Official Rythmik Audio Subwoofer thread - Page 724 - AVS Forum | Home Theater Discussions And Reviews
 3381Likes
Old 11-23-2015, 03:41 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
Remove all ifs... run it, its free...
Originally Posted by rossandwendy View Post
I've been running out of the LFE connection on my Rythmik F12 but would like to try out the LINE connection. I just recalibrated Audyssey a couple days ago and everything sounds great. Must I run Audyssey again if I switch from LFE to LINE?
Ross
rossandwendy likes this.
qguy is offline
Old 11-23-2015, 04:30 PM
rossandwendy's Avatar
Quoted: 57 Post(s)
Liked: 57
Originally Posted by Soulburner View Post
One odd thing I found when making the switch is that my sub distances changed. They went from 9ft and 7ft, to 15ft and 12ft to achieve the best blend at 80hz. Not sure why.
Sounds like there's some differences in time alignment then, when switching?
_____________________________________
Receiver: Marantz SR7008
Source: Oppo BDP-83 multi-region, Sony BDP790 3D
Display: Sony 45ES on Silver Ticket 120" screen
Speakers/Sub: EMP Tek R55Ti, R56Ci, R5Bi, dual Rythmik L22's
rossandwendy is offline
Old 11-23-2015, 07:00 PM
steveting99's Avatar
Quoted: 1804 Post(s)
Liked: 616
Brian/Enrico,
Can you help me understand the purpose of the low pass slope setting on the A370PEQ3 plate amp? I've currently set this to EXT/12, but want to know more about the 80Hz/24dB and 50Hz/24dB settings. What does this do exactly?
I have a receiver (Marantz SR-7009) that does the bass management. Think the receiver uses a 12dB/octave slope on either side of the crossover frequency.
Currently using the F8+KEF E301 to make the front speakers full range.
By using line input, if I change the low pass slope setting to 80Hz/24dB, would that mean the crossover on the receiver has to be also set to 80Hz to match or is it irrelevant? I'm having some difficulty understanding the low pass slope feature on the A370PEQ3 plate amp.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
Old 11-23-2015, 10:09 PM
DonH50's Avatar
Quoted: 1870 Post(s)
Liked: 1396
Ross
Yes. Phase shift is different and thus time (delay) changes even with the crossover set to max frequency. Changing the filter, as well as other features on the line input, changes the phase.
If everything sounds great why the change?
Regarding crossover settings, IIRC AVR/12 is a 12 dB/octave crossover with frequency set by the knob on the amp. The other settings use a 24 dB/octave slope at fixed frequencies of 50 Hz or 80 Hz. Whatever you do is cascaded with the AVR's response. If the AVR is set to 80 Hz and uses a second-order (12 dB/octave) filter, then EXT/12 set to 80 Hz will provide a 24 dB/octave electronic rolloff in addition to the intrinsic speaker response (probably not much contribution at 80 Hz). Brian has explained it in this thread, somewhere...
Note the (one) trade with using the LFE input is that the wider (higher) bandwidth raises the noise floor slightly compared to the line inputs. IME the difference is negligible.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
Old 11-24-2015, 03:24 AM
Cain's Avatar
Quoted: 331 Post(s)
Liked: 180
Cables.
I have a Marantz 8802A. What cabke should I use with my F25s?
I'd prefer XLR since one cable needs at least a 35 foot run.
What cables do you guys like?
Cain is offline
Old 11-24-2015, 04:00 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
That is coz Line In is low passed on the sub resulting in LPF induced added delay. That should be normal.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
Old 11-24-2015, 04:45 AM
Jacob B's Avatar
Quoted: 81 Post(s)
Liked: 25
Originally Posted by steveting99 View Post
Hi Jacob B,
Best to place the F8 (FM8 in your case) close as possible to the front left and front right speakers if you're wanting to combined response with a high crossover on the receiver that doesn't localize. It really depends on how far away the speakers are from the Main Listening Position (MLP).
I know I am sacrificing a bit on the placement of the right FM8 in relation the right main speaker, but that is a consequence of my asymmetrical room. It might localize further right than the mid and highs from the right main speaker - we will see (hear).
I will likely have to play with the AVR crossover frequency - 180-200 hz might be too high for music, but work well for movies or vice versa.
I hooked them all up last week, but not with their own power circuit yet. I have a humm in all speakers. I will not investigate until they have their own circuit. Right now they share circuit with light dimmers, 220v to 110v power converter, media server, router, switch, printer, etc. They have ground connected. I have not tested them yet for humm with the RCA cables disconnected (which would remove the signal path / long cable run (50 feet) as a potential cause).
Thoughts, anyone?
Except for a big drop after 50 hz, which I believe is caused by the lower output from the FM8 as compared to the E15HP, it sounds great! I will turn up the FM8s a couple of clicks and run bas EQ again.
I watched San Andreas with my sons this weekend and the earthquake could be felt - the berkline recliners were shaking :-D
Jacob B is offline
Old 11-24-2015, 04:48 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
Originally Posted by Cain View Post
Cables.
If you have the XLR2 or XLR3 amp on your Rythmik, and balanced outputs on your Marantz, you may as well use the XLR inputs and outputs. With a 35' cable I sure would! Unless you're really into specialty cables, the Mogami Gold Studio balanced cable will be fine. You can get it at any good pro audio shop or guitar store. Guitar Center sells the 25' Mogami Gold Studio for about $70/ea, but you can find it online for less I believe. It is also available in longer runs, but I don't know if GC stocks it---check out the Mogami website. If you use specialty cables already, and want to spend more (for whatever reason!), the Kimber Kable Hero model is considered by audiophiles to be really good at reproducing bass. But a 35' run will cost more than you can probably justify.
BDP24 is offline
Old 11-24-2015, 04:54 AM
Cain's Avatar
Quoted: 331 Post(s)
Liked: 180
Thx BDP. I'm looking at silver serpent cable, and mongami.
Cain is offline
Old 11-24-2015, 04:57 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
If you're looking for Mongami, you'll never find it ;-)!
Cain likes this.
BDP24 is offline
Old 11-24-2015, 05:25 AM
enricoclaudio's Avatar
Quoted: 1129 Post(s)
Liked: 1174
I use Mogami Gold Studio for both, pro audio and home audio. Let me be clear, Mogami cables are not gonna make your F25 sound better than with GLS, Live Wire, Musicians Gear or Monoprice cables. The reason I do recommend Mogami is because its build quality, durability and connectors (Neutrik). Also Mogami cables come with lifetime warranty. I usually buy Mogami at Guitar Center because our business account (from church) and we get 20% discount but you can find them at Amazon for a decent price too.
http://www.amazon.com/Mogami-Gold-St...ds=mogami+50ft
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
Old 11-24-2015, 06:24 AM
tvuong's Avatar
Quoted: 1577 Post(s)
Liked: 911
@Cain once you get the F25's hooked up and set up properly, can you give us a mini review? You are the other guy that has more than one F25 I know of. What speakers do you have? Thanks.
tvuong is offline
Old 11-24-2015, 06:29 AM
JT78681's Avatar
Quoted: 1382 Post(s)
Liked: 912
I thought he returned the F25 he had and went another route? Now he has two?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 11-24-2015, 07:56 AM
Liked: 1174
Cain will update you guys after he is done with some fine tuning. It's very interesting his experience with the F25 vs another brand/model!!!
Old 11-24-2015, 08:06 AM
Quoted: 57 Post(s)
Liked: 57
I think there is always room for small improvements with my system. It sounds darn good to me right now, but I detect a bit of excess energy in the upper bass which occasionally makes the F12 vaguely locatable, and thought I'd try the LINE connection for the steeper subwoofer rolloff and ability to experiment with the amp's crossover knob. I suspect it might very slightly clean that up. But I could leave it as is and still be happy. Often times when I start chasing the very subtle, nuanced improvements it becomes difficult to achieve and I later realize I was better off just leaving it all alone and enjoying
Ross
Old 11-24-2015, 08:24 AM
Liked: 1174
Cain has Paradigm Reference Active 40 v2.
Old 11-24-2015, 08:40 AM
PlasmaPZ80U's Avatar
Quoted: 1973 Post(s)
Liked: 566
I agree with the above. If your crossover is 60hz, you probably don't have to redo Audyssey when switching from LFE to Line In. But if it's 80 or higher, your output at the crossover and above will change so you should do it again.
Noticed the same thing when I was playing around with the crossover knob on my old sub. I was told the change in bandwidth was responsible for the change in sw distance/delay.
PlasmaPZ80U is offline
Old 11-24-2015, 09:37 AM
tvuong's Avatar
Liked: 911
IIRC, he got one F25 and was planning to return it after receiving a pair of psa s3000. It would be nice to see his opinion between the two as I do not know of anyone ever has the f25 and s3000.
tvuong is offline
Old 11-24-2015, 10:12 AM
JimWilson's Avatar
Quoted: 1313 Post(s)
Liked: 1662
Tinkeritis: an affliction whereby a person is unable to stop fiddling with dials, knobs and switches and just sit back and allow themselves to enjoy their system. Often contracted by people who spend significant amounts of time on home theater forums.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
Old 11-24-2015, 10:13 AM
Cain's Avatar
Quoted: 331 Post(s)
Liked: 180
Let me get everything all set up and I'll be glad to share my experience. I'd prefer not to say which other subs I tried, but you guys already did. Tom V. is simply one of the finest folks around and is fantastic to talk to and deal with. Great subs, terrific folks.
That having been said for my set-up, my room and listening to a lot of music like I do, the F25 is better for me.
More later gang.... Take care.
Cain is offline
Old 11-24-2015, 10:17 AM
Cain's Avatar
Quoted: 331 Post(s)
Liked: 180
Be glad to. Gimme a couple of weeks, I only have one sub ATM.
Cain is offline
Old 11-24-2015, 12:04 PM
Liked: 566
I have it for sure
Old 11-24-2015, 12:17 PM
Quoted: 57 Post(s)
Liked: 57
Truth! 😆
Old 11-24-2015, 02:35 PM
Cain's Avatar
Quoted: 331 Post(s)
Liked: 180
Yep, they are my three front speakers...
Cain is offline
Old 11-24-2015, 03:11 PM
Cain's Avatar
Quoted: 331 Post(s)
Liked: 180
What I absolutely HATE is focusing on the sound, not the music, on the picture, not the movie. It's a damned sickness I tell ya'.
Cain is offline
Old 11-24-2015, 03:16 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 380
Yup, and I'm partly responsible for this latest wave. But the way I see it is if people end up with a better sound than they had before, all the tinkering was well worth it.
Soulburner is offline
Cain's Avatar
Quoted: 331 Post(s)
Liked: 180
It a nutshell, for me (we all have different rooms, different electronics, different music, different tastes) - the s3000is in my room were better for movies, the F25 is better for music. I love listening to music, all types.
Cain is offline
Old 11-24-2015, 03:58 PM
tvuong's Avatar
Liked: 911
^^ what frequency and dampening did you have it set at? From what I have read and talked to Brian in person, the F25 is his cleanest sounding sub which could translate to less 'full body' sound in movie. For me, it took a few bass heavy movies to accustom to the tightness/well controlled less 'full body' sound. You should try the hi dampening for music and low for movie. The fact that one can tailor the sound between music and movie is worth mentioning with Rythmik subs.
tvuong is offline
Old 11-24-2015, 04:02 PM
Cain's Avatar
Quoted: 331 Post(s)
Liked: 180
Thx tv! Do you have a F25?
Cain is offline
Old 11-24-2015, 04:18 PM
tvuong's Avatar
Liked: 911
^^ no, I have a pair of fv15hps (ported). The amp control should be similar to the f25. I would probably have the F25's if Rythmik had it when I was shopping for sub. My room is only ~2500 ft^3 sealed.
tvuong is offline
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
