Official Rythmik Audio Subwoofer thread - Page 760 - AVS Forum | Home Theater Discussions And Reviews
 4272Likes
Old 02-11-2016, 05:37 PM
eorr23's Avatar
Quoted: 38 Post(s)
Liked: 70
Hey guys, I am still toying with settings and just got around to using the subtuner from Rythmik. After using the subtuner, it recommended me setting the crossover to 31hz. I was a bit confused since my preamp's bass management is set to 80hz. I guess I don't fully understand what the crossover nob does on the back of the sub. Any guidance would be greatly appreciated.
For reference my gear is listed in my signature.
Equipment list:
B&W 803d, Rythmik F12SE, Emotiva XSP-1, Emotiva XPA-2, Oppo 105, Project 2Xperience Classic, Panamax M5300-PM, Panasonic 60ST60
eorr23 is offline
Old 02-11-2016, 08:06 PM
qguy's Avatar
Quoted: 122 Post(s)
Liked: 91
The lowest crossover will be used, since you used 31 hz at the subwoofer, the sub will produce 31 hz down to its lowest limit. Now if you want to use the pre-amp crossover, adjust the crossoover to the max level and control the crossover from the pre-amp. Is this is for HT, 80 hz would be a good stating point. For 2 channel audio, start at 31 hz and tweak from there
qguy is offline
Old 02-12-2016, 07:22 AM
eorr23's Avatar
Quoted: 38 Post(s)
Liked: 70
Thanks qguy, I am using it for both music and movies but I care more about performance for music. Luckily its a long weekend so I will have plenty of time to play around with settings. Probably going to give REW a try for the first time as well, I am definitely excited to SEE what I am hearing.
Equipment list:
eorr23 is offline
Old 02-12-2016, 08:47 AM
klh007's Avatar
Quoted: 42 Post(s)
Originally Posted by Jacob B View Post
If I bought the Lyngdorf TDAi2170 as mentioned, it would power the front L/R speaker. AVR would be set to Left and right = LARGE, and NO SUB.
The Lyngdorf would bass manage as well as EQ Front L/R and the two pairs of subs (stereo, i.e. 2.2), and the AVR (Denon X5200W) would bass manage and EQ (XT32) the center and all the surround speakers.
I will test it in the near future, and see if it will fix my problem of a collapsed stereo soundstage with crossover set to 80 Hz and higher (200 Hz is desired due to the two E15HP+FM8 stacks...) :-)
Cheers,
Jacob
Jacob, I hope you get the TDAI-2170, I'd love to hear how the Room Perfect worked for you, and how effective the bass EQ is.
Kemper Holt
klh007 is offline
Old 02-12-2016, 11:14 AM
brianmlamb's Avatar
Quoted: 351 Post(s)
Liked: 154
I received my L12 about a week ago and have been enjoying it ever since. One of the things I have yet to fully understand though is the bass extension control.
From the website:
"The bass extension control enables the user to customize the frequency response of the low end for the best trade-off between output and extension. If set to low music, bass below 18 Hz will be filtered. The damping factor of this mode is 0.5 for the best time domain response. However, the disadvantage is slower attenuation of subsonic signals. For HT application, we recommend low-HT mode which incorporates a 3rd order highpass filter to filter out subsonic signals below 20hz. High extension setting is recommended for application where longer playback time and lower power consumption is required."
So for my understanding:
High is like party mode, use it when blaring music for hours to not overheat the amp.
What confuses me is Low HT vs Low music.
Looking at the graph, Low music has the deepest extension which would give lower bass notes for movies that actually use that spectrum right? And 99% of music (excluding pipe organs) doesn't hit down below 20hz and a slower attenuation would be less desirable for music I'd think so wouldn't the logic on these 2 be reversed? I must be missing something here and admit I'm a noob when it comes to sub tuning so please educate me.
brianmlamb is online now
Old 02-12-2016, 12:19 PM
PlasmaPZ80U's Avatar
Quoted: 2111 Post(s)
Liked: 629
Basically, you're adjusting 2 parameters at once, extension as you see in the graphs and damping/q value, which is what makes the sound cleaner and faster (lower q) or slower/boomier/more full body (higher Q).
For normal use you should pick low music or low ht, whichever sounds best to you... for high spl playback, high may be preferable.
brianmlamb likes this.
PlasmaPZ80U is online now
Old 02-12-2016, 12:37 PM
Liked: 629
I should add the low ht has the rumble filter on to limit sub 20Hz signals, which if loud enough could cause the driver to bottom out. An example would be playing Edge of Tomorrow intro at high spl. Low music might cause it to bottom out whereas low ht might not or not as easily. High mode would apply even more aggressive rumble filter to protect the driver but you lose significant low end output/extension as a result.
I'd use low music for music and possibly movies if you don't listen at high spl or you don't watch movies with lots of sub 20Hz bass.
I'd use low ht for ht use that does involve loud peaks and sub 20Hz bass.
Use high for loud music played for long periods of time, especially music that doesn't have lots of sub 20Hz content.
Old 02-12-2016, 07:08 PM
toddman36's Avatar
Quoted: 443 Post(s)
Liked: 142
Anyone have the FVX15? Likes, dislikes?
(R&L: Infinity Beta 50) (Center: Infinity Beta C360) (Surround side & Back: Infinity IW ERS 210 x 4) (TM: Infinity ERS 110 x 2) (Sub: Def Tech SC1)
(7.1.2 Config.) (AVR: Denon 4100) (Audiosource Amp 110 for TM's) (BRP: Pioneer 80FD) (Display: Panasonic TC-P65S1)
toddman36 is offline
Old 02-13-2016, 05:32 AM
benhacker22's Avatar
Quoted: 13 Post(s)
Originally Posted by benhacker22 View Post
Been lurking on this thread for a few months as I was looking to find a replacement sub. I had an MFW-15 and was very happy with that sub until.....the HUM hit. Thought I had been pretty fortunate for awhile, but alas the amp went out. There were options to "fix/upgrade" the sub, but why go through all that when can get something for a similar price. I wanted to find something that would be similar in output and sound as the MFW-15. I was all set to buy a HSU VTF15H-MK2 when I ran across this Rythmik thread and found out they were relatively local. After reading MANY pages of this thread (great regular contributors) and having conversations with Enrico and Brian regarding my room (2700 cu/ft) and budget, I settled on the FVX15. I was able to pick it up local so I did not have to worry about settling/keeping the sub to avoid paying for return shipping and would have option to upgrade to FV15HP.
I have had it for 2 months as of today and all I can say is WOW! I have a modest 5.1 setup and use my system for 80% movies and 20% music. I have a Yamaha receiver, ran YPAO, tweaked to my liking, and am very happy with results (most movie watching is between -28 to -20 volume). I go back and forth between 1 port closed/HT and both ports open (1 port closed is winning). Could I get better sound/output with REW and other EQ options? Probably so, but watching MMFR (amazing), TIH, Cloverfield, Iron Man, Dark Night, Pacific Rim, WOtW, and Jurassic World with the FVX15 has been VERY satisfying and enjoyable!!! Versus the MFW, the bass just sounds and feels cleaner and tighter. I can only imagine what a second one would do in my room (not in the budget now, but who knows about later). This is a great sub and am very satisfied with my purchase!
There isn't a whole lot of feedback regarding the FVX15, so wanted to give my impressions.
Here is my previous feedback regarding the FVX15. Have stuck with 1 port mode and now listen to most movies at -20. Still VERY happy with this sub!!
toddman36 likes this.
Receiver - Yamaha
Sub - Rythmik FVX-15
benhacker22 is online now
Old 02-13-2016, 10:17 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 265 Post(s)
Liked: 365
Originally Posted by dominguez1 View Post
Will the ports be firing in the same direction as the drivers for either the fv25 or fv18?
The first rev of both models will be top firing port. I know some customers like to see front firing ports. But my consideration is as follows:
  1. Tuning using port is much easier. Enclsoure size and port length can be easily adjusted. This will shorten turn around time.
  2. For FV25, the enclosure will be tall enough (40") that one doesn't even see the port opening with seating position.
  3. Our FV15HP 12.5hz CEA number measured by Josh is capped by port noise in band 6. Otherwise, the CEA number would have been higher. With top firing, wind noise is less audible and we can expect the number to improve. In addition, there are 3 ports for FV25. If we keep the air velocity same, FV25 will have at least 9db higher CEA output at 12.5hz just by the port opening area. Any additional output due to wind noise being less audible from its side is icing on the cake. For both FV25/FV18, the main increase in output will be in the 12.5hz/16hz range.
After the top firing version is done, we may proceed to front firing version of FV18. FV25 will not use front firing becasue the total length of the slot will be just too long.
Rythmik is offline
Old 02-13-2016, 10:37 AM
enricoclaudio's Avatar
Quoted: 1333 Post(s)
Liked: 1377
For those who like numbers, +9dB more than the FV15HP @ 12.5Hz means 107.5dB @ 12.5Hz... So the FV25 would be at the same level of Danley DTS-10 LMS-R
turbojohngt and JT78681 like this.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Emotiva XMC-1 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Bluesound Node 2 | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
Old 02-13-2016, 11:17 AM
JimWilson's Avatar
Quoted: 1440 Post(s)
Liked: 1892
Just a quick comment on this point Brian... I don't think this would be advisable. If I understand you correctly there would be two different versions of the same model - with the only difference being the port orientation - and personally I think that would do nothing but add confusion for your customers and further clutter the product line, to say nothing of the difficulty it creates for Rythmik having to support, purchase and stock them both. You might want to just decide which model would best suit everyone's needs - the customer and Rythmik - and offer that version. That's just my 2 cents though. YMMV.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
Old 02-13-2016, 11:37 AM
Cardiff Kook's Avatar
Originally Posted by DonH50 View Post
If timing is aligned properly then frequency response should follow and vice-versa. Fourier tells us they are the same signal whether expressed in the time or frequency domain. I am not sure how you are determining "perfect time alignment". Time delay and phase shift in the system make it (highly) likely that different phase shifts will be required at different frequencies to account for things like crossovers, physical distance, interaction with the room, etc.
The quick answer is that I would adjust for best frequency response since we hear changes in frequency response more readily than transient time events. Our ears, and brain, integrate the signals. That said, I always check impulse responses, and even with just frequency response you want to make sure you aren't wasting a bunch of power trying to feed a null.
Note time alignment also changes the relative phase, all of which impacts those peaks and valleys you hear and measure.
Thanks Don,
Let me Set up my question better...
Some experts recommend that a way to integrate the sub and mains is to start by reversing the phase on the mains and then adjusting the phase on the sub so that the volume in the crossover range is minimized. You then reverse the phase back and you now have them in phase. However, this is possibly not the arrangement which will lead to smoothest frequency response.
The answer I hear you stating is that frequency smoothness should trump timing or impulse response where the two conflict. That the next step is to fiddle with both crossover and volume to seek even FR. Is this correct?
Would it also be correct then that if I have a bass bump in my mains at let us say 6o hz, that I should consider increasing the crossover of the sub (from a much lower frequency) specifically to counteract that hump? Don't get me wrong I am not suggesting a sub is a great way to counteract frequency anomalies in the upper or mid bass, but in the lower mid bass it may be a possibility (note that Magnepan specifically recommends DWMs be used in such a way to smooth even upper bass).
Great discussion. I wish more people would chime in....
Cardiff Kook is offline
Old 02-13-2016, 11:38 AM
Thanks Don,
Old 02-13-2016, 02:34 PM
Exclusively Servo
Rythmik's Avatar
Quoted: 265 Post(s)
Liked: 365
No those will be two different model numbers. But their tuning frequency will be same so that the same amplifier can be used for both models.
Rythmik is offline
Old 02-13-2016, 04:55 PM
RTROSE's Avatar
Quoted: 194 Post(s)
Liked: 169
.......[*]For FV25, the enclosure will be tall enough (40") that one doesn't even see the port opening with seating position.
Would there be an option or any negative impact laying the sub on it's side? Just thinking about those of us who may not have the vertical clearance in front of our screens for 40".
Holy crap! That's flippin' AWESOME!
RTROSE
RTROSE is offline
Old 02-13-2016, 05:59 PM
dominguez1's Avatar
Quoted: 1071 Post(s)
Liked: 860
Thanks Brian. The performance of those models seem right in line to impress just as the FV15HP did in the 15in driver ported market...IOW, market leader.
I do get concerned about the top firing ports...not from a usability standpoint, but from a tactile response standpoint. With the sound wave firing upwards near tune, it won't have the same Sound Intensity (in the near field) as it would if it were firing in the same direction as the driver. That is something that I cherished with the FV15HP...
turbojohngt likes this.
dominguez1 is online now
Old 02-14-2016, 12:11 PM
Quoted: 13 Post(s)
If I am not mistaken, the FV25 will be a vented version of the F25. Is there going to be an top ported FV18 and a front ported FV18?? Either way the output looks to be HUGE! Look forward to seeing what these look like!
Receiver - Yamaha
Old 02-14-2016, 02:45 PM
dominguez1's Avatar
Liked: 860
Do you have an estimate for the FV18? +3db over the FV15HP approximately, or more down low like the FV25?
Old 02-14-2016, 05:00 PM
DonH50's Avatar
Quoted: 2028 Post(s)
Liked: 1589
Originally Posted by Cardiff Kook View Post
Thanks Don,
reversing the phase helps if your AVR or whatever has limited phase/delay range or you have them set up in such a manner that they need to be out of phase to provide a wavefront in-phase at the listening position. The goal is always to have the sound at all frequencies from all sources arrive in-phase at the listening position.
There is no pat answer to frequency vs. time domain except that they are two ways of expressing the same thing. One does not "trump" the other. If one is perfect, or horrible, the other will be as well. In between you choose but the time and frequency domains are tightly coupled so you can't really isolate one from the other. Frequency domain is easier for most people to measure and understand but if you do the math it doesn't matter. Note frequency response includes phase; most just look at magnitude.
If you have a frequency variation then the solution depends upon the root cause. Could be the speakers interacting with each other or the room, and how they interact is influenced by the phase response, which includes phase shift through the crossover.
I have Magnepans but not DWM's. They are woofers, not subwoofers, and while some really like them for the added bass, and properly placed and phased they can help mid-bass, I would not run them very low in frequency. Like all planar speakers, there is limited excursion available, and they distort heavily when presented with large signals that are the norm in the bass region.
You could certainly try varying the crossover, and if you have Rythmiks, adjusting the sub's phase to optimize their alignment.
HTH - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
Old 02-15-2016, 09:43 AM
turbojohngt's Avatar
Quoted: 97 Post(s)
Liked: 158
Ditto! And pics!
turbojohngt is offline
Old 02-15-2016, 10:03 AM
Liked: 1377
No yet. We are waiting for the voice coil samples for DS1800 to arrive Like Brian mentioned before the drivers on the FV25 are 2ohm version of DS1510 so it can handle up to 1000 watts each driver. The amp on the FV25 is the HX2000XLR3 with two 900 watts Hypex modules.
Old 02-15-2016, 11:21 AM
HTH - Don
Thanks Don!
Old 02-15-2016, 11:29 PM
Carrick's Avatar
Quoted: 466 Post(s)
Liked: 64
Sounds pricey... Cha-Ching
Top firing is out for me with a L-R slanted ceiling
Carrick is offline
Old 02-16-2016, 12:37 AM
jeffreybehr's Avatar
Smile I'm new to the Rythmik world but have been interested in audio/video...
...for almost 60 years. I guess I'm primarily a hi-end audiofool, but I'm also a hi-end vidiot.
I built a set of what I call SuperSubs a few years ago; here's a somewhat-weird composite pic of them.
Now I want to reclaim that front-wall space, so I recently ordered a pair of F15HP SWs with the 550-Watt amps. They should be here this week.
I was exposed to Rythmik because the plateamps in my Serenity Super-7 main speakers...
...are that brand. They use GR Research's 12" servo-coil drivers, and I'm very happy with the quality and quantity of bass delivered by those open-baffle woofers. I intend to install the F15s on the back wall of my musicroom/theater and use them for real subwoofing, that is, from c. 14-35Hz.
The room is 21' wide and 19' deep with a ceiling that rises from 6-1/2' at the front wall to 12' over the listener's head and then back down to 8' behind me.
We'll see soon how all that goes.
Tin-eared audiofool, vidiot, Classical-music lover, and highly amateur fotografer.
http://jeffreybehr.zenfolio.com/p610729623
jeffreybehr is offline
Old 02-17-2016, 07:20 AM
Exclusively Servo
Rythmik's Avatar
Quoted: 265 Post(s)
Liked: 365
I contribute that sound intensity that you hear from our subs (I assume not from others) to the following.
1) The servo increases the equivalent motor strength by a facor of 3x. So the air push out from the ports can be more effortless and in excellent time alignment with the woofer output (which is more for bass above 30hz).
2) Excellent spectrogram plots (in particular in one port mode of FV15HP). Our subs should all have that extra realistic sound effect for gun shots sound becasue gun shots are like impulse signals (short duration but high energy) with a lot of high frequency energies. For a sub with correct phase response, the bass and higher frequency can align well and give us more realism instead of sound like the body sound of gun shot is lagging behind the leading sound wave. We also have rear ported subs. They are selling well. It is articulate enough that many customers can clearly hear the difference between extension settings even though it is very subtle. Another thing to consider is if you look at the databass measurement of some subs with very apparent delay towards 14hz or below (where the port output dominates), their delay time is in the range of 100ms or so. That is 100ft distance. The depth of the enclosure is only 2ft. So the placement of the ports should not introduce any meaningful perception of delay. Instead, it is the design of the subwoofer in terms roll-off characteristics. In addition, I don't know why but the impulse response in our FV15HP measured by Josh all have significant sharp leading edge spike-like going up and return. That leading edge is high frequency components. The falling edge then begins the low frequency response which looks a bit like decaying sine wave. But other subs have both shap rising and falling edges or even have more sharp falling edge than rising edge, indicating large phase shift at high frequencies. I don't know the exact cause, but I suspect it is the over-done DSP processing or even worse, wrong polarity.
It will take me a few months to finish those two designs. Hope the above makes you less worry about the impact of top firing vs front firing ports.
Rythmik is offline
Old 02-17-2016, 08:30 AM
gimp's Avatar
selling F15HP with H600XLR3
I'm selling my Rythmik Audio F15HP with H600XLR3 amplifier. e B a y item number:231844131940
gimp is offline
Old 02-17-2016, 11:17 AM
Quoted: 67 Post(s)
Hey Guys,
Searched the thread and I didn't seem to find much info on this. Sorry if it's been covered.
I live in Toronto, and I'm looking into getting the L12. Rythmik says 90USD for shipping and duty. I can deal with that price, but will i be asked to pay more upon delivery? Like additional customs, or is it all included in the 90USD. Any Canadians able to offer some input?
This is the worst time for the CAD to tank, since I just moved into my own condo and I'm looking to build my system up .
dcolaco is offline
Old 02-17-2016, 12:23 PM
Quoted: 97 Post(s)
Liked: 158
Originally Posted by dcolaco View Post
Hey Guys,
I would imagine so, they would charge you whatever Ontario sales tax is as well as a brokerage fee. But I would ask either Brian or Enrico to make sure.
Old 02-17-2016, 01:20 PM
Quoted: 67 Post(s)
Emailed Rythmik and Enrico replied saying that its 90 USD door to door inclusive of everything. That's not bad and the total works out similar to the SVS SB1000. From what i have read the L12 is better than the SB1000 right?
dcolaco is offline
f12g subwoofer , integra dtc 9.8 , lv12r , Rythmik , Rythmik Audio , Rythmik Audio F12 Direct Servo Subwoofer , Rythmik Audio F15 Subwoofer , servo sub
