Official Rythmik Audio Subwoofer thread - Page 730 - AVS Forum | Home Theater Discussions And Reviews
 3886Likes
post #21871 of 29280 Old 11-29-2015, 01:57 PM
PlasmaPZ80U's Avatar
Quoted: 2036 Post(s)
Liked: 587
When I set my crossover knob to 80Hz, YPAO didn't change sw distance but set sw trim 3 dB higher.
PlasmaPZ80U is offline
post #21872 of 29280 Old 11-29-2015, 02:12 PM
tvuong's Avatar
Quoted: 1656 Post(s)
Liked: 984
Originally Posted by JT78681 View Post
What are your settings on the amp? I'm thinking of trying this, but I can't measure since I sold my mic a few months ago.
Try only if your surrounds can be set with a 90hz crossover or lower.
tvuong is online now
post #21873 of 29280 Old 11-29-2015, 02:18 PM
MrGrey's Avatar
Quoted: 618 Post(s)
Liked: 790
Well I made the switch and re-ran Audyssey. I can't measure, but to my ears it sounds good. It doesn't appear I lost any output or tactile response at the MLP. Maybe gained a little headroom since I'm not asking the subs to extend so high?
Yes for sure it sounds like i gained more db with the line in compared to the LFE. i see no lost if you keep it below 90hz or 80hz its a gain from what i see and hear on my fv15hp.
Receiver - Sony STR-DH550
Fronts - Klipsch Reference Premiere RP-280F
Center
- Klipsch Reference Premiere RP-450C
Surrounds - Trash
Sub - Rythmik FV15HP
The Ultimate List of BASS in Movies w/ Frequency Charts
MrGrey is offline
post #21874 of 29280 Old 11-29-2015, 02:55 PM
Bond 007's Avatar
Quoted: 2543 Post(s)
Liked: 2004
Originally Posted by tracerit View Post
What are the conditions of these B-stock black oak units?
Same as new.
Bond 007 is online now
post #21875 of 29280 Old 11-29-2015, 02:56 PM
tracerit's Avatar
Quoted: 68 Post(s)
Just wanted to provide one last update on my subwoofer search. I'd like to thank everyone here who responded and provided advice, you all helped me narrow my decision to the LV12R That excitement was dulled a bit after finding out there isn't a true risk free home trial of the subwoofer, which I highly doubt I would've used. Maybe if my first encounter into +$500 subs wasn't through SVS on slickdeals, I woudln't have had such high expectations in regards to home trials. I accepted the fact that businesses need to make money too, so I didn't care much for the return shipping anymore. Then the stock issue came up and since I'm in a hurry to pick up a subwoofer with this weekend's sale, I started looking elsewhere and found the HSU VTF-2 MK4. Turns out they're just 15 miles from me so warranty issues should be easier and cheaper to handle, and they also have a home trial. But their home trial isn't completely risk free either. Unfortunately I'm gonna be hit with tax on this but the price comes out to be around what I would've paid for the LV12R. Reviews between the two seem to be a draw as well.
So now it's time to go through all this again, but with finding front speakers :P
tracerit is offline
post #21876 of 29280 Old 11-29-2015, 03:11 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
Originally Posted by PlasmaPZ80U View Post
I found sometimes simply changing the direction the sub is facing by 90 deg, can fix (or create) nulls. In my case, having the sub face the MLP got rid of a null that was present when the sub was facing right of the MLP by 90 deg.
I've found that to be the case with dips, but not with nulls. Nulls are caused by the dimensions of your walls and the distance to them from the sub. The only way to change nulls is to sit somewhere else, or cancel them with multiple sub placement.
Samsung PN64H5000 (recommended settings)
Denon AVR-X4000
A little R&R: Reaction Audio CX-10 (2) | Rythmik Audio F12 (2)
And a pair of Emotiva Airmotiv 5s
Soulburner is offline
post #21877 of 29280 Old 11-29-2015, 03:15 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
Originally Posted by MrGrey View Post
Yes its off, i never found use for it.. maybe its because of my ignorance or that i heard that using it to fix nulls or beyond a certain frequency is not recommended.
The best use for PEQ is to take down mountains. For example, I had a big peak at my seat at 50-60hz. I used the PEQ to bring it down by about 8db, then Audyssey took care of the rest. I owe my flat response to getting the F12s with the PEQ. I wouldn't have been able to do it with a non-PEQ amp like the L12.
Here's the peak. The light blue line is after I used the PEQ:
Then Audyssey took care of the rest:
MrGrey likes this.
Denon AVR-X4000
post #21878 of 29280 Old 11-29-2015, 03:51 PM
Liked: 587
Yeah, I meant dips, not nulls.
post #21879 of 29280 Old 11-29-2015, 05:22 PM
JT78681's Avatar
Quoted: 1429 Post(s)
Liked: 957
Thanks! All my speakers are 80hz capable. I've listened to quite a bit of content now with line-in and it sounds great. Like grey said it feels like I've gained a bit of output.
MrGrey likes this.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #21880 of 29280 Old 11-29-2015, 06:51 PM
Bond 007's Avatar
Liked: 2004
Are you using a y-splitter at the sub?
post #21881 of 29280 Old 11-29-2015, 06:52 PM
Bond 007's Avatar
Liked: 2004
post #21882 of 29280 Old 11-29-2015, 06:57 PM
JT78681's Avatar
Liked: 957
Nope
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #21883 of 29280 Old 11-30-2015, 08:16 AM
sevenz's Avatar
Quoted: 71 Post(s)
Liked: 51
Appreciate it if someone can jump in to help me on this? I can't fully recall what was the best extension filter settings before and after audyssey calibration. I remember i read this info somewhere but can't seem to find the exact post as the thread is too long. Currently I've dual subs in my setup - 1 F15HP and 1 E15HP placed in diagonal corners of the room. My AVR is the Denon 4520 (with Audyssey XT32). I'm using the LFE input on the sub, and the LINE IN input is not used.
Are the below settings correct?
Before audyssey calibration:
PEQ = Off
Damping = low (or should this be set as MID?)
Freq = 14Hz
Rumble filter = OFF
Line In / Low Pass = AVR12
After audyssey calibration:
PEQ = Off
Damping = high
Freq = 14Hz
Rumble filter = ON
Also, for the PEQ settings, if my PEQ is set to OFF, does the 3 knobs of gain, bandwidth and freq need to be set to any specific level? Because i recall the user manual indicating to set it to the below settings, but shouldnt these 3 knobs functions be disabled when PEQ is set to OFF?
Gain = 0db
Bandwidth = middle position
Frequency = middle position (40 Hz)
Thanks much.
sevenz is offline
post #21884 of 29280 Old 11-30-2015, 08:47 AM
Liked: 587
I did my own experiment with cascading LPFs:
http://www.avsforum.com/forum/91-audio-theory-setup-chat/1449924-simplified-rew-setup-use-usb-mic-hdmi-connection-including-measurement-techniques-how-interpret-graphs-572.html#post39349338
Current Setup REW measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1 (CI CXD01ANI)
post #21885 of 29280 Old 11-30-2015, 09:25 AM
tvuong's Avatar
Liked: 984
PEQ = Off
Freq = 14Hz
Rumble filter = OFF
PEQ = Off
Damping = high
Freq = 14Hz
Rumble filter = ON
Gain = 0db
Thanks much.
Low dampening is recommended pre-audyssey; however, since I only use hi dampening, I calibrate with hi. You are correct that the 3 knobs are disabled when peq is off. You might find the peq is useful if you are able to see graphs of your subs.
sevenz likes this.
post #21886 of 29280 Old 11-30-2015, 09:51 AM
laulau's Avatar
Quoted: 78 Post(s)
Liked: 116
@sevenz
Brian's advice is in post #6240.
sevenz likes this.
Salk STRT / SongCtr-RT / SongSurr I ; Rythmik F12 (x2) (latest ver of setup guide) ; Denon 4520CI; D-Sonic M2-800S; Oppo BDP93; Panny 65VT50; BJCables; CCast; FireTV ; Furman Elite-15 PFi; Omnimic & REW; CalMAN 5 HT i1D3 & i1Pro2 ::CANs:: RPi3&Digi+ > AGD DAC19 > Cavalli LC > HFM HE400i :: Rpi3&/Digi+ Pro > Schiit Bifrost 4490 > Schiit Valhalla > Senn HD600 & HD6XX :: RPi3&Digi+Pro > Schiit Mimby > Schiit Vali 2 > Meze 99 Classics :: FB2K >Schiit Modi2U >Schiit Magni2U > Oppo PM3
laulau is offline
post #21887 of 29280 Old 11-30-2015, 10:29 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 382
I would recommend the Line In connection, see the last 5 pages or so for discussion on this.
PEQ = If you are going to use PEQ, do it before Audyssey. See my post from yesterday.
Damping = low (or should this be set as MID?) Brian (Rythmik) recommends mid.
Freq = 14Hz
Rumble filter = OFF
Line In / Low Pass = AVR12 Depends on your preference and system
PEQ = Off Depends if you need it, which you should do before Audyssey
Damping = high This is my preference
Freq = 14Hz Also my preference
Rumble filter = ON Only needed for high SPL. Otherwise, OFF gives better sound quality.
Line In / Low Pass = AVR12 I prefer the 80/24 setting, which would be set pre-Audyssey
Gain = 0db
Thanks much.
Off should mean off. Not sure why he recommends that.
sevenz likes this.
Denon AVR-X4000
post #21888 of 29280 Old 11-30-2015, 10:38 AM
Cain's Avatar
Quoted: 339 Post(s)
Liked: 183
Originally Posted by Rythmik View Post
I'd like to make this clear so that customers don't make mistakes
For sealed subs, turn off rumble filter and set the extension to 14hz/ mid damping before running roomEQ such as Audyssey.
For vented subs with single tuning, set the extension filter to 14hz, low damping before running roomEQ.
For vented subs with dual tuning, plug one port and set the rumble filter to OFF/1, and 14hz low damping before running room EQ.
After the roomEQ is done, you can then play with extension filter and rumble filter setting.
The precaution is to avoid roomEQ accidentally boost frequency below 20hz which can defeat the purpose of having those controls on our amps.This maybe counterintuitive but it is important (because one may think he should use the settings that he wants to use when doing roomEQ). If roomEQ has its way in correcting frequency response, it will undo all the rumble filter, and extension filter setting.
Brian's suggested settings pre-Audyssey.
Cain is offline
post #21889 of 29280 Old 11-30-2015, 10:52 AM
JT78681's Avatar
Liked: 957
^^^ I follow this method when calibrating.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #21890 of 29280 Old 11-30-2015, 11:24 AM
JimWilson's Avatar
Quoted: 1416 Post(s)
Liked: 1852
Are you referring to their physical condition? If so, it will vary from a returned unit in perfection condition to one with a minor blemish or two. Front a functional standpoint they're 100%.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
post #21891 of 29280 Old 11-30-2015, 11:28 AM
JT78681's Avatar
Liked: 957
^^^ Both of my FV15HP's were b-stock and in immaculate condition. I could not find any imperfection on either of them.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #21892 of 29280 Old 11-30-2015, 11:59 AM
Liked: 587
Originally Posted by laulau View Post
@sevenz
Thanks for the link, for my sub low bass extension is all I need to do.
post #21893 of 29280 Old 11-30-2015, 02:47 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
Did you not read the fine print on the site ?, "Perfectly looking B-Stock subwoofers, does not play below 50 hz"
qguy is offline
post #21894 of 29280 Old 11-30-2015, 07:27 PM
Tony~M's Avatar
Quoted: 39 Post(s)
Liked: 31
Hello All,
Hope you are all well.
Today was a total waste of my time. UPS says my L22 is out for delivery, but it is now 10:25pm.....I wasted my whole day waiting for it. My UPS guy never rings the doorbell, so I have to hang out near the door for when he drops the boxes and runs away. This time...nothing...nada...still waiting. I am curious when the tracking will update saying it is no longer on time for scheduled delivery....UPS....blah....
Quote from UPS website:
Benefits
Prompt, dependable, cost-effective shipping
With guaranteed delivery, know in advance when your shipment will arrive
An economical choice for all of your routine shipments
Yeah...right....lol.
Later,
Tony
Tony~M is offline
post #21895 of 29280 Old 11-30-2015, 08:51 PM
Tony~M's Avatar
Quoted: 39 Post(s)
Liked: 31
Hello All,
MMmmm...midnight and no sub...stupid Oooops man took it home to demo it...
Later,
Tony
Tony~M is offline
post #21896 of 29280 Old 12-01-2015, 02:02 AM
Bond 007's Avatar
Liked: 2004
Originally Posted by tony~m View Post
hello all,
hope you are all well.
Today was a total waste of my time. Ups says my l22 is out for delivery, but it is now 10:25pm.....i wasted my whole day waiting for it. My ups guy never rings the doorbell, so i have to hang out near the door for when he drops the boxes and runs away. This time...nothing...nada...still waiting. I am curious when the tracking will update saying it is no longer on time for scheduled delivery....ups....blah....
Quote from ups website:
Benefits
prompt, dependable, cost-effective shipping
with guaranteed delivery, know in advance when your shipment will arrive
an economical choice for all of your routine shipments
yeah...right....lol.
Later,
tony
800 742-5877
post #21897 of 29280 Old 12-01-2015, 04:10 AM
Tony~M's Avatar
Quoted: 39 Post(s)
Liked: 31
800 742-5877
Hello Bond 007,
Hope you are well.
Mmm...do the smaller subs like the L22 come UPS freight?
Funny I went to pick up my Daughter from school and there was a UPS freight semi-truck driving in front of me...he looked lost and turned left and then made a u-turn and went the other way...I now wonder if that truck had my sub on it...blah... He needs to deliver it while it is still light out, so he can read the house numbers.
Later,
Tony
Tony~M is offline
post #21898 of 29280 Old 12-01-2015, 05:58 AM
sevenz's Avatar
Quoted: 71 Post(s)
Liked: 51
@sevenz
Awesome, thanks people! And yes u found Brian's post!
sevenz is offline
post #21899 of 29280 Old 12-01-2015, 06:12 AM
JT78681's Avatar
Liked: 957
@tvuong
I noticed that the few times I have calibrated in mid or high dampening I lose headroom and it puts the sub trim on the plus side. When I calibrate in low dampening I'm usually perfect ending up at about -2 on the trim after boosting 6db. After calibration I just switch to mid or high (currently using high).
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
post #21900 of 29280 Old 12-01-2015, 06:32 AM
JT78681's Avatar
Liked: 957
I have a question. If using line-in does the crossover on the amplifier defeat the crossover in the receiver. I'd actually like to set my crossover to 90hz. Can I do this post Audyssey via the receiver or since I'm using line-in does it need to be adjusted on the amplifier itself?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
