Official Rythmik Audio Subwoofer thread - Page 745 - AVS Forum | Home Theater Discussions And Reviews
 3194Likes
Old 12-28-2015, 12:17 PM
JT78681's Avatar
Quoted: 1376 Post(s)
Liked: 900
@DonH50
English Don.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 12-28-2015, 12:19 PM
PlasmaPZ80U's Avatar
Quoted: 1964 Post(s)
Liked: 560
I use the phase control at 180 deg/10ms on my LV12R since my AVR doesn't take care of it automatically (either via sw phase setting on AVR or sw dist on AVR). Otherwise, I get huge nulls at my 80Hz crossover point, like with CC+sub or L+R+sub. I could just use the AVR's sw phase setting (has two options, normal and reverse), but then I'd have to manually flip it after each YPAO run.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
Old 12-28-2015, 12:23 PM
Liked: 560
Originally Posted by DonH50 View Post
IIRC the phase control is linear from 0 to 180 degrees (0 to 16 ms). The velocity of sound waves in dry air at sea level and room temp (Standard conditions) is about 1127 feet/second, or roughly 1 foot per ms. If I did the math right, 16 ms is 180 degrees at 31.25 Hz (1/32 ms = 31.25 Hz).
Note that the delay is added to whatever other delays are in the system, including amplifier latency (negligible), processing for room correction (can be significant), and phase shift in the crossovers (can be very significant). Probably best to not get hung up on the numbers. The goal is to get the sub and mains in phase at the MLP so the actual delay may have little to do with their physical distance.
HTH - Don
REW + sw dist tweak are great tools for getting integration right. It should also make setting the phase control a more straightforward process, either adjust and measure and re-adjust and re-measure or use the RTA tool.
Old 12-28-2015, 12:27 PM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
Originally Posted by JT78681 View Post
@DonH50
English Don.
I'm an engineer. English is a second or third language.
Play a tone at the crossover frequency and adjust the knob until the sound is loudest, or do the same with an SPL meter, or (best) measure the response using REW or similar. Don't worry about where the knob ends up.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
Old 12-28-2015, 12:36 PM
tvuong's Avatar
Quoted: 1544 Post(s)
Liked: 875
Even if the phase adjustment is linear, my plan is to adjust the phase on one sub and leave the other as constant. With REW, it is easy to see if they compliment each other pre-audyssey. Then Aud will take care the rest. Again, the plan is not having Aud doing too much eq.
tvuong is offline
JT78681's Avatar
Liked: 900
Haha I know you are, so I had to mess with you. Your posts are always very informative.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 12-28-2015, 01:17 PM
DonH50's Avatar
Liked: 1325
You'll need to delay the sub closer to you to prevent a non-causal filter response. Predicting the future is still somewhat beyond most AVRs. That is, leave the knob at "0" on the sub furthest away, and increase the delay on the closer one.
DonH50 is offline
Old 12-28-2015, 01:18 PM
DonH50's Avatar
Liked: 1325
Wasn't "English Don" a shooter in some old western movie? Don't make me pull out my revolver...
DonH50 is offline
Old 12-28-2015, 01:23 PM
tvuong's Avatar
Liked: 875
They are both equidistant to me. My left sub has a better FR, so I am planning to adjust the phase on the right sub such that the combined FR is flatter.
tvuong is offline
Old 12-28-2015, 01:24 PM
Exclusively Servo
Rythmik's Avatar
Quoted: 230 Post(s)
Liked: 314
I am having 4 matching surrounds coming that can go down to 80hz which allows me to connect subs with line in. I am planning to turn off Aud, measure subs, then play with the phase knob(s) to get the flattest FR for the 2 subs. Then run Aud cal and adjust with sub distances tweak if needed to flat out the xover region with my speakers.
Looking at the phase knob, it can be varied from 0-16ms. Am I safe to assume 4ms=9 O'clock position and 12ms=3 O'clock position? Also is 1ms~1 foot?
10 o'clock for 4ms and 3 o'clock for 12ms.
Rythmik is offline
Old 12-28-2015, 01:25 PM
JT78681's Avatar
Liked: 900
Sounds about right.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 12-28-2015, 01:29 PM
tvuong's Avatar
Liked: 875
Thanks Brian.
tvuong is offline
dabrick7's Avatar
Quoted: 21 Post(s)
Liked: 31
English Bob, Unforgiven?
DonH50, BDP24 and zencarver like this.
dabrick7 is offline
Old 12-28-2015, 01:42 PM
tvuong's Avatar
Liked: 875
What? Finally moving away from high dampening? I think there is a big difference between low and high dampening. That full body bass is definitely more pronounced in low. It's a lot tighter when you move to mid or high (shocker ). I've spent a lot of time experimenting with all of them. Here is an old graph that shows all three in my room. Low has an output advantage from just under 20hz to just over 40hz. I now use line in, but I sold my measuring gear, so I don't have a graph on what that looks like.
So far, for movie, lo D is great but too boomy for music as compared to hi D. Med D might be the answer for both.
tvuong is offline
Old 12-28-2015, 02:03 PM
Liked: 560
I have found that with low damping, giving the sub more breathing room from the wall or corner sounds cleaner, smoother, and clearer. In other words, the tone of the bass improves and it just sounds better overall. For me, that meant a distance of about 8 inches from the mid wall placement, vs. the minimum recommended distance of about 3-4 inches.
Switching to mid damping is also a great compromise between low and high damping.
Old 12-28-2015, 02:20 PM
JT78681's Avatar
Liked: 900
Mid has been a great compromise for me so far and to my ears it's the best. I get a little bit better extension versus low. I lose a little bit of headroom obviously, but this isn't really an issue since I typically don't go past -10 on the volume.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 12-29-2015, 04:43 AM
Cain's Avatar
Quoted: 323 Post(s)
Liked: 176
I just watched Edge of Tomorrow (EoT)...
Wow, the first 60 seconds of that movie scared my wife upstairs in the Den over my theater...
I played it at about -15, and still WoW.....
My F25s didn't break a sweat.
The good news is the sound is like nothing I've ever heard.
The bad news is it shakes the heck out of my projector blurring the image considerably. Between the sound and the image blurring you feel like you might be having a stroke!!
I'm now trying to minimize my projector shake. Any suggestions are most welcome.
Mike Butny, JT78681 and MrGrey like this.
Cain is offline
Old 12-29-2015, 07:30 AM
Cain's Avatar
Quoted: 323 Post(s)
Liked: 176
Just for fun, JT. Edge of Tomorrow at reference MV with +6db subs hot. There was port chuffing but it was not bad. No bad sound was heard at all Again, look at how fast Rythmik puts a brake on the driver. Sorry for the crappy phone video.
https://www.dropbox.com/s/8prrwqwhk0...20hot.MOV?dl=0
Whoah!!
Cain is offline
Old 12-29-2015, 07:38 AM
BDP24's Avatar
Quoted: 259 Post(s)
Liked: 173
My favorite Clint Eastwood western, a fine movie.
BDP24 is offline
Old 12-29-2015, 07:43 AM
JT78681's Avatar
Liked: 900
Originally Posted by Cain View Post
Whoah!!
The excursion is much more visible with the silver cones. Ah my old Infinity's those were great speakers for the cost.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 12-29-2015, 08:07 AM
Cain's Avatar
Quoted: 323 Post(s)
Liked: 176
https://www.youtube.com/watch?v=ZFkRgCSIaoI
WOW!! What were your settings, volume and sub level, etc.???
Cain is offline
Old 12-29-2015, 08:09 AM
Liked: 560
Is the LV12R driver high excursion?
Says so here:
http://www.rythmikaudio.com/LV12R_features.html#driver
But I remember posts saying it wasn't but the L12 and L22 were. Also, it appears the new LVX12 is.
Old 12-29-2015, 08:18 AM
JT78681's Avatar
Liked: 900
If I recall dampening was set to low and one port plugged. Subs were 6db hot and volume was only at -15.
Cain likes this.
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 12-29-2015, 01:24 PM
DonH50's Avatar
Liked: 1325
Ah, Unforgiven, and not a Don after all!
I should play with my Q settings again just for fun, but have had zero time for tweaking lately (and little time for listening, alas).
DonH50 is offline
Old 12-30-2015, 01:30 PM
Cain's Avatar
Quoted: 323 Post(s)
Liked: 176
OK, good news. Love my new F25 Subs.
Bad news they shake my projector.
My projector is currently connected to a Chief arm that is mounted to the rear wall of my Theater. the subs are shaking the heck out of my rear wall.
Thoughts? suggestions??
Cain is offline
Old 12-30-2015, 01:46 PM
JT78681's Avatar
Liked: 900
Ah man still haven't rectified this?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 12-30-2015, 02:06 PM
Cain's Avatar
Quoted: 323 Post(s)
Liked: 176
Not even close yet.
Cain is offline
Old 12-30-2015, 02:31 PM
JT78681's Avatar
Liked: 900
Not even close yet.
Have you thought about trying out some sort of rubber bushings between the projector and mount?
Display - LG OLED
Receiver - Denon
Speakers - Klipsch
Subs - Rythmik
JT78681 is offline
Old 12-30-2015, 02:46 PM
Cain's Avatar
Quoted: 323 Post(s)
Liked: 176
Thank you for the suggestion.
I think my problem now is the projector being on the end of an arm that is attached to the rear wall. That wall is hammered with LF and it vibrates.
My first move will be to try and attach the projector to my soffit or maybe my ceiling. Once that is done I can research some type of rubber bushings to help with the vibration.
Chief makes a gizmo, but it requires seven inches of vertical height, that I do not have.
Cain is offline
Old 12-30-2015, 03:01 PM
Quoted: 37 Post(s)
@ Cain : Here I come again with a recommendation for auralex sub dude:-). It practically eliminated rattles at mine and my friends place. Pls try the bigger version called gramma or subdued HT under the subs if you have not tried it yet.
rsmt2000 is online now
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
