Official Rythmik Audio Subwoofer thread - Page 759 - AVS Forum | Home Theater Discussions And Reviews
 1242Likes
post #22741 of 22761 Unread 01-30-2016, 06:28 AM
MrGrey's Avatar
Quoted: 116 Post(s)
Liked: 49
I wonder if i can use PEQ to smooth out the range from 55hz - 70hz
Name:	new sub location.png
Receiver - Sony STR-DH550
Fronts - Klipsch Reference Premiere RP-280F
Center
- Klipsch Reference Premiere RP-450C
Sub - Rythmik FV15HP
MrGrey is offline
post #22742 of 22761 Unread 01-30-2016, 07:20 AM
JimWilson's Avatar
Quoted: 802 Post(s)
Liked: 957
Rarely can you pull up a dip, because more often than not those are due to room interactions that no amount of boost can overcome. Most people use the PEQ to draw down a peak. There's no harm in trying though.
If you take yourself too seriously expect me to do the exact opposite
JimWilson is offline
post #22743 of 22761 Unread 01-31-2016, 05:07 AM
MrGrey's Avatar
Quoted: 116 Post(s)
Liked: 49
No i used it to reduce the 55hz peak i had and then smooth out the rest with REW and a house curve. it worked really well. too bad the FV15HP doesn't have a PEQ screen where we can reduce two specific frequency's at once.
Center
MrGrey is offline
post #22744 of 22761 Unread 01-31-2016, 11:14 AM
DonH50's Avatar
Quoted: 1262 Post(s)
Liked: 815
It's a single-band PEQ so not sure reducing two frequencies at once is in the cards unless they are very close (and thus treated as one). I have zero desire for a readout screen on my sub but that's just me... Don't want to pay for it, don't want something else to wear out or break, especially something I'd use very rarely, and prefer to use other measurement systems to dial things in.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #22745 of 22761 Unread 01-31-2016, 11:53 PM
Jacob B's Avatar
Quoted: 80 Post(s)
Liked: 24
Originally Posted by PlasmaPZ80U View Post
I'm not too familiar with how mid bass modules are integrated with the mains and regular subs, but I would use a combination of REW, your ears, and Audyssey on your AVR for best results.
Can you or someone else explain to me how a mid bass module is integrated into a typical 5.1 setup?
I'm not sure I know how that works exactly.
The FM8s are daisy chained with each their E15HP, a pair in each front corner. E15HP lowpass set at 50 Hz/24dB and FM8 high pass set at 50 hz. FM8 lowpass set at 200 Hz/24dB.
I have now been playing around with different AVR settings for the last month or so.
I currently have the center speaker crossed at at 80 hz and the mains at 200 hz for 7.1 movies.
This works pretty well except for musicals and other vocal heavy blu-rays.
However, I have changed the settings for 2 CH music (there is a special setting for that on my Denon X5200W).
Here, I have set crossover to 60 hz, effectively eliminating the use of my FM8s.
The reason is that the stereo soundstage collapsed with the 200 Hz setting, since the frequencies below 200 Hz effectively were played in mono as the same signal was fed to each FM8. I tried setting 80 Hz, but that also collapsed the soundstage, just not so much.
I really need a processor able to manage stereo subs...!
For the same reasons, I set the center speaker to 80 Hz, to avoid problems when not in the centerseat, which wil be the only place were a phantom sub 200 Hz centerspeaker would be played correctly. I haven't tested that part a whole lot yet, though.
Anyone else crossing high and experiencing the same?
cheers,
Jacob
Jacob B is offline
post #22746 of 22761 Unread 01-31-2016, 11:58 PM
Jacob B's Avatar
Quoted: 80 Post(s)
Liked: 24
What is the benefit of using the FV15HP PEQ, which is in the analogue domain, to smooth a single peak, as opposed to letting an EQ in the digital domain take care of everything (like Audyssey etc)?
Cheers,
Jacob
Jacob B is offline
post #22747 of 22761 Unread 02-01-2016, 06:54 AM
JimWilson's Avatar
Quoted: 802 Post(s)
Liked: 957
So long as the peak is leveled out, what difference does it make where it occurred? I'm not being antagonistic when I ask that, just curious as to why it would be germane. I'm only interested in what the output sounds like when it hits my ears, not where it was adjusted.
With regards to the PEQ itself... not everyone has a sound processor with an auto-EQ system like Audyseey, YPAO, MCACC, etc. In the two channel world very few people have that in their electronics chain, and even if they do some folks just flat out don't like using them because it alters the sound in a way they aren't comfortable with. In that case, the PEQ gives them the ability to tailor the sound manually.
post #22748 of 22761 Unread 02-01-2016, 08:32 AM
grasshoppers's Avatar
Quoted: 667 Post(s)
Liked: 396
Cheers,
Jacob
I read somewhere that by using PEQ to smooth
A peak more Audyssey resources (which are limited)
Could be used (applied) to further correct other
Issues more effectively. Hopefully that makes sense.
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is online now
post #22749 of 22761 Unread 02-01-2016, 08:35 AM
Jacob B's Avatar
Quoted: 80 Post(s)
Liked: 24
I am not qualified to present the argument, but some claim that SUB EQ performed strictly in the digital domain (for digital sources) has less unwanted side effects on the sound - in other words, there is more to good sound than a perceived flat frequency response in the bass region or a perfect housecurve.
I understand that many dedicated 2 Ch systems will not have SUB EQ. In addition, if the source is analogue, a digital EQ processor might not be desired.
Cheers,
Jacob
PS any comments on the mono mid bass issue I have...?
Jacob B is offline
post #22750 of 22761 Unread 02-01-2016, 10:28 AM
DonH50's Avatar
Liked: 815
If you really want to use them as stereo subs, it may be easier to buy an external crossover like a miniDSP or analog dbx 223, and use it to cross over to the sub arrays. That way your AVR "sees" a pair of full-range speakers (set them to "large") and will treat (compensate) as such. That is the way I ran my system for many years. It works if the subs and mains are close together so the AVR can handle them as single (L/R) speakers.
HTH - Don
DonH50 is offline
post #22751 of 22761 Unread 02-01-2016, 11:40 PM
Jacob B's Avatar
Quoted: 80 Post(s)
Liked: 24
HTH - Don
Don,
The subs are pretty close to the main speakers - right next to on the left and about a foot on the right. See picture below. Since the picture was taken, I have moved the right main speaker 1½ feet to the right.
I am considering buying the Lyngdorf TDAi 2170 to drive the main speakers and bass manage the subs. It can manage stereo subs and has a proprietary 2.2 EQ (Room Perfect). I would do exactly how you suggest: set the main speakers to large + no sub in the AVR and the connect the subs to the Lyngdorf. Then either turn off Audyssey XT32 on the AVR or set it to BYPASS FL/FR.
http://hometheaterhifi.com/reviews/a...lifier-review/
Cheers,
Jacob
Jacob B is offline
post #22752 of 22761 Unread 02-02-2016, 10:31 PM
raynist's Avatar
Quoted: 660 Post(s)
Liked: 640
Is there anyone here that is from the Pittsburgh Metro or surrounding area?
Any interest in a Pittsburgh area meet up?
raynist is online now
post #22753 of 22761 Unread 02-03-2016, 11:33 AM
DonH50's Avatar
Liked: 815
Don,
<image elided>
Cheers,
Jacob
Hmmm... I would leave XT32 running to deal with the speakers and integration of subs to mains, your call... The external crossover is a cheap solution but only if you are using an external amplifier to drive the L/R speakers or have a pre-out/in loop on your AVR, something rare these days.
DonH50 is offline
post #22754 of 22761 Unread 02-03-2016, 12:52 PM
enricoclaudio's Avatar
Quoted: 428 Post(s)
Liked: 420
Hi guys,
As I mentioned before Chris Fogel, from Hyperion Sound @ ELBO Studios in Glendale, CA got an FV15HP back in June 2015 for his film mastering studio. Today we got a second order from him for a pair of F12s for a small stereo room. He is very impressed with the capabilities of the FV15HP. So I just wanted to share with you guys the list of the movies he already mastered using the FV15HP:
Creed
Spy
Trumbo
Zoolander 2
5th Wave
Ghostbusters (still in production)
Birth of a Nation (just won Sundance)
Halo 5 soundtrack (game)
Best Regards,
Enrico Castagnetti
Rythmik Audio
My Multimedia Room Gallery
enricoclaudio is offline
post #22755 of 22761 Unread 02-03-2016, 03:51 PM
PlasmaPZ80U's Avatar
Quoted: 1251 Post(s)
Liked: 337
I switched to a 3.1 setup from a 5.1 one since my surround placement was poor. SQ improved overall and I get more bass from the front now (surrounds were much smaller than mains and now that info is downmixed into the mains). I also had the chance to move the sub a bit and give it more breathing room. Anyhow, my sub is playing higher now, as the measurement below shows:
Name:	sub only (LFE) with Line In 12dB LPF slope.png
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, Sony Core (Sony SS-CS5) Mains and Center (Sony SS-CS8), Rythmik LV12R; PS4, Xbox One, Motorola RNG150N
PlasmaPZ80U is offline
post #22756 of 22761 Unread 02-03-2016, 03:56 PM
Liked: 337
Also, I'm finding I don't need to set the sw trim as hot anymore (+2dB is plenty whereas before it was +4dB). I think the added bass comes from the surround info playing through the mains, which are much bigger and also because it now seems all bass comes from the front of the room. Since all bass is summed mono, the extra 80Hz and up bass from the mains and the sub 80Hz bass coming apparently from just the front makes it actually louder/seem louder.
post #22757 of 22761 Unread Yesterday, 10:49 AM
Quoted: 428 Post(s)
Liked: 420
The container came in today so we have L12 and LV12R back in stock!! A lot of shipping is happening today so if you are on the waiting list for any of these models most probably you will receive an UPS email with tracking number in a few hours.
Best Regards,
Enrico Castagnetti
Rythmik Audio
post #22758 of 22761 Unread Yesterday, 08:55 PM
RTROSE's Avatar
Quoted: 94 Post(s)
Liked: 97
Hey it's February, any updates on the prototypes? Inquiring minds want to know. I know that Rythmik is a small company where you guys wear multiple hats so I understand there is only so much you can do in a day, but having said that I do have a suggestion. On your website you should consider adding a future projects, or in the works section to keep everyone updated about new developments and possible future products. You might even find that it creates some additional buzz for your company. Anyway just a suggestion. Now back to our regularly scheduled subwoofer forum.
RTROSE
RTROSE is online now
post #22759 of 22761 Unread Today, 06:39 PM
Namikis's Avatar
I have had a couple of minor problems with my Rhythmik FV15HP - and the company's customer service has been very good in both cases. The first plate amp failed due to and issue with bad capacitors in an early manufacturing batch. I emailed them and within hours Brian Ding contacted me and determined what the issue was and decided to send me a new plate. Fast forward to last week - a year later - I called to ask for help replacing the fabric on the grill, which I suspect was attacked by one of my cats (i have no video proof, just circumstantial evidence). Brian helped me again, suggesting he could have a new grill shipped to me at cost (very affordable!). I received it yesterday. Really happy with the sub, but even happier with the support when things go wrong. Thank you Brian!!
Namikis is online now
post #22760 of 22761 Unread Today, 08:22 PM
RTROSE's Avatar
Quoted: 94 Post(s)
Liked: 97
I will second your thoughts and experiences regarding Rythmik's support of their products. Too often nowadays the customer is all but forgotten in customer service. However this is not the case with Rythmik they go out of their way to make sure the customer is the focus of their business before, during, and after the sale.
RTROSE
post #22761 of 22761 Unread Today, 08:26 PM
Namikis's Avatar
I am in the Pitt area, but you already knew that
f12g subwoofer , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
