with a huge room and tested 105db at 12hz and 110db at 16hz (115db target).
You can tell there is pressure there, but that ultra low bass just seems to rattle a bunch of stuff. Im not sure what the kick you in the chest bass range is, but I never notice that at 10-12hz with testing.
Now dont take that to think these subs dont hit like a mutha, because they do. From 30hz to 100hz I achieve between 115db and 120db.
65E6P / X800
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is online now
post #21537 of 28197 Old 11-15-2015, 12:36 PM
JimWilson's Avatar
Quoted: 1316 Post(s)
Liked: 1670
I've owned the former and have heard the latter so if there's something you're curious about ask away. But before you do I have a question; what constitutes a "large space" for you? If you can provide the HxWxD of the entire space - not just what might be considered the viewing area - that might help make the decision for you.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #21538 of 28197 Old 11-15-2015, 01:16 PM
PretzelFisch's Avatar
Quoted: 400 Post(s)
Liked: 262
chest thump I think is in the 100-300 mid bass range.
PretzelFisch is online now
post #21539 of 28197 Old 11-15-2015, 02:56 PM
Quoted: 51 Post(s)
Liked: 5
Sure, Jim. Thanks for the response! I apologize for the following description: our condo is difficult to describe! And for the record, I'm about 70% TV/Movies/Videogames and 30% music.
We are currently in a loft-style 1 bedroom, 1400 square feet condo. Our "family room," where the TV and sound system reside, is open to our kitchen and dining room. That space, in turn, is open to our bedroom as the walls do not go all the way up to the ceiling (a la loft style). The ceiling is also 13 feet high. It's a cool space to live, but NOT the ideal space for a sub.
The reason I did not include any descriptions about the space in my prior post is because this is only a temporary rental. We plan on being here only for another year and a half, before getting something larger. Thus, I don't want to choose a sub specifically for the very large, open condo that yearns for at least 2 ported beasts because I know the space will be different in the relatively near future. I would like to choose the best single sub I can moving forward- regardless of the space. Yes, I know that it is impossible to ignore the room, but I really don't want my fiance killing me in a year when I tell her we have to buy a new sub when we move.
In terms of specifics about the subs: my fiance doesn't like to watch movies too loudly (which drives me crazy; give me more volume!), so I need a sub that can give me some clean chest thumping even at moderate volumes. That pushed me towards a sealed sub, but this space pushed me towards ported. I oscillate back and forth every hour!
To wrap this overly long post up (I apologize!), the reason I have been pulled towards Rythmik is due to the "clean" sound people like you have described! Though I'm concerned the servo technology may detract from that chest thump, which- please correct me if I'm wrong- but as I understand from a previous thread where you conducted an impromptu comparison between Rythmik and SVS, you ended up with the SVS as your personal sub for that very reason?
Thanks for all the help! I'm just a guy that needs great sound from a great sub!
adeszko is offline
post #21540 of 28197 Old 11-15-2015, 02:57 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3170
Seems a little high for the kick, since most subs cutoff before than. I was thinking 50-100hz range. Mine rolls off pretty good from 100-120.
65E6P / X800
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
